I have a custom board to tx2, but its has only hdmi0 conected, the hdmi1 Port is unconneted on designer. So, the l4t kernel for devkit does’t enable screen. Is there a Guide How to change the drivers (and/or other things) from hdmi1 to hdmi0?
You could refer to other users’ threads.
In brief, you need to download the kernel source from download center, modify the dts and then re-compile the device tree blob.
WayneWWW, How can I just compile the kernel without modifications? Is there any guide?
if I compile the kernel under directory “Linux_for_Tegra/sources/kernel/kernel-4.9/” the dts files under directory “Linux_for_Tegra/sources/hardware/nvidia/platform/t18x/quill/kernel-dts” will be compiled?
Is there any tutorial to work with dts files (in general)?
Please refer to the l4t documentation → kernel customization.
Hi WayneWWW, I did all sugested in #2, but I still not having video on HDMI0.
My custom board has nothing conected on HDMI1, so I don’t have video att all.
From serial port I can see the log:
[0000.221] I> Welcome to MB2(TBoot-BPMP)(version: 01.00.160913-t186-M-00.00-mobile-1b8ce67c)
[0000.229] I> bit @ 0xd480000
[0000.232] I> Boot-device: eMMC
[0000.236] I> sdmmc bdev is already initialized
[0000.241] I> pmic: reset reason (nverc) : 0x80
[0000.247] I> Found 16 partitions in SDMMC_BOOT (instance 3)
[0000.255] I> Found 31 partitions in SDMMC_USER (instance 3)
[0000.261] I> A/B: bin_type (16) slot 0
[0000.264] I> Loading partition bpmp-fw at 0xd7800000
[0000.269] I> Reading two headers - addr:0xd7800000 blocks:1
[0000.275] I> Addr: 0xd7800000, start-block: 58777608, num_blocks: 1
[0000.290] I> Binary(16) of size 533504 is loaded @ 0xd7800000
[0000.296] I> A/B: bin_type (17) slot 0
[0000.299] I> Loading partition bpmp-fw-dtb at 0xd79f0000
[0000.304] I> Reading two headers - addr:0xd79f0000 blocks:1
[0000.310] I> Addr: 0xd79f0000, start-block: 58780024, num_blocks: 1
[0000.324] I> Binary(17) of size 465840 is loaded @ 0xd798e200
[0000.503] I> Loading SCE-FW ...
[0000.506] I> A/B: bin_type (12) slot 0
[0000.509] I> Loading partition sce-fw at 0xd7300000
[0000.514] I> Reading two headers - addr:0xd7300000 blocks:1
[0000.520] I> Addr: 0xd7300000, start-block: 58782024, num_blocks: 1
[0000.529] I> Binary(12) of size 125168 is loaded @ 0xd7300000
[0000.535] I> Init SCE
[0000.537] I> Loading APE-FW ...
[0000.540] I> A/B: bin_type (11) slot 0
[0000.544] I> Loading partition adsp-fw at 0xd7400000
[0000.548] I> Reading two headers - addr:0xd7400000 blocks:1
[0000.554] I> Addr: 0xd7400000, start-block: 58761224, num_blocks: 1
[0000.563] I> Binary(11) of size 107808 is loaded @ 0xd7400000
[0000.569] I> Copy BTCM section
[0000.572] I> A/B: bin_type (13) slot 0
[0000.576] I> Loading partition cpu-bootloader at 0x96000000
[0000.581] I> Reading two headers - addr:0x96000000 blocks:1
[0000.587] I> Addr: 0x96000000, start-block: 58740744, num_blocks: 1
[0000.598] I> Binary(13) of size 277776 is loaded @ 0x96000000
[0000.604] I> A/B: bin_type (20) slot 0
[0000.607] I> Loading partition bootloader-dtb at 0x8520f400
[0000.613] I> Reading two headers - addr:0x8520f400 blocks:1
[0000.618] I> Addr: 0x8520f400, start-block: 58742792, num_blocks: 1
[0000.630] I> Binary(20) of size 344048 is loaded @ 0x8520f400
[0000.636] I> A/B: bin_type (14) slot 0
[0000.640] I> Loading partition secure-os at 0x8530f600
[0000.645] I> Reading two headers - addr:0x8530f600 blocks:1
[0000.650] I> Addr: 0x8530f600, start-block: 58744840, num_blocks: 1
[0000.662] I> Binary(14) of size 312752 is loaded @ 0x8530f600
[0000.670] I> TOS boot-params @ 0x85000000
[0000.674] I> TOS params prepared
[0000.677] I> Loading EKS ...
[0000.679] I> A/B: bin_type (15) slot 0
[0000.683] I> Loading partition eks at 0x8590f800
[0000.688] I> Reading two headers - addr:0x8590f800 blocks:1
[0000.693] I> Addr: 0x8590f800, start-block: 58757128, num_blocks: 1
[0000.701] I> Binary(15) of size 1040 is loaded @ 0x8590f800
[0000.706] I> EKB detected (length: 0x400) @ 0x8590f800
[0000.711] I> Copied encrypted keys
[0000.715] I> boot profiler @ 0x275844000
[0000.719] I> boot profiler for TOS @ 0x275844000
[0000.724] I> Unhalting SCE
[0000.726] I> Primary Memory Start:80000000 Size:70000000
[0000.732] I> Extended Memory Start:f0110000 Size:1856f0000
[0000.738] I> MB2(TBoot-BPMP) done
NOTICE: BL31: v1.3(release):a28d87f09
NOTICE: BL31: Built : 21:15:42, Aug 12 2019
ipc-unittest-main: 1519: Welcome to IPC unittest!!!
ipc-unittest-main: 1531: waiting forever
ipc-unittest-srv: 329: Init unittest services!!!
keystore-demo: 141: Hello world from keystore-demo app
keystore-demo: 207: main: EKB contents match expected value
exit called, thread 0xffffffffea87ad58, name trusty_app_2_7d18fc60-e9fc-11e8
platform_bootstrap_epilog: trusty bootstrap complete
[0000.979] I> Welcome to Cboot
[0000.982] I> Cboot Version: t186-dcb303f9
[0000.986] I> CPU-BL Params @ 0x275800000
[0000.989] I> 0) Base:0x00000000 Size:0x00000000
[0000.994] I> 1) Base:0x277f00000 Size:0x00100000
[0000.998] I> 2) Base:0x277e00000 Size:0x00100000
[0001.003] I> 3) Base:0x277d00000 Size:0x00100000
[0001.007] I> 4) Base:0x277c00000 Size:0x00100000
[0001.012] I> 5) Base:0x277b00000 Size:0x00100000
[0001.016] I> 6) Base:0x277800000 Size:0x00200000
[0001.021] I> 7) Base:0x277400000 Size:0x00400000
[0001.026] I> 8) Base:0x277a00000 Size:0x00100000
[0001.030] I> 9) Base:0x277300000 Size:0x00100000
[0001.035] I> 10) Base:0x276800000 Size:0x00800000
[0001.039] I> 11) Base:0x30000000 Size:0x00040000
[0001.044] I> 12) Base:0xf0000000 Size:0x00100000
[0001.048] I> 13) Base:0x30040000 Size:0x00001000
[0001.052] I> 14) Base:0x30048000 Size:0x00001000
[0001.057] I> 15) Base:0x30049000 Size:0x00001000
[0001.061] I> 16) Base:0x3004a000 Size:0x00001000
[0001.066] I> 17) Base:0x3004b000 Size:0x00001000
[0001.070] I> 18) Base:0x3004c000 Size:0x00001000
[0001.075] I> 19) Base:0x3004d000 Size:0x00001000
[0001.079] I> 20) Base:0x3004e000 Size:0x00001000
[0001.083] I> 21) Base:0x3004f000 Size:0x00001000
[0001.088] I> 22) Base:0x00000000 Size:0x00000000
[0001.092] I> 23) Base:0xf0100000 Size:0x00010000
[0001.097] I> 24) Base:0x00000000 Size:0x00000000
[0001.101] I> 25) Base:0x00000000 Size:0x00000000
[0001.106] I> 26) Base:0x00000000 Size:0x00000000
[0001.110] I> 27) Base:0x00000000 Size:0x00000000
[0001.114] I> 28) Base:0x84400000 Size:0x00400000
[0001.119] I> 29) Base:0x30000000 Size:0x00010000
[0001.123] I> 30) Base:0x278000000 Size:0x08000000
[0001.128] I> 31) Base:0x00000000 Size:0x00000000
[0001.132] I> 32) Base:0x276000000 Size:0x00600000
[0001.137] I> 33) Base:0x80000000 Size:0x70000000
[0001.141] I> 34) Base:0xf0110000 Size:0x1856f0000
[0001.146] I> 35) Base:0x00000000 Size:0x00000000
[0001.150] I> 36) Base:0x00000000 Size:0x00000000
[0001.155] I> 37) Base:0x2772e0000 Size:0x00020000
[0001.159] I> 38) Base:0x84000000 Size:0x00400000
[0001.164] I> 39) Base:0x96000000 Size:0x02000000
[0001.168] I> 40) Base:0x85000000 Size:0x01200000
[0001.172] I> 41) Base:0x275800000 Size:0x00500000
[0001.177] I> 42) Base:0x00000000 Size:0x00000000
[0001.181] I> 43) Base:0x00000000 Size:0x00000000
[0001.186] GIC-SPI Target CPU: 4
[0001.189] Interrupts Init done
[0001.192] calling constructors
[0001.196] initializing heap
[0001.198] initializing threads
[0001.202] initializing timers
[0001.205] creating bootstrap completion thread
[0001.210] top of bootstrap2()
[0001.213] CPU: ARM Cortex A57
[0001.216] CPU: MIDR: 0x411FD073, MPIDR: 0x80000100
[0001.221] initializing platform
[0001.224] I> Boot-device: eMMC
[0001.229] I> sdmmc bdev is already initialized
[0001.235] I> Found 16 partitions in SDMMC_BOOT (instance 3)
[0001.241] I> Found 31 partitions in SDMMC_USER (instance 3)
[0001.247] W> opt-in fuse is not set, skip fuse_burning
[0001.251] I> Reserved memory at 0xfbe00000 for U-Boot relocation
[0001.257] W> No valid slot number is found in scratch register
[0001.263] W> Return default slot: _a
[0001.266] I> A/B: bin_type (21) slot 0
[0001.270] I> Loading partition kernel-dtb at 0x80000000 from device(0x1)
[0001.283] I> Kernel_dtb @0x80000000
[0001.287] I> Bl_dtb @0x8520f400
[0001.290] I> gpio framework initialized
[0001.296] I> tegrabl_gpio_driver_register: register 'nvidia,tegra186-gpio' driver
[0001.306] I> tegrabl_gpio_driver_register: register 'nvidia,tegra186-gpio-aon' driver
[0001.313] I> tegrabl_tca9539_init: i2c bus: 0, slave addr: 0xee
[0001.323] E> I2C: slave not found in slaves.
