It is said that JAO is pin-compatible with JAX.
With this thought, I installed a JAO module on the custom JAX carrier board which runs pretty well in the field. However not serial output nor recovery mode.
There are some timing requirement for Jetson AGX Orin power up sequence. Please check Jetson AGX Orin Series Design Guide Figure 5-2 for the details, and compare it with your carrier board design.
I could not make any progress on it.
I’m wondered that Jetson AGX Xavier devkit + Jetson AGX Orin module(3701) can be work with JP50.
Even Recovery button, lsusb shows only 0955:7223 as a result.
JP50 GA EA v2 to test on the Ubuntu 20.04 host
could not find any remarkable difference in power sequence between JAX and JAO
AGX Orin Design Guide_v1.1 nor Orin Adaptation and Bringup for Jetson AGX Orin in the JP50 GA EA_v2 did not help
Jetson_AGX_Orin_Jetson_AGX_Xavier_IF_Comparison_Migration_DA-10655-001_v1.2 did not help as well
We didn’t mention that. The AGX and Orin modules are different. Pin compatible does not mean they can work directly after plug in.
There is quite a bit of different between JAX and JAO board design which need to be taken account in device tree and other configs, for example UPHY, Display (JAX Devkit has HDMI and JAO devkit has DP)., etc.
Those device tree, pinmux changed for your JAX module to work on your AGX custom carrier board need to do again to generate image for JAO module to flash it.
Then I need to test AGX Orin devkit to test AGX Orin module firstly.
And for the custom AGX Xavier carrier board, compare PINs carefully and modify device tree.
Dear @kayccc
I one of coworker with @MtHiker.
Now, I’m trying to flash L4T for Orin Dev Kit Carrier Board with AGX Orin Sample Module.
And I have a question how can I make sure device is Recovery Mode or Not
This device shows always when usb otg port is connected whether I push rocovery button or not.
lsusb always find device , but SDK Manager can’t find any devices.
I checked recovery mode connection on the SDK Manager.
It doesn’t works.
I heard this symptom is same as MtHiker’s custom board.
I think we need to be make sure it first.
