Custom payload meta type?
all of the above
• DeepStream Version
5.0
4.4
• TensorRT Version
7.1
440.64.00
So, I have this function that serializes my protobuf metadata as string and
attaches it to the buffer as type NVDS_PAYLOAD_META.
bool
ProtoPayloadFilter::on_batch_meta(NvDsBatchMeta* batch_meta, dp::Batch* batch) {
  // try to get a new user metadata pointer from the pool
  auto user_meta = nvds_acquire_user_meta_from_pool(batch_meta);
  if (user_meta == nullptr) {
    GST_WARNING("could not get user metadata from batch pool");
    return false;
  // try to serialize the batch to string
  auto payload = new std::string();
  if (!batch->SerializeToString(payload)) {
    GST_WARNING("could not convert payload to string");
    delete payload;
    return false;
  // attach the payload to the user_meta as type NVDS_PAYLOAD_META
  user_meta->user_meta_data = (void*) payload;
  // not sure if this will work, but we'll find out if the broker accepts it
  // I'm inferring this from deepstream_user_metadata_app.c, intellisense
  // and fgrep for "payload"
  user_meta->base_meta.meta_type = NVDS_PAYLOAD_META;
  user_meta->base_meta.copy_func = copy_dp_payload_meta;
  user_meta->base_meta.release_func = release_dp_payload_meta;
  user_meta->base_meta.uContext = this;
  // attach the payload to the buffer at the batch level
  nvds_add_user_meta_to_batch(batch_meta, user_meta);
  return true;
My question is: is there an equivalent function to “nvds_get_user_meta_type” so I can get a new payload type? Later in my pipeline I have a broker element, but i don’t want to send all NVDS_PAYLOAD_META. I’m assuming it’ll work if it’s just my metadata, but I want to make sure I ignore other NVDS_PAYLOAD_META that I didn’t assign.
Edit: also, I’d like to make sure it works with the standard nvidia message broker elements, so I want to do it “properly”.
Sorry for a late reply.
You could use msg-conv-comp-id to force converter / broker components to process only those messages having same value for componentId field and ignore other messages. You should modify the application to fill componentId field of
NvDsEventMsgMeta structure.
Thanks, Amy. I am not using NvDsEventMsgMeta for my custom metadata. I’ve just attached a std::string* to user_meta->user_meta_data with the appropriate copy and release functions. I can see now i’m doing this wrong (for various reasons).
I see your broker element (at least the deepstrem-4.0 version) checks like this:
        if (user_meta && user_meta->base_meta.meta_type == NVDS_PAYLOAD_META) {
          payload = (NvDsPayload *) user_meta->user_meta_data;
          if (self->compId && payload->componentId != self->compId)
            continue;
          if (self->asyncSend) {
            g_mutex_lock (&self->flowLock);
            err = self->nvds_msgapi_send_async (self->connHandle, self->topic,
                                                (uint8_t *) payload->payload,
                                                payload->payloadSize,
                                                nvds_msgapi_send_callback, self);
My code works with my custom broker which has a different loop to parse the batch level user meta, but I want to make sure it works with nvdsmsgbroker as well. I see now, reading this code and with your suggestion, that i must I encapsulate my bytes in a NvDsPayload and set componentId as you suggest. Thank you for pointing me to componentId !
I noticed that user_meta attached to the batch (with nvds_add_user_meta_to_batch) isn’t parsed by the current nvidia message broker. I am using batch level meta for my case. Are there any future plans for the broker to handle payloads in batch_meta->batch_user_meta_list, or should I modify nvmsgbroker to handle this case?
Hi
nvmsgbroker parse payloads in frame_meta_list, you may change the broker accordingly to meet your needs.