[0001.327] E> I2C: Could not write 0 bytes to slave: 0x00ee with repeat start false.
[0001.336] E> I2C_DEV: Failed to send register address 0x00000004.
[0001.341] E> I2C_DEV: Could not write 1 registers of size 1 to slave 0xee at 0x00000004 via instance 0.
[0001.351] E> tca9539_device_init: failed to write polar reg
[0001.356] E> tegrabl_tca9539_init: failed to init device!
[0001.361] I> tegrabl_tca9539_init: i2c bus: 0, slave addr: 0xe8
[0001.368] E> I2C: slave not found in slaves.
[0001.372] E> I2C: Could not write 0 bytes to slave: 0x00e8 with repeat start false.
[0001.380] E> I2C_DEV: Failed to send register address 0x00000004.
[0001.386] E> I2C_DEV: Could not write 1 registers of size 1 to slave 0xe8 at 0x00000004 via instance 0.
[0001.396] E> tca9539_device_init: failed to write polar reg
[0001.401] E> tegrabl_tca9539_init: failed to init device!
[0001.409] I> fixed regulator driver initialized
[0001.441] I> register 'maxim' power off handle
[0001.446] I> virtual i2c enabled
[0001.450] I> registered 'maxim,max77620' pmic
[0001.454] I> tegrabl_gpio_driver_register: register 'max77620-gpio' driver
[0001.467] I> Find /i2c@c250000's alias i2c7
[0001.471] I> Reading eeprom i2c=7 address=0x50
[0001.501] I> Device at /i2c@c250000:0x50
[0001.505] I> Reading eeprom i2c=7 address=0x57
[0001.509] E> I2C: slave not found in slaves.
[0001.513] E> I2C: Could not write 0 bytes to slave: 0x00ae with repeat start true.
[0001.522] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.527] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xae at 0x00000000 via instance 7.
[0001.537] E> eeprom: Failed to read I2C slave device
[0001.542] I> Eeprom read failed 0x3526070d
[0001.546] I> Find /i2c@c240000's alias i2c1
[0001.550] I> Reading eeprom i2c=1 address=0x51
[0001.557] E> I2C: slave not found in slaves.
[0001.561] E> I2C: Could not write 0 bytes to slave: 0x00a2 with repeat start true.
[0001.569] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.575] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa2 at 0x00000000 via instance 1.
[0001.584] E> eeprom: Retry to read I2C slave device.
[0001.589] E> I2C: slave not found in slaves.
[0001.593] E> I2C: Could not write 0 bytes to slave: 0x00a2 with repeat start true.
[0001.602] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.607] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa2 at 0x00000000 via instance 1.
[0001.617] E> eeprom: Failed to read I2C slave device
[0001.622] I> Eeprom read failed 0x3526070d
[0001.626] I> Find /i2c@3160000's alias i2c0
[0001.630] I> Reading eeprom i2c=0 address=0x50
[0001.635] E> I2C: slave not found in slaves.
[0001.639] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start true.
[0001.647] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.653] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at 0x00000000 via instance 0.
[0001.662] E> eeprom: Failed to read I2C slave device
[0001.667] I> Eeprom read failed 0x3526070d
[0001.672] I> Find /i2c@3180000's alias i2c2
[0001.676] I> Reading eeprom i2c=2 address=0x54
[0001.680] I> Enabling gpio chip_id = 2, gpio pin = 9
[0001.685] C> GPIO driver for chip_id 0x2 could not be found
[0001.690] E> cam_eeprom_read: Can't get gpio driver
[0001.695] I> Eeprom read failed 0x4d4d000d
[0001.699] I> Reading eeprom i2c=2 address=0x57
[0001.703] I> Enabling gpio chip_id = 2, gpio pin = 9
[0001.708] C> GPIO driver for chip_id 0x2 could not be found
[0001.713] E> cam_eeprom_read: Can't get gpio driver
[0001.718] I> Eeprom read failed 0x4d4d000d
[0001.722] I> create_pm_ids: id: 3310-1000-D01-B, len: 15
[0001.727] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00,, len: 93
[0001.760] I> enabling 'vdd-hdmi' regulator
[0001.764] E> tegrabl_display_get_pdata, failed to parse dtb settings
[0001.773] E> cannot find any other nvdisp nodes
[0001.777] E> no valid display unit config found in dtb
[0001.783] W> display init failed
[0001.786] initializing target
[0001.789] calling apps_init()
[0001.793] starting app kernel_boot_app
[0001.799] I> found decompressor handler: lz4-legacy
[0001.803] I> decompressing BMP blob ...
[0001.819] I> Kernel type = Normal
[0001.822] I> Loading kernel from partition ...
[0001.826] W> No valid slot number is found in scratch register
[0001.832] W> Return default slot: _a
[0001.835] I> A/B: bin_type (24) slot 0
[0001.840] I> Boot image size read from image header: f2d10
[0001.845] I> Boot image load address: 0x0x80400000
[0001.850] I> Loading partition kernel at 0x80400000 from device(0x1)
[0002.643] I> Kernel hdr @0x80400000
[0002.646] I> Kernel dtb @0x80000000
[0002.649] I> T18x: Authenticate boot.img (bin_type 24), max size 0x4000000
[0002.658] I> T18x: Authenticate tegra194-p2888-0001-p2822-0000.dtb (bin_type 21), max size 0x100000
[0002.668] I> Checking boot.img header magic ... [0002.672] I> [OK]
[0002.674] I> Valid boot.img @ 0x80400000
[0002.677] I> decompressor handler not found
[0002.681] I> Copying kernel image (477378 bytes) from 0x80400800 to 0x80800000 ... [0002.689] I> Done
[0002.691] I> Move ramdisk (len: 0) from 0x80475800 to 0x94830000
[0002.699] I> Updated bpmp info to DTB
[0002.704] I> Ramdisk: Base: 0x94830000; Size: 0x0
[0002.709] I> Updated initrd info to DTB
[0002.712] W> WARN: Fail to override "console=none" in commandline
[0002.718] E> tegrabl_linuxboot_add_disp_param, du 0 failed to get display params
[0002.726] E> tegrabl_linuxboot_add_disp_param, du 0 failed to get display params
[0002.733] E> tegrabl_linuxboot_add_disp_param, du 0 failed to get display params
[0002.740] I> disabled_core_mask: 0xffffff0c
[0002.744] W> No valid slot number is found in scratch register
[0002.750] W> Return default slot: _a
[0002.753] I> Active slot suffix:
[0002.756] I> add_boot_slot_suffix: slot_suffix =
[0002.761] I> Linux Cmdline: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 video=tegrafb no_console_suspend=1 earlycon=uart8250,mmio32,0x3100000 nvdumper_reserved=0x2772e0000 gpt usbcore.old_scheme_first=1 tegraid=18.1.2.0.0 maxcpus=6 boot.slot_suffix= boot.ratchetvalues=0.2031647.1 bl_prof_dataptr=0x10000@0x275840000 sdhci_tegra.en_boot_part_access=1
[0002.797] I> Updated bootarg info to DTB
[0002.801] I> eeprom_get_mac_addr: MAC (type: 0): 00:04:4b:c7:19:66
[0002.807] I> eeprom_get_mac_addr: MAC (type: 1): 00:04:4b:c7:19:67
[0002.813] I> eeprom_get_mac_addr: MAC (type: 2): 00:04:4b:c7:19:68
[0002.821] E> Found no plugin manager ids in source DT
[0002.826] W> Add plugin manager ids from board info
[0002.831] E> "plugin-manager" doesn't exist, creating
[0002.836] E> "ids" doesn't exist, creating
[0002.840] E> "connection" doesn't exist, creating
[0002.845] E> "configs" doesn't exist, creating
[0002.849] I> create_pm_ids: id: 3310-1000-D01-B, len: 15
[0002.854] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00,, len: 93
[0002.865] I> Adding plugin-manager/ids/3310-1000-D01=/i2c@c250000:module@0x50
[0002.872] E> "i2c@c250000" doesn't exist, creating
[0002.877] E> "module@0x50" doesn't exist, creating
[0002.884] I> Adding plugin-manager/ids/3310-1000-D01-B
[0002.891] I> Adding plugin-manager/configs/3310-mem-type 00
[0002.896] I> Adding plugin-manager/configs/3310-power-config 00
[0002.902] I> Adding plugin-manager/configs/3310-misc-config 00
[0002.908] I> Adding plugin-manager/configs/3310-modem-config 00
[0002.914] I> Adding plugin-manager/configs/3310-touch-config 00
[0002.920] I> Adding plugin-manager/configs/3310-display-config 00
[0002.926] I> Adding plugin-manager/cvm
[0002.930] E> "chip-id" doesn't exist, creating
[0002.934] I> Adding plugin-manager/chip-id/A02P
[0002.939] E> "odm-data" doesn't exist, creating
[0002.944] I> Adding /chosen/plugin-manager/odm-data
[0002.953] I> added [base:0x80000000, size:0x70000000] to /memory
[0002.959] I> added [base:0xf0200000, size:0x185600000] to /memory
[0002.965] I> added [base:0x275e00000, size:0x200000] to /memory
[0002.971] I> added [base:0x276600000, size:0x200000] to /memory
[0002.976] I> added [base:0x277000000, size:0x200000] to /memory
[0002.982] I> Updated memory info to DTB
[0002.986] E> add_disp_param: failed to get display params for du=0
[0002.994] E> "reset" doesn't exist, creating
[0002.998] E> "pmc-reset-reason" doesn't exist, creating
[0003.004] E> "pmic-reset-reason" doesn't exist, creating
[0003.010] I> Adding ecid(0000000164510283100000000e0682c0) to DT
[0003.016] I> disabled_core_mask: 0xffffff0c
[0003.029] I> Add serial number:0425018067973 as DT property
[0003.037] I> Plugin-manager override starting
[0003.043] I> node /plugin-manager/fragement@0 matches
[0003.053] I> node /plugin-manager/fragement@4 matches
[0003.065] I> node /plugin-manager/fragment-sdwake-p3310-1000-300 matches
[0003.084] I> node /plugin-manager/fragement-pmon-p3310-1000-300 matches
[0003.093] I> node /plugin-manager/fragement-pmon-p3310-1000-800 matches
[0003.102] I> node /plugin-manager/fragment-devslp@0 matches
[0003.114] I> node /plugin-manager/fragment-500-pcie-config matches
[0003.128] I> node /plugin-manager/fragment-500-xusb-config matches
[0003.150] I> node /plugin-manager/fragment-p3310-c00-comm matches
[0003.163] I> node /plugin-manager/fragment-p3310-c00-pmic matches
[0003.173] I> node /plugin-manager/fragment-p3310-c01 matches
[0003.185] I> node /plugin-manager/fragment-p3310-c03 matches
[0003.221] I> node /plugin-manager/fragment-p3310-c00-camera matches
[0003.247] I> Disable plugin-manager status in FDT
[0003.251] I> Plugin-manager override finished successfully
[0003.256] I> tegrabl_load_kernel_and_dtb: Done
[0003.261] E> tegrabl_display_clear: display is not initialized
[0003.266] W> Boot logo display failed...
