To avoid exceeding the limit of characters, logs from the bottom:
Copy flash script to /tmp/jetson-builder/build/Linux_for_Tegra/tools/kernel_flash/images
'/tmp/jetson-builder/build/Linux_for_Tegra/tools/kernel_flash/l4t_flash_from_kernel.sh' -> '/tmp/jetson-builder/build/Linux_for_Tegra/tools/kernel_flash/images/l4t_flash_from_kernel.sh'
Success
* Step 2: Generate rcm boot commandline *
ROOTFS_AB= ROOTFS_ENC= /tmp/jetson-builder/build/Linux_for_Tegra/flash.sh --no-flash --rcm-boot jetson-orin-nano-devkit mmcblk0p1
# L4T BSP Information:
# R36 , REVISION: 2.0
# User release: 0.0
ECID is 0x80012344705DE7452C00000002FF01C0
copying emc_fuse_dev_params(/tmp/jetson-builder/build/Linux_for_Tegra/bootloader/generic/BCT/tegra234-br-bct-diag-boot.dts)... done.
copying device_config(/tmp/jetson-builder/build/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-device-p3767-0000.dts)... done.
copying misc_config(/tmp/jetson-builder/build/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-misc-p3767-0000.dts)... done.
./tegraflash.py --chip "0x23" --applet "/tmp/jetson-builder/build/Linux_for_Tegra/bootloader/mb1_t234_prod.bin" --skipuid --cfg readinfo_t234_min_prod.xml --dev_params tegra234-br-bct-diag-boot.dts --device_config tegra234-mb1-bct-device-p3767-0000.dts --misc_config tegra234-mb1-bct-misc-p3767-0000.dts --bins "mb2_applet applet_t234.bin" --cmd "dump eeprom cvm cvm.bin; dump try_custinfo custinfo_out.bin; reboot recovery"
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[ 0.0233 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[ 0.0236 ] File rcm_state open failed
[ 0.0240 ] ERROR: failed to read rcm_state
[ 0.0240 ]
[ 0.0306 ] tegrasign_v3.py --key None --getmode mode.txt
[ 0.0308 ] Assuming zero filled SBK key
[ 0.0242 ] Pre-processing config: tegra234-mb1-bct-device-p3767-0000.dts
[ 0.0366 ] Pre-processing config: tegra234-mb1-bct-misc-p3767-0000.dts
[ 0.0459 ] Parsing partition layout
[ 0.0463 ] tegraparser_v2 --pt readinfo_t234_min_prod.xml.tmp
[ 0.0478 ] Kernel DTB used: None
[ 0.0478 ] WARNING: dce base dtb is not provided
[ 0.0478 ] Parsing partition layout
[ 0.0483 ] tegraparser_v2 --pt readinfo_t234_min_prod.xml.tmp
[ 0.0486 ] Creating list of images to be signed
[ 0.0489 ] tegrahost_v2 --chip 0x23 0 --partitionlayout readinfo_t234_min_prod.xml.bin --list images_list.xml zerosbk
[ 0.0492 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[ 0.0502 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[ 0.0504 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[ 0.0534 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[ 0.0542 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[ 0.0579 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[ 0.0580 ] adding BCH for mb2_t234_aligned.bin
[ 0.0600 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[ 0.0697 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[ 0.0700 ] adding BCH for mb2_t234_aligned.bin
[ 0.0809 ] Filling MB1 storage info
[ 0.0809 ] Parsing dev params for multi chains
[ 0.0867 ] Generating br-bct
[ 0.0870 ] Updating dev and MSS params in BR BCT
[ 0.0870 ] tegrabct_v2 --dev_param tegra234-br-bct-diag-boot_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[ 0.0876 ] Updating bl info
[ 0.0878 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo readinfo_t234_min_prod.xml.bin
[ 0.0879 ] WARNING: boot chain is not completed. set to 0
[ 0.0885 ] Generating signatures
[ 0.0952 ] tegrasign_v3.py --key None --list images_list.xml --pubkeyhash pub_key.key --sha sha512
[ 0.0953 ] Assuming zero filled SBK key
[ 0.1040 ] Warning: pub_key.key is not found
[ 0.0976 ] Parsing dev params for multi chains
[ 0.0976 ] Generating br-bct
[ 0.0980 ] Updating dev and MSS params in BR BCT
[ 0.0980 ] tegrabct_v2 --dev_param tegra234-br-bct-diag-boot_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[ 0.0991 ] Updating bl info
[ 0.0993 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo readinfo_t234_min_prod.xml.bin --updatesig images_list_signed.xml
[ 0.0994 ] WARNING: boot chain is not completed. set to 0
[ 0.1000 ] Generating SHA2 Hash
[ 0.1076 ] Sha saved in br_bct_BR.sha
[ 0.1011 ] Get Signed section of bct
[ 0.1015 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --listbct bct_list.xml
[ 0.1022 ] Signing BCT
[ 0.1088 ] tegrasign_v3.py --key None --list bct_list.xml --pubkeyhash pub_key.key --sha sha512
