Hi, We are unable to start the jet Orin NX according to the official design of the carrier board. What are the startup conditions?
Start current test:
Self developed carrier board 12V power supply (abnormal startup):
The current starts at around 0.48A and then drops to around 0.23A
You can refer to the power on sequence listed in the Design Guide doc to check your own sequence.
Hi!
The startup conditions are described at Jetson Orin NX Series and Jetson Orin Nano Series more specifically at section 6.1: Power Supply and Sequencing , there you will find important information about the pins must be energized, voltage parameters, and signals sequences.
Thanks,
Oscar Fallas
Embedded SW Engineer at RidgeRun
Contact us: support@ridgerun.com
Developers wiki: https://developer.ridgerun.com
Website: https://www.ridgerun.com/
