Custom carrier board use USB0 can't flash to Nvme
We use jetpack4.6 and custom carrier board,not use type-c, USB0 is used as the interface for flashing kernel and rootfs . This interface can normally flashed internal EMMC, but not NVME.
The flashing of Nvme will timeout:
official devkit xavier can flash normal by type-c ,also can see “7035” :
How to use USB0 port to flash Nvme normally on my customer carrier board?
Any suggestions would be welcome,thanks!
BR.
What is your method to flash NVMe now?
Hi WayneWWW,
Thanks for your reply!
PC host ubuntu18.04, use SDKManger 1.7.1.8928 to flash NVMe,.It can flash official devkit xavier normal , but not customer carrier board.
My customer carrier board removed the Type-C module and used USB0 only to flash the system.
USB0 can normally flash in EMMC mode, but cannot flash in NVME mode by SDKManger . When “Waiting for target to boot-up…” is displayed, it always times out and exit.
How can I flash NVME using the USB0 interface? Or, does flashing NVME have to be type-C?
BR.
No, I think this issue is just due to the custom board.
Since you changed the design, the default sdkm or jetpack is not able to support that kind.
Please firstly make sure your have a dtb that can guarantee the usb0 port works fine as device mode. And refer to the initrd flash steps here.
https://docs.nvidia.com/jetson/l4t/index.html#page/Tegra%20Linux%20Driver%20Package%20Development%20Guide/flashing.html#wwpID0E0PI0HA
Hi WayneWWW,
Yes, I agree with you.
The question is how do I make sure have a dtb that can guarantee the usb0 port works fine as device mode?
Some information is below:
Our SCH:
My DTS:
 * Common include DTS file for CVM:P2888-0001 and CVB:P2822-0000 variants.
 * Copyright (c) 2018-2020, NVIDIA CORPORATION.  All rights reserved.
 * This program is free software; you can redistribute it and/or modify
 * it under the terms of the GNU General Public License as published by
 * the Free Software Foundation; version 2 of the License.
 * This program is distributed in the hope that it will be useful, but WITHOUT
 * ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or
 * FITNESS FOR A PARTICULAR PURPOSE.  See the GNU General Public License for
 * more details.
#include "dt-bindings/extcon-ids.h"
#include "dt-bindings/gpio/tegra194-gpio.h"
#include "tegra194-p2888-0000-a00.dtsi"
#include <t19x-common-platforms/tegra194-platforms-eqos.dtsi>
#include "tegra194-p2822-0000-a00.dtsi"
#include "tegra194-power-tree-p2888-0001-p2822-1000.dtsi"
#include <t19x-common-platforms/tegra194-comms.dtsi>
#include "tegra194-thermal-p2888.dtsi"
#include "tegra194-plugin-manager-p2888-0000.dtsi"
#include "tegra194-plugin-manager-p2822-0000.dtsi"
#include "tegra194-super-module-e2614-p2888-0000.dtsi"
#include <t19x-common-platforms/tegra194-no-pll-aon-clock.dtsi>
#include "tegra194-p2822-0000-eeprom.dtsi"
	nvidia,dtsfilename = __FILE__;
	nvidia,dtbbuildtime = __DATE__, __TIME__;
	nvidia,fastboot-usb-vid = <0x0955>;
	nvidia,fastboot-usb-pid = <0xee1e>;
	model = "Jetson-AGX";
	compatible = "nvidia,galen", "nvidia,jetson-xavier", "nvidia,p2822-0000+p2888-0001", "nvidia,tegra194";
	chosen {
		bootargs ="console=ttyTCU0,115200";
		board-has-eeprom;
	firmware {
		android {
			compatible = "android,firmware";
			hardware = "jetson-xavier";
			vbmeta {
				compatible = "android,vbmeta";
				parts = "vbmeta,kernel,kernel-dtb,APP,vendor,SOS";
			fstab {
				compatible = "android,fstab";
				vendor {
					compatible = "android,vendor";
					dev = "/dev/block/platform/3460000.sdhci/by-name/vendor";
					type = "ext4";
					mnt_flags = "ro";
					fsmgr_flags = "wait,avb";
				odm {
					compatible = "android,odm";
					dev = "/dev/block/platform/3460000.sdhci/by-name/odm";
					type = "ext4";
					mnt_flags = "ro";
	bluedroid_pm {
		compatible = "nvidia,tegra-bluedroid_pm";
		bluedroid_pm,reset-gpio = <&tegra_main_gpio TEGRA194_MAIN_GPIO(M, 6) 0>;
		bluedroid_pm,host-wake-gpio = <&tegra_main_gpio TEGRA194_MAIN_GPIO(Y, 0) 0>;
		bluedroid_pm,ext-wake-gpio = <&tegra_main_gpio TEGRA194_MAIN_GPIO(M, 7) 0>;
		interrupt-parent = <&tegra_main_gpio>;
		interrupts = <TEGRA194_MAIN_GPIO(Y, 0) 0x01>;
	spi@c260000 {
		status = "disabled";
	spi@3210000 {