[ 0.1089 ] Assuming zero filled SBK key
[ 0.1115 ] Sha saved in br_bct_BR.sha
[ 0.1116 ] Warning: pub_key.key is not found
[ 0.1050 ] Updating BCT with signature
[ 0.1055 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesig bct_list_signed.xml
[ 0.1060 ] Offset :4608 Len :3584
[ 0.1064 ] Generating SHA2 Hash
[ 0.1130 ] tegrasign_v3.py --key None --list bct_list.xml --sha sha512
[ 0.1131 ] Assuming zero filled SBK key
[ 0.1145 ] Sha saved in br_bct_BR.sha
[ 0.1080 ] Updating BCT with SHA2 Hash
[ 0.1082 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesha bct_list_signed.xml
[ 0.1084 ] Offset :4608 Len :3584
[ 0.1086 ] Offset :68 Len :8124
[ 0.1088 ] Generating coldboot mb1-bct
[ 0.1091 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct.cfg --misc tegra234-mb1-bct-misc-p3767-0000_cpp.dtb --device tegra234-mb1-bct-device-p3767-0000_cpp.dtb
[ 0.1093 ] MB1-BCT version: 0.13
[ 0.1106 ] Parsing config file :tegra234-mb1-bct-device-p3767-0000_cpp.dtb
[ 0.1107 ] Added Platform Config 9 data with size :- 100
[ 0.1107 ]
[ 0.1107 ] Updating mb1-bct with firmware information
[ 0.1111 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo readinfo_t234_min_prod.xml.bin
[ 0.1120 ] tegrahost_v2 --chip 0x23 0 --align mb1_cold_boot_bct_MB1_aligned.bct
[ 0.1124 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --appendsigheader mb1_cold_boot_bct_MB1_aligned.bct zerosbk
[ 0.1125 ] adding BCH for mb1_cold_boot_bct_MB1_aligned.bct
[ 0.1202 ] tegrasign_v3.py --key None --list mb1_cold_boot_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[ 0.1202 ] Assuming zero filled SBK key
[ 0.1213 ] Warning: pub_key.key is not found
[ 0.1150 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_cold_boot_bct_MB1_aligned_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_aligned_sigheader.bct.hash zerosbk
[ 0.1157 ] Generating recovery mb1-bct
[ 0.1159 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct.cfg --misc tegra234-mb1-bct-misc-p3767-0000_cpp.dtb --device tegra234-mb1-bct-device-p3767-0000_cpp.dtb
[ 0.1160 ] MB1-BCT version: 0.13
[ 0.1175 ] Parsing config file :tegra234-mb1-bct-device-p3767-0000_cpp.dtb
[ 0.1176 ] Added Platform Config 9 data with size :- 100
[ 0.1176 ]
[ 0.1176 ] Updating mb1-bct with firmware information
[ 0.1179 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct_MB1.bct --recov --updatefwinfo readinfo_t234_min_prod.xml.bin
[ 0.1187 ] tegrahost_v2 --chip 0x23 0 --align mb1_bct_MB1_aligned.bct
[ 0.1191 ] Generating SHA2 Hash for mb1bct
[ 0.1266 ] Sha saved in mb1_bct_MB1_aligned.sha
[ 0.1202 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --appendsigheader mb1_bct_MB1_aligned.bct zerosbk
[ 0.1203 ] adding BCH for mb1_bct_MB1_aligned.bct
[ 0.1277 ] tegrasign_v3.py --key None --list mb1_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[ 0.1278 ] Assuming zero filled SBK key
[ 0.1286 ] Warning: pub_key.key is not found
[ 0.1222 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_bct_MB1_aligned_sigheader.bct.encrypt mb1_bct_MB1_aligned_sigheader.bct.hash zerosbk
[ 0.1228 ] Error: Skip generating mem_bct because sdram_config is not defined
[ 0.1228 ] Copying signatures
[ 0.1230 ] tegrahost_v2 --chip 0x23 0 --partitionlayout readinfo_t234_min_prod.xml.bin --updatesig images_list_signed.xml
[ 0.1267 ] mb1_t234_prod_aligned_sigheader.bin.encrypt filename is from images_list
[ 0.1269 ] psc_bl1_t234_prod_aligned_sigheader.bin.encrypt filename is from images_list
[ 0.1269 ] Boot Rom communication
[ 0.1271 ] tegrarcm_v2 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
[ 0.1275 ] BR_CID: 0x80012344705DE7452C00000002FF01C0
[ 0.1544 ] Sending bct_br
[ 0.1974 ] Sending mb1
[ 0.1982 ] Sending psc_bl1
[ 0.2160 ] Sending bct_mb1
[ 0.2256 ] Boot Rom communication completed
[ 0.2265 ] tegrahost_v2 --chip 0x23 0 --align applet_t234_aligned.bin
[ 0.2273 ] tegrahost_v2 --chip 0x23 0 --magicid MB2A --appendsigheader applet_t234_aligned.bin zerosbk
[ 0.2276 ] adding BCH for applet_t234_aligned.bin
[ 0.2422 ] tegrasign_v3.py --key None --list applet_t234_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[ 0.2425 ] Assuming zero filled SBK key
[ 0.2441 ] Warning: pub_key.key is not found
[ 0.2379 ] tegrahost_v2 --chip 0x23 0 --updatesigheader applet_t234_aligned_sigheader.bin.encrypt applet_t234_aligned_sigheader.bin.hash zerosbk
[ 0.2397 ] Sending mb2_applet...