[0003.270] I> Kernel EP: 0x80800000, DTB: 0x80000000
U-Boot 2016.07-gd917e08cec (Aug 12 2019 - 21:16:16 -0700)
TEGRA186
Model: NVIDIA P2771-0000-500
DRAM: 7.8 GiB
MMC: Tegra SD/MMC: 0, Tegra SD/MMC: 1
*** Warning - bad CRC, using default environment
In: serial
Out: serial
Err: serial
Net: eth0: ethernet@2490000
Hit any key to stop autoboot: 2 1 0
MMC: no card present
switch to partitions #0, OK
mmc0(part 0) is current device
Scanning mmc 0:1...
Found /boot/extlinux/extlinux.conf
Retrieving file: /boot/extlinux/extlinux.conf
733 bytes read in 125 ms (4.9 KiB/s)
L4T boot options
1: primary kernel
Enter choice: 1: primary kernel
Retrieving file: /boot/initrd
5565090 bytes read in 219 ms (24.2 MiB/s)
Retrieving file: /boot/Image
34179080 bytes read in 874 ms (37.3 MiB/s)
append: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 video=tegrafb no_console_suspend=1 earlycon=uart8250,mmio32,0x3100000 nvdumper_reserved=0x2772e0000 gpt usbcore.old_scheme_first=1 tegraid=18.1.2.0.0 maxcpus=6 boot.slot_suffix= boot.ratchetvalues=0.2031647.1 bl_prof_dataptr=0x10000@0x275840000 sdhci_tegra.en_boot_part_access=1 quiet
## Flattened Device Tree blob at 80000000
Booting using the fdt blob at 0x80000000
reserving fdt memory region: addr=80000000 size=10000
Using Device Tree in place at 0000000080000000, end 0000000080058f4f
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x100
[ 0.000000] Linux version 4.9.140-tegra (buildbrain@mobile-u64-770) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #1 SMP PREEMPT Mon Aug 12 21:29:52 PDT 2019
[ 0.000000] Boot CPU: AArch64 Processor [411fd073]
[ 0.000000] OF: fdt:memory scan node memory@80000000, reg size 16416,
[ 0.000000] OF: fdt: - 80000000 , 70000000
[ 0.000000] OF: fdt: - f0200000 , 185600000
[ 0.000000] OF: fdt: - 275e00000 , 200000
[ 0.000000] OF: fdt: - 276600000 , 200000
[ 0.000000] OF: fdt: - 277000000 , 200000
[ 0.000000] earlycon: uart8250 at MMIO32 0x0000000003100000 (options '')
[ 0.000000] bootconsole [uart8250] enabled
<hit enter to activate fiq debugger>
[ 0.721853] pca953x 0-0074: failed reading register
[ 0.722549] pca953x 0-0077: failed reading register
[ 1.418148] tegra-xusb-padctl 3520000.xusb_padctl: failed to setup XUSB ports: -517
[ 1.443333] pre_t19x_iso_plat_register(): iso bandwidth 4687500KB is not available, client tegra_camera_ctrl
[ 1.443442] misc tegra_camera_ctrl: tegra_camera_isomgr_register: unable to register to isomgr
[ 1.443481] misc tegra_camera_ctrl: tegra_camera_probe: failed to register CAMERA as isomgr client
[ 1.535723] tegradc 15210000.nvdisplay: dc_hdmi_hotplug_init: couldn't get regulator vdd_hdmi_5v0, -517
[ 1.750478] pre_t19x_iso_plat_register(): iso bandwidth 81920KB is not available, client eqos
[ 1.897011] FAN: coudln't get the regulator
[ 11.675032] tegra-i2c 3190000.i2c: pio timed out addr: 0x50 tlen:28 rlen:128
[ 11.682154] tegra-i2c 3190000.i2c: --- register dump for debugging ----
[ 11.688791] tegra-i2c 3190000.i2c: I2C_CNFG - 0x22c00
[ 11.693854] tegra-i2c 3190000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 11.700477] tegra-i2c 3190000.i2c: I2C_FIFO_CONTROL - 0xe0
[ 11.705969] tegra-i2c 3190000.i2c: I2C_FIFO_STATUS - 0x800040
[ 11.711724] tegra-i2c 3190000.i2c: I2C_INT_MASK - 0x7d
[ 11.716869] tegra-i2c 3190000.i2c: I2C_INT_STATUS - 0x0
[ 11.722106] tegra-i2c 3190000.i2c: i2c transfer timed out addr: 0x50
[ 21.915125] tegra-i2c 3190000.i2c: pio timed out addr: 0x50 tlen:28 rlen:128
[ 21.922255] tegra-i2c 3190000.i2c: --- register dump for debugging ----
[ 21.929057] tegra-i2c 3190000.i2c: I2C_CNFG - 0x22c00
[ 21.934152] tegra-i2c 3190000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 21.940800] tegra-i2c 3190000.i2c: I2C_FIFO_CONTROL - 0xe0
[ 21.946326] tegra-i2c 3190000.i2c: I2C_FIFO_STATUS - 0x800040
[ 21.952099] tegra-i2c 3190000.i2c: I2C_INT_MASK - 0x7d
[ 21.957264] tegra-i2c 3190000.i2c: I2C_INT_STATUS - 0x0
[ 21.962528] tegra-i2c 3190000.i2c: i2c transfer timed out addr: 0x50
[ 22.004380] ina3221x 0-0042: ina3221 reset failure status: 0xffffff87
[ 22.011992] ina3221x 0-0043: ina3221 reset failure status: 0xffffff87
[ 22.079474] pre_t19x_iso_plat_register(): iso bandwidth 24576KB is not available, client ape_adma
[ 22.088486] tegra_isomgr_adma_register: Failed to register adma isomgr client. err=-22
[ 22.438179] isp 15600000.isp: isp_probe: failed
[ 22.473653] tegra-xusb-padctl 3520000.xusb_padctl: failed to setup XUSB ports: -517
[ 22.504795] tegra-xusb-padctl 3520000.xusb_padctl: failed to setup XUSB ports: -517
[ 23.082801] cgroup: cgroup2: unknown option "nsdelegate"
[ 23.754382] tegra-xusb-padctl 3520000.xusb_padctl: failed to setup XUSB ports: -517
[ 23.982804] tegra-xusb-padctl 3520000.xusb_padctl: failed to setup XUSB ports: -517
[ 27.916304] tegra-xusb-padctl 3520000.xusb_padctl: failed to setup XUSB ports: -517
[ 27.948086] CPU1: shutdown
[ 27.995987] tegra-xusb-padctl 3520000.xusb_padctl: failed to setup XUSB ports: -517
[ 28.030523] CPU2: shutdown
[ 28.541683] tegra-xusb-padctl 3520000.xusb_padctl: failed to setup XUSB ports: -517
[ 28.580204] tegra-xusb-padctl 3520000.xusb_padctl: failed to setup XUSB ports: -517
[ 29.016846] __tegra_isomgr_reserve(): bad handle ffffffffffffffea
[ 29.023224] eqos 2490000.ether_qos: EQOS ISO BW 81920 reservation failed with 0
[ 32.155107] tegra-i2c 3190000.i2c: pio timed out addr: 0x50 tlen:28 rlen:128
[ 32.162487] tegra-i2c 3190000.i2c: --- register dump for debugging ----
[ 32.175134] tegra-i2c 3190000.i2c: I2C_CNFG - 0x22c00
[ 32.180386] tegra-i2c 3190000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 32.187634] tegra-i2c 3190000.i2c: I2C_FIFO_CONTROL - 0xe0
[ 32.194565] tegra-i2c 3190000.i2c: I2C_FIFO_STATUS - 0x800040
[ 32.203285] tegra-i2c 3190000.i2c: I2C_INT_MASK - 0x7d
[ 32.208654] tegra-i2c 3190000.i2c: I2C_INT_STATUS - 0x0
[ 32.214071] tegra-i2c 3190000.i2c: i2c transfer timed out addr: 0x50
Ubuntu 18.04.2 LTS nvidia-desktop ttyS0
nvidia-desktop login: [ 35.749097] vdd-1v8: voltage operation not allowed
[ 35.754370] sdhci-tegra 3440000.sdhci: could not set regulator OCR (-1)
[ 35.779613] vdd-1v8: voltage operation not allowed
[ 35.784628] sdhci-tegra 3440000.sdhci: could not set regulator OCR (-1)
[ 35.812447] vdd-1v8: voltage operation not allowed
[ 35.817633] sdhci-tegra 3440000.sdhci: could not set regulator OCR (-1)
[ 35.828694] vdd-1v8: voltage operation not allowed
[ 35.833656] sdhci-tegra 3440000.sdhci: could not set regulator OCR (-1)
[ 35.949285] vdd-1v8: voltage operation not allowed
[ 35.954255] sdhci-tegra 3440000.sdhci: could not set regulator OCR (-1)
[ 35.962010] vdd-1v8: voltage operation not allowed
[ 35.967010] sdhci-tegra 3440000.sdhci: could not set regulator OCR (-1)
[ 35.975510] vdd-1v8: voltage operation not allowed
[ 35.980389] sdhci-tegra 3440000.sdhci: could not set regulator OCR (-1)
[ 42.395217] tegra-i2c 3190000.i2c: pio timed out addr: 0x50 tlen:28 rlen:128
[ 42.402559] tegra-i2c 3190000.i2c: --- register dump for debugging ----
[ 42.409360] tegra-i2c 3190000.i2c: I2C_CNFG - 0x22c00
[ 42.417264] tegra-i2c 3190000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 42.424119] tegra-i2c 3190000.i2c: I2C_FIFO_CONTROL - 0xe0
[ 42.429801] tegra-i2c 3190000.i2c: I2C_FIFO_STATUS - 0x800040
[ 42.436409] tegra-i2c 3190000.i2c: I2C_INT_MASK - 0x7d
[ 42.442004] tegra-i2c 3190000.i2c: I2C_INT_STATUS - 0x0
[ 42.447496] tegra-i2c 3190000.i2c: i2c transfer timed out addr: 0x50
[ 46.183921] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 46.358751] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 46.379111] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 46.448066] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 47.465021] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 47.507946] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 47.541509] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 47.578761] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 47.613027] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 47.644205] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 47.676314] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 47.707604] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 47.731299] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 47.760582] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 47.787400] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 47.821440] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 47.852884] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 47.885837] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 47.919250] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 47.950952] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 47.983186] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 48.116160] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 48.260613] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 49.172190] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 52.635128] tegra-i2c 3190000.i2c: pio timed out addr: 0x50 tlen:28 rlen:128
[ 52.642342] tegra-i2c 3190000.i2c: --- register dump for debugging ----
[ 52.649113] tegra-i2c 3190000.i2c: I2C_CNFG - 0x22c00
[ 52.654694] tegra-i2c 3190000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 52.661381] tegra-i2c 3190000.i2c: I2C_FIFO_CONTROL - 0xe0
[ 52.666925] tegra-i2c 3190000.i2c: I2C_FIFO_STATUS - 0x800040
[ 52.672739] tegra-i2c 3190000.i2c: I2C_INT_MASK - 0x7d
[ 52.677933] tegra-i2c 3190000.i2c: I2C_INT_STATUS - 0x0
[ 52.683238] tegra-i2c 3190000.i2c: i2c transfer timed out addr: 0x50
[ 62.942199] tegra-i2c 3190000.i2c: pio timed out addr: 0x50 tlen:28 rlen:128
[ 62.949407] tegra-i2c 3190000.i2c: --- register dump for debugging ----
[ 62.956170] tegra-i2c 3190000.i2c: I2C_CNFG - 0x22c00
[ 62.961365] tegra-i2c 3190000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 62.968092] tegra-i2c 3190000.i2c: I2C_FIFO_CONTROL - 0xe0
[ 62.973662] tegra-i2c 3190000.i2c: I2C_FIFO_STATUS - 0x800040
[ 62.979471] tegra-i2c 3190000.i2c: I2C_INT_MASK - 0x7d
[ 62.984654] tegra-i2c 3190000.i2c: I2C_INT_STATUS - 0x0
[ 62.989931] tegra-i2c 3190000.i2c: i2c transfer timed out addr: 0x50
[ 73.215659] tegra-i2c 3190000.i2c: pio timed out addr: 0x50 tlen:28 rlen:128
[ 73.222874] tegra-i2c 3190000.i2c: --- register dump for debugging ----
[ 73.230293] tegra-i2c 3190000.i2c: I2C_CNFG - 0x22c00
[ 73.235535] tegra-i2c 3190000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 73.242277] tegra-i2c 3190000.i2c: I2C_FIFO_CONTROL - 0xe0
[ 73.247828] tegra-i2c 3190000.i2c: I2C_FIFO_STATUS - 0x800040
[ 73.253615] tegra-i2c 3190000.i2c: I2C_INT_MASK - 0x7d
[ 73.258804] tegra-i2c 3190000.i2c: I2C_INT_STATUS - 0x0
[ 73.264124] tegra-i2c 3190000.i2c: i2c transfer timed out addr: 0x50
[ 83.464090] tegra-i2c 3190000.i2c: pio timed out addr: 0x50 tlen:28 rlen:128
[ 83.471335] tegra-i2c 3190000.i2c: --- register dump for debugging ----
[ 83.478153] tegra-i2c 3190000.i2c: I2C_CNFG - 0x22c00
[ 83.483375] tegra-i2c 3190000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 83.490103] tegra-i2c 3190000.i2c: I2C_FIFO_CONTROL - 0xe0
[ 83.495717] tegra-i2c 3190000.i2c: I2C_FIFO_STATUS - 0x800040
[ 83.501533] tegra-i2c 3190000.i2c: I2C_INT_MASK - 0x7d
