Custom CSI-2 Sensor on TX1 Port-a, Unhandled fault: alignment fault
hi,
We have a custom board design where we use Port-A of the CSI-2 interface of the TX1, we use adv7482 as V4L2 sensor on our board and the software is L4T-28.1. The CSI-TXA of adv7482 is connect to the Port-A of the CSI-2 interface of the TX1.
we configure our board to capture image using the following command:
“gst-launch-1.0 v4l2src ! ‘video/x-raw, width=1920, height=1080’ ! nvvidconv flip-method=2 ! ‘video/x-raw(memory:NVMM), width=1920, height=1080, format=(string)I420’ ! omxh264enc iframeinterval=25 bitrate=4000000 ! ‘video/x-h264, stream-format=(string)byte-stream’ ! mpegtsmux alignment=7 ! tsparse pcr-pid=58 ! udpsink host=190.192.153.68 port=2640”
But our board doesn’t work properly. When there is no data tramsmit to Port-A of the CSI-2 interface of the TX1 from CSI-TXA of adv7482, the error as follows will appear.
[ 26.583225] video4linux video0: frame start syncpt timeout!0
[ 26.589032] Unhandled fault: alignment fault (0x96000061) at 0xffffff8000000021
[ 26.596359] Internal error: : 96000061 [#1] PREEMPT SMP
[ 26.601573] Modules linked in:
[ 26.604630] CPU: 0 PID: 1483 Comm: vi-output, adv7 Not tainted 4.4.38 #3
[ 26.611314] Hardware name: jetson_tx1 (DT)
[ 26.615400] task: ffffffc07c021900 ti: ffffffc07c0a4000 task.ti: ffffffc07c0a4000
[ 26.622911] PC is at cil_write+0xc/0x14
[ 26.626799] LR is at tegra_csi_error_recover+0xf8/0x1e4
[ 26.632056] pc : [] lr : [] pstate: 60000145
[ 26.639468] sp : ffffffc07c0a7c40
[ 26.642807] x29: ffffffc07c0a7c40 x28: 0000000000000068
[ 26.648201] x27: 0000000000000014 x26: ffffffc07d5f8598
[ 26.653592] x25: 0000000000000214 x24: 0000000000000000
[ 26.658980] x23: 0000000000000020 x22: 0000000000000001
[ 26.664367] x21: ffffffc07d5f8600 x20: 0000000000000000
[ 26.669753] x19: ffffffc07d609418 x18: 0000000000000000
[ 26.675137] x17: 0000000000000000 x16: 0000000000000000
[ 26.680520] x15: 0000000000000000 x14: 0ffffffffffffffe
[ 26.685906] x13: 0000000000000030 x12: 0101010101010101
[ 26.691289] x11: 7f7f7f7f7f7f7f7f x10: 0000000000000860
[ 26.696675] x9 : ffffffc07c0a7ae0 x8 : ffffffc07c0221c0
[ 26.702058] x7 : 0000000000000001 x6 : 000000002a70cdca
[ 26.707442] x5 : 0000000000000000 x4 : ffffffc0012d2390
[ 26.712829] x3 : 0000000000003f6c x2 : 0000000000000000
[ 26.718213] x1 : ffffff8000000021 x0 : ffffff8000000001
[ 26.723596]
[ 26.725128] Process vi-output, adv7 (pid: 1483, stack limit = 0xffffffc07c0a4020)
[ 26.732633] Call trace:
[ 26.735128] [] cil_write+0xc/0x14
[ 26.740061] [] tegra_channel_vi_csi_recover+0x6c/0x180
[ 26.746796] [] tegra_channel_ec_recover+0x1c/0x28
[ 26.753097] [] tegra_channel_capture_frame+0x1f0/0x2c8
[ 26.759835] [] tegra_channel_kthread_capture_start+0x12c/0x154
[ 26.767288] [] kthread+0x100/0x108
[ 26.772300] [] ret_from_fork+0x10/0x40
[ 26.777649] —[ end trace 0d10c228f7ea224f ]—
    Have this HW been verified before? Make sure the MIPI signal is MIPI compliance and try use the v4l2-ctl to get sensor data to reduce the debug complicate.
    hi,
    The hardware have been verified before, We used L4T-24.2 before and the hardware work properly.