[ 0.2402 ] tegrarcm_v2 --chip 0x23 0 --pollbl --download applet applet_t234_sigheader.bin.encrypt
[ 0.2404 ] BL: version 1.4.0.1-t234-54845784-08e631ca last_boot_error: 0
[ 0.4507 ] Sending applet
[ 0.5567 ] completed
[ 0.5574 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[ 0.5579 ] MB2 Applet version 01.00.0000
[ 0.7428 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[ 0.7431 ] MB2 Applet version 01.00.0000
[ 0.7733 ] Retrieving board information
[ 0.7738 ] tegrarcm_v2 --chip 0x23 0 --oem platformdetails chip chip_info.bin
[ 0.7742 ] MB2 Applet version 01.00.0000
[ 0.8282 ] Saved platform info in chip_info.bin
[ 0.8340 ] Chip minor revision: 1
[ 0.8341 ] Bootrom revision: 0x7
[ 0.8341 ] Ram code: 0x2
[ 0.8342 ] Chip sku: 0xd5
[ 0.8342 ] Chip Sample: prod
[ 0.8352 ] Retrieving EEPROM data
[ 0.8352 ] tegrarcm_v2 --oem platformdetails eeprom cvm /tmp/jetson-builder/build/Linux_for_Tegra/bootloader/cvm.bin --chip 0x23 0
[ 0.8357 ] MB2 Applet version 01.00.0000
[ 0.8840 ] Saved platform info in /tmp/jetson-builder/build/Linux_for_Tegra/bootloader/cvm.bin
[ 0.9172 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[ 0.9175 ] MB2 Applet version 01.00.0000
[ 0.9480 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[ 0.9484 ] MB2 Applet version 01.00.0000
[ 0.9918 ] Dumping customer Info
[ 0.9926 ] tegrarcm_v2 --chip 0x23 0 --oem dump bct tmp.bct
[ 0.9928 ] MB2 Applet version 01.00.0000
[ 1.0400 ] Saved bct in tmp.bct
[ 1.0606 ] tegrabct_v2 --brbct tmp.bct --chip 0x23 0 --custinfo /tmp/jetson-builder/build/Linux_for_Tegra/bootloader/custinfo_out.bin
[ 1.0612 ] C[ 1.0616 ] ustomer data saved in /tmp/jetson-builder/build/Linux_for_Tegra/bootloader/custinfo_out.bin successfully
[ 1.0616 ] Rebooting to recovery mode
[ 1.0622 ] tegrarcm_v2 --chip 0x23 0 --ismb2
[ 1.0923 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[ 1.0926 ] MB2 Applet version 01.00.0000
[ 1.1401 ] Booting to recovery mode
[ 1.1406 ] tegrarcm_v2 --chip 0x23 0 --reboot recovery
[ 1.1410 ] MB2 Applet version 01.00.0000
Board ID(3767) version(300) sku(0005) revision(K.2)
Chip SKU(00:00:00:D5) ramcode(00:00:00:02) fuselevel(fuselevel_production) board_FAB(300)
emc_opt_disable_fuse:(0)
Copy /tmp/jetson-builder/build/Linux_for_Tegra/kernel/dtb/tegra234-p3768-0000+p3767-0005-nv.dtb to /tmp/jetson-builder/build/Linux_for_Tegra/kernel/dtb/tegra234-p3768-0000+p3767-0005-nv.dtb.rec
copying bctfile(/tmp/jetson-builder/build/Linux_for_Tegra/bootloader/generic/BCT/tegra234-p3767-0001-sdram-l4t.dts)... done.
copying minratchet_config(/tmp/jetson-builder/build/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-ratchet-p3767-0000.dts)... done.
copying pinmux_config(/tmp/jetson-builder/build/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-pinmux-p3767-dp-a03.dtsi)... done.
copying gpioint_config(/tmp/jetson-builder/build/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-gpioint-p3767-0000.dts)... done.
copying pmic_config(/tmp/jetson-builder/build/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-pmic-p3767-0000-a02.dts)... done.
copying pmc_config(/tmp/jetson-builder/build/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-padvoltage-p3767-dp-a03.dtsi)... done.
copying deviceprod_config(/tmp/jetson-builder/build/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-cprod-p3767-0000.dts)... done.
copying prod_config(/tmp/jetson-builder/build/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-prod-p3767-0000.dts)... done.
copying scr_config(/tmp/jetson-builder/build/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb2-bct-scr-p3767-0000.dts)... done.
copying wb0sdram(/tmp/jetson-builder/build/Linux_for_Tegra/bootloader/generic/BCT/tegra234-p3767-0001-wb0sdram-l4t.dts)... done.
copying bootrom_config(/tmp/jetson-builder/build/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-reset-p3767-0000.dts)... done.
Existing uphylane_config(/tmp/jetson-builder/build/Linux_for_Tegra/bootloader/tegra234-mb1-bct-uphylane-si.dtsi) reused.
copying dev_params(/tmp/jetson-builder/build/Linux_for_Tegra/bootloader/generic/BCT/tegra234-br-bct-p3767-0000-l4t.dts)... done.
copying dev_params_b(/tmp/jetson-builder/build/Linux_for_Tegra/bootloader/generic/BCT/tegra234-br-bct_b-p3767-0000-l4t.dts)... done.
copying mb2bct_cfg(/tmp/jetson-builder/build/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb2-bct-misc-p3767-0000.dts)... done.
Existing pscfwfile(/tmp/jetson-builder/build/Linux_for_Tegra/bootloader/pscfw_t234_prod.bin) reused.
Existing pscbl1file(/tmp/jetson-builder/build/Linux_for_Tegra/bootloader/psc_bl1_t234_prod.bin) reused.
Existing mtsmcefile(/tmp/jetson-builder/build/Linux_for_Tegra/bootloader/mce_flash_o10_cr_prod.bin) reused.
Existing tscfwfile(/tmp/jetson-builder/build/Linux_for_Tegra/bootloader/tsec_t234.bin) reused.
Existing mb2applet(/tmp/jetson-builder/build/Linux_for_Tegra/bootloader/applet_t234.bin) reused.
Existing bootloader(/tmp/jetson-builder/build/Linux_for_Tegra/bootloader/mb2_t234.bin) reused.
copying initrd(/tmp/jetson-builder/build/Linux_for_Tegra/rootfs/boot/initrd)... done.
bl is uefi
Making Boot image... done.
Not signing of boot.img
Making recovery ramdisk for recovery image...
Re-generating recovery ramdisk for recovery image...
