CUSTOMISED_BOARD
I am trying to test the USB 2.0 on customized board but it is not detected, that NVIDIA jetson agx orin module is successfully booting on customized carrier board and through serial console i have taken the log. So, please help me out for this.
astra@root1:~$ sudo minicom -s
[sudo] password for astra:
Welcome to minicom 2.8
OPTIONS: I18n
Port /dev/ttyUSB0, 14:52:47
Press CTRL-A Z for help on special keys
[0000.062] I> MB1 (version: 1.4.0.4-t234-54845784-e89ea9bc)
[0000.067] I> t234-A01-1-Silicon (0x12347) Prod
[0000.071] I> Boot-mode : Coldboot
[0000.075] I> Entry timestamp: 0x00000000
[0000.078] I> last_boot_error: 0x0
[0000.081] I> BR-BCT: preprod_dev_sign: 0
[0000.085] I> rst_source: 0x0, rst_level: 0x0
[0000.089] I> Task: SE error check
[0000.093] I> Task: Bootchain select WAR set
[0000.097] I> Task: Enable SLCG
[0000.099] I> Task: CRC check
[0000.102] I> Task: Initialize MB2 params
[0000.106] I> MB2-params @ 0x40060000
[0000.110] I> Task: Crypto init
[0000.113] I> Task: Perform MB1 KAT tests
[0000.117] I> Task: NVRNG health check
[0000.120] I> NVRNG: Health check success
[0000.124] I> Task: MSS Bandwidth limiter settings for iGPU clients
[0000.130] I> Task: Enabling and initialization of Bandwidth limiter
[0000.136] I> No request to configure MBWT settings for any PC!
[0000.142] I> Task: Secure debug controls
[0000.146] I> Task: strap war set
[0000.149] I> Task: Initialize SOC Therm
[0000.152] I> Task: Program NV master stream id
[0000.157] I> Task: Verify boot mode
[0000.162] I> Task: Alias fuses
[0000.166] W> FUSE_ALIAS: Fuse alias on production fused part is not supported.
[0000.173] I> Task: Print SKU type
[0000.176] I> FUSE_OPT_CCPLEX_CLUSTER_DISABLE = 0x00000000
[0000.182] I> FUSE_OPT_GPC_DISABLE = 0x00000000
[0000.186] I> FUSE_OPT_TPC_DISABLE = 0x00000000
[0000.190] I> FUSE_OPT_DLA_DISABLE = 0x00000000
[0000.195] I> FUSE_OPT_PVA_DISABLE = 0x00000000
[0000.199] I> FUSE_OPT_NVENC_DISABLE = 0x00000000
[0000.203] I> FUSE_OPT_NVDEC_DISABLE = 0x00000000
[0000.208] I> FUSE_OPT_FSI_DISABLE = 0x00000000
[0000.212] I> FUSE_OPT_EMC_DISABLE = 0x00000000
[0000.216] I> FUSE_BOOTROM_PATCH_VERSION = 0x7
[0000.220] I> FUSE_PSCROM_PATCH_VERSION = 0x7
[0000.225] I> FUSE_OPT_ADC_CAL_FUSE_REV = 0x2
[0000.229] I> FUSE_SKU_INFO_0 = 0xd0
[0000.232] I> FUSE_OPT_SAMPLE_TYPE_0 = 0x3 PS
[0000.236] I> FUSE_PACKAGE_INFO_0 = 0x2
[0000.240] I> SKU: Prod
[0000.242] I> Task: Boost clocks
[0000.245] I> Initializing NAFLL for BPMP_CPU_NIC.
[0000.250] I> BPMP NAFLL: fll_lock = 1, dvco_min_reached = 0
[0000.255] I> BPMP NAFLL lock success.
[0000.259] I> BPMP_CPU_NIC : src = 42, divisor = 0
[0000.263] I> Initializing PLLC2 for AXI_CBB.
[0000.268] I> AXI_CBB : src = 35, divisor = 0
[0000.272] I> Task: Voltage monitor
[0000.275] I> VMON: Vmon re-calibration and fine tuning done
[0000.281] I> Task: UPHY init
[0000.285] I> HSIO UPHY init done
[0000.288] W> Skipping GBE UPHY config
[0000.292] I> Task: Boot device init
[0000.295] I> Boot_device: QSPI_FLASH instance: 0
[0000.300] I> Qspi clock source : pllc_out0
[0000.304] I> QSPI Flash: Macronix 64MB
[0000.308] I> QSPI-0l initialized successfully
[0000.312] I> Task: TSC init
[0000.315] I> Task: Load membct
[0000.318] I> RAM_CODE 0x4000431
[0000.321] I> Loading MEMBCT
[0000.323] I> Slot: 0
[0000.325] I> Binary[0] block-3840 (partition size: 0x40000)
[0000.331] I> Binary name: MEM-BCT-0
[0000.334] I> Size of crypto header is 8192
[0000.338] I> Size of crypto header is 8192
[0000.342] I> strt_pg_num(3840) num_of_pgs(16) read_buf(0x40050000)
[0000.348] I> BCH of MEM-BCT-0 read from storage
[0000.353] I> BCH address is : 0x40050000
[0000.357] I> MEM-BCT-0 header integrity check is success
[0000.362] I> Binary magic in BCH component 0 is MEM0
[0000.367] I> component binary type is 0
[0000.370] I> strt_pg_num(3856) num_of_pgs(115) read_buf(0x40040000)
[0000.377] I> MEM-BCT-0 binary is read from storage
[0000.382] I> MEM-BCT-0 binary integrity check is success
[0000.387] I> Binary MEM-BCT-0 loaded successfully at 0x40040000 (0xe580)
[0000.394] I> RAM_CODE 0x4000431
[0000.399] I> RAM_CODE 0x4000431
[0000.403] I> Task: Load Page retirement list
[0000.407] I> Task: SDRAM params override
[0000.411] I> Task: Save mem-bct info
[0000.414] I> Task: Carveout allocate
[0000.418] I> RCM blob carveout will not be allocated
[0000.422] I> Update CCPLEX IST carveout from MB1-BCT
[0000.427] I> ECC region[0]: Start:0x0, End:0x0
[0000.432] I> ECC region[1]: Start:0x0, End:0x0
[0000.436] I> ECC region[2]: Start:0x0, End:0x0
[0000.440] I> ECC region[3]: Start:0x0, End:0x0
[0000.444] I> ECC region[4]: Start:0x0, End:0x0
[0000.449] I> Non-ECC region[0]: Start:0x80000000, End:0x1080000000
[0000.455] I> Non-ECC region[1]: Start:0x0, End:0x0
[0000.459] I> Non-ECC region[2]: Start:0x0, End:0x0
[0000.464] I> Non-ECC region[3]: Start:0x0, End:0x0
[0000.469] I> Non-ECC region[4]: Start:0x0, End:0x0
[0000.479] I> allocated(CO:44) base:0x1049800000 size:0x36800000 align: 0x100000
[0000.487] I> allocated(CO:31) base:0x1040000000 size:0x8000000 align: 0x8000000
[0000.494] I> allocated(CO:43) base:0x103c000000 size:0x4000000 align: 0x200000
[0000.501] I> allocated(CO:39) base:0x1039e00000 size:0x2200000 align: 0x10000
[0000.508] I> allocated(CO:20) base:0x1036000000 size:0x2000000 align: 0x2000000
[0000.515] I> allocated(CO:24) base:0x1034000000 size:0x2000000 align: 0x2000000
[0000.522] I> allocated(CO:28) base:0x1032000000 size:0x2000000 align: 0x2000000
[0000.530] I> allocated(CO:29) base:0x1030000000 size:0x2000000 align: 0x2000000
[0000.537] I> allocated(CO:22) base:0x1048000000 size:0x1000000 align: 0x1000000
[0000.544] I> allocated(CO:35) base:0x1038e00000 size:0x1000000 align: 0x100000
[0000.551] I> allocated(CO:41) base:0x102f000000 size:0x1000000 align: 0x100000
[0000.558] I> allocated(CO:02) base:0x1049000000 size:0x800000 align: 0x800000
[0000.565] I> allocated(CO:03) base:0x1038000000 size:0x800000 align: 0x800000
[0000.572] I> allocated(CO:06) base:0x102e800000 size:0x800000 align: 0x800000
[0000.579] I> allocated(CO:56) base:0x102e000000 size:0x800000 align: 0x200000
[0000.586] I> allocated(CO:07) base:0x1038800000 size:0x400000 align: 0x400000
[0000.593] I> allocated(CO:33) base:0x102dc00000 size:0x400000 align: 0x200000
[0000.600] I> allocated(CO:19) base:0x102d980000 size:0x280000 align: 0x10000
[0000.607] I> allocated(CO:23) base:0x1038c00000 size:0x200000 align: 0x200000
[0000.614] I> allocated(CO:01) base:0x102d800000 size:0x100000 align: 0x100000
[0000.621] I> allocated(CO:05) base:0x102d700000 size:0x100000 align: 0x100000
[0000.628] I> allocated(CO:08) base:0x102d600000 size:0x100000 align: 0x100000
[0000.635] I> allocated(CO:09) base:0x102d500000 size:0x100000 align: 0x100000
[0000.642] I> allocated(CO:12) base:0x102d400000 size:0x100000 align: 0x100000
[0000.650] I> allocated(CO:15) base:0x102d300000 size:0x100000 align: 0x100000
[0000.657] I> allocated(CO:17) base:0x102d200000 size:0x100000 align: 0x100000
[0000.664] I> allocated(CO:27) base:0x102d100000 size:0x100000 align: 0x100000
[0000.671] I> allocated(CO:42) base:0x102d000000 size:0x100000 align: 0x100000
[0000.678] I> allocated(CO:54) base:0x102d900000 size:0x80000 align: 0x80000
[0000.685] I> allocated(CO:34) base:0x102cff0000 size:0x10000 align: 0x10000
[0000.691] I> allocated(CO:72) base:0x102cdf0000 size:0x200000 align: 0x10000
[0000.698] I> allocated(CO:47) base:0x102c800000 size:0x400000 align: 0x200000
[0000.705] I> allocated(CO:50) base:0x102c600000 size:0x200000 align: 0x100000
[0000.712] I> allocated(CO:52) base:0x102cdc0000 size:0x30000 align: 0x10000
[0000.719] I> allocated(CO:48) base:0x102cda0000 size:0x20000 align: 0x10000
[0000.726] I> allocated(CO:69) base:0x102cd80000 size:0x20000 align: 0x10000
[0000.733] I> allocated(CO:49) base:0x102cd70000 size:0x10000 align: 0x10000
[0000.740] I> NSDRAM base: 0x80000000, end: 0x102cdf0000, size: 0xfacdf0000
[0000.747] I> Task: Thermal check
[0000.750] I> Using min_chip_limit as min_tmon_limit
[0000.754] I> Using max_chip_limit as max_tmon_limit
[0000.759] I> BCT max_tmon_limit = 105
[0000.763] I> BCT min_tmon_limit = -28
[0000.766] I> BCT max_tmon_limit = 105
[0000.770] I> BCT min_tmon_limit = -28
[0000.773] I> SKU specific max_chip_limit = 105
[0000.777] I> SKU specific min_chip_limit = -28
[0000.782] I> BCT max_chip_limit = 105
[0000.785] I> BCT min_chip_limit = -28
[0000.789] I> enable_soctherm_polling = 0
[0000.792] I> max temp read = 28
[0000.795] I> min temp read = 27
[0000.798] I> Enabling thermtrip
[0000.801] I> Task: Update FSI SCR with thermal fuse data
[0000.806] I> Task: Enable WDT 5th expiry
[0000.810] I> Task: I2C register
[0000.813] I> Task: Set I2C bus freq
[0000.817] I> Task: Reset FSI
[0000.819] I> Task: Pinmux init
[0000.823] I> Task: Prod config init
[0000.826] I> Task: Pad voltage init
[0000.829] I> Task: Prod init
[0000.832] I> Task: Program rst req config reg
[0000.836] I> Task: Common rail init
[0000.840] W> DEVICE_PROD: module = 13, instance = 4 not found in device prod.
