Well, i want to create a pipeline like this pgie->tracker->sgie1->dsexample->sgie2, can i done it by using deepstream-app source.
• DeepStream Version 6.0.1
Yes, you can. but you need to change dsexample location in the pipeline.
thanks for your help. I see the function create_common_elements create all the sgie and parallel them. Did i get it correctly and if right should i change it to insert the dsexample between sgie or i should do in other way.
by default, dsexample linked after pgie, you can change the code in create_pipeline in deepstream_app.c accordingly to meet your needs.