[ 83.506720] tegra-i2c 3190000.i2c: I2C_INT_STATUS - 0x0
[ 83.512009] tegra-i2c 3190000.i2c: i2c transfer timed out addr: 0x50
[ 84.174106] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 93.705899] tegra-i2c 3190000.i2c: pio timed out addr: 0x50 tlen:28 rlen:128
[ 93.713145] tegra-i2c 3190000.i2c: --- register dump for debugging ----
[ 93.719915] tegra-i2c 3190000.i2c: I2C_CNFG - 0x22c00
[ 93.725100] tegra-i2c 3190000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 93.731891] tegra-i2c 3190000.i2c: I2C_FIFO_CONTROL - 0xe0
[ 93.737486] tegra-i2c 3190000.i2c: I2C_FIFO_STATUS - 0x800040
[ 93.743307] tegra-i2c 3190000.i2c: I2C_INT_MASK - 0x7d
[ 93.748546] tegra-i2c 3190000.i2c: I2C_INT_STATUS - 0x0
[ 93.753855] tegra-i2c 3190000.i2c: i2c transfer timed out addr: 0x50
[ 103.946455] tegra-i2c 3190000.i2c: pio timed out addr: 0x50 tlen:28 rlen:128
[ 103.953749] tegra-i2c 3190000.i2c: --- register dump for debugging ----
[ 103.960517] tegra-i2c 3190000.i2c: I2C_CNFG - 0x22c00
[ 103.965723] tegra-i2c 3190000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 103.972538] tegra-i2c 3190000.i2c: I2C_FIFO_CONTROL - 0xe0
[ 103.978079] tegra-i2c 3190000.i2c: I2C_FIFO_STATUS - 0x800040
[ 103.983866] tegra-i2c 3190000.i2c: I2C_INT_MASK - 0x7d
[ 103.989045] tegra-i2c 3190000.i2c: I2C_INT_STATUS - 0x0
[ 103.994347] tegra-i2c 3190000.i2c: i2c transfer timed out addr: 0x50
[ 114.186827] tegra-i2c 3190000.i2c: pio timed out addr: 0x50 tlen:28 rlen:128
[ 114.194084] tegra-i2c 3190000.i2c: --- register dump for debugging ----
[ 114.201195] tegra-i2c 3190000.i2c: I2C_CNFG - 0x22c00
[ 114.206591] tegra-i2c 3190000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 114.213558] tegra-i2c 3190000.i2c: I2C_FIFO_CONTROL - 0xe0
[ 114.219168] tegra-i2c 3190000.i2c: I2C_FIFO_STATUS - 0x800040
[ 114.224999] tegra-i2c 3190000.i2c: I2C_INT_MASK - 0x7d
[ 114.230190] tegra-i2c 3190000.i2c: I2C_INT_STATUS - 0x0
[ 114.235617] tegra-i2c 3190000.i2c: i2c transfer timed out addr: 0x50
[ 114.793465] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 124.427053] tegra-i2c 3190000.i2c: pio timed out addr: 0x50 tlen:28 rlen:128
[ 124.434354] tegra-i2c 3190000.i2c: --- register dump for debugging ----
[ 124.441083] tegra-i2c 3190000.i2c: I2C_CNFG - 0x22c00
[ 124.446259] tegra-i2c 3190000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 124.453000] tegra-i2c 3190000.i2c: I2C_FIFO_CONTROL - 0xe0
[ 124.458586] tegra-i2c 3190000.i2c: I2C_FIFO_STATUS - 0x800040
[ 124.464430] tegra-i2c 3190000.i2c: I2C_INT_MASK - 0x7d
[ 124.469646] tegra-i2c 3190000.i2c: I2C_INT_STATUS - 0x0
[ 124.474985] tegra-i2c 3190000.i2c: i2c transfer timed out addr: 0x50
[ 124.482365] tegradc 15210000.nvdisplay: hdmi: edid read failed
[ 134.667193] tegra-i2c 3190000.i2c: pio timed out addr: 0x50 tlen:28 rlen:128
[ 134.667210] tegra-i2c 3190000.i2c: --- register dump for debugging ----
[ 134.667223] tegra-i2c 3190000.i2c: I2C_CNFG - 0x22c00
[ 134.667235] tegra-i2c 3190000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 134.667246] tegra-i2c 3190000.i2c: I2C_FIFO_CONTROL - 0xe0
[ 134.667257] tegra-i2c 3190000.i2c: I2C_FIFO_STATUS - 0x800040
[ 134.667269] tegra-i2c 3190000.i2c: I2C_INT_MASK - 0x7d
[ 134.667279] tegra-i2c 3190000.i2c: I2C_INT_STATUS - 0x0
[ 134.667293] tegra-i2c 3190000.i2c: i2c transfer timed out addr: 0x50
[ 144.907394] tegra-i2c 3190000.i2c: pio timed out addr: 0x50 tlen:28 rlen:128
[ 144.907410] tegra-i2c 3190000.i2c: --- register dump for debugging ----
[ 144.907423] tegra-i2c 3190000.i2c: I2C_CNFG - 0x22c00
[ 144.907435] tegra-i2c 3190000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 144.907447] tegra-i2c 3190000.i2c: I2C_FIFO_CONTROL - 0xe0
[ 144.907458] tegra-i2c 3190000.i2c: I2C_FIFO_STATUS - 0x800040
[ 144.907470] tegra-i2c 3190000.i2c: I2C_INT_MASK - 0x7d
[ 144.907482] tegra-i2c 3190000.i2c: I2C_INT_STATUS - 0x0
[ 144.907497] tegra-i2c 3190000.i2c: i2c transfer timed out addr: 0x50
[ 145.083462] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 155.403198] tegra-i2c 3190000.i2c: pio timed out addr: 0x50 tlen:28 rlen:128
[ 155.403216] tegra-i2c 3190000.i2c: --- register dump for debugging ----
[ 155.403231] tegra-i2c 3190000.i2c: I2C_CNFG - 0x22c00
[ 155.403245] tegra-i2c 3190000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 155.403257] tegra-i2c 3190000.i2c: I2C_FIFO_CONTROL - 0xe0
[ 155.403268] tegra-i2c 3190000.i2c: I2C_FIFO_STATUS - 0x800040
[ 155.403280] tegra-i2c 3190000.i2c: I2C_INT_MASK - 0x7d
[ 155.403290] tegra-i2c 3190000.i2c: I2C_INT_STATUS - 0x0
[ 155.403304] tegra-i2c 3190000.i2c: i2c transfer timed out addr: 0x50
[ 204.186186] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 264.175746] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 324.176934] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 342.442548] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 342.468724] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 342.500311] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 342.525003] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 342.557388] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 342.583764] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 342.620618] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 342.659248] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 342.684433] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 342.718193] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 342.752381] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 342.784666] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 342.819294] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 342.853435] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 342.885300] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 342.920115] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 342.953463] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 342.985911] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 343.020168] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 343.053280] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 343.084373] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 343.117550] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 343.151381] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 343.183404] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 343.217128] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 343.251617] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 343.285845] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 343.309020] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 343.345373] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 343.388041] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 343.422253] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 343.452859] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 343.487436] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 343.529925] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 343.570822] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 343.606970] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 343.636128] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 343.671178] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 343.711972] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 343.753178] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 343.786550] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 343.819834] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 343.853333] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 343.886209] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 343.919770] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 343.952390] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 343.985995] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 344.017581] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 344.052460] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 344.085410] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 344.119954] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 344.152796] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 344.184899] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 344.218588] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 344.253161] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 344.286280] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 344.310930] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 344.346691] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 344.387382] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 344.423425] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 344.453123] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 344.487085] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 344.510549] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 344.535567] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 344.570265] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 344.603151] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 344.633551] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 344.667729] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 344.701351] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 344.733102] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 344.767164] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 344.801976] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 344.835701] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 344.870218] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 344.903441] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 344.935453] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 344.966716] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 345.003452] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 345.042691] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 345.079939] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 345.120616] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 345.155884] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 345.186136] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 345.220120] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 345.243561] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 345.279702] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 345.319859] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 345.355771] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 345.394927] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 345.416100] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 345.453702] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 345.491830] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 345.518721] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 345.553170] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 345.587009] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 345.619386] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 345.652859] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 345.686897] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 