Custom map error when checking with maptool_inspection
Software Version
DRIVE OS Linux 5.2.6
DRIVE OS Linux 5.2.6 and DriveWorks 4.0
DRIVE OS Linux 5.2.0
other DRIVE OS version
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.8.0.10363
other
Host Machine Version
native Ubuntu 18.04
other
I have created a custom map of my environment, which you can find attached. While checking its sanity with the maptool_inspection tool, I receive the following error:
[01-06-2022 13:46:06] Platform: Detected Generic x86 Platform
[01-06-2022 13:46:06] TimeSource: monotonic epoch time offset is 1654079525097753
[01-06-2022 13:46:06] Platform: number of GPU devices detected 1
[01-06-2022 13:46:06] Platform: currently selected GPU device discrete ID 0
[01-06-2022 13:46:06] SDK: Resources mounted from ../../data/
[01-06-2022 13:46:06] Initialize DriveWorks SDK v2.2.3136
[01-06-2022 13:46:06] Release build with GNU 7.4.0 from heads/buildbrain-branch-0-gca7b4b26e65
[01-06-2022 13:46:06] Initialize DriveWorks VisualizationSDK v2.2.3136
[01-06-2022 13:46:06] Initialize DriveWorksGL SDK v2.2.3136
[01-06-2022 13:46:06] GL-SDK: initialize OpenGL
[01-06-2022 13:46:06] Maps: Reading map data from "/home/maria/Documents/map.xml" ...[01-06-2022 13:46:06] Driveworks exception thrown: DW_FILE_INVALID: Maps: node hadCompliance not found.
terminate called after throwing an instance of 'std::runtime_error'
  what():  [2022-06-01 13:46:06] DW Error DW_FILE_INVALID executing DW function:
 dwMaps_initialize(&map, mapFile, context)
 at /dvs/git/dirty/gitlab-master_av/dw/sdk/samples/maps/common/MapsAppCommon.cpp:414
Aborted (core dumped)
What should I do to resolve it?
map.xml (1.7 MB)
Dear @siomari,
The route cause is invalid dwMap version value. It should match to DW_MAPS_SERIALIZATION_FORMAT_XML_VERSION from maps.h header file.
Thank you @SivaRamaKrishnaNV.
Now I get segmentation fault:
-06-2022 15:33:24] Platform: Detected Generic x86 Platform
[01-06-2022 15:33:24] TimeSource: monotonic epoch time offset is 1654079525097753
[01-06-2022 15:33:24] Platform: number of GPU devices detected 1
[01-06-2022 15:33:24] Platform: currently selected GPU device discrete ID 0
[01-06-2022 15:33:24] SDK: Resources mounted from ../../data/
[01-06-2022 15:33:24] Initialize DriveWorks SDK v2.2.3136
[01-06-2022 15:33:24] Release build with GNU 7.4.0 from heads/buildbrain-branch-0-gca7b4b26e65
[01-06-2022 15:33:24] Initialize DriveWorks VisualizationSDK v2.2.3136
[01-06-2022 15:33:24] Initialize DriveWorksGL SDK v2.2.3136
[01-06-2022 15:33:24] GL-SDK: initialize OpenGL
[01-06-2022 15:33:24] Maps: Reading map data from "/home/maria/Documents/map.xml" ...Segmentation fault (core dumped)
How can I fix it?
Dear @siomari,
The route cause of “Segmentation fault” is difficult to figure out. You need to isolate the node which is causing the issue. Could you add subset of map data and try debugging?
Hi @siomari
Please share the command encountering the issue. Does the workaround for Proper way to run ./maptool_inspection to inspect a map help?
Hello @VickNV
I don’t think I have problem running the tool. Some parts of my map work fine but some of them return segmentation fault.
The command I run is: ./maptool_inspection --map=/home/maria/Documents/map.xml
Dear @siomari,
Could you share a simple map file and share the part causing segfault. It helps us to identify if it is SW issue or not?
I found the cause of seg fault. I used the traversability tag in roads that have just one lane, which is wrong.
Thank you both for your help!
