• Hardware Platform (Jetson / GPU) GPU
• DeepStream Version 6.4
• TensorRT Version
• Issue Type( questions, new requirements, bugs) Question
I have a yolov4 trained to classify vehicles into different classes e.g car, truck.
i created the onnx, and when inspected it:
Model Inputs:
Input name: input
Shape: [16, 3, 416, 416]
Model Outputs:
Output name: boxes
Shape: [16, 10647, 1, 4]
Output name: confs
Shape: [16, 10647, 6]
now, when i am integrating in deepstream, the engine file is being built but there is a error:
DsInferContext[UID 4]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:2138> [UID = 4]: serialize cuda engine to file: /home/a2i/Downloads/deep_app_stable/deepstream_lpr_app-master/deepstream-lpr-app/secondary3yolov4/yolov4_16_3_416_416_static.onnx_b16_gpu0_fp16.engine successfully
WARNING: [TRT]: The getMaxBatchSize() function should not be used with an engine built from a network created with NetworkDefinitionCreationFlag::kEXPLICIT_BATCH flag. This function will always return 1.
INFO: …/nvdsinfer/nvdsinfer_model_builder.cpp:610 [Implicit Engine Info]: layers num: 3
0 INPUT kFLOAT input 3x416x416
1 OUTPUT kFLOAT boxes 10647x1x4
2 OUTPUT kFLOAT confs 10647x6
ERROR: [TRT]: 3: Cannot find binding of given name: confs
0:09:42.824025094 9242 0x562bdc7c3cc0 ERROR nvinfer gstnvinfer.cpp:676:gst_nvinfer_logger: NvDsInferContext[UID 4]: Error in NvDsInferContextImpl::parseBoundingBox() <nvdsinfer_context_impl_output_parsing.cpp:59> [UID = 4]: Could not find output coverage layer for parsing objects
0:09:42.824099654 9242 0x562bdc7c3cc0 ERROR nvinfer gstnvinfer.cpp:676:gst_nvinfer_logger: NvDsInferContext[UID 4]: Error in NvDsInferContextImpl::fillDetectionOutput() <nvdsinfer_context_impl_output_parsing.cpp:735> [UID = 4]: Failed to parse bboxes
0:09:42.824122895 9242 0x562bdc7c3cc0 ERROR nvinfer gstnvinfer.cpp:676:gst_nvinfer_logger: NvDsInferContext[UID 4]: Error in NvDsInferContextImpl::parseBoundingBox() <nvdsinfer_context_impl_output_parsing.cpp:59> [UID = 4]: Could not find output coverage layer for parsing objects
Honestly, i am interested in confidence values mostly, i can do without bboxes if thats what causing trouble.
This is my config:
[property]
GPU setup
gpu-id=0
model-color-format=0
Paths to model files
onnx-file=/home/a2i/Downloads/deep_app_stable/deepstream_lpr_app-master/deepstream-lpr-app/secondary3yolov4/yolov4_16_3_416_416_static.onnx
#model-engine-file=/home/a2i/Downloads/deep_app_stable/deepstream_lpr_app-master/deepstream-lpr-app/secondary3yolov4/yolov4_1_3_416_416_static.onnx_b1_gpu0_fp16.engine
labelfile-path=/home/a2i/Downloads/deep_app_stable/deepstream_lpr_app-master/deepstream-lpr-app/secondary3yolov4/labels.txt
Model configuration
network-mode=2 # Set to FP16 for optimal speed and precision (0=FP32, 1=INT8, 2=FP16)
num-detected-classes=6
Inference configuration
gie-unique-id=4
maintain-aspect-ratio=1
output-blob-names=confs
output-tensor-meta=1
Custom parsing and libraries
parse-bbox-func-name=NvDsInferParseCustomYoloV4
custom-lib-path=/opt/nvidia/deepstream/deepstream-6.4/lib/libnvdsinfer_custom_impl_Yolo.so
Batch and Optimization Settings
batch-size=16
workspace-size=8192
Thresholds
confidence-threshold=0.000001
infer-dims=3;416;416
any help would be appreciated