/tmp/jetson-builder/build/Linux_for_Tegra/bootloader/ramdisk_tmp /tmp/jetson-builder/build/Linux_for_Tegra/bootloader /tmp/jetson-builder/build/Linux_for_Tegra
52057 blocks
gzip: /tmp/jetson-builder/build/Linux_for_Tegra/kernel/Image: not in gzip format
_BASE_KERNEL_VERSION=5.15.122-rt-tegra
cp: cannot stat '/tmp/jetson-builder/build/Linux_for_Tegra/rootfs/usr/sbin/sfdisk': No such file or directory
warning: cp -f /tmp/jetson-builder/build/Linux_for_Tegra/rootfs/usr/sbin/sfdisk /tmp/jetson-builder/build/Linux_for_Tegra/bootloader/ramdisk_tmp//bin/sfdisk
79521 blocks
Making Recovery image...
copying recdtbfile(/tmp/jetson-builder/build/Linux_for_Tegra/kernel/dtb/tegra234-p3768-0000+p3767-0005-nv.dtb.rec)... done.
20+0 records in
20+0 records out
20 bytes copied, 0,000162042 s, 123 kB/s
Existing sosfile(/tmp/jetson-builder/build/Linux_for_Tegra/bootloader/mb1_t234_prod.bin) reused.
Existing tegraboot(/tmp/jetson-builder/build/Linux_for_Tegra/bootloader/mb2_t234.bin) reused.
Existing cpu_bootloader(/tmp/jetson-builder/build/Linux_for_Tegra/bootloader/mb2_t234.bin) reused.
Existing mb2blfile(/tmp/jetson-builder/build/Linux_for_Tegra/bootloader/mb2_t234.bin) reused.
Existing xusbfile(/tmp/jetson-builder/build/Linux_for_Tegra/bootloader/xusb_t234_prod.bin) reused.
Existing pvafile(/tmp/jetson-builder/build/Linux_for_Tegra/bootloader/nvpva_020.fw) reused.
Existing dcefile(/tmp/jetson-builder/build/Linux_for_Tegra/bootloader/display-t234-dce.bin) reused.
Existing nvdecfile(/tmp/jetson-builder/build/Linux_for_Tegra/bootloader/nvdec_t234_prod.fw) reused.
Existing psc_rf(/tmp/jetson-builder/build/Linux_for_Tegra/bootloader/psc_rf_t234_prod.bin) reused.
Existing mb2_rf(/tmp/jetson-builder/build/Linux_for_Tegra/bootloader/mb2rf_t234.bin) reused.
Existing mb1file(/tmp/jetson-builder/build/Linux_for_Tegra/bootloader/mb1_t234_prod.bin) reused.
Existing bpffile(/tmp/jetson-builder/build/Linux_for_Tegra/bootloader/bpmp_t234-TE950M-A1_prod.bin) reused.
copying bpfdtbfile(/tmp/jetson-builder/build/Linux_for_Tegra/bootloader/generic/tegra234-bpmp-3767-0003-3509-a02.dtb)... done.
Existing camerafw(/tmp/jetson-builder/build/Linux_for_Tegra/bootloader/camera-rtcpu-t234-rce.img) reused.
Existing apefile(/tmp/jetson-builder/build/Linux_for_Tegra/bootloader/adsp-fw.bin) reused.
Existing spefile(/tmp/jetson-builder/build/Linux_for_Tegra/bootloader/spe_t234.bin) reused.
Existing wb0boot(/tmp/jetson-builder/build/Linux_for_Tegra/bootloader/sc7_t234_prod.bin) reused.
Existing tosfile(/tmp/jetson-builder/build/Linux_for_Tegra/bootloader/tos-optee_t234.img) reused.
Existing eksfile(/tmp/jetson-builder/build/Linux_for_Tegra/bootloader/eks_t234.img) reused.
copying dtbfile(/tmp/jetson-builder/build/Linux_for_Tegra/kernel/dtb/tegra234-p3768-0000+p3767-0005-nv.dtb)... done.
Copying nv_boot_control.conf to rootfs
Skip generating system.img
Not signing of kernel-dtb
Existing tbcfile(/tmp/jetson-builder/build/Linux_for_Tegra/bootloader/uefi_jetson.bin) reused.
131072+0 records in
131072+0 records out
67108864 bytes (67 MB, 64 MiB) copied, 0,148657 s, 451 MB/s
Sync'ing esp.img ... done.
copying tbcdtbfile(/tmp/jetson-builder/build/Linux_for_Tegra/kernel/dtb/tegra234-p3768-0000+p3767-0005-nv.dtb)... done.
copying cfgfile(/tmp/jetson-builder/build/Linux_for_Tegra/bootloader/generic/cfg/flash_t234_qspi_sd.xml) to flash.xml... done.
Existing flashapp(/tmp/jetson-builder/build/Linux_for_Tegra/bootloader/tegraflash.py) reused.
copying overlay_dtb(/tmp/jetson-builder/build/Linux_for_Tegra/kernel/dtb/L4TConfiguration.dtbo)... done.
copying overlay_dtb(/tmp/jetson-builder/build/Linux_for_Tegra/kernel/dtb/tegra234-carveouts.dtbo)... done.
copying overlay_dtb(/tmp/jetson-builder/build/Linux_for_Tegra/kernel/dtb/tegra-optee.dtbo)... done.
copying overlay_dtb(/tmp/jetson-builder/build/Linux_for_Tegra/kernel/dtb/tegra234-p3768-0000+p3767-0000-dynamic.dtbo)... done.