345.718294] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 345.752876] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 345.786896] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 345.818298] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 345.852950] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 345.886120] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 345.919794] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 345.954189] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 345.985737] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 346.019963] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 346.053820] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 346.086473] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 346.119748] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 346.153153] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 346.185686] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 346.219450] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 346.254012] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 346.286519] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 346.319930] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 346.354025] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 346.401816] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 346.436713] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 346.469421] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 346.503592] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 346.536307] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 346.570556] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 346.604384] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 346.650948] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 346.686709] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 346.719332] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 346.754158] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 346.787433] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 346.819558] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 346.853907] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 346.886568] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 346.920534] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 346.953806] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 346.987341] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 347.019619] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 347.053644] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 347.087205] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 347.120678] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 347.168857] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 347.203587] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 347.236597] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 347.269833] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 347.319473] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 347.353962] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 347.385745] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 347.435683] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 347.470195] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 347.503715] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 347.553124] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 347.586911] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 347.632891] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 347.667030] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 347.717102] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 347.751068] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 347.800529] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 347.835380] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 347.885912] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 347.920094] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 347.969732] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 348.013285] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 348.062144] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 348.106888] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 348.154083] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 348.185822] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 348.235598] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 348.294043] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 348.327863] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 348.386804] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 348.438031] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 348.484935] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 348.536750] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 348.578864] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 348.629744] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 348.689265] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 348.737628] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 348.785109] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 348.837258] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 348.902074] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 348.952620] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 349.002454] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 349.069476] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 349.117810] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 349.184900] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 349.253361] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 349.311888] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 349.378290] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 349.437284] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 349.503313] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 349.569753] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 349.635765] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 349.702272] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 349.786143] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 349.853214] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 349.935249] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 350.018880] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 350.102569] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 350.185894] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 350.269182] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 350.369443] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 350.453729] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 350.569544] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 350.670256] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 350.786131] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 350.904227] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 351.035877] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 351.186013] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 351.359852] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 351.552086] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 351.809058] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 352.783555] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
Can you help me?
Are you sure the hardware design is correct?
Your log implies many kinds of error
The i2c error
[ 42.447496] tegra-i2c 3190000.i2c: i2c transfer timed out addr: 0x50 -
The sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0 error
HDMI & USB problem on TX2 with a custom board - Jetson TX2 - NVIDIA Developer Forums
Also, the usb and eqos drivers are dead too.
Could you try to set the vdd_hdmi_5v0 to battery_reg for now?
See next post
See next post
Hello WayneWWW
I’ve modified the file t18x-common-platforms/tegra186-quill-power-tree-p3310-1000-a00-00.dtsi like this:
host1x {
nvdisplay@15200000 {
avdd_lcd-supply = <&en_avdd_disp_3v3>;
dvdd_lcd-supply = <&en_vdd_disp_1v8>;
avdd_dsi_csi-supply = <&spmic_sd1>;
outp-supply = <&vpp_lcd>;
outn-supply = <&vmm_lcd>;
vdd_lcd_bl-supply = <&battery_reg>;
vdd_lcd_bl_en-supply = <&vdd_bl_en>;
/* added hdmi for testing in head 0 */
avdd_hdmi-supply = <&spmic_ldo7>;
avdd_hdmi_pll-supply = <&spmic_sd2>;
vdd_hdmi_5v0-supply = <&battery_reg>; //<&vdd_hdmi>;
nvdisplay@15210000 {
nvdisplay@15220000 {
vi@15700000 {
nvcsi@150c0000 {
nvidia,csi_regulator = "avdd_dsi_csi";
Unfortunately there’s no video on HDMI0…
The serial log is here:
[0000.198] I> bit @ 0xd480000
[0000.201] I> Boot-device: eMMC
[0000.205] I> sdmmc bdev is already initialized
[0000.210] I> pmic: reset reason (nverc) : 0x80
[0000.216] I> Found 16 partitions in SDMMC_BOOT (instance 3)
[0000.224] I> Found 31 partitions in SDMMC_USER (instance 3)
[0000.230] I> A/B: bin_type (16) slot 0
[0000.233] I> Loading partition bpmp-fw at 0xd7800000
[0000.238] I> Reading two headers - addr:0xd7800000 blocks:1
[0000.244] I> Addr: 0xd7800000, start-block: 58777608, num_blocks: 1
[0000.259] I> Binary(16) of size 533504 is loaded @ 0xd7800000
[0000.265] I> A/B: bin_type (17) slot 0
[0000.268] I> Loading partition bpmp-fw-dtb at 0xd79f0000
[0000.273] I> Reading two headers - addr:0xd79f0000 blocks:1
[0000.279] I> Addr: 0xd79f0000, start-block: 58780024, num_blocks: 1
[0000.293] I> Binary(17) of size 465840 is loaded @ 0xd798e200
[0000.472] I> Loading SCE-FW ...
[0000.475] I> A/B: bin_type (12) slot 0
[0000.478] I> Loading partition sce-fw at 0xd7300000
[0000.483] I> Reading two headers - addr:0xd7300000 blocks:1
[0000.489] I> Addr: 0xd7300000, start-block: 58782024, num_blocks: 1
[0000.498] I> Binary(12) of size 125168 is loaded @ 0xd7300000
[0000.504] I> Init SCE
[0000.506] I> Loading APE-FW ...
[0000.509] I> A/B: bin_type (11) slot 0
[0000.513] I> Loading partition adsp-fw at 0xd7400000
[0000.518] I> Reading two headers - addr:0xd7400000 blocks:1
[0000.523] I> Addr: 0xd7400000, start-block: 58761224, num_blocks: 1
[0000.532] I> Binary(11) of size 107808 is loaded @ 0xd7400000
[0000.538] I> Copy BTCM section
[0000.541] I> A/B: bin_type (13) slot 0
[0000.545] I> Loading partition cpu-bootloader at 0x96000000
[0000.550] I> Reading two headers - addr:0x96000000 blocks:1
[0000.556] I> Addr: 0x96000000, start-block: 58740744, num_blocks: 1
[0000.567] I> Binary(13) of size 277776 is loaded @ 0x96000000
[0000.573] I> A/B: bin_type (20) slot 0
[0000.576] I> Loading partition bootloader-dtb at 0x8520f400
[0000.582] I> Reading two headers - addr:0x8520f400 blocks:1
[0000.587] I> Addr: 0x8520f400, start-block: 58742792, num_blocks: 1
[0000.600] I> Binary(20) of size 344048 is loaded @ 0x8520f400
[0000.605] I> A/B: bin_type (14) slot 0
[0000.609] I> Loading partition secure-os at 0x8530f600
[0000.614] I> Reading two headers - addr:0x8530f600 blocks:1
[0000.619] I> Addr: 0x8530f600, start-block: 58744840, num_blocks: 1
[0000.631] I> Binary(14) of size 312752 is loaded @ 0x8530f600
[0000.639] I> TOS boot-params @ 0x85000000
[0000.643] I> TOS params prepared
[0000.646] I> Loading EKS ...