    Recently we want to replace L4T-24.2 with L4T-28.1, then we meet this problem.
    This problem also can appear in another situation:
    we use adv7511 transmit data to adv7482 through tmds interface,then adv7482 get date and transmit to Port-A of the CSI-2 interface of the TX1 through CSI-TXA, then the hardware work well, in this moment we shut down adv7511 and there is no data transmit to adv7482, and there is no date transmit to Port-A of the CSI-2 interface of the TX1, the error appear, in the processing, the configuration of CSI-TXA of adv7482 does not change.
    I will use v4l2-ctl to get sensor data.
    hi,
    I have used v4l2-ctl to get sensor data, the command is:
    v4l2-ctl --set-fmt-video=width=1920,height=1080 --stream-mmap=3 --stream-count=10 --stream-to=./test.yuv
    The same error appeard.
    In the same usage condition, we built our driver of adv7482 into the kernel of L4T-24.2, and run with the same board, the board works without the error, the print of the board is as follows. In both drivers, the configure of adv7482 is the same.
    [   61.682997] video4linux video0: frame start syncpt timeout!0
    [   61.893211] video4linux video0: frame start syncpt timeout!0
    [   62.103328] video4linux video0: frame start syncpt timeout!0
    [   62.313305] video4linux video0: frame start syncpt timeout!0
    [   62.523016] video4linux video0: frame start syncpt timeout!0
    [   62.733231] video4linux video0: frame start syncpt timeout!0
    [   62.943006] video4linux video0: frame start syncpt timeout!0
    [   63.153452] video4linux video0: frame start syncpt timeout!0
    [   63.363329] video4linux video0: frame start syncpt timeout!0
    [   63.574028] video4linux video0: frame start syncpt timeout!0
    [   63.783004] video4linux video0: frame start syncpt timeout!0
    [   63.993432] video4linux video0: frame start syncpt timeout!0
    [   64.203255] video4linux video0: frame start syncpt timeout!0
    [   64.413200] video4linux video0: frame start syncpt timeout!0
    [   64.622994] video4linux video0: frame start syncpt timeout!0
    [   64.833291] video4linux video0: frame start syncpt timeout!0
    [   65.042980] video4linux video0: frame start syncpt timeout!0
    [   65.243203] video4linux video0: frame start syncpt timeout!0
    [   65.453574] video4linux video0: frame start syncpt timeout!0
    [   65.662972] video4linux video0: frame start syncpt timeout!0
    [   65.873161] video4linux video0: frame start syncpt timeout!0
    [   66.083539] video4linux video0: frame start syncpt timeout!0
    [   66.293248] video4linux video0: frame start syncpt timeout!0
    [   66.503215] video4linux video0: frame start syncpt timeout!0
    [   66.712974] video4linux video0: frame start syncpt timeout!0
    [   66.923154] video4linux video0: frame start syncpt timeout!0
    [   67.133015] video4linux video0: frame start syncpt timeout!0
    [   67.343177] video4linux video0: frame start syncpt timeout!0
    [   67.552993] video4linux video0: frame start syncpt timeout!0
    [   67.763195] video4linux video0: frame start syncpt timeout!0
    [   67.972867] video4linux video0: frame start syncpt timeout!0
    [   68.173176] video4linux video0: frame start syncpt timeout!0
    [   68.382972] video4linux video0: frame start syncpt timeout!0
    [   68.593473] video4linux video0: frame start syncpt timeout!0
    [   68.803752] video4linux video0: frame start syncpt timeout!0
    [   69.013282] video4linux video0: frame start syncpt timeout!0
    [   69.223483] video4linux video0: frame start syncpt timeout!0