[0000.851] I> DONE: Thermal config
[0000.855] I> DONE: SOC rail config
[0000.859] W> PMIC_CONFIG: Rail: MEMIO rail config not found in MB1 BCT.
[0000.865] I> DONE: MEMIO rail config
[0000.868] I> DONE: GPU rail info
[0000.873] I> DONE: CV rail info
[0000.876] I> Task: Mem clock src
[0000.879] I> Task: Misc. board config
[0000.883] I> PMIC_CONFIG: Platform config not found in MB1 BCT.
[0000.889] I> Task: SDRAM init
[0000.892] I> MemoryType: 4 MemBctRevision: 8
[0000.898] I> MSS CAR: PLLM/HUB programming for MemoryType: 4 and MemBctRevision: 8
[0000.906] I> MSS CAR: Init PLLM
[0000.909] I> MSS CAR: Init PLLHUB
[0000.914] I> Encryption: MTS: en, TX: en, VPR: en, GSC: en
[0000.925] I> SDRAM initialized!
[0000.928] I> SDRAM Size in Total 0x1000000000
[0000.932] I> Task: Dram Ecc scrub
[0000.936] I> Task: DRAM alias check
[0000.952] I> Task: Program NSDRAM carveout
[0000.956] I> NSDRAM carveout encryption is enabled
[0000.961] I> Program NSDRAM carveout
[0000.964] I> Task: Register checker
[0000.968] I> Task: Enable clock-mon
[0000.982] I> FMON: Fmon re-programming done
[0000.986] I> Task: Mapper init
[0000.989] I> Task: SC7 Context Init
[0000.992] I> Task: CCPLEX IST init
[0000.995] I> Task: CPU WP0
[0000.999] I> Loading MCE
[0001.002] I> Slot: 0
[0001.004] I> Binary[8] block-22784 (partition size: 0x80000)
[0001.009] I> Binary name: MCE
[0001.012] I> Size of crypto header is 8192
[0001.016] I> Size of crypto header is 8192
[0001.020] I> strt_pg_num(22784) num_of_pgs(16) read_buf(0x4003e000)
[0001.026] I> BCH of MCE read from storage
[0001.030] I> BCH address is : 0x4003e000
[0001.034] I> MCE header integrity check is success
[0001.039] I> Binary magic in BCH component 0 is MTSM
[0001.043] I> component binary type is 8
[0001.047] I> Size of crypto header is 8192
[0001.051] I> strt_pg_num(22800) num_of_pgs(350) read_buf(0x40000000)
[0001.059] I> MCE binary is read from storage
[0001.064] I> MCE binary integrity check is success
[0001.068] I> Binary MCE loaded successfully at 0x40000000 (0x2baf0)
[0001.075] I> Size of crypto header is 8192
[0001.086] I> Size of crypto header is 8192
[0001.090] I> Sending WP0 mailbox command to PSC
[0001.099] I> Task: XUSB Powergate
[0001.102] I> Skipping powergate XUSB.
[0001.105] I> Task: MB1 fixed firewalls
[0001.112] W> Firewall readback mismatch
[0001.117] I> Task: Load bpmp-fw
[0001.120] I> Slot: 0
[0001.122] I> Binary[15] block-9984 (partition size: 0x180000)
[0001.127] I> Binary name: BPMP_FW
[0001.130] I> Size of crypto header is 8192
[0001.134] I> Size of crypto header is 8192
[0001.138] I> strt_pg_num(9984) num_of_pgs(16) read_buf(0x807fe000)
[0001.144] I> BCH of BPMP_FW read from storage
[0001.149] I> BCH address is : 0x807fe000
[0001.153] I> BPMP_FW header integrity check is success
[0001.157] I> Binary magic in BCH component 0 is BPMF
[0001.162] I> component binary type is 15
[0001.166] I> Size of crypto header is 8192
[0001.170] I> strt_pg_num(10000) num_of_pgs(1990) read_buf(0x80000000)
[0001.188] I> BPMP_FW binary is read from storage
[0001.194] I> BPMP_FW binary integrity check is success
[0001.199] I> Binary BPMP_FW loaded successfully at 0x80000000 (0xf8bc0)
[0001.205] I> Slot: 0
[0001.207] I> Binary[16] block-13056 (partition size: 0x400000)
[0001.213] I> Binary name: BPMP_FW_DTB
[0001.217] I> Size of crypto header is 8192
[0001.220] I> Size of crypto header is 8192
[0001.224] I> strt_pg_num(13056) num_of_pgs(16) read_buf(0x807fc000)
[0001.231] I> BCH of BPMP_FW_DTB read from storage
[0001.235] I> BCH address is : 0x807fc000
[0001.239] I> BPMP_FW_DTB header integrity check is success
[0001.244] I> Binary magic in BCH component 0 is BPMD
[0001.249] I> component binary type is 16
[0001.253] I> Size of crypto header is 8192
[0001.257] I> strt_pg_num(13072) num_of_pgs(502) read_buf(0x807bd3f0)
[0001.266] I> BPMP_FW_DTB binary is read from storage
[0001.271] I> BPMP_FW_DTB binary integrity check is success
[0001.277] I> Binary BPMP_FW_DTB loaded successfully at 0x807bd3f0 (0x3eb00)
[0001.283] I> Task: BPMP fw ast config
[0001.287] I> Task: Load psc-fw
[0001.290] I> Slot: 0
[0001.292] I> Binary[17] block-21248 (partition size: 0xc0000)
[0001.298] I> Binary name: PSC_FW
[0001.301] I> Size of crypto header is 8192
[0001.305] I> Size of crypto header is 8192
[0001.308] I> strt_pg_num(21248) num_of_pgs(16) read_buf(0x80ffe000)
[0001.315] I> BCH of PSC_FW read from storage
[0001.319] I> BCH address is : 0x80ffe000
[0001.323] I> PSC_FW header integrity check is success
[0001.328] I> Binary magic in BCH component 0 is PFWP
[0001.332] I> component binary type is 17
[0001.336] I> Size of crypto header is 8192
[0001.340] I> strt_pg_num(21264) num_of_pgs(591) read_buf(0x80fb4200)
[0001.350] I> PSC_FW binary is read from storage
[0001.355] I> PSC_FW binary integrity check is success
[0001.359] I> Binary PSC_FW loaded successfully at 0x80fb4200 (0x49df0)
[0001.366] I> Task: Load nvdec-fw
[0001.369] I> Slot: 0
[0001.371] I> Binary[7] block-6400 (partition size: 0x100000)
[0001.377] I> Binary name: NVDEC
[0001.379] I> Size of crypto header is 8192
[0001.383] I> Size of crypto header is 8192
[0001.387] I> strt_pg_num(6400) num_of_pgs(16) read_buf(0x800fe000)
[0001.394] I> BCH of NVDEC read from storage
[0001.398] I> BCH address is : 0x800fe000
[0001.401] I> NVDEC header integrity check is success
[0001.406] I> Binary magic in BCH component 0 is NDEC
[0001.411] I> component binary type is 7
[0001.415] I> Size of crypto header is 8192
[0001.419] I> strt_pg_num(6416) num_of_pgs(560) read_buf(0x80000000)
[0001.428] I> NVDEC binary is read from storage
[0001.433] I> NVDEC binary integrity check is success
[0001.438] I> Binary NVDEC loaded successfully at 0x80000000 (0x46000)
[0001.444] I> Size of crypto header is 8192
[0001.455] I> Task: Load tsec-fw
[0001.458] I> TSEC-FW load support not enabled
[0001.463] I> Task: GPIO interrupt map
[0001.466] I> Task: SC7 context save
[0001.470] I> Slot: 0
[0001.472] I> Binary[27] block-0 (partition size: 0x100000)
[0001.477] I> Binary name: BR_BCT
[0001.480] I> Size of crypto header is 8192
[0001.484] I> Size of crypto header is 8192
[0001.488] I> Size of crypto header is 8192
[0001.492] I> strt_pg_num(0) num_of_pgs(16) read_buf(0xa0000000)
[0001.498] I> BR_BCT binary is read from storage
[0001.502] I> BR_BCT binary integrity check is success
[0001.507] I> Binary BR_BCT loaded successfully at 0xa0000000 (0x2000)
[0001.513] I> Slot: 0
[0001.515] I> Binary[13] block-23808 (partition size: 0x30000)
[0001.521] I> Binary name: SC7-FW
[0001.524] I> Size of crypto header is 8192
[0001.528] I> Size of crypto header is 8192
[0001.532] I> Size of crypto header is 8192
[0001.536] I> Size of crypto header is 8192
[0001.540] I> strt_pg_num(23808) num_of_pgs(16) read_buf(0xa0002000)
[0001.546] I> BCH of SC7-FW read from storage
[0001.550] I> BCH address is : 0xa0002000
[0001.554] I> SC7-FW header integrity check is success
[0001.559] I> Binary magic in BCH component 0 is WB0B
[0001.564] I> component binary type is 13
[0001.567] I> Size of crypto header is 8192
[0001.571] I> strt_pg_num(23824) num_of_pgs(349) read_buf(0xa0004000)
[0001.580] I> SC7-FW binary is read from storage
[0001.584] I> SC7-FW binary integrity check is success
[0001.589] I> Binary SC7-FW loaded successfully at 0xa0004000 (0x2ba00)
[0001.596] I> Slot: 0
[0001.598] I> Binary[22] block-24192 (partition size: 0x30000)
[0001.603] I> Binary name: PSC_RF
[0001.606] I> Size of crypto header is 8192
[0001.610] I> Size of crypto header is 8192
[0001.614] I> Size of crypto header is 8192
[0001.618] I> Size of crypto header is 8192
[0001.622] I> strt_pg_num(24192) num_of_pgs(16) read_buf(0xa002fa00)
[0001.628] I> BCH of PSC_RF read from storage
[0001.632] I> BCH address is : 0xa002fa00
[0001.636] I> PSC_RF header integrity check is success
[0001.641] I> Binary magic in BCH component 0 is PSCR
[0001.646] I> component binary type is 22
[0001.650] I> Size of crypto header is 8192
[0001.654] I> strt_pg_num(24208) num_of_pgs(224) read_buf(0xa0031a00)
