PGIE of network-type=100 and setting output-tensor-meta=1 causes full frame SGIE deepstream default detector BBOX to not be drawn. SGIE inference happens but the BBOX are not there in the final video.
Pls set network-type=0
For SGIE I have set network-type=0.
PGIE is a custom model and not a detector, should I also set it to 0?
Ok, then you need to check the output of your sgie.
