we are interested in setting a custom input and output MIPI resolution. Is it possible to implement it on the Jetson Tx2?
The resolution is based on an analog signal STANAG 3350 Class A (875i 30 Frames per second) (active 1024x768 30Fps).
Should be able support for follow the MIPI spec.
