Hi all, I would like to power the Jetson TX2 Developer Kit from a custom power supply. I see from this datasheet that the power plug has part number 2DC-G313-B01 but I can’t find any vendors for that part. Is there some other, more accessible power plug that are also compatible?
Datasheet for the plug: https://singatron.com/wp-content/uploads/2DC-G213-B51.pdf
Thank you in advance!
The datasheet for the Meanwell power supply was more revealing. It says that the power plug is the standard P1M type.
Meanwell power supply datasheet: GST90A-MEAN WELL Switching Power Supply Manufacturer
Thanks self!
I’m not positive, but that power supply shows a 5.5mm OD x 2.5mm ID. I think the Jetson might require the 2.1mm ID (someone correct me if wrong, haven’t looked at that in a long time). Ok, so 5.5mm x 2.5mm is valid.
The P/N of plug is 2DP-G313–B01, 5.5mm x 2.5mm, you can check with vendor for that.