[0000.649] I> A/B: bin_type (15) slot 0
[0000.652] I> Loading partition eks at 0x8590f800
[0000.657] I> Reading two headers - addr:0x8590f800 blocks:1
[0000.662] I> Addr: 0x8590f800, start-block: 58757128, num_blocks: 1
[0000.670] I> Binary(15) of size 1040 is loaded @ 0x8590f800
[0000.675] I> EKB detected (length: 0x400) @ 0x8590f800
[0000.680] I> Copied encrypted keys
[0000.684] I> boot profiler @ 0x275844000
[0000.688] I> boot profiler for TOS @ 0x275844000
[0000.693] I> Unhalting SCE
[0000.695] I> Primary Memory Start:80000000 Size:70000000
[0000.701] I> Extended Memory Start:f0110000 Size:1856f0000
[0000.707] I> MB2(TBoot-BPMP) done
[0000.948] I> Welcome to Cboot
[0000.951] I> Cboot Version: t186-dcb303f9
[0000.955] I> CPU-BL Params @ 0x275800000
[0000.958] I> 0) Base:0x00000000 Size:0x00000000
[0000.963] I> 1) Base:0x277f00000 Size:0x00100000
[0000.967] I> 2) Base:0x277e00000 Size:0x00100000
[0000.972] I> 3) Base:0x277d00000 Size:0x00100000
[0000.976] I> 4) Base:0x277c00000 Size:0x00100000
[0000.981] I> 5) Base:0x277b00000 Size:0x00100000
[0000.985] I> 6) Base:0x277800000 Size:0x00200000
[0000.990] I> 7) Base:0x277400000 Size:0x00400000
[0000.994] I> 8) Base:0x277a00000 Size:0x00100000
[0000.999] I> 9) Base:0x277300000 Size:0x00100000
[0001.003] I> 10) Base:0x276800000 Size:0x00800000
[0001.008] I> 11) Base:0x30000000 Size:0x00040000
[0001.012] I> 12) Base:0xf0000000 Size:0x00100000
[0001.017] I> 13) Base:0x30040000 Size:0x00001000
[0001.021] I> 14) Base:0x30048000 Size:0x00001000
[0001.026] I> 15) Base:0x30049000 Size:0x00001000
[0001.030] I> 16) Base:0x3004a000 Size:0x00001000
[0001.035] I> 17) Base:0x3004b000 Size:0x00001000
[0001.039] I> 18) Base:0x3004c000 Size:0x00001000
[0001.043] I> 19) Base:0x3004d000 Size:0x00001000
[0001.048] I> 20) Base:0x3004e000 Size:0x00001000
[0001.052] I> 21) Base:0x3004f000 Size:0x00001000
[0001.057] I> 22) Base:0x00000000 Size:0x00000000
[0001.061] I> 23) Base:0xf0100000 Size:0x00010000
[0001.066] I> 24) Base:0x00000000 Size:0x00000000
[0001.070] I> 25) Base:0x00000000 Size:0x00000000
[0001.074] I> 26) Base:0x00000000 Size:0x00000000
[0001.079] I> 27) Base:0x00000000 Size:0x00000000
[0001.083] I> 28) Base:0x84400000 Size:0x00400000
[0001.088] I> 29) Base:0x30000000 Size:0x00010000
[0001.092] I> 30) Base:0x278000000 Size:0x08000000
[0001.097] I> 31) Base:0x00000000 Size:0x00000000
[0001.101] I> 32) Base:0x276000000 Size:0x00600000
[0001.106] I> 33) Base:0x80000000 Size:0x70000000
[0001.110] I> 34) Base:0xf0110000 Size:0x1856f0000
[0001.115] I> 35) Base:0x00000000 Size:0x00000000
[0001.119] I> 36) Base:0x00000000 Size:0x00000000
[0001.123] I> 37) Base:0x2772e0000 Size:0x00020000
[0001.128] I> 38) Base:0x84000000 Size:0x00400000
[0001.132] I> 39) Base:0x96000000 Size:0x02000000
[0001.137] I> 40) Base:0x85000000 Size:0x01200000
[0001.141] I> 41) Base:0x275800000 Size:0x00500000
[0001.146] I> 42) Base:0x00000000 Size:0x00000000
[0001.150] I> 43) Base:0x00000000 Size:0x00000000
[0001.155] GIC-SPI Target CPU: 4
[0001.158] Interrupts Init done
[0001.161] calling constructors
[0001.165] initializing heap
[0001.167] initializing threads
[0001.170] initializing timers
[0001.174] creating bootstrap completion thread
[0001.178] top of bootstrap2()
[0001.182] CPU: ARM Cortex A57
[0001.185] CPU: MIDR: 0x411FD073, MPIDR: 0x80000100
[0001.190] initializing platform
[0001.193] I> Boot-device: eMMC
[0001.197] I> sdmmc bdev is already initialized
[0001.203] I> Found 16 partitions in SDMMC_BOOT (instance 3)
[0001.210] I> Found 31 partitions in SDMMC_USER (instance 3)
[0001.215] W> opt-in fuse is not set, skip fuse_burning
[0001.220] I> Reserved memory at 0xfbe00000 for U-Boot relocation
[0001.226] W> No valid slot number is found in scratch register
[0001.232] W> Return default slot: _a
[0001.235] I> A/B: bin_type (21) slot 0
[0001.239] I> Loading partition kernel-dtb at 0x80000000 from device(0x1)
[0001.252] I> Kernel_dtb @0x80000000
[0001.256] I> Bl_dtb @0x8520f400
[0001.258] I> gpio framework initialized
[0001.265] I> tegrabl_gpio_driver_register: register 'nvidia,tegra186-gpio' driver
[0001.274] I> tegrabl_gpio_driver_register: register 'nvidia,tegra186-gpio-aon' driver
[0001.282] I> tegrabl_tca9539_init: i2c bus: 0, slave addr: 0xee
[0001.292] E> I2C: slave not found in slaves.
[0001.296] E> I2C: Could not write 0 bytes to slave: 0x00ee with repeat start false.
[0001.304] E> I2C_DEV: Failed to send register address 0x00000004.
[0001.310] E> I2C_DEV: Could not write 1 registers of size 1 to slave 0xee at 0x00000004 via instance 0.
[0001.319] E> tca9539_device_init: failed to write polar reg
[0001.325] E> tegrabl_tca9539_init: failed to init device!
[0001.330] I> tegrabl_tca9539_init: i2c bus: 0, slave addr: 0xe8
[0001.337] E> I2C: slave not found in slaves.
[0001.341] E> I2C: Could not write 0 bytes to slave: 0x00e8 with repeat start false.
[0001.349] E> I2C_DEV: Failed to send register address 0x00000004.
[0001.355] E> I2C_DEV: Could not write 1 registers of size 1 to slave 0xe8 at 0x00000004 via instance 0.
[0001.364] E> tca9539_device_init: failed to write polar reg
[0001.370] E> tegrabl_tca9539_init: failed to init device!
[0001.378] I> fixed regulator driver initialized
[0001.409] I> register 'maxim' power off handle
[0001.415] I> virtual i2c enabled
[0001.418] I> registered 'maxim,max77620' pmic
[0001.422] I> tegrabl_gpio_driver_register: register 'max77620-gpio' driver
[0001.435] I> Find /i2c@c250000's alias i2c7
[0001.439] I> Reading eeprom i2c=7 address=0x50
[0001.470] I> Device at /i2c@c250000:0x50
[0001.473] I> Reading eeprom i2c=7 address=0x57
[0001.478] E> I2C: slave not found in slaves.
[0001.482] E> I2C: Could not write 0 bytes to slave: 0x00ae with repeat start true.
[0001.490] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.496] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xae at 0x00000000 via instance 7.
[0001.505] E> eeprom: Failed to read I2C slave device
[0001.510] I> Eeprom read failed 0x3526070d
[0001.515] I> Find /i2c@c240000's alias i2c1
[0001.519] I> Reading eeprom i2c=1 address=0x51
[0001.525] E> I2C: slave not found in slaves.
[0001.529] E> I2C: Could not write 0 bytes to slave: 0x00a2 with repeat start true.
[0001.537] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.543] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa2 at 0x00000000 via instance 1.
[0001.553] E> eeprom: Retry to read I2C slave device.
[0001.558] E> I2C: slave not found in slaves.
[0001.562] E> I2C: Could not write 0 bytes to slave: 0x00a2 with repeat start true.
[0001.570] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.576] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa2 at 0x00000000 via instance 1.
[0001.585] E> eeprom: Failed to read I2C slave device
[0001.590] I> Eeprom read failed 0x3526070d
[0001.595] I> Find /i2c@3160000's alias i2c0
[0001.599] I> Reading eeprom i2c=0 address=0x50
[0001.603] E> I2C: slave not found in slaves.
[0001.607] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start true.
[0001.615] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.621] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at 0x00000000 via instance 0.
[0001.631] E> eeprom: Failed to read I2C slave device
[0001.636] I> Eeprom read failed 0x3526070d
[0001.640] I> Find /i2c@3180000's alias i2c2
[0001.644] I> Reading eeprom i2c=2 address=0x54
[0001.649] I> Enabling gpio chip_id = 2, gpio pin = 9
[0001.653] C> GPIO driver for chip_id 0x2 could not be found
[0001.659] E> cam_eeprom_read: Can't get gpio driver
[0001.663] I> Eeprom read failed 0x4d4d000d
[0001.667] I> Reading eeprom i2c=2 address=0x57
[0001.672] I> Enabling gpio chip_id = 2, gpio pin = 9
[0001.676] C> GPIO driver for chip_id 0x2 could not be found
[0001.682] E> cam_eeprom_read: Can't get gpio driver
[0001.687] I> Eeprom read failed 0x4d4d000d
[0001.690] I> create_pm_ids: id: 3310-1000-D01-B, len: 15
[0001.696] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00,, len: 93
[0001.728] I> enabling 'vdd-hdmi' regulator
[0001.732] E> tegrabl_display_get_pdata, failed to parse dtb settings
[0001.741] E> cannot find any other nvdisp nodes
[0001.746] E> no valid display unit config found in dtb
[0001.752] W> display init failed
[0001.755] initializing target
[0001.758] calling apps_init()
[0001.761] starting app kernel_boot_app
[0001.767] I> found decompressor handler: lz4-legacy
[0001.772] I> decompressing BMP blob ...
[0001.787] I> Kernel type = Normal
[0001.790] I> Loading kernel from partition ...