[0001.661] I> PSC_RF binary is read from storage
[0001.666] I> PSC_RF binary integrity check is success
[0001.671] I> Binary PSC_RF loaded successfully at 0xa0031a00 (0x1be60)
[0001.680] I> Task: Save WP0 payload to SC7 ctx
[0001.684] I> Task: Load MB2rf binary to SC7 ctx
[0001.689] I> Slot: 0
[0001.691] I> Binary[14] block-24576 (partition size: 0x20000)
[0001.696] I> Binary name: MB2_RF
[0001.699] I> Size of crypto header is 8192
[0001.703] I> Size of crypto header is 8192
[0001.707] I> Size of crypto header is 8192
[0001.711] I> Size of crypto header is 8192
[0001.715] I> strt_pg_num(24576) num_of_pgs(16) read_buf(0xa00d5d10)
[0001.721] I> BCH of MB2_RF read from storage
[0001.725] I> BCH address is : 0xa00d5d10
[0001.729] I> MB2_RF header integrity check is success
[0001.734] I> Binary magic in BCH component 0 is MB2R
[0001.739] I> component binary type is 14
[0001.743] I> Size of crypto header is 8192
[0001.747] I> strt_pg_num(24592) num_of_pgs(224) read_buf(0xa00d7d10)
[0001.754] I> MB2_RF binary is read from storage
[0001.759] I> MB2_RF binary integrity check is success
[0001.764] I> Binary MB2_RF loaded successfully at 0xa00d7d10 (0x1bf60)
[0001.770] I> Task: Save fuse alias data to SC7 ctx
[0001.775] I> Task: Save PMIC data to SC7 ctx
[0001.779] I> Task: Save Pinmux data to SC7 ctx
[0001.783] I> Task: Save Pad Voltage data to SC7 ctx
[0001.788] I> Task: Save controller prod data to SC7 ctx
[0001.793] I> Task: Save prod cfg data to SC7 ctx
[0001.797] I> Task: Save I2C bus freq data to SC7 ctx
[0001.802] I> Task: Save SOCTherm data to SC7 ctx
[0001.807] I> Task: Save FMON data to SC7 ctx
[0001.811] I> Task: Save VMON data to SC7 ctx
[0001.815] I> Task: Save TZDRAM data to SC7 ctx
[0001.819] I> Task: Save GPIO int data to SC7 ctx
[0001.824] I> Task: Save clock data to SC7 ctx
[0001.828] I> Task: Save debug data to SC7 ctx
[0001.832] I> Task: Save MBWT data to SC7 ctx
[0001.840] I> SC7 context save done
[0001.843] I> Task: Load MB2/Applet/FSKP
[0001.847] I> Loading MB2
[0001.849] I> Slot: 0
[0001.851] I> Binary[6] block-8448 (partition size: 0x80000)
[0001.857] I> Binary name: MB2
[0001.860] I> Size of crypto header is 8192
[0001.864] I> Size of crypto header is 8192
[0001.867] I> strt_pg_num(8448) num_of_pgs(16) read_buf(0x8007e000)
[0001.874] I> BCH of MB2 read from storage
[0001.877] I> BCH address is : 0x8007e000
[0001.881] I> MB2 header integrity check is success
[0001.886] I> Binary magic in BCH component 0 is MB2B
[0001.891] I> component binary type is 6
[0001.894] I> Size of crypto header is 8192
[0001.898] I> strt_pg_num(8464) num_of_pgs(846) read_buf(0x80000000)
[0001.909] I> MB2 binary is read from storage
[0001.914] I> MB2 binary integrity check is success
[0001.919] I> Binary MB2 loaded successfully at 0x80000000 (0x69a70)
[0001.925] I> Task: Map CCPLEX SHARED carveout
[0001.929] I> Task: Prepare MB2 params
[0001.933] I> Task: Dram ecc test
[0001.936] I> Task: Misc NV security settings
[0001.940] I> NVDEC sticky bits programming done
[0001.945] I> Successfully powergated NVDEC
[0001.949] I> Task: Disable/Reload WDT
[0001.952] I> Task: Program misc carveouts
[0001.956] I> Program IPC carveouts
[0001.960] I> Task: Disable SCPM/POD reset
[0001.963] I> SLCG Global override status := 0x0
[0001.968] I> MB1: MSS reconfig completed
I> MB2 (version: 0.0.0.0-t234-54845784-22833a33)
I> Emulation:
I> Entry timestamp: 0x001e734d
I> Regular heap: [base:0x40040000, size:0x10000]
I> DMA heap: [base:0x102e000000, size:0x800000]
I> Task: MB2 Params integrity check
I> Task: Enable CCPLEX WDT 5th expiry
I> Task: ARI update carveout TZDRAM
I> Task: Configure OEM set LA/PTSA values
I> Task: Check MC errors
I> Task: SMMU external bypass disable
I> Task: Enable hot-plug capability
I> Task: TZDRAM heap init
I> Task: PSC mailbox init
I> Task: Enable clock for external modules
I> Task: Measured Boot init
I> Task: fTPM silicon identity init
I> fTPM is not enabled.
I> Task: OEM SC7 context save init
I> Task: Map CCPLEX_INTERWORLD_SHMEM carveout
I> Task: Program CBB PCIE AMAP regions
I> Secondary storage device: QSPI_FLASH instance: 0
I> Secondary storage device: SDMMC_USER instance: 3
I> sdmmc HS400 mode enabled
I> Task: Partition Manager Init
I> strt_pg_num(1) num_of_pgs(1) read_buf(0x102e001000)
I> strt_pg_num(131071) num_of_pgs(1) read_buf(0x102e001000)
I> strt_pg_num(131039) num_of_pgs(32) read_buf(0x102e001200)
I> Found 60 partitions in QSPI_FLASH (instance 0)
W> Cannot find any partition table for 00000003
W> PARTITION_MANAGER: Failed to publish partition.
I> Found 15 partitions in SDMMC_USER (instance 3)
I> Task: Pass DRAM ECC PRL Flag to FSI
I> Task: Load and authenticate registered FWs
I> Task: Load AUXP FWs
I> Successfully register SPE FW load task with MB2 loader
I> Successfully register RCE FW load task with MB2 loader
I> Successfully register DCE FW load task with MB2 loader
I> Unpowergating APE
I> Unpowergate done
I> Successfully register APE FW load task with MB2 loader
I> Skipping FSI FW load
I> Successfully register XUSB FW load task with MB2 loader
I> Successfully register PVA FW load task with MB2 loader
I> Partition name: A_spe-fw
I> Size of partition: 589824
I> Binary@ device:3/0 block-55040 (partition size: 0x90000), name: A_spe-fw
I> strt_pg_num(55040) num_of_pgs(16) read_buf(0x40067a30)
I> strt_pg_num(55056) num_of_pgs(512) read_buf(0x102d600000)
I> Partition name: A_rce-fw
I> Size of partition: 1048576
I> Binary@ device:3/0 block-56192 (partition size: 0x100000), name: A_rce-fw
I> strt_pg_num(56192) num_of_pgs(16) read_buf(0x40067a30)
I> strt_pg_num(56208) num_of_pgs(880) read_buf(0x102d200000)
I> spe: Authentication Finalize Done
I> Binary spe loaded successfully at 0x102d600000
I> Partition name: A_dce-fw
I> Size of partition: 5242880
I> Binary@ device:3/0 block-44800 (partition size: 0x500000), name: A_dce-fw
I> strt_pg_num(44800) num_of_pgs(16) read_buf(0x40067a30)
I> rce: Authentication Finalize Done
I> Binary rce loaded successfully at 0x102d200000
I> Successfully register RCE FW context save task with MB2 loader
I> dce : oem authentication of header done
I> strt_pg_num(44816) num_of_pgs(1) read_buf(0x102e1403d8)
I> strt_pg_num(44816) num_of_pgs(8) read_buf(0x102e1403d8)
I> dce : meta-blob integrity check is success.
I> strt_pg_num(44824) num_of_pgs(512) read_buf(0x102e0003c0)
I> strt_pg_num(45336) num_of_pgs(512) read_buf(0x102e0403c0)
I> dce : will be decompressed at 0x1036000000
I> version 1 Bin 1 BCheckSum 0 content_size 0 Content ChkSum 1 reserved_00 0
I> Reserved10 0 BlockMaxSize 5 Reserved11 0
I> strt_pg_num(45848) num_of_pgs(512) read_buf(0x102e0803c0)
I> dce : decompressed to 12067600 bytes
I> dce: plain binary integrity check is success
I> Partition name: A_adsp-fw
I> Size of partition: 2097152
I> Binary@ device:3/0 block-58240 (partition size: 0x200000), name: A_adsp-fw
I> strt_pg_num(58240) num_of_pgs(16) read_buf(0x40067a30)
I> strt_pg_num(58256) num_of_pgs(800) read_buf(0x1038800000)
I> dce: Authentication Finalize Done
I> Binary dce loaded successfully at 0x1036000000
I> Partition name: A_xusb-fw
I> Size of partition: 262144
I> Binary@ device:3/0 block-9472 (partition size: 0x40000), name: A_xusb-fw
I> strt_pg_num(9472) num_of_pgs(16) read_buf(0x40067a30)
I> strt_pg_num(9488) num_of_pgs(312) read_buf(0x102d700000)
I> ape: Authentication Finalize Done
I> Binary ape loaded successfully at 0x1038800000
I> Successfully register APE FW context save task with MB2 loader
I> Partition name: A_pva-fw
I> Binary@ device:3/0 block-62336 (partition size: 0x40000), name: A_pva-fw
I> strt_pg_num(62336) num_of_pgs(16) read_buf(0x40067a30)
I> xusb: Authentication Finalize Done
I> Binary xusb loaded successfully at 0x102d700000
I> Successfully register XUSB FW context save task with MB2 loader
I> pva-fw : oem authentication of header done
I> strt_pg_num(62352) num_of_pgs(1) read_buf(0x102e1403d8)
I> strt_pg_num(62352) num_of_pgs(8) read_buf(0x102e1403d8)
I> pva-fw : meta-blob integrity check is success.