/tmp/jetson-builder/build/Linux_for_Tegra/bootloader/L4TConfiguration_updated.dts: Warning (unit_address_vs_reg): Node /fragment@0 has a unit name, but no reg property
/tmp/jetson-builder/build/Linux_for_Tegra/bootloader/L4TConfiguration.dtbo: Warning (unit_address_vs_reg): Node /fragment@0 has a unit name, but no reg property
./tegraflash.py --bl uefi_jetson_with_dtb.bin --concat_cpubl_bldtb --cpubl uefi_jetson.bin --sdram_config tegra234-p3767-0001-sdram-l4t.dts --cust_info custinfo_out.bin --odmdata gbe-uphy-config-8,hsstp-lane-map-3,hsio-uphy-config-0 --overlay_dtb L4TConfiguration.dtbo,tegra234-carveouts.dtbo,tegra-optee.dtbo,tegra234-p3768-0000+p3767-0000-dynamic.dtbo, --bldtb tegra234-p3768-0000+p3767-0005-nv.dtb --applet mb1_t234_prod.bin --cmd "sign" --cfg flash.xml --chip 0x23 --minratchet_config tegra234-mb1-bct-ratchet-p3767-0000.dts --device_config tegra234-mb1-bct-device-p3767-0000.dts --misc_config tegra234-mb1-bct-misc-p3767-0000.dts --pinmux_config tegra234-mb1-bct-pinmux-p3767-dp-a03.dtsi --gpioint_config tegra234-mb1-bct-gpioint-p3767-0000.dts --pmic_config tegra234-mb1-bct-pmic-p3767-0000-a02.dts --pmc_config tegra234-mb1-bct-padvoltage-p3767-dp-a03.dtsi --deviceprod_config tegra234-mb1-bct-cprod-p3767-0000.dts --prod_config tegra234-mb1-bct-prod-p3767-0000.dts --scr_config tegra234-mb2-bct-scr-p3767-0000.dts --wb0sdram_config tegra234-p3767-0001-wb0sdram-l4t.dts --br_cmd_config tegra234-mb1-bct-reset-p3767-0000.dts --uphy tegra234-mb1-bct-uphylane-si.dtsi --dev_params tegra234-br-bct-p3767-0000-l4t.dts,tegra234-br-bct_b-p3767-0000-l4t.dts --mb2bct_cfg tegra234-mb2-bct-misc-p3767-0000.dts --bins "psc_fw pscfw_t234_prod.bin; mts_mce mce_flash_o10_cr_prod.bin; tsec_fw tsec_t234.bin; mb2_applet applet_t234.bin; mb2_bootloader mb2_t234.bin; xusb_fw xusb_t234_prod.bin; pva_fw nvpva_020.fw; dce_fw display-t234-dce.bin; nvdec nvdec_t234_prod.fw; bpmp_fw bpmp_t234-TE950M-A1_prod.bin; bpmp_fw_dtb tegra234-bpmp-3767-0003-3509-a02.dtb; rce_fw camera-rtcpu-t234-rce.img; ape_fw adsp-fw.bin; spe_fw spe_t234.bin; tos tos-optee_t234.img; eks eks_t234.img; kernel boot.img; kernel_dtb tegra234-p3768-0000+p3767-0005-nv.dtb" --bct_backup
version 1.0.0
[ 0.0141 ] tegrasign_v3.py --key None --getmode mode.txt
[ 0.0142 ] Assuming zero filled SBK key
[ 0.0138 ] Parsing partition layout
[ 0.0143 ] tegraparser_v2 --pt flash.xml.tmp
[ 0.0186 ] Change tegra234-bpmp-3767-0003-3509-a02.dtb to tegra234-bpmp-3767-0003-3509-a02_with_odm.dtb
[ 0.0483 ] /usr/bin/python3 dtbcheck.py -c t234 -o tegra234-bpmp-3767-0003-3509-a02_with_odm.dtb tegra234-bpmp-3767-0003-3509-a02_with_odm_tmp.dtb
[ 0.2289 ] Concatenating L4TConfiguration.dtbo,tegra234-carveouts.dtbo,tegra-optee.dtbo,tegra234-p3768-0000+p3767-0000-dynamic.dtbo to tegra234-p3768-0000+p3767-0005-nv_with_odm_overlay.dtb.updated
[ 0.2290 ] Concatenating bl dtb to cpubl binary
[ 0.2314 ] MB2 binary: mb2_t234.bin
[ 0.2314 ] Pre-processing mb2bct config: tegra234-mb2-bct-misc-p3767-0000.dts
[ 0.2456 ] Pre-processing mb2bct config: tegra234-mb2-bct-scr-p3767-0000.dts
[ 0.5725 ] Generating coldboot mb2-bct
[ 0.5725 ] tegrabct_v2 --chip 0x23 0 --mb2bct mb2_cold_boot_bct.cfg --mb2bctcfg tegra234-mb2-bct-misc-p3767-0000_cpp.dtb --scr tegra234-mb2-bct-scr-p3767-0000_cpp.dtb
[ 0.5728 ] ERROR: value 0x31 is out of range
[ 0.5739 ] ERROR: value 0x31 is out of range
[ 0.5740 ] ERROR: value 0x31 is out of range
[ 0.5741 ] ERROR: value 0x31 is out of range
[ 0.5742 ] WARNING: unknown property 'tfc_version'
[ 0.5743 ] WARNING: unknown property 'addr_header_version'
[ 0.5831 ] Updating mb2-bct with storage information
[ 0.5836 ] tegrabct_v2 --chip 0x23 0 --mb2bct mb2_cold_boot_bct_MB2.bct --updatestorageinfo flash.xml.bin
[ 0.5847 ] Concatenating mb2-bct to mb2 binary
[ 0.5847 ] mb2_bin_file = mb2_t234.bin
[ 0.5847 ] mb2_bct_file = mb2_cold_boot_bct_MB2.bct
[ 0.5878 ] DCE binary: display-t234-dce.bin
[ 0.5879 ] Kernel DTB used: kernel_tegra234-p3768-0000+p3767-0005-nv.dtb
[ 0.5879 ] Concatenating kernel-dtb to dce-fw binary
[ 0.5879 ] dce_bin = display-t234-dce.bin
[ 0.5879 ] kernel_dtb = kernel_tegra234-p3768-0000+p3767-0005-nv.dtb
