Hi
When customising a kernel using nvbuild.sh, the system stopped booting. The kernel is identical to defconfig(!).
[ 1.903227] Root device found: PARTUUID=91103c6d-9044-4d9f-9013-9ce44fb8206d
[ 2.159089] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[ 2.313325] hub 1-2:1.0: USB hub found
[ 2.313834] hub 1-2:1.0: 4 ports detected
[ 2.437939] usb 2-1: new SuperSpeed Plus Gen 2x1 USB device number 2 using tegra-xusb
[ 2.490831] hub 2-1:1.0: USB hub found
[ 2.492293] hub 2-1:1.0: 4 ports detected
[ 12.849089] ERROR: mounting PARTUUID=91103c6d-9044-4d9f-9013-9ce44fb8206d as /mnt fail…
[ 12.850424] ERROR: PARTUUID=91103c6d-9044-4d9f-9013-9ce44fb8206d mount fail…
[ 12.852056] ttyTCU0: Press [ENTER] to start bash in 30 seconds…
[ 13.692195] Starting bash…
Thank you!