I> strt_pg_num(62360) num_of_pgs(512) read_buf(0x102e0003c0)
I> pva-fw : will be decompressed at 0x102d980000
I> pva-fw : decompressed to 2156512 bytes
I> pva-fw: plain binary integrity check is success
I> pva-fw: Authentication Finalize Done
I> Binary pva-fw loaded successfully at 0x102d980000
I> Successfully register PVA FW context save task with MB2 loader
I> Task: Carveout setup
I> Program remaining OEM carveouts
I> Task: Enable FSITHERM
I> Task: Enable FSI VMON
I> FSI VMON: FSI Vmon re-calibration and fine tuning done
I> Task: Validate FSI Therm readings
I> Task: Restore XUSB sec
I> Task: Enable FSI SE clock
I> Enable FSI-SE clock…
I> Task: Initialize SBSA UART CAR
I> Task: Initialize CPUBL Params
I> CPUBL-params @ 0x1032000000
I> Task: Ratchet update
W> Skip ratchet update - OPTIN fuse not set
I> Task: Prepare eeprom data
I> Task: Revoke PKC fuse
I> PKC revoke fuse burn not requested
I> Task: FSI padctl context save
I> Task: Unpowergate APE
W> mb2_unpowergate_ape: skip! APE is in unpowergated state
I> Task: Memctrl reconfig pending clients
I> Task: OEM firewalls
I> OEM firewalls configured
I> Task: Powergate APE
I> Powergating APE
I> Powergate done
I> Task: OEM firewall restore saved settings
I> Task: Unhalt AUXPs
I> Unhalting SPE…
I> Enabling combined UART
����spe: early_init
����vic initialized
����tsc initialized
����aon lic initialized
����spe: tag is 5243985d1b1eb3f06fac6d36bd7e74ac
����spe: SafeRTOS v8.4
����spe: init
����scheduler initialized
����aon hsp initialized
����tag initialized
����tcu initialized
����bpmp ipc initialized
����spe: late init
����cpu_nic clock initialized
����apb clock initialized
����pm initialized
����bpmp hsp initialized
����top1 hsp initialized
����ccplex ipc initialized
����spe: start scheduler
I> Task: Trigger mailbox for PSC-BL1 exit
I> Sending opcode 0x4d420802 to psc
I> Received ACK from psc
I> Task: Start secure NOR provision
I> Skip Secure NOR provisioning
I> Task: Trigger load FSI keyblob
I> Skipping FSI key blob copy
I> Task: Complete load FSI keyblob
I> Task: MB2-PSC_FW Key Manager Init
I> Sending opcode OP_PSC_KEY_MANAGER to psc-fw
I> Sending opcode 0x4b45594d t��
hwwdt_init: WDT boot cfg 0x710010 sts 0x10
bpmp: socket 0
bpmp: base binary md5 is da583751bbfe2b7f6e204562d97ff39e
bpmp: combined binary md5 is 39f77b2baaf3f0522607569dd3ae9a48
bpmp: firmware tag is 39f77b2baaf3f0522607-da583751bbf
initialized vwdt
initialized mail_early
initialized fuse
initialized vfrel
initialized adc
fmon_populate_monitors: found 199 monitors
initialized fmon
initialized mc
initialized reset
initialized uphy_early
initialized emc_early
initialized pm
465 clocks registered
initialized clk_mach
initialized clk_cal_early
initialized clk_mach_early_config
initialized io_dpd
initialized soctherm
initialized regime
initialized i2c
vrmon_dt_init: vrmon node not found
vrmon_chk_boot_state: found 0 rail monitors
initialized vrmon
initialized regulator
��o psc
I> Task: Unhalt FSI
I> FSI unhalt skipped
I> Unhalting RCE
I> RCE unhalt successful
I> Unhalting DCE
I> DCE unhalt successful
I> APE unhalt skipped
I> Task: Load HV/CPUBL
I> Task: Load TOS
I> Task: Trigger load TS��[ 2.574590] Camera-FW on t234-rce-safe started
��initialized avfs_clk_platform
initialized powergate
��TCU early console enabled.
��EC leyblob
I> Sen��initialized dvs
initialized clk_mach_config
initialized suspend
initialized strap
initialized mce_dbell
��ding opcode 0x53535452 to psc
��I> Sent opcode to psc
I> Partition name: A_cpu-bootloader
I> Size of partition: 3670016
I> Binary@ device:3/0 block-24832 (partition size: 0x380000), name: A_cpu-bootloader
��DCE Started
��I> strt_pg_num(24832) num_of_pgs(16) read_buf(0x40067a30)
I> cpubl : oem authentication of header done
I> strt_pg_num(24848) num_of_pgs(1) read_buf(0x102e143f98)
I> strt_pg_num(24848) num_of_pgs(8) read_buf(0x102e143f98)
��DCE_R5_Init
��I> cpubl : meta-blob integrity check is success.
I> strt_pg_num(24856) num_o��initialized emc
initialized emc_mrq
��f_pgs(512) read_buf(0x102e003f80)
��initialized clk_cal
initialized uphy_dt
initialized uphy_mrq
HSIO UPHY reset has been de-asserted 0x0
��I> str��initialized uphy
��t_pg_num(25368) num_of_pgs(��initialized pg_late
initialized pg_mrq_init
swdtimer_init: reg polling start w period 47 ms
initialized swdtimer
initialized hwwdt_late
initialized bwmgr
initialized thermal_host_trip
initialized thermal_mrq
initialized oc_mrq
initialized reset_mrq
initialized mail_mrq
initialized fmon_mrq
initialized clk_mrq
initialized avfs_mrq
initialized i2c_mrq
initialized tag_mrq
initialized bwmgr_mrq
initialized console_mrq
missing prod DT calibration data for 199 fmons
initialized clk_sync_fmon_post
DCE_SW_Init
��512) read_buf(0x102e043f80)
I> cpubl : will be decompressed at 0��initialized clk_cal_late
initialized noc_late
initialized cvc
��x102c800000
I> version 1 Bin 1 BChec��initialized avfs_clk_mach_post
initialized avfs_clk_platform_post
initialized cvc_late
initialized rm
initialized console_late
handling unreferenced clks
enable can1_core
enable can1_host
enable can2_core
enable can2_host
enable pwm3
enable mss_encrypt
enable maud
enable pllg_ref
enable dsi_core
enable aza_2xbit
enable pllc4_muxed
enable sdmmc4_axicif
enable xusb_ss
enable xusb_fs
enable xusb_falcon
enable xusb_core_mux
enable dsi_lp
enable sdmmc_legacy_tm
initialized clk_mach_post
initialized pg_post
initialized regulator_post
initialized profile
initialized mrq
initialized patrol_scrubber
initialized cac��[ 2.777928] Camera-FW on t234-rce-safe ready SHA1=e2238c99 (crt 12.432 ms,��tmon
initialized extras_post
bpmp: init complete
�� total boot 216.842 ms)
��kSum 0 content_size 0 Content ChkSum 1 reserved_00 0
I> strt_pg_num(25880) num_of_pgs(512) read_buf(0x102e083f80)
I> strt_pg_num(26392) num_of_pgs(512) read_buf(0x102e0c3f80)
I> strt_pg_num(26904) num_of_pgs(512) read_buf(0x102e103f80)
I> strt_pg_num(27416) num_of_pgs(512) read_buf(0x102e003f80)
I> strt_pg_num(27928) num_of_pgs(512) read_buf(0x102e043f80)
I> strt_pg_num(28440) num_of_pgs(512) read_buf(0x102e083f80)
I> strt_pg_num(28952) num_of_pgs(512) read_buf(0x102e0c3f80)
I> strt_pg_num(29464) num_of_pgs(512) read_buf(0x102e103f80)
I> strt_pg_num(29976) num_of_pgs(512) read_buf(0x102e003f80)
I> strt_pg_num(30488) num_of_pgs(512) read_buf(0x102e043f80)
��Admin Task Init
Admin Task Init complete
Print Task Init
RM Task Init
SHA Task Init
Admin Task Started
DCE SC7 SHA Enabled
RM Task Started
RM Task Running
Print Task Started
Print Task Running
SHA Task Started
DCE: FW Boot Complete
Admin Task Running
SHA Task Running
��I> strt_pg_num(31000) num_of_pgs(512) read_buf(0x102e083f80)
I> cpubl : decompressed to 3657856 bytes
I> cpubl: plain binary integrity check is success
I> Partition name: A_secure-os
I> Size of partition: 4194304
I> Binary@ device:3/0 block-32000 (partition size: 0x400000), name: A_secure-os
I> strt_pg_num(32000) num_of_pgs(16) read_buf(0x40067a30)
I> strt_pg_num(32016) num_of_pgs(3672) read_buf(0x103fd35000)
I> NSDRAM carveout base: 0x80000000, size: 0xfacdf0000
I> cpubl_params: nsdram: carveout: 1, encryption: 1
I> cpubl: Authentication Finalize Done
I> Binary cpubl loaded successfully at 0x102c800000
I> tos: Authentication Finalize Done
I> Binary tos loaded successfully at 0x103fd35000
I> Relocating OP-TEE dtb from: 0x103feff180 to 0x103c040020, size: 0x2754
I> [0] START: 0x80000000, SIZE: 0xfacdf0000
I> [1] START: 0x1032000000, SIZE: 0x2000000
I> Setting NS memory ranges to OP-TEE dtb finished.
I> Partition name: A_eks
I> Binary@ device:3/0 block-44288 (partition size: 0x40000), name: A_eks
I> strt_pg_num(44288) num_of_pgs(16) read_buf(0x40067a30)
I> strt_pg_num(44304) num_of_pgs(8) read_buf(0x103c020000)
I> eks: Authentication Finalize Done
I> Binary eks loaded successfully at 0x103c020000
I> EKB detected (length: 0x410) @ VA:0x103c020000
I> Task: Add cpubl params integrity check
I> Added cpubl params digest.
I> Task: Prepare TOS params
I> Setting EKB blob info to OPTEE dtb finished.
