Custom Layout settings for Planetarium Dome
we are in the process of evaluating the use of Omniverse in our planetarium. Our planetarium is a 180-degree hemisphere.
I have created a fisheye camera for our planetarium display, referred to as a “fulldome”.
I have an Omniverse layout where one of the viewports is separated into its own window. This floating viewport is set to view through the fisheye camera.
We need to be able to make the floating viewport to “fill the screen” on our dome “desktop”.
Is there a way to make the floating viewport full-screen and borderless?
Please find attached our custom layout json file.
DomeLayout_v003_json.txt (15.3 KB)
I am not sure about a floating viewport going fullscreen, but certainly you can make a non floating / default UI viewport fullscreen by hitting F7 and then F11. F7 maximizes the viewport in the UI and F11 makes the whole UI fullscreen. Does that help? Does the viewport have to be floating?