[ 0.5879 ] dce_with_dtb = display-t234-dce_with_kernel_tegra234-p3768-0000+p3767-0005-nv.bin
[ 0.5952 ] Update display-t234-dce_with_kernel_tegra234-p3768-0000+p3767-0005-nv.bin to dce_fw partitions
[ 0.5972 ] Parsing partition layout
[ 0.5976 ] tegraparser_v2 --pt flash.xml.tmp
[ 0.5988 ] Creating list of images to be signed
[ 0.5991 ] Generating ratchet blob
[ 0.5992 ] Pre-processing config: tegra234-mb1-bct-reset-p3767-0000.dts
[ 0.6051 ] Pre-processing config: tegra234-mb1-bct-device-p3767-0000.dts
[ 0.6112 ] Pre-processing config: tegra234-mb1-bct-cprod-p3767-0000.dts
[ 0.6174 ] Pre-processing config: tegra234-mb1-bct-gpioint-p3767-0000.dts
[ 0.6232 ] Pre-processing config: tegra234-mb1-bct-misc-p3767-0000.dts
[ 0.6315 ] Pre-processing config: tegra234-mb1-bct-pinmux-p3767-dp-a03.dtsi
[ 0.6433 ] Pre-processing config: tegra234-mb1-bct-padvoltage-p3767-dp-a03.dtsi
[ 0.6490 ] Pre-processing config: tegra234-mb1-bct-pmic-p3767-0000-a02.dts
[ 0.6551 ] Pre-processing config: tegra234-mb1-bct-prod-p3767-0000.dts
[ 0.6617 ] Pre-processing config: tegra234-p3767-0001-sdram-l4t.dts
[ 1.3869 ] Pre-processing config: tegra234-mb1-bct-uphylane-si.dtsi
[ 1.3930 ] Pre-processing config: tegra234-p3767-0001-wb0sdram-l4t.dts
[ 2.1197 ] Pre-processing config: tegra234-mb1-bct-ratchet-p3767-0000.dts
[ 2.1265 ] Generating coldboot mb1-bct
[ 2.1270 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct.cfg --misc tegra234-mb1-bct-misc-p3767-0000_cpp.dtb --wb0sdram tegra234-p3767-0001-wb0sdram-l4t_cpp.dtb --pinmux tegra234-mb1-bct-pinmux-p3767-dp-a03_cpp.dtb --pmc tegra234-mb1-bct-padvoltage-p3767-dp-a03_cpp.dtb --pmic tegra234-mb1-bct-pmic-p3767-0000-a02_cpp.dtb --brcommand tegra234-mb1-bct-reset-p3767-0000_cpp.dtb --prod tegra234-mb1-bct-prod-p3767-0000_cpp.dtb --gpioint tegra234-mb1-bct-gpioint-p3767-0000_cpp.dtb --uphy tegra234-mb1-bct-uphylane-si_cpp.dtb --device tegra234-mb1-bct-device-p3767-0000_cpp.dtb --deviceprod tegra234-mb1-bct-cprod-p3767-0000_cpp.dtb --minratchet tegra234-mb1-bct-ratchet-p3767-0000_cpp.dtb --ratchet_blob ratchet_blob.bin
[ 2.1274 ] MB1-BCT version: 0.13
[ 2.1287 ] Parsing config file :tegra234-mb1-bct-pinmux-p3767-dp-a03_cpp.dtb
[ 2.1288 ] Added Platform Config 0 data with size :- 2416
[ 2.1306 ] Parsing config file :tegra234-mb1-bct-padvoltage-p3767-dp-a03_cpp.dtb
[ 2.1310 ] WARNING: unknown node 'g2'
[ 2.1310 ] WARNING: unknown node 'g9'
[ 2.1310 ] Added Platform Config 2 data with size :- 24
[ 2.1310 ]
[ 2.1310 ] Parsing config file :tegra234-mb1-bct-pmic-p3767-0000-a02_cpp.dtb
[ 2.1310 ] Added Platform Config 4 data with size :- 288
[ 2.1310 ]
[ 2.1310 ] Parsing config file :tegra234-mb1-bct-reset-p3767-0000_cpp.dtb
[ 2.1310 ] Added Platform Config 3 data with size :- 52
[ 2.1310 ]
[ 2.1310 ] Parsing config file :tegra234-mb1-bct-prod-p3767-0000_cpp.dtb
[ 2.1310 ] WARNING: unknown property 'major'
[ 2.1310 ] WARNING: unknown property 'minor'
[ 2.1310 ] Added Platform Config 5 data with size :- 512
[ 2.1310 ]
[ 2.1310 ] Parsing config file :tegra234-mb1-bct-gpioint-p3767-0000_cpp.dtb
[ 2.1311 ] WARNING: unknown property 'major'
[ 2.1311 ] WARNING: unknown property 'minor'
[ 2.1311 ] Added Platform Config 7 data with size :- 380
[ 2.1311 ]
[ 2.1311 ] Parsing config file :tegra234-mb1-bct-uphylane-si_cpp.dtb
[ 2.1311 ] Added Platform Config 8 data with size :- 24
[ 2.1311 ]
[ 2.1311 ] Parsing config file :tegra234-mb1-bct-device-p3767-0000_cpp.dtb
[ 2.1311 ] Added Platform Config 9 data with size :- 100
[ 2.1311 ]
[ 2.1311 ] Parsing config file :tegra234-mb1-bct-cprod-p3767-0000_cpp.dtb
[ 2.1311 ] ModuleCount 0 NumProdNames 0
[ 2.1311 ] Added Platform Config 6 data with size :- 16
[ 2.1311 ]
[ 2.1311 ] Parsing config file :tegra234-mb1-bct-ratchet-p3767-0000_cpp.dtb
[ 2.1311 ] ERROR: /ratchet/atf is not supported
[ 2.1311 ]
[ 2.1311 ] Updating mb1-bct with firmware information
[ 2.1315 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo flash.xml.bin
[ 2.1329 ] tegrahost_v2 --chip 0x23 0 --align mb1_cold_boot_bct_MB1_aligned.bct
[ 2.1339 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --ratchet_blob ratchet_blob.bin --appendsigheader mb1_cold_boot_bct_MB1_aligned.bct zerosbk
