I am training my custom dataset for object detection. My training is failed and here i have pasted the error message.
python3 train_ssd.py --dataset-type=voc --data=data/pedestrian2_30Aug22_pascalvoc/ --model=models/pedestrian2_30Aug22_pascalvoc/ --batch-size=4 --epochs=2
2022-08-30 19:27:12.638284: I tensorflow/stream_executor/platform/default/dso_loader.cc:53] Successfully opened dynamic library libcudart.so.10.2
2022-08-30 19:27:22 - Using CUDA…
2022-08-30 19:27:22 - Namespace(balance_data=False, base_net=None, base_net_lr=0.001, batch_size=4, checkpoint_folder=‘models/pedestrian2_30Aug22_pascalvoc/’, dataset_type=‘voc’, datasets=[‘data/pedestrian2_30Aug22_pascalvoc/’], debug_steps=10, extra_layers_lr=None, freeze_base_net=False, freeze_net=False, gamma=0.1, log_level=‘info’, lr=0.01, mb2_width_mult=1.0, milestones=‘80,100’, momentum=0.9, net=‘mb1-ssd’, num_epochs=2, num_workers=2, pretrained_ssd=‘models/mobilenet-v1-ssd-mp-0_675.pth’, quick_validation=False, resolution=300, resume=None, scheduler=‘cosine’, t_max=100, use_cuda=True, validation_epochs=1, weight_decay=0.0005)
2022-08-30 19:27:43 - model resolution 300x300
2022-08-30 19:27:43 - SSDSpec(feature_map_size=19, shrinkage=16, box_sizes=SSDBoxSizes(min=60, max=105), aspect_ratios=[2, 3])
2022-08-30 19:27:43 - SSDSpec(feature_map_size=10, shrinkage=32, box_sizes=SSDBoxSizes(min=105, max=150), aspect_ratios=[2, 3])
2022-08-30 19:27:43 - SSDSpec(feature_map_size=5, shrinkage=64, box_sizes=SSDBoxSizes(min=150, max=195), aspect_ratios=[2, 3])
2022-08-30 19:27:43 - SSDSpec(feature_map_size=3, shrinkage=100, box_sizes=SSDBoxSizes(min=195, max=240), aspect_ratios=[2, 3])
2022-08-30 19:27:43 - SSDSpec(feature_map_size=2, shrinkage=150, box_sizes=SSDBoxSizes(min=240, max=285), aspect_ratios=[2, 3])
2022-08-30 19:27:43 - SSDSpec(feature_map_size=1, shrinkage=300, box_sizes=SSDBoxSizes(min=285, max=330), aspect_ratios=[2, 3])
2022-08-30 19:27:43 - Prepare training datasets.
warning - image WalkingParisSunset_00001097 has no box/labels annotations, ignoring from dataset
2022-08-30 19:27:44 - VOC Labels read from file: (‘BACKGROUND’, ‘background’, ‘Pedestrian’)
2022-08-30 19:27:44 - Stored labels into file models/pedestrian2_30Aug22_pascalvoc/labels.txt.
2022-08-30 19:27:44 - Train dataset size: 659
2022-08-30 19:27:44 - Prepare Validation datasets.
2022-08-30 19:27:45 - VOC Labels read from file: (‘BACKGROUND’, ‘background’, ‘Pedestrian’)
2022-08-30 19:27:45 - Validation dataset size: 659
2022-08-30 19:27:45 - Build network.
2022-08-30 19:27:46 - Init from pretrained ssd models/mobilenet-v1-ssd-mp-0_675.pth
2022-08-30 19:27:46 - Took 0.58 seconds to load the model.
2022-08-30 19:27:46 - Learning rate: 0.01, Base net learning rate: 0.001, Extra Layers learning rate: 0.01.
2022-08-30 19:27:46 - Uses CosineAnnealingLR scheduler.
2022-08-30 19:27:46 - Start training from epoch 0.
/home/gbewegung/.local/lib/python3.6/site-packages/torch/nn/_reduction.py:44: UserWarning: size_average and reduce args will be deprecated, please use reduction=‘sum’ instead.
warnings.warn(warning.format(ret))
2022-08-30 19:28:05 - Epoch: 0, Step: 10/165, Avg Loss: 9.3615, Avg Regression Loss 4.4629, Avg Classification Loss: 4.8986
2022-08-30 19:28:10 - Epoch: 0, Step: 20/165, Avg Loss: 6.9237, Avg Regression Loss 3.6438, Avg Classification Loss: 3.2799
2022-08-30 19:28:13 - Epoch: 0, Step: 30/165, Avg Loss: 6.1242, Avg Regression Loss 3.3326, Avg Classification Loss: 2.7916
2022-08-30 19:28:18 - Epoch: 0, Step: 40/165, Avg Loss: 6.8517, Avg Regression Loss 3.7716, Avg Classification Loss: 3.0801
2022-08-30 19:28:21 - Epoch: 0, Step: 50/165, Avg Loss: 5.4286, Avg Regression Loss 2.7843, Avg Classification Loss: 2.6443
2022-08-30 19:28:23 - Epoch: 0, Step: 60/165, Avg Loss: 4.8790, Avg Regression Loss 2.3757, Avg Classification Loss: 2.5033
2022-08-30 19:28:26 - Epoch: 0, Step: 70/165, Avg Loss: 4.8492, Avg Regression Loss 2.3427, Avg Classification Loss: 2.5066
2022-08-30 19:28:28 - Epoch: 0, Step: 80/165, Avg Loss: 4.4427, Avg Regression Loss 2.0119, Avg Classification Loss: 2.4308
2022-08-30 19:28:32 - Epoch: 0, Step: 90/165, Avg Loss: 5.0296, Avg Regression Loss 2.4892, Avg Classification Loss: 2.5403
2022-08-30 19:28:34 - Epoch: 0, Step: 100/165, Avg Loss: 4.5285, Avg Regression Loss 2.0972, Avg Classification Loss: 2.4313
2022-08-30 19:28:36 - Epoch: 0, Step: 110/165, Avg Loss: 3.9718, Avg Regression Loss 1.7432, Avg Classification Loss: 2.2286
2022-08-30 19:28:39 - Epoch: 0, Step: 120/165, Avg Loss: 4.0890, Avg Regression Loss 1.7168, Avg Classification Loss: 2.3722
2022-08-30 19:28:41 - Epoch: 0, Step: 130/165, Avg Loss: 4.3012, Avg Regression Loss 1.8998, Avg Classification Loss: 2.4014
2022-08-30 19:28:44 - Epoch: 0, Step: 140/165, Avg Loss: 4.2805, Avg Regression Loss 1.9802, Avg Classification Loss: 2.3003
2022-08-30 19:28:46 - Epoch: 0, Step: 150/165, Avg Loss: 5.0491, Avg Regression Loss 2.5790, Avg Classification Loss: 2.4701
2022-08-30 19:28:49 - Epoch: 0, Step: 160/165, Avg Loss: 4.3675, Avg Regression Loss 2.1717, Avg Classification Loss: 2.1958
2022-08-30 19:28:51 - Epoch: 0, Training Loss: 5.2401, Training Regression Loss 2.5659, Training Classification Loss: 2.6743
2022-08-30 19:29:02 - Epoch: 0, Validation Loss: 4.0435, Validation Regression Loss 1.7113, Validation Classification Loss: 2.3322
File “train_ssd.py”, line 414, in
mean_ap, class_ap = eval.compute()
File “/home/gbewegung/jetson-inference/python/training/detection/ssd/eval_ssd.py”, line 88, in compute
self.true_case_stat[class_index],
KeyError: 1
