Custom ssd-mobilenet.onnx model not building .engine file - slow to initialise every time
G’Day Nvidia team,
I have just built a custom model using Dusty’s Hello AI tutorials + Jetson-inference and its’ slow to initialise every time (not just the first time).
When I run detectnet csi://0 an engine is built within data/networks/SSD-mobilenet-v2.
However, when I run detectnet --model=models/targets/ssd-mobilenet.onnx --labels=models/targets/labels.txt --input-blob=input_0 --output-cvg=scores --output-bbox=boxes 0 an engine is not built and thus, it is slow to initialise this code every time.
I have tried deleting the .engine file, but a new one is not created when I run the custom model. I have read and write access to the directories.
I will take any advice you have for me.
Cheers,
Alan
Further info incase it’s relevant:
I built the project from source, but trained within the container (because I can’t get train_ssd.py to work natively).
My current config:
Jetson Nano 4GB - 64GB SD card - powered through micro-USB.
Jetpack 4.6.2 (L4T 32.7.2)
Python 3.6.9
4GB swap loaded as per NVIDIA Nano intro tutorial.
Hi @sanespeed, after you run detectnet, is there any .engine file in your models/targets/ directory?
In the console log, it should have printed out a message like completed saving engine cache to <FILE>
If not, can you post the console log here please? Thanks.
Hey @dusty_nv !
Yes, there is a .engine file under models/targets, but it seems it’s not being used when it’s re-run?
When running classic detectnet:
[TRT] device GPU, completed building CUDA engine
[TRT] network profiling complete, saving engine cache to /usr/local/bin/networks/SSD-Mobilenet-v2/ssd_mobilenet_v2_coco.uff.1.1.8201.GPU.FP16.engine
[TRT] device GPU, completed saving engine cache to /usr/local/bin/networks/SSD-Mobilenet-v2/ssd_mobilenet_v2_coco.uff.1.1.8201.GPU.FP16.engine
When running custom detectnet:
[TRT] network profiling complete, saving engine cache to models/targets/ssd-mobilenet.onnx.1.1.8201.GPU.FP16.engine
[TRT] failed to open engine cache file for writing models/targets/ssd-mobilenet.onnx.1.1.8201.GPU.FP16.engine
[TRT] device GPU, completed saving engine cache to models/targets/ssd-mobilenet.onnx.1.1.8201.GPU.FP16.engine
Interestingly, at the start of the script running it says something like: found engine file at models/targets/ssd-mobilenet.onnx.1.1.8201.GPU.FP16.engine
Can you try running sudo chown -R $USER models/targets ?
My guess is that since you ran train_ssd.py in the container, it created that models/targets directory with root privileges, and now that you are running outside the container it can’t write to it anymore.
Once again, you’re the saviour of Jetson AI,
It’s fixed. It’s now saving and loading the engine.
Thanks for all of your great work Dusty, you’ve been a huge help to me!
OK great, sorry about that - happy to help!
