I am trying to load an overlayed custom dtb on the Orin devkit to use the camera, but I am having trouble.
I installed m.2 ssd and wrote r34.1.1 to m.2 ssd using sdk manager. Then I create a custom dtb file by using config-by-hardware
I have since confirmed that kernel_tegra234-p3701-0000-p3737-0000-user-custom.dtb
has been generated and extlinux.conf is set to read it.
However, the settings have not been reflected after the reboot.
If I am installing on an M.2 SSD, is the procedure any different than when installing on an eMMC only?
Is there anything else I should check?
