I have implemented multistream deepstream pipeline using deepstream_test_3.py for custom yolov8 model with fp32 and it was working fine but when i am trying to run with network-mode=1 for int8 precision I am getting the following error.
File does not exist: /workspace/Primary_Detector/calib.table
WARNING: [TRT]: Calibration Profile is not defined. Calibrating with Profile 0
ERROR: [TRT]: [checkSanity.cpp::checkLinks::218] Error Code 2: Internal Error (Assertion item.second != nullptr failed. region should have been removed from Graph::regions)
/opt/nvidia/deepstream/deepstream-7.1/entrypoint.sh: line 15: 30 Segmentation fault (core dumped) /opt/nvidia/nvidia_entrypoint.sh $@
you need to set an int8 calibration file if wanting to run model with network-mode=1(int8).
please refer to this topic for how to generate int8 calibration file.
I have followed the same topic to set up my calibration file . Kindly look into the actual error :
Can you please give detailed instructions on how to uninstall TensorRT 10.3 from JetPack 6.2 and install TensorRT 10.4 (on Jetson Orin Nano Developer Kit)? It would be of huge help.
Thanks in advance.