[ 2.1342 ] adding BCH for mb1_cold_boot_bct_MB1_aligned.bct
[ 2.1356 ] tegrasign_v3.py --key None --list mb1_cold_boot_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[ 2.1357 ] Assuming zero filled SBK key
[ 2.1366 ] Warning: pub_key.key is not found
[ 2.1365 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_cold_boot_bct_MB1_aligned_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_aligned_sigheader.bct.hash zerosbk
[ 2.1373 ] tegrahost_v2 --chip 0x23 0 --partitionlayout flash.xml.bin --ratchet_blob ratchet_blob.bin --list images_list.xml zerosbk
[ 2.1377 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[ 2.1388 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[ 2.1390 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[ 2.1425 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[ 2.1428 ] Header already present for tsec_t234_aligned.bin
[ 2.1447 ] Header already present for nvdec_t234_prod_aligned.fw
[ 2.1471 ] adding BCH for mb2_t234_with_mb2_cold_boot_bct_MB2_aligned.bin
[ 2.1514 ] adding BCH for xusb_t234_prod_aligned.bin
[ 2.1613 ] Header already present for bpmp_t234-TE950M-A1_prod_aligned.bin
[ 2.1667 ] adding BCH for tegra234-bpmp-3767-0003-3509-a02_with_odm_aligned.dtb
[ 2.1779 ] Header already present for pscfw_t234_prod_aligned.bin
[ 2.1829 ] Header already present for mce_flash_o10_cr_prod_aligned.bin
[ 2.1865 ] Header already present for sc7_t234_prod.bin
[ 2.1886 ] Header already present for psc_rf_t234_prod_aligned.bin
[ 2.1911 ] adding BCH for mb2rf_t234_aligned.bin
[ 2.1923 ] adding BCH for uefi_jetson_with_dtb_aligned.bin
[ 2.2008 ] adding BCH for tos-optee_t234_aligned.img
[ 2.2766 ] adding BCH for eks_t234_aligned.img
[ 2.3061 ] INFO: compressing display-t234-dce_with_kernel_tegra234-p3768-0000+p3767-0005-nv_aligned.bin
[ 2.4515 ] INFO: complete compression, display-t234-dce_with_kernel_tegra234-p3768-0000+p3767-0005-nv_aligned.bin, ratio = 6%
[ 2.4674 ] adding BCH for display-t234-dce_with_kernel_tegra234-p3768-0000+p3767-0005-nv_aligned_blob_w_bin_aligned.bin
[ 2.4824 ] adding BCH for spe_t234_aligned.bin
[ 2.4910 ] adding BCH for camera-rtcpu-t234-rce_aligned.img
[ 2.4974 ] adding BCH for adsp-fw_aligned.bin
[ 2.5077 ] INFO: compressing nvpva_020_aligned.fw
[ 2.5433 ] INFO: complete compression, nvpva_020_aligned.fw, ratio = 2%
[ 2.5457 ] adding BCH for nvpva_020_aligned_blob_w_bin_aligned.fw
[ 2.5471 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[ 2.5484 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[ 2.5487 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[ 2.5523 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[ 2.5526 ] Header already present for tsec_t234_aligned.bin
[ 2.5540 ] Header already present for nvdec_t234_prod_aligned.fw
[ 2.5566 ] adding BCH for mb2_t234_with_mb2_cold_boot_bct_MB2_aligned.bin
[ 2.5609 ] adding BCH for xusb_t234_prod_aligned.bin
[ 2.5710 ] Header already present for bpmp_t234-TE950M-A1_prod_aligned.bin
[ 2.5768 ] adding BCH for tegra234-bpmp-3767-0003-3509-a02_with_odm_aligned.dtb
[ 2.5887 ] Header already present for pscfw_t234_prod_aligned.bin
[ 2.5932 ] Header already present for mce_flash_o10_cr_prod_aligned.bin
[ 2.5965 ] Header already present for sc7_t234_prod.bin
[ 2.5992 ] Header already present for psc_rf_t234_prod_aligned.bin
[ 2.6014 ] adding BCH for mb2rf_t234_aligned.bin
[ 2.6035 ] adding BCH for uefi_jetson_with_dtb_aligned.bin
[ 2.6133 ] adding BCH for tos-optee_t234_aligned.img
[ 2.6913 ] adding BCH for eks_t234_aligned.img
[ 2.7203 ] INFO: compressing display-t234-dce_with_kernel_tegra234-p3768-0000+p3767-0005-nv_aligned.bin
[ 2.8658 ] INFO: complete compression, display-t234-dce_with_kernel_tegra234-p3768-0000+p3767-0005-nv_aligned.bin, ratio = 6%
[ 2.8832 ] adding BCH for display-t234-dce_with_kernel_tegra234-p3768-0000+p3767-0005-nv_aligned_blob_w_bin_aligned.bin
[ 2.8977 ] adding BCH for spe_t234_aligned.bin
[ 2.9059 ] adding BCH for camera-rtcpu-t234-rce_aligned.img
[ 2.9127 ] adding BCH for adsp-fw_aligned.bin
[ 2.9230 ] INFO: compressing nvpva_020_aligned.fw
[ 2.9573 ] INFO: complete compression, nvpva_020_aligned.fw, ratio = 2%