I> Setting OPTEE arg3: 0x103c040020
I> OEM sc7 context saved
I> Task: Disable MSS perf stats
I> Task: Program display sticky bits
I> Task: Storage device deinit
I> Task: SMMU init
I> Task: Program GICv3 registers
I> Task: Audit firewall settings
I> Task: Bootchain failure check
I> Current Boot-Chain Slot: 0
I> BR-BCT Boot-Chain is 0, and status is 1. Set UPDATE_BRBCT bit to 0
I> Task: Burn RESERVED_ODM0 fuse
I> Task: Lock fusing
I> Task: Clear dec source key
I> MB2 finished
��NOTICE: BL31: v2.8(release):e12e3fa93
NOTICE: BL31: Built : 21:01:44, Sep 12 2024
I/TC:
I/TC: Non-secure external DT found
I/TC: OP-TEE version: 4.2 (gcc version 11.3.0 (Buildroot 2022.08)) #2 Fri Sep 13 04:10:17 UTC 2024 aarch64
I/TC: WARNING: This OP-TEE configuration might be insecure!
I/TC: WARNING: Please check Porting guidelines — OP-TEE documentation documentation
I/TC: Primary CPU initializing
I/TC: Test OEM keys are being used. This is insecure for shipping products!
I/TC: fTPM ID is not enabled.
I/TC: ftpm-helper PTA: fTPM DT or EKB is not available. fTPM provisioning is not supported.
I/TC: Primary CPU switching to normal world boot
Jetson UEFI firmware (version 36.4.0-gcid-37537400 built on 2024-09-13T04:02:39+00:00)
��I/TC: Reserved shared memory is disabled
I/TC: Dynamic shared memory is enabled
I/TC: Normal World virtualization support is disabled
I/TC: Asynchronous notifications are disabled
I/TC: WARNING: Test UEFI variable auth key is being used !
I/TC: WARNING: UEFI variable protection is not fully enabled !
Jetson System firmware version 36.4.0-gcid-37537400 date 2024-09-13T04:02:39+00:
00
ESC to enter Setup.
F11 to enter Boot Manager Menu.
Enter to continue boot.
L4TLauncher: Attempting Direct Boot
EFI stub: Booting Linux Kernel…
EFI stub: Using DTB from configuration table
EFI stub: Loaded initrd from LINUX_EFI_INITRD_MEDIA_GUID device path
EFI stub: Exiting boot services…
��debugfs initialized
��[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd421]
[ 0.000000] Linux version 5.15.148-tegra (buildbrain@mobile-u64-5441-d8000) (aarch64-buildroot-linux-gnu-gcc.br_real (Buildroot 2022.08) 1)
[ 0.000000] Machine model: NVIDIA Jetson AGX Orin Developer Kit
[ 0.000000] efi: EFI v2.70 by EDK II
[ 0.000000] efi: RTPROP=0x1027f3f198 TPMFinalLog=0x1018b00000 SMBIOS=0xffff0000 SMBIOS 3.0=0x1027930000 MEMATTR=0x1021a4b018 ESRT=0x1021a6
[ 0.000000] random: crng init done
[ 0.000000] secureboot: Secure boot disabled
[ 0.000000] esrt: Reserving ESRT space from 0x0000001021a6ee18 to 0x0000001021a6ee50.
[ 0.000000] Reserved memory: created CMA memory pool at 0x0000000ff4000000, size 512 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] NUMA: No NUMA configuration found
[ 0.000000] NUMA: Faking a node at [mem 0x0000000080000000-0x0000001033ffffff]
[ 0.000000] NUMA: NODE_DATA [mem 0x1022d15800-0x1022d17fff]
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal [mem 0x0000000100000000-0x0000001033ffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000080000000-0x00000000fffdffff]
[ 0.000000] node 0: [mem 0x00000000fffe0000-0x00000000ffffffff]
[ 0.000000] node 0: [mem 0x0000000100000000-0x00000010189a6fff]
[ 0.000000] node 0: [mem 0x00000010189a7000-0x0000001018b0ffff]
[ 0.000000] node 0: [mem 0x0000001018b10000-0x0000001018b1afff]
[ 0.000000] node 0: [mem 0x0000001018b1b000-0x0000001018b1bfff]
[ 0.000000] node 0: [mem 0x0000001018b1c000-0x0000001025ffffff]
[ 0.000000] node 0: [mem 0x0000001026000000-0x0000001027f3ffff]
[ 0.000000] node 0: [mem 0x0000001027f40000-0x000000102c5fffff]
[ 0.000000] node 0: [mem 0x000000102c600000-0x000000102c7fffff]
[ 0.000000] node 0: [mem 0x000000102c800000-0x000000102cd6ffff]
��WARNING: clock_disable: clk_power_ungate on gated domain 35 for gpusysclk
��[ 0.000000] node 0: [mem 0x000000102d700000-0x000000102d7fffff]
[ 0.000000] node 0: [mem 0x0000001032000000-0x0000001033ffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x0000001033ffffff]
[ 0.000000] On node 0, zone Normal: 2448 pages in unavailable ranges
[ 0.000000] On node 0, zone Normal: 18432 pages in unavailable ranges
��WARNING: clock_disable: clk_power_ungate on gated domain 35 for gpc1clk
��[ 0.000000] On node 0, zone Normal: 16384 pages in unavailable ranges
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: Trusted OS migration not required
[ 0.000000] psci: SMC Calling Convention v1.2
[ 0.000000] percpu: Embedded 29 pages/cpu s80408 r8192 d30184 u118784
��WARNING: clock_disable: clk_power_ungate on gated domain 35 for gpc0clk
��[ 0.000000] Detected PIPT I-cache on CPU0
[ 0.000000] CPU features: detected: Address authentication (architected algorithm)
[ 0.000000] CPU features: detected: GIC system register CPU interface
[ 0.000000] CPU features: detected: Virtualization Host Extensions
[ 0.000000] CPU features: detected: Hardware dirty bit management
[ 0.000000] CPU features: detected: Spectre-v4
[ 0.000000] CPU features: detected: Spectre-BHB
[ 0.000000] CPU features: kernel page table isolation forced ON by KASLR
[ 0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[ 0.000000] alternatives: patching kernel code
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 16187760
[ 0.000000] Policy zone: Normal
[ 0.000000] Kernel command line: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 mminit_loglevel=4 console=ttyTCU0,115200 console=ttyAMA0,e
��=2031616@0x102C610000 bl_prof_ro_ptr=65536@0x102C600000
[ 0.000000] Unknown kernel command line parameters “bl_prof_dataptr=2031616@0x102C610000 bl_prof_ro_ptr=65536@0x102C600000”, will be passe.
��WARNING: clock_disable: clk_power_ungate on gated domain 34 for nafll_dla1_core
��[ 0.000000] Dentry cache hash table entries: 8388608 (order: 14, 67108864 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 4194304 (order: 13, 33554432 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] software IO TLB: mapped [mem 0x00000000fbfe0000-0x00000000fffe0000] (64MB)
��WARNING: clock_disable: clk_power_ungate on gated domain 34 for dla1_falcon
��[ 0.000000] Memory: 63801564K/65780160K available (20160K kernel code, 4064K rwdata, 10060K rodata, 7680K init, 529K bss, 1454308K reser)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=12, Nodes=1
[ 0.000000] trace event string verifier disabled
[ 0.000000] rcu: Pree��WARNING: clock_disable: clk_power_ungate on gated domain 34 for nafll_dla1_falcon
��mptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=12.
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] Rude variant of Tasks RCU enabled.
[ ��WARNING: clock_disable: clk_power_ungate on gated domain 34 for dla0_core
�� 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=12
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.00000��WARNING: clock_disable: clk_power_ungate on gated domain 34 for nafll_dla0_core
��0] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: 960 SPIs implemented
[ 0.000000] GICv3: 0 Extended SPIs implemented
[ 0.000000] GICv3: Distributor has no Range Selector support
[ 0.000000] Root IRQ handler: gic_handle_irq
[ 0.000000] GICv3: 16 PPIs imp��WARNING: clock_disable: clk_power_ungate on gated domain 34 for dla0_falcon
��lemented
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x000000000f440000
[ 0.000000] arch_timer: cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000002] ��WARNING: clock_disable: clk_power_ungate on gated domain 34 for nafll_dla0_falcon
��sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.000638] Console: colour dummy device 80x25
[ 0.000663] printk: console [tty0] enabled
[ 0.000807] Calibrating delay loop (skipped), value calculated using timer frequency… 62.50 BogoMIPS (lpj=125000)
[ 0.000827] pid_max: default: 32768 minimum: 301
[ 0.000899] LSM: Security Framework initializing
[ 0.000948] Yama: becoming mindful.
[ 0.000981] SELinux: Initializing.
[ 0.001380] Mount-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.001661] Mountpoint-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.005579] rcu: Hierarchical SRCU implementation.
[ 0.010198] Tegra Revision: A01 SKU: 208 CPU Process: 0 SoC Process: 0
[ 0.010575] Remapping and enabling EFI services.
[ 0.011890] smp: Bringing up secondary CPUs …
[ 0.012807] Detected PIPT I-cache on CPU1
[ 0.012923] GICv3: CPU1: found redistributor 100 region 0:0x000000000f460000
[ 0.013019] CPU1: Booted secondary processor 0x0000000100 [0x410fd421]
[ 0.013821] Detected PIPT I-cache on CPU2
[ 0.013834] GICv3: CPU2: found redistributor 200 region 0:0x000000000f480000
[ 0.013856] CPU2: Booted secondary processor 0x0000000200 [0x410fd421]
[ 0.014524] Detected PIPT I-cache on CPU3
[ 0.014537] GICv3: CPU3: found redistributor 300 region 0:0x000000000f4a0000
[ 0.014558] CPU3: Booted secondary processor 0x0000000300 [0x410fd421]
[ 0.017281] Detected PIPT I-cache on CPU4
[ 0.017307] GICv3: CPU4: found redistributor 10000 region 0:0x000000000f4c0000
[ 0.017340] CPU4: Booted secondary processor 0x0000010000 [0x410fd421]
[ 0.018048] Detected PIPT I-cache on CPU5
[ 0.018064] GICv3: CPU5: found redistributor 10100 region 0:0x000000000f4e0000
[ 0.018085] CPU5: Booted secondary processor 0x0000010100 [0x410fd421]
[ 0.018752] Detected PIPT I-cache on CPU6
[ 0.018767] GICv3: CPU6: found redistributor 10200 region 0:0x000000000f500000
[ 0.018787] CPU6: Booted secondary processor 0x0000010200 [0x410fd421]
[ 0.019463] Detected PIPT I-cache on CPU7
[ 0.019475] GICv3: CPU7: found redistributor 10300 region 0:0x000000000f520000
[ 0.019496] CPU7: Booted secondary processor 0x0000010300 [0x410fd421]
[ 0.022231] Detected PIPT I-cache on CPU8
[ 0.022258] GICv3: CPU8: found redistributor 20000 region 0:0x000000000f540000
[ 0.022290] CPU8: Booted secondary processor 0x0000020000 [0x410fd421]
[ 0.023015] Detected PIPT I-cache on CPU9
[ 0.023034] GICv3: CPU9: found redistributor 20100 region 0:0x000000000f560000
[ 0.023055] CPU9: Booted secondary processor 0x0000020100 [0x410fd421]
[ 0.023769] Detected PIPT I-cache on CPU10
[ 0.023785] GICv3: CPU10: found redistributor 20200 region 0:0x000000000f580000
[ 0.023807] CPU10: Booted secondary processor 0x0000020200 [0x410fd421]
[ 0.024488] Detected PIPT I-cache on CPU11
[ 0.024501] GICv3: CPU11: found redistributor 20300 region 0:0x000000000f5a0000
[ 0.024523] CPU11: Booted secondary processor 0x0000020300 [0x410fd421]
[ 0.024611] smp: Brought up 1 node, 12 CPUs
[ 0.024620] SMP: Total of 12 processors activated.
