Custom carrier board with p3448-0002 jetson nano reboot error
Hi, I need some help. I encountered the following problems:
1.I used custom carrier board with p3448-0002 jetson nano, I flash the rootfs in sd card rather than emmc
the extlinux as below:
the block device as below:
2.according to shutdown the power, filesystem are loading ok, but it cannot been loaded from reboot;the error log as below:
sd_card_reboot_error.txt (86.1 KB)
3.my custom carrier board Hardware schematic as below:
the dts only change it from “disabled” to “okay”
4.the 118 pin can not been configured as DC detect, so I configure the Set to low level by hardware.
This kind of issue has been replied for many times. Please search “sdmmc3” over this forum first.
You need to provide “vmmc-supply” and “cd-gpios” to your sdhci device tree node.
The problem has been solved,thanks!
