I was wondering if there was an alternative way to flash the Kernel so that a custom 5.4 Kernel is able to run on a Jetson Xavier NX Devkit? If not, I was hoping to get help on a specific error I was experiencing while trying steps on other forum questions.
By custom, I mean code within a 5.4 Linux kernel was edited to fit a specific need. I can provide more information on the kernel itself if needed.
I have followed a few guides which have stated replacing the kernel’s image in /boot/Image and adding an entry for the kernel in /boot/extlinux/extlinux.conf. From there, I have ensured to flash the device tree but got the error where upon boot and pressing the correct number to boot the second kernel, the boot screen states
** WARNING: Test Key is used **
L4TLauncher: Attempting GRUB Boot
L4TLauncher: Attempting Direct Boot
L4T boot options
0: primary kernel
1: second kernel
Press 0-1 to boot selection within 3.0 seconds.
Press any other key to boot default (Option: 0)
EFI stub: Booting Linux Kernel…
EFI stub: Using DTB from configuration table
EFI stub: Exiting boot services and installing virtual address map…
From there, the Xavier hangs. I have tried connecting the Xavier to a 18.04 Ubuntu host machine and having the host read input via dmesg --follow but it does not produce any input.
Please note I am not limited to anything in specific (such as any specific version of Jetpack) and am open to any suggestions or advice! Also, is this even possible? Thanks in advance!