[ 0.024625] CPU features: detected: 32-bit EL0 Support
[ 0.024629] CPU features: detected: Data cache clean to the PoU not required for I/D coherence
[ 0.024634] CPU features: detected: Common not Private translations
[ 0.024636] CPU features: detected: CRC32 instructions
[ 0.024637] CPU features: detected: Data cache clean to Point of Persistence
[ 0.024639] CPU features: detected: Generic authentication (architected algorithm)
[ 0.024641] CPU features: detected: RCpc load-acquire (LDAPR)
[ 0.024643] CPU features: detected: LSE atomic instructions
[ 0.024645] CPU features: detected: Privileged Access Never
[ 0.024647] CPU features: detected: RAS Extension Support
[ 0.024652] CPU features: detected: Speculative Store Bypassing Safe (SSBS)
[ 0.053185] spectre-bhb mitigation disabled by command line option
[ 0.081040] CPU: All CPU(s) started at EL2
[ 0.089773] devtmpfs: initialized
[ 0.112787] KASLR enabled
[ 0.113018] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.113050] futex hash table entries: 4096 (order: 6, 262144 bytes, linear)
[ 0.122601] pinctrl core: initialized pinctrl subsystem
[ 0.123696] SMBIOS 3.6.0 present.
[ 0.123709] DMI: NVIDIA NVIDIA Jetson AGX Orin Developer Kit/Jetson, BIOS 36.4.0-gcid-37537400 09/13/2024
[ 0.124319] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.126820] DMA: preallocated 8192 KiB GFP_KERNEL pool for atomic allocations
[ 0.127506] DMA: preallocated 8192 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.128172] DMA: preallocated 8192 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.128296] audit: initializing netlink subsys (disabled)
[ 0.128539] audit: type=2000 audit(0.124:1): state=initialized audit_enabled=0 res=1
[ 0.130535] thermal_sys: Registered thermal governor ‘step_wise’
[ 0.130539] thermal_sys: Registered thermal governor ‘user_space’
[ 0.130540] thermal_sys: Registered thermal governor ‘power_allocator’
[ 0.135387] cpuidle: using governor menu
[ 0.135650] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.135825] ASID allocator initialised with 32768 entries
[ 0.137959] Serial: AMBA PL011 UART driver
[ 0.148934] 31d0000.serial: ttyAMA0 at MMIO 0x31d0000 (irq = 118, base_baud = 0) is a SBSA
[ 0.148975] printk: console [ttyAMA0] enabled
[ 0.160261] platform bpmp: Fixing up cyclic dependency with 2c60000.external-memory-controller
[ 0.169687] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.169695] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[ 0.169696] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.169697] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[ 0.170851] cryptd: max_cpu_qlen set to 1000
[ 0.173151] ACPI: Interpreter disabled.
[ 0.175255] iommu: Default domain type: Translated
[ 0.175264] iommu: DMA domain TLB invalidation policy: strict mode
[ 0.175596] SCSI subsystem initialized
[ 0.175824] vgaarb: loaded
[ 0.176030] usbcore: registered new interface driver usbfs
[ 0.176057] usbcore: registered new interface driver hub
[ 0.176087] usbcore: registered new device driver usb
[ 0.176517] pps_core: LinuxPPS API ver. 1 registered
[ 0.176523] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
[ 0.176542] PTP clock support registered
[ 0.176612] EDAC MC: Ver: 3.0.0
[ 0.178193] Registered efivars operations
[ 0.178875] FPGA manager framework
[ 0.178968] Advanced Linux Sound Architecture Driver Initialized.
[ 0.179562] Bluetooth: Core ver 2.22
[ 0.179592] NET: Registered PF_BLUETOOTH protocol family
[ 0.179599] Bluetooth: HCI device and connection manager initialized
[ 0.179610] Bluetooth: HCI socket layer initialized
[ 0.179615] Bluetooth: L2CAP socket layer initialized
[ 0.179633] Bluetooth: SCO socket layer initialized
[ 0.180154] clocksource: Switched to clocksource arch_sys_counter
[ 0.218640] VFS: Disk quotas dquot_6.6.0
[ 0.218709] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.218933] pnp: PnP ACPI: disabled
[ 0.222167] NET: Registered PF_INET protocol family
[ 0.222874] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.225155] tcp_listen_portaddr_hash hash table entries: 32768 (order: 7, 524288 bytes, linear)
[ 0.225815] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.225864] TCP established hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[ 0.226274] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[ 0.227582] TCP: Hash tables configured (established 524288 bind 65536)
[ 0.227854] UDP hash table entries: 32768 (order: 8, 1048576 bytes, linear)
[ 0.227976] UDP-Lite hash table entries: 32768 (order: 8, 1048576 bytes, linear)
[ 0.228393] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.228903] RPC: Registered named UNIX socket transport module.
[ 0.228910] RPC: Registered udp transport module.
[ 0.228915] RPC: Registered tcp transport module.
[ 0.228919] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.228939] PCI: CLS 0 bytes, default 64
[ 0.229213] Unpacking initramfs…
[ 0.237171] hw perfevents: enabled with armv8_cortex_a78 PMU driver, 7 counters available
[ 0.237530] kvm [1]: IPA Size Limit: 48 bits
[ 0.237568] kvm [1]: GICv3: no GICV resource entry
[ 0.237577] kvm [1]: disabling GICv2 emulation
[ 0.237602] kvm [1]: GIC system register CPU interface enabled
[ 0.237732] kvm [1]: vgic interrupt IRQ9
[ 0.237935] kvm [1]: VHE mode initialized successfully
[ 0.241475] Initialise system trusted keyrings
[ 0.241530] Key type blacklist registered
[ 0.241697] workingset: timestamp_bits=42 max_order=24 bucket_order=0
[ 0.245667] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.246137] NFS: Registering the id_resolver key type
[ 0.246164] Key type id_resolver registered
[ 0.246165] Key type id_legacy registered
[ 0.246217] nfs4filelayout_init: NFSv4 File Layout Driver Registering…
[ 0.246231] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering…
[ 0.246254] ntfs: driver 2.1.32 [Flags: R/O].
[ 0.246490] 9p: Installing v9fs 9p2000 file system support
[ 0.247175] integrity: Platform Keyring initialized
[ 0.258542] Key type asymmetric registered
[ 0.258548] Asymmetric key parser ‘x509’ registered
[ 0.258625] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[ 0.258635] io scheduler mq-deadline registered
[ 0.258644] io scheduler kyber registered
[ 0.269619] EINJ: ACPI disabled.
[ 0.281702] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.283645] SuperH (H)SCI(F) driver initialized
[ 0.283980] msm_serial: driver initialized
[ 0.284628] printk: console [ttyTCU0] enabled
[ 0.285498] arm-smmu 8000000.iommu: probing hardware configuration…
[ 0.285503] arm-smmu 8000000.iommu: SMMUv2 with:
[ 0.285512] arm-smmu 8000000.iommu: stage 1 translation
[ 0.285513] arm-smmu 8000000.iommu: stage 2 translation
[ 0.285515] arm-smmu 8000000.iommu: nested translation
[ 0.285522] arm-smmu 8000000.iommu: stream matching with 128 register groups
[ 0.285526] arm-smmu 8000000.iommu: 128 context banks (0 stage-2 only)
[ 0.285540] arm-smmu 8000000.iommu: Supported page sizes: 0x61311000
[ 0.285541] arm-smmu 8000000.iommu: Stage-1: 48-bit VA → 48-bit IPA
[ 0.285542] arm-smmu 8000000.iommu: Stage-2: 48-bit IPA → 48-bit PA
[ 0.286534] arm-smmu 10000000.iommu: probing hardware configuration…
[ 0.286539] arm-smmu 10000000.iommu: SMMUv2 with:
[ 0.286543] arm-smmu 10000000.iommu: stage 1 translation
[ 0.286545] arm-smmu 10000000.iommu: stage 2 translation
[ 0.286546] arm-smmu 10000000.iommu: nested translation
[ 0.286548] arm-smmu 10000000.iommu: stream matching with 128 register groups
[ 0.286550] arm-smmu 10000000.iommu: 128 context banks (0 stage-2 only)
[ 0.286557] arm-smmu 10000000.iommu: Supported page sizes: 0x61311000
[ 0.286560] arm-smmu 10000000.iommu: Stage-1: 48-bit VA → 48-bit IPA
[ 0.286561] arm-smmu 10000000.iommu: Stage-2: 48-bit IPA → 48-bit PA
[ 0.286908] arm-smmu 12000000.iommu: probing hardware configuration…
[ 0.286912] arm-smmu 12000000.iommu: SMMUv2 with:
[ 0.286915] arm-smmu 12000000.iommu: stage 1 translation
[ 0.286916] arm-smmu 12000000.iommu: stage 2 translation
[ 0.286916] arm-smmu 12000000.iommu: nested translation
[ 0.286919] arm-smmu 12000000.iommu: stream matching with 128 register groups
[ 0.286921] arm-smmu 12000000.iommu: 128 context banks (0 stage-2 only)
[ 0.286925] arm-smmu 12000000.iommu: Supported page sizes: 0x61311000
[ 0.286927] arm-smmu 12000000.iommu: Stage-1: 48-bit VA → 48-bit IPA
[ 0.286929] arm-smmu 12000000.iommu: Stage-2: 48-bit IPA → 48-bit PA
[ 0.297795] loop: module loaded
[ 0.298939] megasas: 07.717.02.00-rc1
[ 0.303213] tun: Universal TUN/TAP device driver, 1.6
[ 0.303795] thunder_xcv, ver 1.0
[ 0.303820] thunder_bgx, ver 1.0
[ 0.303835] nicpf, ver 1.0
[ 0.304727] hclge is initializing
[ 0.304758] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version
[ 0.304768] hns3: Copyright (c) 2017 Huawei Corporation.
