Customise source_id in FrameMeta
• Hardware Platform (Jetson / GPU) Jetson AGX Orin
• DeepStream Version 6.1
• JetPack Version (valid for Jetson only) 5.0.2
• TensorRT Version 8.4.1
• Issue Type( questions, new requirements, bugs) Question
I added a probe after nvinference to get bbox values and category id. I’m currently using frame source_id to map the output to the stream.
Now I want to dynamically add/remove stream on runtime. If I want to do this, I need to manually set the source_id.
Is there a way to add custom source_id in FrameMeta?
If not, is there any other way to map the probe with the source stream?
please refer to sample deepstream_reference_apps/runtime_source_add_delete at master · NVIDIA-AI-IOT/deepstream_reference_apps · GitHub, it will dynamically add/remove stream on runtime.
@fanzh I’m already referring this code for dynamically adding/removing streams. The question is how I can check the data inside nvinference probe coming from which stream?
yes, you can add custom information by nvds_add_user_meta_to_frame, please find it in osd_sink_pad_buffer_probe of opt\nvidia\deepstream\deepstream-6.2\sources\apps\sample_apps\deepstream-test4\deepstream_test4_app.c
