[Custom Carrier Board] Dual fan setup on AGX Orin - How to monitor the second fan's TACH?
Hi everyone,
I am currently designing a custom carrier board for the Jetson AGX Orin module that requires a dual-fan cooling setup. In our hardware design, both fans share the same PWM control signal to run synchronously.
However, we need to monitor the tachometer (RPM) signals for both fans independently to ensure redundancy and detect if one of the fans fails.
I have checked the official Orin AGX Pinmux Spreadsheet and the TRM, but I could only find ONE native hardware TACH pin:
  • Pin E54 / SOC_GPIO29 / GP62 → Configured as NV_THERM_FAN_TACH0
I searched the entire Pinmux spreadsheet for “TACH” and could not find any alternate functions (SFIO) like TACH_1 or TACH_2 on other pins.
Could you please help clarify the following questions?
  1. Hardware Confirmation: Can you confirm that the Orin AGX SoC physically only has ONE hardware Fan Tachometer controller, and there is no alternative native pin for a second fan’s TACH?
  2. Recommended Workaround: If we must monitor the second fan’s RPM for safety requirements, what is NVIDIA’s recommended best practice?
    • Option A: Route the 2nd TACH to a standard GPIO and calculate the RPM via software edge-triggered interrupts. (I am concerned about the CPU overhead and missing interrupts at high RPMs).
    • Option B: Add an external I2C-based hardware monitor / fan controller IC to handle the 2nd fan.
    • Option C: Since they share the same PWM, is it standard practice for Jetson designs to simply leave the second TACH disconnected and rely on SoC thermal tripping if it fails?
Any guidance, insights, or reference designs for dual-fan monitoring on the Orin platform would be greatly appreciated.
Thanks in advance!
Hi fa1053,
Based on the current public Jetson AGX Orin documentation, only one fan control/tach path is documented in the BSP (FAN 1 / single tach readback).
If you need independent RPM fault monitoring for a 2nd fan, the practical approach is to use an external monitor/controller; GPIO pulse counting would be a custom workaround, not the standard documented path.
We are currently on JetPack 7.2. We will follow your recommendation. Thank you very much for the help!