[ 0.304810] e1000: Intel(R) PRO/1000 Network Driver
[ 0.304814] e1000: Copyright (c) 1999-2006 Intel Corporation.
[ 0.304843] e1000e: Intel(R) PRO/1000 Network Driver
[ 0.304846] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 0.304872] igb: Intel(R) Gigabit Ethernet Network Driver
[ 0.304877] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 0.304895] igbvf: Intel(R) Gigabit Virtual Function Network Driver
[ 0.304901] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 0.305116] sky2: driver version 1.30
[ 0.305796] VFIO - User Level meta-driver version: 0.3
[ 0.307334] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 0.307345] ehci-pci: EHCI PCI platform driver
[ 0.307378] ehci-platform: EHCI generic platform driver
[ 0.307453] ehci-orion: EHCI orion driver
[ 0.307530] ehci-exynos: EHCI Exynos driver
[ 0.307594] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 0.307621] ohci-pci: OHCI PCI platform driver
[ 0.307645] ohci-platform: OHCI generic platform driver
[ 0.307711] ohci-exynos: OHCI Exynos driver
[ 0.308180] usbcore: registered new interface driver usb-storage
[ 0.310006] i2c_dev: i2c /dev entries driver
[ 0.311371] pps pps0: new PPS source ktimer
[ 0.311380] pps pps0: ktimer PPS source registered
[ 0.311389] pps_ldisc: PPS line discipline registered
[ 0.313527] device-mapper: ioctl: 4.45.0-ioctl (2021-03-22) initialised: dm-devel@redhat.com
[ 0.315500] sdhci: Secure Digital Host Controller Interface driver
[ 0.315506] sdhci: Copyright(c) Pierre Ossman
[ 0.315963] Synopsys Designware Multimedia Card Interface Driver
[ 0.316607] sdhci-pltfm: SDHCI platform and OF driver helper
[ 0.317829] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.318788] SMCCC: SOC_ID: ID = jep106:036b:0234 Revision = 0x00000401
[ 0.319330] tegra-bpmp bpmp: Adding to iommu group 0
[ 0.320734] tegra-bpmp bpmp: firmware: 39f77b2baaf3f0522607-da583751bbf
[ 0.476310] Freeing initrd memory: 15488K
[ 3.679537] clocksource: tsc: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 3.679563] clocksource: osc: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 49772407460 ns
[ 3.679566] clocksource: usec: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns
[ 3.679815] hid: raw HID events driver (C) Jiri Kosina
[ 3.680268] usbcore: registered new interface driver usbhid
[ 3.680274] usbhid: USB HID core driver
[ 3.685296] optee: probing for conduit method.
[ 3.685344] optee: revision 4.2 (d78bc5fa)
[ 3.744711] optee: dynamic shared memory is enabled
[ 3.744988] optee: initialized driver
[ 3.747610] usbcore: registered new interface driver snd-usb-audio
[ 3.749306] NET: Registered PF_PACKET protocol family
[ 3.750389] Bluetooth: RFCOMM TTY layer initialized
[ 3.750400] Bluetooth: RFCOMM socket layer initialized
[ 3.750423] Bluetooth: RFCOMM ver 1.11
[ 3.750638] 9pnet: Installing 9P2000 support
[ 3.750745] Key type dns_resolver registered
[ 3.752141] printk: console [tty0]: printing thread started
[ 3.752789] printk: console [ttyTCU0]: printing thread started
[ 3.753899] printk: console [ttyAMA0]: printing thread started
[ 3.753991] Loading compiled-in X.509 certificates
[ 3.756752] Loaded X.509 cert ‘Build time autogenerated kernel key: 6057098974cb65317d873b1c27b0a3a1aaaa62bd’
[ 3.853429] gpio-394 (camera-control-output-low): hogged as output/low
[ 3.853452] gpio-397 (camera-control-output-low): hogged as output/low
[ 3.853473] gpio-487 (camera-control-output-low): hogged as output/low
[ 3.853490] gpio-486 (camera-control-output-low): hogged as output/low
[ 3.858484] tegra-gpcdma 2600000.dma-controller: Adding to iommu group 1
[ 3.860361] tegra-gpcdma 2600000.dma-controller: GPC DMA driver register 31 channels
[ 3.862051] serial-tegra 3100000.serial: RX in PIO mode
[ 3.862055] serial-tegra 3100000.serial: TX in PIO mode
[ 3.862168] 3100000.serial: ttyTHS1 at MMIO 0x3100000 (irq = 112, base_baud = 0) is a TEGRA_UART
[ 3.863182] serial-tegra 3110000.serial: RX in PIO mode
[ 3.863186] serial-tegra 3110000.serial: TX in PIO mode
[ 3.863215] 3110000.serial: ttyTHS2 at MMIO 0x3110000 (irq = 206, base_baud = 0) is a TEGRA_UART
[ 3.866012] tegra_rtc c2a0000.rtc: registered as rtc1
[ 3.866021] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 3.866429] tegra-i2c 3160000.i2c: Adding to iommu group 1
[ 3.873095] tegra-i2c 3180000.i2c: Adding to iommu group 1
[ 3.875801] tegra-i2c 3190000.i2c: Adding to iommu group 1
[ 3.880576] tegra-i2c 31b0000.i2c: Adding to iommu group 1
[ 3.886776] tegra-i2c 31c0000.i2c: Adding to iommu group 1
[ 3.891532] tegra-i2c 31e0000.i2c: Adding to iommu group 1
[ 3.895547] tegra-i2c c240000.i2c: Adding to iommu group 1
[ 3.901487] tegra-i2c c250000.i2c: Adding to iommu group 1
[ 3.933839] cpufreq: cpufreq_online: CPU4: Running at unlisted initial frequency: 2009000 KHz, changing to: 2035200 KHz
[ 3.936927] cpufreq: cpufreq_online: CPU8: Running at unlisted initial frequency: 2011000 KHz, changing to: 2035200 KHz
[ 3.940458] sdhci-tegra 3460000.mmc: Adding to iommu group 2
[ 3.941495] sdhci-tegra 3400000.mmc: Adding to iommu group 3
[ 3.942734] irq: IRQ233: trimming hierarchy from :bus@0:pmc@c360000
[ 3.942795] irq: IRQ234: trimming hierarchy from :bus@0:interrupt-controller@f400000-1
[ 3.942835] irq: IRQ235: trimming hierarchy from :bus@0:pmc@c360000
[ 3.942892] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[ 4.465019] ALSA device list:
[ 4.465025] No soundcards found.
[ 4.468947] mmc0: CQHCI version 5.10
[ 4.469316] sdhci-tegra 3400000.mmc: Got CD GPIO
[ 4.506257] mmc0: SDHCI controller on 3460000.mmc [3460000.mmc] using ADMA 64-bit
[ 4.519747] irq: IRQ236: trimming hierarchy from :bus@0:interrupt-controller@f400000-1
[ 4.520319] mmc1: SDHCI controller on 3400000.mmc [3400000.mmc] using ADMA 64-bit
[ 4.521439] Freeing unused kernel memory: 7680K
[ 4.521623] Run /init as init process
[ 4.532896] Checking overlayfs setting…
[ 4.544698] Overlayfs is disabled…
[ 4.551070] Root device found: mmcblk0p1
[ 4.616784] mmc0: Command Queue Engine enabled
[ 4.616790] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[ 4.617021] mmcblk0: mmc0:0001 G1M15M 59.3 GiB
[ 4.620624] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15
[ 4.621081] mmcblk0boot0: mmc0:0001 G1M15M 31.5 MiB
[ 4.621507] mmcblk0boot1: mmc0:0001 G1M15M 31.5 MiB
[ 4.621888] mmcblk0rpmb: mmc0:0001 G1M15M 4.00 MiB, chardev (511:0)
[ 7.622907] Found dev node: /dev/mmcblk0p1
[ 7.847189] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
[ 7.851860] Rootfs mounted over mmcblk0p1
[ 7.864212] Switching from initrd to actual rootfs
[ 7.984901] systemd[1]: System time before build time, advancing clock.
[ 8.024633] NET: Registered PF_INET6 protocol family
[ 8.025875] Segment Routing with IPv6
[ 8.025881] In-situ OAM (IOAM) with IPv6
[ 8.054746] systemd[1]: systemd 249.11-0ubuntu3.12 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT +GN)
[ 8.055124] systemd[1]: Detected architecture arm64.
[ 8.056668] systemd[1]: Hostname set to .
[ 8.103389] systemd[1]: Using hardware watchdog ‘NVIDIA Tegra186 WDT’, version 0, device /dev/watchdog
[ 8.103406] systemd[1]: Set hardware watchdog to 2min.
[ 8.345113] systemd[1]: /etc/systemd/system/nvs-service.service:41: Standard output type syslog is obsolete, automatically updating to jou.
[ 8.351381] systemd[1]: /etc/systemd/system/nvargus-daemon.service:42: Standard output type syslog is obsolete, automatically updating to .
[ 8.418728] systemd[1]: Queued start job for default target Graphical Interface.
[ 8.420108] systemd[1]: Created slice Slice /system/modprobe.
[ 8.420671] systemd[1]: Created slice Slice /system/serial-getty.
[ 8.442196] systemd[1]: Created slice Slice /system/systemd-fsck.
[ 8.442512] systemd[1]: Created slice User and Session Slice.
[ 8.442666] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 8.443004] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 8.443150] systemd[1]: Reached target Slice Units.
[ 8.443208] systemd[1]: Reached target Mounting snaps.
[ 8.443251] systemd[1]: Reached target Mounted snaps.
[ 8.443301] systemd[1]: Reached target Swaps.
[ 8.443354] systemd[1]: Reached target Local Verity Protected Volumes.
[ 8.449788] systemd[1]: Listening on RPCbind Server Activation Socket.
[ 8.499159] systemd[1]: Listening on Syslog Socket.
[ 8.518338] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 8.518457] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 8.518758] systemd[1]: Listening on Journal Audit Socket.
[ 8.518910] systemd[1]: Listening on Journal Socket (/dev/log).
[ 8.519108] systemd[1]: Listening on Journal Socket.
[ 8.519730] systemd[1]: Listening on udev Control Socket.
[ 8.519876] systemd[1]: Listening on udev Kernel Socket.