		status = "okay";
		spi@0 {
			compatible = "tegra-spidev";
			reg = <0x0>;
			spi-max-frequency = <33000000>;
			controller-data {
				nvidia,enable-hw-based-cs;
				/*nvidia,rx-clk-tap-delay = <0x11>;*/
	spi@3230000 {
		status = "okay";
		spi@0 {
			reg = <0x0>;
			controller-data {
	spi@3270000 {
	spi@3300000 {
	pmc@c370000 {
		nvidia,invert-interrupt;
	hdr40_i2c0: i2c@c240000 {
		bmi160@69 {
			compatible = "bmi,bmi160";
			reg = <0x69>;
			interrupt-parent = <&tegra_aon_gpio>;
			interrupts = <TEGRA194_AON_GPIO(AA, 2) GPIO_ACTIVE_LOW>;
			accelerometer_matrix    = [01 00 00 00 01 00 00 00 01];
			gyroscope_matrix        = [01 00 00 00 01 00 00 00 01];
			accelerometer_delay_us_min = <1250>;
			gyroscope_delay_us_min = <1250>;
		ucsi_ccg: ucsi_ccg@8 {
			typec-extcon {
				typec_port0: port-0 {
					#extcon-cells = <1>;
				typec_port1: port-1 {
			typec-pd {
				typec_pd: pd {
#if TEGRA_XUSB_PADCONTROL_VERSION >= DT_VERSION_2
	xusb_padctl: xusb_padctl@3520000 {
		status = "okay";
		pads {
			usb2 {
				lanes {
					usb2-0 {
						nvidia,function = "xusb";
						status = "okay";
					usb2-1 {
						status = "okay";
					usb2-2 {
						status = "okay";
					usb2-3 {
						status = "okay";
			usb3 {
				lanes {
					usb3-0 {
						status = "okay";
					usb3-2 {
						status = "okay";
					usb3-3 {
						status = "okay";
		ports {
			usb2-0 {
				mode = "device";
				status = "okay";
			usb2-1 {
				mode = "device";
				status = "okay";
			usb2-2 {
				mode = "device";
				status = "okay";
			usb2-3 {
				mode = "device";
				status = "okay";
			usb3-0 {
				nvidia,usb2-companion = <1>;
				status = "device";
			usb3-2 {
				nvidia,usb2-companion = <0>;
				status = "device";
			usb3-3 {
				nvidia,usb2-companion = <3>;
				status = "device";
#endif
	tegra_xudc: xudc@3550000 {
		extcon-cables = <&typec_port0 0>;
		extcon-cable-names = "vbus";
		phys = <&{/xusb_padctl@3520000/pads/usb2/lanes/usb2-0}>,
			<&{/xusb_padctl@3520000/pads/usb3/lanes/usb3-2}>;
		phy-names = "usb2", "usb3";
		nvidia,xusb-padctl = <&xusb_padctl>;
#endif
		nvidia,boost_cpu_freq = <1200>;
		status = "okay";
	tegra_xhci: xhci@3610000 {
		extcon-cables = <&typec_port0 1>;
		extcon-cable-names = "id";
			<&{/xusb_padctl@3520000/pads/usb2/lanes/usb2-1}>,
			<&{/xusb_padctl@3520000/pads/usb2/lanes/usb2-3}>,
			<&{/xusb_padctl@3520000/pads/usb2/lanes/usb2-2}>,
			<&{/xusb_padctl@3520000/pads/usb3/lanes/usb3-2}>,
			<&{/xusb_padctl@3520000/pads/usb3/lanes/usb3-0}>,
			<&{/xusb_padctl@3520000/pads/usb3/lanes/usb3-3}>;
		phy-names = "usb2-0", "usb2-1", "usb2-3", "usb2-2",
			"usb3-2", "usb3-0", "usb3-3";
#endif
		status = "okay";
	arm-pmu {
		status = "okay";
	power-domain {
	interrupt-controller {
	mods-simple-bus {
	eeprom-manager {
	cpuidle {
		compatible = "nvidia,tegra19x-cpuidle";
		status = "okay";
	thermal-zones {
	reserved-memory {
		ramoops_carveout {
			status = "okay";
	mttcan@c310000 {
		status = "okay";
	mttcan@c320000 {
		status = "okay";
	serial@3110000 {
		status = "okay";
	pwm@3280000 {
		status = "okay";
	pwm@32c0000 {
		status = "okay";
	pwm@32f0000 {
		status = "okay";
	hdr40_i2c1: i2c@31e0000 {
		pinctrl-names = "default";
		pinctrl-0 = <&dpaux_default>;
		bmi160@69 {
			reg = <0x69>;
	host1x {
		dpaux@155F0000 {
			status = "okay";
			compatible = "nvidia,tegra194-dpaux3-padctl";
			/delete-property/ power-domains;
			dpaux_default: pinmux@0 {
				dpaux3_pins {
					pins = "dpaux3-3";
					function = "i2c";
	ufshci@2450000 {
		nvidia,enable-hs-mode;
		nvidia,cd-gpios = <&tegra_aon_gpio TEGRA194_AON_GPIO(EE, 0) GPIO_ACTIVE_HIGH>;
		nvidia,cd-wakeup-capable;
	pfsd {
		pwm_polarity= <PWM_POLARITY_NORMAL>;
		suspend_state = <0>;
	clocks-init {
		compatible = "nvidia,clocks-config";
		status = "okay";
		disable {
			clocks = <&aon_clks TEGRA194_CLK_PLLAON>,
				<&bpmp_clks TEGRA194_CLK_CAN1>,
				<&bpmp_clks TEGRA194_CLK_CAN2>;
&head0 {
	extcon-cables = <&typec_port0 2 &typec_port1 2>;
	extcon-cable-names = "typec0", "typec1";
&head1 {
&head2 {
&sor0 {
	nvidia,typec-port = /bits/ 8 <0>;
&sor1 {
	nvidia,typec-port = /bits/ 8 <1>;
#if LINUX_VERSION >= 414
#include <tegra194-linux-4.14.dtsi>
#endif
BR.
You can file a new issue for it.