    [   69.433186] video4linux video0: frame start syncpt timeout!0
    [   69.643481] video4linux video0: frame start syncpt timeout!0
    [   69.853256] video4linux video0: frame start syncpt timeout!0
    [   70.062967] video4linux video0: frame start syncpt timeout!0
    [   70.273185] video4linux video0: frame start syncpt timeout!0
    [   70.483136] video4linux video0: frame start syncpt timeout!0
    [   70.692509] video4linux video0: frame start syncpt timeout!0
    [   70.893131] video4linux video0: frame start syncpt timeout!0
    [   71.104337] video4linux video0: frame start syncpt timeout!0
    [   71.313209] video4linux video0: frame start syncpt timeout!0
    [   71.523230] video4linux video0: frame start syncpt timeout!0
    [   71.733046] video4linux video0: frame start syncpt timeout!0
    [   71.943094] video4linux video0: frame start syncpt timeout!0
    [   72.153336] video4linux video0: frame start syncpt timeout!0
    [   72.363005] video4linux video0: frame start syncpt timeout!0
    [   72.573112] video4linux video0: frame start syncpt timeout!0
    [   72.782965] video4linux video0: frame start syncpt timeout!0
    [   72.983247] video4linux video0: frame start syncpt timeout!0
    [   73.193171] video4linux video0: frame start syncpt timeout!0
    [   73.403238] video4linux video0: frame start syncpt timeout!0
    [   73.613155] video4linux video0: frame start syncpt timeout!0
    [   73.823016] video4linux video0: frame start syncpt timeout!0
    [   74.033168] video4linux video0: frame start syncpt timeout!0
    [   74.243494] video4linux video0: frame start syncpt timeout!0
    [   74.453150] video4linux video0: frame start syncpt timeout!0
    [   74.662890] video4linux video0: frame start syncpt timeout!0
    [   74.873300] video4linux video0: frame start syncpt timeout!0
    [   75.083100] video4linux video0: frame start syncpt timeout!0
    [   75.293202] video4linux video0: frame start syncpt timeout!0
    [   75.503127] video4linux video0: frame start syncpt timeout!0
    [   75.713183] video4linux video0: frame start syncpt timeout!0
    [   75.923169] video4linux video0: frame start syncpt timeout!0
    [   76.132506] video4linux video0: frame start syncpt timeout!0
    [   76.343054] video4linux video0: frame start syncpt timeout!0
    [   76.553258] video4linux video0: frame start syncpt timeout!0
    [   76.762983] video4linux video0: frame start syncpt timeout!0
    [   76.973237] video4linux video0: frame start syncpt timeout!0
    [   77.192311] video4linux video0: frame start syncpt timeout!0
    [   77.202499] tegra_mipi_cal 700e3000.mipical: Mipi cal timeout,val:117bd0, lanes:300000
    [   77.402359] video4linux video0: frame start syncpt timeout!0
    [   77.412357] tegra_mipi_cal 700e3000.mipical: Mipi cal timeout,val:118bd0, lanes:300000
    [   77.612358] video4linux video0: frame start syncpt timeout!0
    [   77.622350] tegra_mipi_cal 700e3000.mipical: Mipi cal timeout,val:118bd0, lanes:300000
    [   77.822365] video4linux video0: frame start syncpt timeout!0
    [   77.832493] tegra_mipi_cal 700e3000.mipical: Mipi cal timeout,val:117bd0, lanes:300000
    [   78.032451] video4linux video0: frame start syncpt timeout!0
    [   78.042492] tegra_mipi_cal 700e3000.mipical: Mipi cal timeout,val:117bd0, lanes:300000
    [   78.242378] video4linux video0: frame start syncpt timeout!0
    [   78.252511] tegra_mipi_cal 700e3000.mipical: Mipi cal timeout,val:117bd0, lanes:300000
    [   78.452363] video4linux video0: frame start syncpt timeout!0
    [   78.462591] tegra_mipi_cal 700e3000.mipical: Mipi cal timeout,val:117bd0, lanes:300000