[ 8.520996] systemd[1]: Mounting Huge Pages File System…
[ 8.573331] systemd[1]: Mounting POSIX Message Queue File System…
[ 8.574450] systemd[1]: Mounting Kernel Debug File System…
[ 8.575636] systemd[1]: Mounting Kernel Trace File System…
[ 8.584686] systemd[1]: Starting Journal Service…
[ 8.603238] systemd[1]: Starting Set the console keyboard layout…
[ 8.605014] systemd[1]: Starting Create List of Static Device Nodes…
[ 8.619751] systemd[1]: Starting Load Kernel Module configfs…
[ 8.621184] systemd[1]: Starting Load Kernel Module drm…
[ 8.635019] systemd[1]: Starting Load Kernel Module efi_pstore…
[ 8.636534] systemd[1]: Starting Load Kernel Module fuse…
[ 8.648958] fuse: init (API version 7.34)
[ 8.650069] systemd[1]: Starting NVIDIA specific first-boot udev script…
[ 8.651296] systemd[1]: Started Nameserver information manager.
[ 8.651576] systemd[1]: Reached target Preparation for Network.
[ 8.651805] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[ 8.656779] systemd[1]: Starting Load Kernel Modules…
[ 8.667720] nvsciipc: loading out-of-tree module taints kernel.
[ 8.670204] nvsciipc: loaded module
[ 8.686376] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 8.686894] nvmap_co_device_init: vpr :dma coherent mem declare 0x0000001049800000,914358272
[ 8.686899] tegra-carveouts tegra-carveouts: assigned reserved memory node vpr-carveout
[ 8.686905] nvmap_page_pool_init: Total RAM pages: 16087255
[ 8.686907] nvmap_page_pool_init: nvmap page pool size: 2010906 pages (3759 MB)
[ 8.686961] nvmap_background_zero_thread: PP zeroing thread starting.
[ 8.686984] nvmap_heap_create: created heap vpr base 0x0000001049800000 size (892928KiB)
[ 8.687012] nvmap_heap_create: fsi :dma coherent mem declare 0x000000102f000000,16777216
[ 8.687015] nvmap_heap_create: created heap fsi base 0x000000102f000000 size (16384KiB)
[ 8.701912] systemd[1]: Starting Remount Root and Kernel File Systems…
[ 8.708117] tegra-host1x 13e00000.host1x: Adding to iommu group 4
[ 8.709272] host1x-context host1x-ctx.0: Adding to iommu group 5
[ 8.709320] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null). Quota mode: none.
[ 8.709410] host1x-context host1x-ctx.1: Adding to iommu group 6
[ 8.709529] host1x-context host1x-ctx.2: Adding to iommu group 7
[ 8.709647] host1x-context host1x-ctx.3: Adding to iommu group 8
[ 8.709764] host1x-context host1x-ctx.4: Adding to iommu group 9
[ 8.709880] host1x-context host1x-ctx.5: Adding to iommu group 10
[ 8.709991] host1x-context host1x-ctx.6: Adding to iommu group 11
[ 8.710111] host1x-context host1x-ctx.7: Adding to iommu group 12
[ 8.710235] host1x-context host1x-ctx.8: Adding to iommu group 13
[ 8.710356] host1x-context host1x-ctx.9: Adding to iommu group 14
[ 8.710468] host1x-context host1x-ctx.10: Adding to iommu group 15
[ 8.710588] host1x-context host1x-ctx.11: Adding to iommu group 16
[ 8.710710] host1x-context host1x-ctx.12: Adding to iommu group 17
[ 8.710828] host1x-context host1x-ctx.13: Adding to iommu group 18
[ 8.710946] host1x-context host1x-ctx.14: Adding to iommu group 19
[ 8.711062] host1x-context host1x-ctx.15: Adding to iommu group 20
[ 8.746834] systemd[1]: Starting Coldplug All udev Devices…
[ 8.786066] nvgpu: 17000000.gpu nvgpu_nvhost_syncpt_init:122 [INFO] syncpt_unit_base 60000000 syncpt_unit_size 4000000 size 1000
[ 8.786066]
[ 8.814783] systemd[1]: Started Journal Service.
[ 8.940866] systemd-journald[272]: Received client request to flush runtime journal.
��TCU debug prints will be routed to traces.
��[ 9.216110] tegra-ivc-bus bc00000.rtcpu:ivc-bus:echo@0: ivc channel driver missing
[ 9.216112] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@1: ivc channel driver missing
[ 9.216113] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@2: ivc channel driver missing
[ 9.216114] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccontrol@3: ivc channel driver missing
[ 9.216116] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccapture@4: ivc channel driver missing
[ 9.216117] tegra-ivc-bus bc00000.rtcpu:ivc-bus:diag@5: ivc channel driver missing
[ 9.392659] (NULL device *): fops function table already registered
[ 9.661460] ucsi_ccg 1-0008: i2c_transfer failed -121
[ 9.661469] ucsi_ccg 1-0008: ucsi_ccg_init failed - -121
[ 9.661476] ucsi_ccg: probe of 1-0008 failed with error -121
��Starting RmBootstrap
Registered event_type:[0] for dce_core_ipc_type:[1]
Registered event_type:[1] for dce_core_ipc_type:[3]
dce_ipc State Initialized
RmBootstrap completed successfully
��[ 13.071554] mdio_bus 6800000.ethernet: MDIO device at address 0 is missing.
[ 13.071572] nvethernet 6800000.ethernet: failed to connect PHY
[ 13.071583] net eno1: ether_open: Cannot attach to PHY (error: -19)
[ 16.249471] rt5640 8-001c: Device with ID register 0xffff0000 is not rt5640/39
Ubuntu 22.04.4 LTS astra-desktop ttyTCU0
astra-desktop login: astra
Password:
Is this a Orin AGX? You filed the topic in wrong forum.
yes, sorry i mistakenly sent.
I just moved it to correct forum.
Please refer to document to update device tree to match your hardware design.
https://docs.nvidia.com/jetson/archives/r36.4.3/DeveloperGuide/HR/JetsonModuleAdaptationAndBringUp/JetsonAgxOrinSeries.html?highlight=universal%20serial%20bus#porting-the-universal-serial-bus
mine BSP version is 36.4.0
It does not matter. The document applies to 36.4.0 too.
We followed the jetson orin agx dev kit schematic only.
we are using DTB file of dev-kit in custom board also.
We taken A10 and A11 pin of SOM module out and connected to USB female A type usb port.
Is there anything i am missing.
If you changed anything that has any difference from NV devkit, then you have to read above page and modify device tree.
There is no such “I only changed a little, could I not change device tree?”.
ok,this connector was used in APCI0534-P017H06.
instead of this i want to check USB2_2_N and USB2_2_p directly.
is it possible to check usb working with same dtb as dev-kit dtb
Once it works i will connect to USB7206CT-I/KDX (USB hub).
I don’t know what is wrong with the understanding here.
You won’t be possible to use NV dtb on your board directly. For example, do you have Cypress CCG in use on your custom board for type C port? I guess there is not. If so, you have to disable it in device tree .
this connector was used in APCI0534-P017H06 development kit.
But we are not using this instead we are connecting USB hub.
You better asking some colleagues to join to discuss. I don’t think your really understand the situation.
I saw you just keep looping the same unrelated items again and again. What you told about really not matter…
You need to disable some items in device tree becasue that thing does not exist on your board but only devkit. Could you understand this statement?
At the time of booting, the USB mouse is getting power-ON(getting red light), while loading DTB file, mouse light get off, i.e mouse not working.
we tried ls /sys/bus/usb/devices/ command, no usb folders are there.
so, is there any solution.
after this led getting off
astra@astra-desktop:~$ sudo su
[sudo] password for astra:
root@astra-desktop:/home/astra# dmesg | grep -i usb
[ 0.175800] usbcore: registered new interface driver usbfs
[ 0.175823] usbcore: registered new interface driver hub
[ 0.175840] usbcore: registered new device driver usb
[ 0.305650] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 0.305878] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 0.306436] usbcore: registered new interface driver usb-storage
[ 3.947644] usbcore: registered new interface driver usbhid
[ 3.947651] usbhid: USB HID core driver
[ 4.014600] usbcore: registered new interface driver snd-usb-audio
UEFI stage and kernel are using different drivers. Of course the driver behavior would be different.
You saw USB working in UEFI stage, so what? It does not matter to kernel.
If you just keep avoiding from reading document and modifying device tree, then no one can really help you here.
In tegra234-p3737-0000+p3701-0000.dts file, I have disabled
i2c@c240000 {
status = “disabled”;
ucsi-ccg@8 {
compatible = “cypress,cypd4226”;
cypress,firmware-build = “nvidia,jetson-agx-xavier”;
interrupt-parent = <&gpio>;
interrupts = <TEGRA234_MAIN_GPIO(Y, 4) IRQ_TYPE_LEVEL_LOW>;
reg = <0x08>;
#address-cells = <1>;
#size-cells = <0>;
			ccg_typec_con0: connector@0 {
				compatible = "usb-c-connector";
				reg = <0>;
				label = "USB-C";
				data-role = "host";
				#size-cells = <0>;
				port@0 {
					reg = <0>;
					hs_ucsi_ccg_p0: endpoint {
						remote-endpoint = <&hs_typec_p0>;
				port@1 {
					reg = <1>;
					ss_ucsi_ccg_p0: endpoint {
						remote-endpoint = <&ss_typec_p0>;
			ccg_typec_con1: connector@1 {
				reg = <1>;
				label = "USB-C";
				data-role = "dual";
				#size-cells = <0>;
				port@0 {
					reg = <0>;
					hs_ucsi_ccg_p1: endpoint {
						remote-endpoint = <&hs_typec_p1>;
				port@1 {
					reg = <1>;
					ss_ucsi_ccg_p1: endpoint {
						remote-endpoint = <&ss_typec_p1>;
because, we don’t have Cypress CCG in our custom board, but still I am unable to detect USB 2_0
Share your dmesg when you modify anything in the device tree.
Also, you better checking where did these remote endpoint go to.
I deleted the below code in dts file
i2c@c240000 {
ucsi-ccg@8 {
reg = <0x08>;
#size-cells = <0>;
				reg = <0>;
				label = "USB-C";
				data-role = "host";
				#size-cells = <0>;
				port@0 {
					reg = <0>;
				port@1 {
					reg = <1>;
				reg = <1>;
				label = "USB-C";
				data-role = "dual";
				#size-cells = <0>;
				port@0 {
					reg = <0>;
				port@1 {
					reg = <1>;
I will share the dmesg also in 5 min
remote-endpoint means it has another part which uses these nodes. You should modify that part too…
please attach it as a text file. It is terrible to copy and post such hundreds lines of log directly.
