• Hardware Platform (GPU) 1660ti
• DeepStream Version 6.0
• TensorRT Version 8.0.1
• NVIDIA GPU Driver Version (valid for GPU only) 470.82.01
• Issue Type: dlopen error: /path/to/library/libByteTracker.so: undefined symbol: _ZN2cv6String10deallocateEv
I’ve followed the repository Byte-Deepstream to created a library from the Byte Track CPP code and passed it as the custom low level tracker library for NvTracker plugin. Since the code for NvTracker is closed source, its difficult to get to the root cause of the issue.
Here is my config file
config.txt (5.1 KB)
I run this with deepstream-app -c /path/to/config.txt
when I run the command I get this error message
Warning: 'input-dims' parameter has been deprecated. Use 'infer-dims' instead.
gstnvtracker: Loading low-level lib at /path/to/Byte-Deepstream/lib/libByteTracker.so
gstnvtracker: Failed to open low-level lib at /path/to/Byte-Deepstream/lib/libByteTracker.so
dlopen error: /home/ahmedtarek/trackers/Byte-Deepstream/lib/libByteTracker.so: undefined symbol: _ZN2cv6String10deallocateEv
gstnvtracker: Failed to initilaize low level lib.
0:00:00.158945660 20584 0x5587629cd560 ERROR nvtracker gstnvtracker.cpp:265:gst_nv_tracker_start: gstnvtracker: Failed to initialize trackerIface
0:00:00.158979796 20584 0x5587629cd560 WARN GST_PADS gstpad.c:1149:gst_pad_set_active:<tracking_tracker:sink> Failed to activate pad
** ERROR: <main:658>: Failed to set pipeline to PAUSED
Quitting
can you help me please with this error ?
