I customized a CUDA operator. On the GPU server, I can compile the operator normally using pytorch extension and run it normally, and can compile it and use it for tensorrt through the following code.
msmv_plugin.zip (48.5 KB)
But when it comes to AGX Orin, although the corresponding .cu file can be compiled and inferred normally using pytorch extension, the operator compiled with the above code will report this error during tensorrt inference:
/home/xiazhongyu/Desktop/bevperception/./tools/analysis_tools/benchmark_trt_henetpp.py:121: DeprecationWarning: Use get_tensor_name instead.
idx = self.engine.get_binding_index(input_name)
/home/xiazhongyu/Desktop/bevperception/./tools/analysis_tools/benchmark_trt_henetpp.py:122: DeprecationWarning: Use set_input_shape instead.
self.context.set_binding_shape(idx, tuple(input_tensor.shape))
/home/xiazhongyu/Desktop/bevperception/./tools/analysis_tools/benchmark_trt_henetpp.py:128: DeprecationWarning: Use get_tensor_name instead.
idx = self.engine.get_binding_index(output_name)
/home/xiazhongyu/Desktop/bevperception/./tools/analysis_tools/benchmark_trt_henetpp.py:129: DeprecationWarning: Use get_tensor_dtype instead.
dtype = torch_dtype_from_trt(self.engine.get_binding_dtype(idx))
/home/xiazhongyu/Desktop/bevperception/./tools/analysis_tools/benchmark_trt_henetpp.py:130: DeprecationWarning: Use get_tensor_shape instead.
shape = tuple(self.context.get_binding_shape(idx))
error in ms_deformable_im2col_cuda_c2345: no kernel image is available for execution on the device
I’m feeling a bit lost here, and I’m wondering if there’s something wrong with the makefile. Could anyone please help me out?
Thank you in advance!
