Custom carrier board startup failed
Hi everyone
We have customized a nano board, and the serial port debugging information after startup is often failed after [0000.810] Performing RAM repair
May I ask the possible reason for hanging up?What are the processes before and after system startup to execute here?Serial debugging information is as follows:
0000.126] [TegraBoot] (version 00.00.2018.01-l4t-24abfa75)
[0000.131] Processing in cold boot mode Bootloader 2
[0000.135] A02 Bootrom Patch rev = 1023
[0000.139] Power-up reason: pmc por
[0000.142] No Battery Present
[0000.145] pmic max77620 reset reason
[0000.148] pmic max77620 NVERC : 0x40
[0000.152] RamCode = 0
[0000.154] Platform has DDR4 type RAM
[0000.157] max77620 disabling SD1 Remote Sense
[0000.161] Setting DDR voltage to 1125mv
[0000.165] Serial Number of Pmic Max77663: 0x1b09a3
[0000.173] Entering ramdump check
[0000.176] Get RamDumpCarveOut = 0x0
[0000.179] RamDumpCarveOut=0x0,  RamDumperFlag=0xe59ff3f8
[0000.184] Last reboot was clean, booting normally!
[0000.189] Sdram initialization is successful
[0000.193] SecureOs Carveout Base=0x00000000ff800000 Size=0x00800000
[0000.199] Lp0 Carveout Base=0x00000000ff780000 Size=0x00001000
[0000.205] BpmpFw Carveout Base=0x00000000ff700000 Size=0x00080000
[0000.211] GSC1 Carveout Base=0x00000000ff600000 Size=0x00100000
[0000.217] GSC2 Carveout Base=0x00000000ff500000 Size=0x00100000
[0000.223] GSC4 Carveout Base=0x00000000ff400000 Size=0x00100000
[0000.228] GSC5 Carveout Base=0x00000000ff300000 Size=0x00100000
[0000.234] GSC3 Carveout Base=0x000000017f300000 Size=0x00d00000
[0000.250] RamDump Carveout Base=0x00000000ff280000 Size=0x00080000
[0000.256] Platform-DebugCarveout: 0
[0000.260] Nck Carveout Base=0x00000000ff080000 Size=0x00200000
[0000.266] Non secure mode, and RB not enabled.
[0000.316] Csd NumOfBlocks=61157376
[0000.379] Using GPT Primary to query partitions
[0000.387] Loading Tboot-CPU binary
[0000.774] Verifying TBC in OdmNonSecureSBK mode
[0000.784] Bootloader load address is 0xa0000000, entry address is 0xa0000258
[0000.791] Bootloader downloaded successfully.
[0000.795] Downloaded Tboot-CPU binary to 0xa0000258
[0000.800] MAX77620_GPIO5 configured
[0000.803] CPU power rail is up
[0000.806] CPU clock enabled
[0000.813] Updating A64 Warmreset Address to 0xa00002e9
Best regards!
This issue is the same as another one, please follow up with below topic:
[url]https://devtalk.nvidia.com/default/topic/1052986/jetson-nano/custom-carrier-board-startup-failed/[/url]
