1、how to add the custom frame information to NvDsFrameMeta?
2、how to use dsmeta_payload.cpp ?(That msg2pNewApi set True is not worked .NVDS_CUSTOM_MSG_BLOB)
3、NvDsEventMsgMeta is only used to add the information of object, not instead of the custom frame information?
Hi @18241266008
NvDsEventMsgMeta
is a type of DeepStream user meta and there is a NvDsUserMetaList
in the batch, frame and object levels of DeepStream metadata, so you can add message meta per-batch, per-frame, or per-object. We use it on the batch level adding a JSON as message meta:
void
add_meta_to_buffer (GstBuffer * buf, gchar * meta)
NvDsBatchMeta *batch_meta;
NvDsUserMeta *user_meta;
batch_meta = gst_buffer_get_nvds_batch_meta (buf);
user_meta = nvds_acquire_user_meta_from_pool (batch_meta);
if (user_meta) {
NvDsEventMsgMeta *msg_meta =
(NvDsEventMsgMeta *) g_malloc0 (sizeof (NvDsEventMsgMeta));
msg_meta->otherAttrs = meta;
msg_meta->objectId = g_strdup ("custom");
user_meta->user_meta_data = (void *) msg_meta;
user_meta->base_meta.batch_meta = batch_meta;
user_meta->base_meta.meta_type = NVDS_EVENT_MSG_META;
user_meta->base_meta.copy_func = (NvDsMetaCopyFunc) custom_meta_copy_func;
user_meta->base_meta.release_func =
(NvDsMetaReleaseFunc) custom_meta_free_func;
nvds_add_user_meta_to_batch (batch_meta, user_meta);
To get the meta on the other element that uses it:
NvDsBatchMeta *batch_meta = gst_buffer_get_nvds_batch_meta (buffer);
if (NULL == batch_meta){
g_print ("No DeepStream meta found\n");
return;
NvDsUserMetaList *user_meta_list = batch_meta->batch_user_meta_list;
while (user_meta_list != NULL) {
NvDsUserMeta *user_meta = (NvDsUserMeta *) user_meta_list->data;
if (user_meta->base_meta.meta_type == NVDS_EVENT_MSG_META) {
(NvDsEventMsgMeta *) user_meta->user_meta_data;
if (g_strcmp0 (msg_meta->objectId, "custom") == 0) {
g_print ("CustomMeta\n%s\n", msg_meta->otherAttrs);
user_meta_list = user_meta_list->next;
I hope this helps
Thanks a lot.
How to get the custom frame information in generate_event_message_minimal function in eventmsg_payload.cpp , from NvDsEventMsgMeta \ events[0].metadata \ user_meta ?My NvDsEventMsgMeta achieved in bbox_generated_probe_after_analytics through create_pipeline
sorry for the late reply, yes, you can add user information in user meta, please refer to sample deepstream-user-metadata-test, which saves user data in user meta.