[0001.794] W> No valid slot number is found in scratch register
[0001.800] W> Return default slot: _a
[0001.803] I> A/B: bin_type (24) slot 0
[0001.808] I> Boot image size read from image header: f2d10
[0001.813] I> Boot image load address: 0x0x80400000
[0001.818] I> Loading partition kernel at 0x80400000 from device(0x1)
[0002.611] I> Kernel hdr @0x80400000
[0002.615] I> Kernel dtb @0x80000000
[0002.618] I> T18x: Authenticate boot.img (bin_type 24), max size 0x4000000
[0002.626] I> T18x: Authenticate tegra194-p2888-0001-p2822-0000.dtb (bin_type 21), max size 0x100000
[0002.636] I> Checking boot.img header magic ... [0002.640] I> [OK]
[0002.642] I> Valid boot.img @ 0x80400000
[0002.646] I> decompressor handler not found
[0002.650] I> Copying kernel image (477378 bytes) from 0x80400800 to 0x80800000 ... [0002.658] I> Done
[0002.660] I> Move ramdisk (len: 0) from 0x80475800 to 0x94830000
[0002.667] I> Updated bpmp info to DTB
[0002.673] I> Ramdisk: Base: 0x94830000; Size: 0x0
[0002.677] I> Updated initrd info to DTB
[0002.681] W> WARN: Fail to override "console=none" in commandline
[0002.687] E> tegrabl_linuxboot_add_disp_param, du 0 failed to get display params
[0002.694] E> tegrabl_linuxboot_add_disp_param, du 0 failed to get display params
[0002.701] E> tegrabl_linuxboot_add_disp_param, du 0 failed to get display params
[0002.709] I> disabled_core_mask: 0xffffff0c
[0002.713] W> No valid slot number is found in scratch register
[0002.718] W> Return default slot: _a
[0002.722] I> Active slot suffix:
[0002.725] I> add_boot_slot_suffix: slot_suffix =
[0002.729] I> Linux Cmdline: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 video=tegrafb no_console_suspend=1 earlycon=uart8250,mmio32,0x3100000 nvdumper_reserved=0x2772e0000 gpt usbcore.old_scheme_first=1 tegraid=18.1.2.0.0 maxcpus=6 boot.slot_suffix= boot.ratchetvalues=0.2031647.1 bl_prof_dataptr=0x10000@0x275840000 sdhci_tegra.en_boot_part_access=1
[0002.766] I> Updated bootarg info to DTB
[0002.769] I> eeprom_get_mac_addr: MAC (type: 0): 00:04:4b:c7:19:66
[0002.776] I> eeprom_get_mac_addr: MAC (type: 1): 00:04:4b:c7:19:67
[0002.782] I> eeprom_get_mac_addr: MAC (type: 2): 00:04:4b:c7:19:68
[0002.790] E> Found no plugin manager ids in source DT
[0002.795] W> Add plugin manager ids from board info
[0002.799] E> "plugin-manager" doesn't exist, creating
[0002.804] E> "ids" doesn't exist, creating
[0002.808] E> "connection" doesn't exist, creating
[0002.813] E> "configs" doesn't exist, creating
[0002.817] I> create_pm_ids: id: 3310-1000-D01-B, len: 15
[0002.823] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00,, len: 93
[0002.833] I> Adding plugin-manager/ids/3310-1000-D01=/i2c@c250000:module@0x50
[0002.841] E> "i2c@c250000" doesn't exist, creating
[0002.845] E> "module@0x50" doesn't exist, creating
[0002.852] I> Adding plugin-manager/ids/3310-1000-D01-B
[0002.859] I> Adding plugin-manager/configs/3310-mem-type 00
[0002.865] I> Adding plugin-manager/configs/3310-power-config 00
[0002.871] I> Adding plugin-manager/configs/3310-misc-config 00
[0002.877] I> Adding plugin-manager/configs/3310-modem-config 00
[0002.883] I> Adding plugin-manager/configs/3310-touch-config 00
[0002.889] I> Adding plugin-manager/configs/3310-display-config 00
[0002.895] I> Adding plugin-manager/cvm
[0002.899] E> "chip-id" doesn't exist, creating
[0002.903] I> Adding plugin-manager/chip-id/A02P
[0002.907] E> "odm-data" doesn't exist, creating
[0002.912] I> Adding /chosen/plugin-manager/odm-data
[0002.921] I> added [base:0x80000000, size:0x70000000] to /memory
[0002.927] I> added [base:0xf0200000, size:0x185600000] to /memory
[0002.933] I> added [base:0x275e00000, size:0x200000] to /memory
[0002.939] I> added [base:0x276600000, size:0x200000] to /memory
[0002.945] I> added [base:0x277000000, size:0x200000] to /memory
[0002.950] I> Updated memory info to DTB
[0002.955] E> add_disp_param: failed to get display params for du=0
[0002.963] E> "reset" doesn't exist, creating
[0002.967] E> "pmc-reset-reason" doesn't exist, creating
[0002.972] E> "pmic-reset-reason" doesn't exist, creating
[0002.979] I> Adding ecid(0000000164510283100000000e0682c0) to DT
[0002.984] I> disabled_core_mask: 0xffffff0c
[0002.997] I> Add serial number:0425018067973 as DT property
[0003.006] I> Plugin-manager override starting
[0003.011] I> node /plugin-manager/fragement@0 matches
[0003.021] I> node /plugin-manager/fragement@4 matches
[0003.033] I> node /plugin-manager/fragment-sdwake-p3310-1000-300 matches
[0003.052] I> node /plugin-manager/fragement-pmon-p3310-1000-300 matches
[0003.061] I> node /plugin-manager/fragement-pmon-p3310-1000-800 matches
[0003.070] I> node /plugin-manager/fragment-devslp@0 matches
[0003.082] I> node /plugin-manager/fragment-500-pcie-config matches
[0003.096] I> node /plugin-manager/fragment-500-xusb-config matches
[0003.119] I> node /plugin-manager/fragment-p3310-c00-comm matches
[0003.132] I> node /plugin-manager/fragment-p3310-c00-pmic matches
[0003.142] I> node /plugin-manager/fragment-p3310-c01 matches
[0003.153] I> node /plugin-manager/fragment-p3310-c03 matches
[0003.189] I> node /plugin-manager/fragment-p3310-c00-camera matches
[0003.214] I> Disable plugin-manager status in FDT
[0003.219] I> Plugin-manager override finished successfully
[0003.224] I> tegrabl_load_kernel_and_dtb: Done
[0003.229] E> tegrabl_display_clear: display is not initialized
[0003.234] W> Boot logo display failed...
[0003.238] I> Kernel EP: 0x80800000, DTB: 0x80000000
TEGRA186
DRAM: 7.8 GiB
In: serial
Out: serial
Err: serial
Scanning mmc 0:1...
733 bytes read in 124 ms (4.9 KiB/s)
L4T boot options
1: primary kernel
5565090 bytes read in 220 ms (24.1 MiB/s)
Starting kernel ...
[ 0.718707] pca953x 0-0074: failed reading register
[ 0.719409] pca953x 0-0077: failed reading register
[ 1.400200] tegra-xusb-padctl 3520000.xusb_padctl: failed to setup XUSB ports: -517
[ 1.425259] pre_t19x_iso_plat_register(): iso bandwidth 4687500KB is not available, client tegra_camera_ctrl
[ 1.425329] misc tegra_camera_ctrl: tegra_camera_isomgr_register: unable to register to isomgr
[ 1.425365] misc tegra_camera_ctrl: tegra_camera_probe: failed to register CAMERA as isomgr client
[ 1.659572] pre_t19x_iso_plat_register(): iso bandwidth 81920KB is not available, client eqos
[ 1.793433] FAN: coudln't get the regulator
[ 11.671662] tegra-i2c 3190000.i2c: pio timed out addr: 0x50 tlen:28 rlen:128
[ 11.678833] tegra-i2c 3190000.i2c: --- register dump for debugging ----
[ 11.685508] tegra-i2c 3190000.i2c: I2C_CNFG - 0x22c00
[ 11.690598] tegra-i2c 3190000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 11.697251] tegra-i2c 3190000.i2c: I2C_FIFO_CONTROL - 0xe0
[ 11.702761] tegra-i2c 3190000.i2c: I2C_FIFO_STATUS - 0x800040
[ 11.708565] tegra-i2c 3190000.i2c: I2C_INT_MASK - 0x7d
[ 11.713764] tegra-i2c 3190000.i2c: I2C_INT_STATUS - 0x0
[ 11.719030] tegra-i2c 3190000.i2c: i2c transfer timed out addr: 0x50
[ 21.911696] tegra-i2c 3190000.i2c: pio timed out addr: 0x50 tlen:28 rlen:128
[ 21.918838] tegra-i2c 3190000.i2c: --- register dump for debugging ----
[ 21.925512] tegra-i2c 3190000.i2c: I2C_CNFG - 0x22c00
[ 21.930611] tegra-i2c 3190000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 21.937915] tegra-i2c 3190000.i2c: I2C_FIFO_CONTROL - 0xe0
[ 21.943431] tegra-i2c 3190000.i2c: I2C_FIFO_STATUS - 0x800040
[ 21.949196] tegra-i2c 3190000.i2c: I2C_INT_MASK - 0x7d
[ 21.954353] tegra-i2c 3190000.i2c: I2C_INT_STATUS - 0x0
[ 21.959606] tegra-i2c 3190000.i2c: i2c transfer timed out addr: 0x50
[ 22.000809] ina3221x 0-0042: ina3221 reset failure status: 0xffffff87
[ 22.008880] ina3221x 0-0043: ina3221 reset failure status: 0xffffff87
[ 22.073980] pre_t19x_iso_plat_register(): iso bandwidth 24576KB is not available, client ape_adma
[ 22.083046] tegra_isomgr_adma_register: Failed to register adma isomgr client. err=-22
[ 22.439422] isp 15600000.isp: isp_probe: failed
[ 22.474387] tegra-xusb-padctl 3520000.xusb_padctl: failed to setup XUSB ports: -517
[ 22.508031] tegra-xusb-padctl 3520000.xusb_padctl: failed to setup XUSB ports: -517
[ 23.074122] cgroup: cgroup2: unknown option "nsdelegate"
[ 23.807432] tegra-xusb-padctl 3520000.xusb_padctl: failed to setup XUSB ports: -517
[ 23.945125] tegra-xusb-padctl 3520000.xusb_padctl: failed to setup XUSB ports: -517
[ 27.887812] CPU1: shutdown
[ 27.905771] tegra-xusb-padctl 3520000.xusb_padctl: failed to setup XUSB ports: -517
[ 27.949100] tegra-xusb-padctl 3520000.xusb_padctl: failed to setup XUSB ports: -517
[ 27.998148] CPU2: shutdown
[ 28.006888] tegra-xusb-padctl 3520000.xusb_padctl: failed to setup XUSB ports: -517
[ 28.557425] tegra-xusb-padctl 3520000.xusb_padctl: failed to setup XUSB ports: -517
[ 28.585458] tegra-xusb-padctl 3520000.xusb_padctl: failed to setup XUSB ports: -517
[ 28.962664] __tegra_isomgr_reserve(): bad handle ffffffffffffffea
[ 28.969748] eqos 2490000.ether_qos: EQOS ISO BW 81920 reservation failed with 0
[ 32.151846] tegra-i2c 3190000.i2c: pio timed out addr: 0x50 tlen:28 rlen:128