    [   78.662361] video4linux video0: frame start syncpt timeout!0
    [   78.672489] tegra_mipi_cal 700e3000.mipical: Mipi cal timeout,val:118bd0, lanes:300000
    [   78.872351] video4linux video0: frame start syncpt timeout!0
    [   78.882488] tegra_mipi_cal 700e3000.mipical: Mipi cal timeout,val:117bd0, lanes:300000
    [   79.082374] video4linux video0: frame start syncpt timeout!0
    [   79.282365] video4linux video0: frame start syncpt timeout!0
    [   79.292492] tegra_mipi_cal 700e3000.mipical: Mipi cal timeout,val:118bd0, lanes:300000
    [   79.492338] video4linux video0: frame start syncpt timeout!0
    [   79.702356] video4linux video0: frame start syncpt timeout!0
    [   79.712680] tegra_mipi_cal 700e3000.mipical: Mipi cal timeout,val:117bd0, lanes:300000
    [   79.912342] video4linux video0: frame start syncpt timeout!0
    [   79.922799] tegra_mipi_cal 700e3000.mipical: Mipi cal timeout,val:117bd0, lanes:300000
    [   80.122349] video4linux video0: frame start syncpt timeout!0
    [   80.132348] tegra_mipi_cal 700e3000.mipical: Mipi cal timeout,val:118bd0, lanes:300000
    [   80.333243] video4linux video0: frame start syncpt timeout!0
    hi,
    hi,
    The log shows tegra didn’t receive the start of frame. It could be the mipi timing or there’s no data output to the mipi bus.
    Yes, i agree with you, in this condition there’s no data output to the mipi bus.
    but I think when tegra receive no data, the error should not be “Unhandled fault: alignment fault (0x96000061) at 0xffffff8000000021”.
    when the error of “Unhandled fault: alignment fault (0x96000061) at 0xffffff8000000021” appeard, the tegra can’t capture image again expect reboot.
    @meyan
    Hi!
    Have you come up with any solution or workaround for this issue?
    I’m curious to know as I’m facing similar issues;
    One “frame start syncpt timeout!0” causes “Unhandled fault: alignment fault (0x96000061) at 0xffffff8000000021” and reboot is required to get things going again.
    Hi!
    We modify the code as follows:
    void tegra_csi_error_recover(struct tegra_csi_channel *chan,
    				enum tegra_csi_port_num port_num)
    	struct tegra_csi_port *port;
    	struct tegra_csi_device *csi;
        struct tegra_csi_port *port_a;
        struct tegra_csi_port *port_b;
    	int i;
    	csi = chan->csi;
    	for (i = 0; i < chan->numports; i++)
    		port = &chan->ports[i];
    		if (port->lanes == 4) {
    			int port_val = ((port_num >> 1) << 1);
    			port_a =
    				&chan->ports[port_val];
    			port_b =
    				&chan->ports[port_val+1];
    			tpg_write(port_a, TEGRA_CSI_PATTERN_GENERATOR_CTRL, PG_ENABLE);
    			//tpg_write(port_b, TEGRA_CSI_PATTERN_GENERATOR_CTRL, PG_ENABLE);
    			cil_write(port_a, TEGRA_CSI_CIL_SW_SENSOR_RESET, 0x1);
    			//cil_write(port_b, TEGRA_CSI_CIL_SW_SENSOR_RESET, 0x1);
    			csi_write(chan, TEGRA_CSI_CSI_SW_STATUS_RESET, 0x1, port_num >> 1);
    			/* sleep for clock cycles to drain the Rx FIFO */
    			usleep_range(10, 20);
    			cil_write(port_a, TEGRA_CSI_CIL_SW_SENSOR_RESET, 0x0);
    			//cil_write(port_b, TEGRA_CSI_CIL_SW_SENSOR_RESET, 0x0);
    			csi_write(chan, TEGRA_CSI_CSI_SW_STATUS_RESET, 0x0, port_num >> 1);
    			tpg_write(port_a, TEGRA_CSI_PATTERN_GENERATOR_CTRL, PG_DISABLE);
    			//tpg_write(port_b, TEGRA_CSI_PATTERN_GENERATOR_CTRL, PG_DISABLE);
    		} else {
    			tpg_write(port,
    			cil_write(port,
    			csi_write(chan,
    			cil_write(port,
    			csi_write(chan,
    			tpg_write(port,
    Now our board works well.You can try it.
