Custom platform :point these files to the board.conf
I just want to know how to point these files to the board.conf
Hi 619539230,
Are you using the devkit or custom board for Orin Nano?
If you are using the devkit, you may use <Linux_for_Tegra>/jetson-orin-nano-devkit.conf as your board config.
Please modify this configuration file to replace the following 2 lines with your new generated dtsi.
PINMUX_CONFIG="tegra234-mb1-bct-pinmux-p3767-dp-a03.dtsi";
PMC_CONFIG="tegra234-mb1-bct-padvoltage-p3767-dp-a03.dtsi";
