We are working on a custom camera outputting RGB888 (24 bits) format over MIPI-CSI on 2 lanes connected to Jetson TX1 running 28.1.
While we could make it work over v4l2src plugin, when we try running with nvcamerasrc, it is not working and the nvcamera daemon outputs following error.
tV4LPixelType: pixel type 0x1000 invalid
setActiveBufferMemory: 2
INPUT: Width 768 Height 576 pixelformat RG10
writeFrameRate: INPUT frameLength:625, frameRate:50.000000
writeGain: INPUT gainCtrl:100 analogGain:1.000000
writeExposure: INPUT coarseTime:615, expTime:0.019680
updateOutputSettings: OUTPUT frameLength:625, frameRate:50.000000
updateOutputSettings: OUTPUT analogGain:1.000000
updateOutputSettings: OUTPUT coarseTime:615, expTime:0.019680
apply:-----------------------
NvPclSettingsApply: Reading PCL settings
PowerServiceUtils:calculateReqClock: entered
PowerServiceHw:addRequest: table size: before: 0, after:1
request table for VI 0:
req[0]: guID=0, stageID=SensorCapture
req[0]: inW=768, inH=576, inBpp = 10, fps=50
req[0]: outW=768, outH=576, outBpp=10
req[0]: out1W=0, out1H=0, out1Bpp=0
req[0]: out2W=0, out2H=0, out2Bpp=0
req[0]: clock=32450000, pixelRate=29500000, timeout=900
req[0]: isoBw=40562, timeout=900
req[0]: non_isoBw=0, timeout=900
request table for CSI 0:
req[0]: clock=0, pixelRate=29500000, timeout=900
req[0]: isoBw=0, timeout=900
PowerServiceHwVi:setIso: m_bwVal_Iso=40562
PowerServiceHw:setClock: PowerServiceHw[1]: requested_clock_Hz=32450000
PowerServiceCore:setCameraBw: totalIsoBw=40562
NvPclSettingsUpdate: Sending Updated Settings through PCL
NvPclSettingsApply: Applying last settings through PCL
apply:+++++++++++++++++++++++
SCF: Error NotImplemented: Unsupported sensor type (in src/components/CaptureSet
upEngineImpl.cpp, function chooseGenInstFunc(), line 126)
SCF: Error NotImplemented: (propagating from src/components/CaptureSetupEngineI
mpl.cpp, function doGetInstructions(), line 1798)
SCF: Error NotImplemented: (propagating from src/components/CaptureSetupEngine.
cpp, function getInstructionList(), line 262)
cpp, function setupCC(), line 186)
SCF: Error NotImplemented: (propagating from src/api/Session.cpp, function capt
ure(), line 811)
disposing CC 0 Session 0
ure(), line 811)
ure(), line 811)
ure(), line 811)
ure(), line 811)
ure(), line 811)
ure(), line 811)
ure(), line 811)
Further in another mode, we will need to extract only 8 bit green channel of the incoming data 24 bit data and output it as MEDIA_BUS_FMT_Y8_1X8. Is it possible to use the VI for this purpose? If so, how?
Thanks in advance.