[ 32.159908] tegra-i2c 3190000.i2c: --- register dump for debugging ----
[ 32.167211] tegra-i2c 3190000.i2c: I2C_CNFG - 0x22c00
[ 32.172870] tegra-i2c 3190000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 32.179796] tegra-i2c 3190000.i2c: I2C_FIFO_CONTROL - 0xe0
[ 32.187000] tegra-i2c 3190000.i2c: I2C_FIFO_STATUS - 0x800040
[ 32.193062] tegra-i2c 3190000.i2c: I2C_INT_MASK - 0x7d
[ 32.198639] tegra-i2c 3190000.i2c: I2C_INT_STATUS - 0x0
[ 32.204053] tegra-i2c 3190000.i2c: i2c transfer timed out addr: 0x50
nvidia-desktop login: [ 35.741036] vdd-1v8: voltage operation not allowed
[ 35.746455] sdhci-tegra 3440000.sdhci: could not set regulator OCR (-1)
[ 35.771985] vdd-1v8: voltage operation not allowed
[ 35.776918] sdhci-tegra 3440000.sdhci: could not set regulator OCR (-1)
[ 35.804860] vdd-1v8: voltage operation not allowed
[ 35.809909] sdhci-tegra 3440000.sdhci: could not set regulator OCR (-1)
[ 35.819245] vdd-1v8: voltage operation not allowed
[ 35.824206] sdhci-tegra 3440000.sdhci: could not set regulator OCR (-1)
[ 35.938111] vdd-1v8: voltage operation not allowed
[ 35.943006] sdhci-tegra 3440000.sdhci: could not set regulator OCR (-1)
[ 35.950799] vdd-1v8: voltage operation not allowed
[ 35.955681] sdhci-tegra 3440000.sdhci: could not set regulator OCR (-1)
[ 35.964277] vdd-1v8: voltage operation not allowed
[ 35.969132] sdhci-tegra 3440000.sdhci: could not set regulator OCR (-1)
[ 42.391756] tegra-i2c 3190000.i2c: pio timed out addr: 0x50 tlen:28 rlen:128
[ 42.399223] tegra-i2c 3190000.i2c: --- register dump for debugging ----
[ 42.408521] tegra-i2c 3190000.i2c: I2C_CNFG - 0x22c00
[ 42.415785] tegra-i2c 3190000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 42.424703] tegra-i2c 3190000.i2c: I2C_FIFO_CONTROL - 0xe0
[ 42.432424] tegra-i2c 3190000.i2c: I2C_FIFO_STATUS - 0x800040
[ 42.440117] tegra-i2c 3190000.i2c: I2C_INT_MASK - 0x7d
[ 42.446621] tegra-i2c 3190000.i2c: I2C_INT_STATUS - 0x0
[ 42.453510] tegra-i2c 3190000.i2c: i2c transfer timed out addr: 0x50
[ 44.388440] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 44.424504] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 44.542815] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 44.751502] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 44.775288] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 44.809071] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 44.829909] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 44.862263] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 44.888824] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 44.922592] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 44.945159] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 44.976755] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 45.003191] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 45.036734] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 45.068872] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 45.101189] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 45.134866] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 45.168969] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 45.199033] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 45.233403] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 45.269049] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 45.410911] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 45.559043] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 48.271226] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 48.440799] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 52.631742] tegra-i2c 3190000.i2c: pio timed out addr: 0x50 tlen:28 rlen:128
[ 52.639015] tegra-i2c 3190000.i2c: --- register dump for debugging ----
[ 52.645819] tegra-i2c 3190000.i2c: I2C_CNFG - 0x22c00
[ 52.651159] tegra-i2c 3190000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 52.658043] tegra-i2c 3190000.i2c: I2C_FIFO_CONTROL - 0xe0
[ 52.663617] tegra-i2c 3190000.i2c: I2C_FIFO_STATUS - 0x800040
[ 52.669426] tegra-i2c 3190000.i2c: I2C_INT_MASK - 0x7d
[ 52.674604] tegra-i2c 3190000.i2c: I2C_INT_STATUS - 0x0
[ 52.679885] tegra-i2c 3190000.i2c: i2c transfer timed out addr: 0x50
[ 55.335063] tegradc 15210000.nvdisplay: sanitize_flip_args: WIN 2 invalid size:w=0,h=0,out_w=0,out_h=0
[ 62.871717] tegra-i2c 3190000.i2c: pio timed out addr: 0x50 tlen:28 rlen:128
[ 62.878838] tegra-i2c 3190000.i2c: --- register dump for debugging ----
[ 62.885606] tegra-i2c 3190000.i2c: I2C_CNFG - 0x22c00
[ 62.890795] tegra-i2c 3190000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 62.897583] tegra-i2c 3190000.i2c: I2C_FIFO_CONTROL - 0xe0
[ 62.903452] tegra-i2c 3190000.i2c: I2C_FIFO_STATUS - 0x800040
[ 62.909429] tegra-i2c 3190000.i2c: I2C_INT_MASK - 0x7d
[ 62.914674] tegra-i2c 3190000.i2c: I2C_INT_STATUS - 0x0
[ 62.920195] tegra-i2c 3190000.i2c: i2c transfer timed out addr: 0x50
FYI I did these steps:
- Edit t18x-common-platforms/tegra186-quill-power-tree-p3310-1000-a00-00.dtsi file in:
Linux_for_Tegra/sources/hardware/nvidia/platform/t18x/common/kernel-dts/t18x-common-platforms
- Compile in
Linux_for_Tegra/sources/kernel/kernel-4.9
Command:
make ARCH=arm64 O=$TEGRA_KERNEL_OUT -j4
- Copy the dtb files from
cd Linux_for_Tegra/sources/hardware/nvidia/platform/t18x/common/kernel-dts/t18x-common-platforms
cp tegra186-quill-p3310-1000-a00-00-base.dtb tegra186-quill-p3310-1000-as-0888.dtb tegra186-quill-p3310-1000-c03-00-base.dtb tegra186-quill-p3310-1000-c03-00-dsi-hdmi-dp.dtb tegra186-quill-p3489-0888-a00-00-base.dtb tegra186-quill-p3489-1000-a00-00-ucm1.dtb tegra186-quill-p3489-1000-a00-00-ucm2.dtb tegra194-p2888-0001-p2822-0000.dtb tegra194-p2888-0001-p2822-0000-maxn.dtb tegra194-p2888-0006-p2822-0000.dtb tegra194-p2888-as-0006-p2822-0000.dtb ../../../../../kernel/dtb
- flash the dtb to the TX2
sudo ./flash.sh -k kernel-dtb jetson-tx2 mmcblk0p1
(on dir Linux_for_Tegra)
What I’m doing wrong?
Thank you!
Wayne or someone else from Nvidia, I really need help on this.
If I understand your problem correctly then I believe we were faced with the same issue with our custom carrier boards that have dual HDMI outputs. The problem we encountered was that the monitor would not startup at all after flashing the standard DTB from SDK Manager. This isn’t really a surprise since the DTB from SDK Manager is for the developer kit baseboard and not for the D3 hardware. Our solution is to flash our DTB after flashing with SDK Manager.
Do I understand that your problem is that your HDMI display isn’t working on your carrier board yet?
Perhaps our device tree source will help you. [url]https://github.com/D3Engineering/d3-jetson-bsp/blob/f619a78088f1a2da995a8df6b17d556b375e877e/hardware/d3/d3-rsp.dtsi#L383[/url].
Yes, HDMI isn’t working on ours carrier board, but We have only HDMI0 (DP0) connected, the HDMI1 (DP1) is connected to nothing, so I don’t have any display working in my board :-(
Thank’s I’ll take a look on this!
Please go ahead with D3’s suggestion first. If this issue is still, I would suggest you to check your hardware design…
D3_growe, how do you compile the dtb? I’m trying to replace the contents of tegra186-quill-p3310-1000-c03-00-base.dts whit you dts, let the line "#include “tegra186-quill-p3310-1000-a00-00-base.dts” to get references.
But I’m facing whit error:
ERROR (phandle_references): Reference to non-existent node or label "vdd_usb2_5v"
Can you help-me?
Alfredo,
For your purposes I think you’re better off using our DTS as a reference and just pulling in a few of the HDMI specific attributes into your device tree.
If you follow the instructions in the README.md you should be able to build the d3/1.3.3 branch from GitHub. D3 has a baseboard that has dual HDMI. You’ll find many device tree files in hardware/d3 name d3-rsp*.dts. You could start reading the device tree from d3-rsp-fp[dlink-imx390.dts.
This error indicates there is a “nickname” of node called “vdd_usb2_5v” but the dtc cannot find what is the real node this nickname refer to.
Thanks! I’ll take a look on this.
Yes, the nickname is used in file tegra186-quill-p3310-1000-a00-00-base.dts and this file includes the file tegra186-quill-power-tree-p3310-1000-a00-00.dtsi and this includes the tegra186-cvb-prod-p2597-b00-p3310-1000-a00-00.dtsi, and, finally, on this file on line 283, there’s the definition of “vdd_usb2_5v”. I can’t understand why this error is happen.
Is there a detailed guide how to build a Device Tree to use the P3310 on a custom board? Because the nvidia “guide” https://developer.nvidia.com/embedded/dlc/Tegra_Linux_Driver_Package_AGX_Xavier_Adaptation_Guide is very simple. I need something more detailed.
Could you share your device tree as a tarball?
I don’t have it anymore, but it’s original dts and dtsi files from Nvidia, where tegra186-quill-p3310-1000-c03-00-base.dts file “body” is replaced with D3 file body: https://github.com/D3Engineering/d3-jetson-bsp/blob/f619a78088f1a2da995a8df6b17d556b375e877e/hardware/d3/d3-rsp.dtsi
