Custom Parser deepstream 6.2 using python prorgramming for Yolov8
• Hardware Platform (Jetson / GPU) Jestson
• DeepStream Version : 6,2
• JetPack Version (valid for Jetson only) 5.2
• TensorRT Version
Hello All,
I have Yolov8 model and I am using deepstream 6.2 python and I want to build custom parser for Yolov8 using python programming
Can you help me to documentation for custom parser using python or give me steps here
Appreciate your feedback
Could you refer to the DeepStream-Yolo-Face first to see if it meets your needs?
inside config_infer_primary_yoloV8_face.txt
parse-bbox-instance-mask-func-name=NvDsInferParseYoloFace
custom-lib-path=nvdsinfer_custom_impl_Yolo_face/libnvdsinfer_custom_impl_Yolo_face.so
output-instance-mask=1
can i replace libnvdsinfer_custom_impl_Yolo_face.so c++ custom parser with
libnvdsinfer_custom_impl_Yolo_face.py python custom parser ?
so can we implement custom parser in python programming language?
No.
Yes. But this is more complicated. You need to get the output tensor data and parse that yourself. You can refer to the deepstream-ssd-parser to learn how to get the output tensor and parse that.
Thanks for your feedback
example you shared use custom parser in probe function but I need custom parser process output detections after yolov8 directly so can you give me direct example that will replace libnvdsinfer_custom_impl_Yolo_face.so with custom libnvdsinfer_custom_impl_Yolo_face.py
No. You cannot replace libnvdsinfer_custom_impl_Yolo_face.so with custom libnvdsinfer_custom_impl_Yolo_face.py. It’s used by the sources\libs\nvdsinfer\nvdsinfer_context_impl.cpp. You can refer to our source code.
    if (!string_empty(initParams.customLibPath))
        std::unique_ptr<DlLibHandle> dlHandle =
            std::make_unique<DlLibHandle>(initParams.customLibPath, RTLD_LAZY);
        if (!dlHandle->isValid())
            printError("Could not open custom lib: %s", dlerror());
            return NVDSINFER_CUSTOM_LIB_FAILED;
        m_CustomLibHandle = std::move(dlHandle);