[ 2.9606 ] adding BCH for nvpva_020_aligned_blob_w_bin_aligned.fw
[ 2.9623 ] Filling MB1 storage info
[ 2.9623 ] Parsing dev params for multi chains
[ 2.9704 ] Generating br-bct
[ 2.9708 ] Updating dev and MSS params in BR BCT
[ 2.9709 ] tegrabct_v2 --dev_param tegra234-br-bct-p3767-0000-l4t_cpp.dtb --sdram tegra234-p3767-0001-sdram-l4t_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[ 3.0382 ] Updating bl info
[ 3.0389 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo flash.xml.bin
[ 3.0452 ] Generating br-bct
[ 3.0456 ] Updating dev and MSS params in BR BCT
[ 3.0456 ] tegrabct_v2 --dev_param tegra234-br-bct_b-p3767-0000-l4t_cpp.dtb --sdram tegra234-p3767-0001-sdram-l4t_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[ 3.1132 ] Updating bl info
[ 3.1139 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo flash.xml.bin
[ 3.1154 ] Generating BCT backup image
[ 3.1155 ] dd if=/dev/zero of=bct_backup.img bs=1 count=32768
[ 3.1164 ] 32768+0 records in
[ 3.1490 ] 32768+0 records out
[ 3.1490 ] 32768 bytes (33 kB, 32 KiB) copied, 0,031709 s, 1,0 MB/s
[ 3.1490 ]
[ 3.1491 ] Concatenating BCT for chain A to bct_backup.img
[ 3.1491 ] dd if=br_bct_BR.bct of=bct_backup.img bs=1 seek=0 conv=notrunc
[ 3.1496 ] 8192+0 records in
[ 3.1542 ] 8192+0 records out
[ 3.1542 ] 8192 bytes (8,2 kB, 8,0 KiB) copied, 0,00413234 s, 2,0 MB/s
[ 3.1542 ]
[ 3.1542 ] Concatenating BCT for chain B to bct_backup.img
[ 3.1542 ] dd if=br_bct_b_BR.bct of=bct_backup.img bs=1 seek=16384 conv=notrunc
[ 3.1548 ] 8192+0 records in
[ 3.1608 ] 8192+0 records out
[ 3.1608 ] 8192 bytes (8,2 kB, 8,0 KiB) copied, 0,00558255 s, 1,5 MB/s
[ 3.1608 ]
[ 3.1608 ] Generating signatures
[ 3.1614 ] tegrasign_v3.py --key None --list images_list.xml --pubkeyhash pub_key.key --sha sha512
[ 3.1616 ] Assuming zero filled SBK key
[ 3.2366 ] Warning: pub_key.key is not found
[ 3.2388 ] Parsing dev params for multi chains
[ 3.2388 ] Generating br-bct
[ 3.2392 ] Updating dev and MSS params in BR BCT
[ 3.2392 ] tegrabct_v2 --dev_param tegra234-br-bct-p3767-0000-l4t_cpp.dtb --sdram tegra234-p3767-0001-sdram-l4t_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[ 3.3152 ] Updating customer data section
[ 3.3162 ] tegrabct_v2 --chip 0x23 0 --brbct br_bct_BR.bct --update_custinfo custinfo_out.bin
[ 3.3170 ] Updating bl info
[ 3.3172 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
[ 3.3188 ] Generating SHA2 Hash
[ 3.3208 ] Sha saved in br_bct_BR.sha
[ 3.3204 ] Get Signed section of bct
[ 3.3206 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --listbct bct_list.xml
[ 3.3209 ] Signing BCT
[ 3.3214 ] tegrasign_v3.py --key None --list bct_list.xml --pubkeyhash pub_key.key --sha sha512
[ 3.3215 ] Assuming zero filled SBK key
[ 3.3243 ] Sha saved in br_bct_BR.sha
[ 3.3245 ] Warning: pub_key.key is not found
[ 3.3241 ] Updating BCT with signature
[ 3.3244 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesig bct_list_signed.xml
[ 3.3246 ] Offset :4608 Len :3584
[ 3.3251 ] Generating SHA2 Hash
[ 3.3256 ] tegrasign_v3.py --key None --list bct_list.xml --sha sha512
[ 3.3257 ] Assuming zero filled SBK key
[ 3.3281 ] Sha saved in br_bct_BR.sha
[ 3.3278 ] Updating BCT with SHA2 Hash
[ 3.3282 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesha bct_list_signed.xml
[ 3.3284 ] Offset :4608 Len :3584
[ 3.3291 ] Offset :68 Len :8124
[ 3.3293 ] Generating br-bct
[ 3.3295 ] Updating dev and MSS params in BR BCT
[ 3.3296 ] tegrabct_v2 --dev_param tegra234-br-bct_b-p3767-0000-l4t_cpp.dtb --sdram tegra234-p3767-0001-sdram-l4t_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[ 3.4034 ] Updating customer data section
[ 3.4039 ] tegrabct_v2 --chip 0x23 0 --brbct br_bct_BR.bct --update_custinfo custinfo_out.bin
[ 3.4047 ] Updating bl info
[ 3.4051 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
[ 3.4072 ] Generating SHA2 Hash
[ 3.4084 ] Sha saved in br_bct_BR.sha
[ 3.4080 ] Get Signed section of bct
[ 3.4083 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --listbct bct_list.xml
[ 3.4095 ] Signing BCT
[ 3.4100 ] tegrasign_v3.py --key None --list bct_list.xml --pubkeyhash pub_key.key --sha sha512
[ 3.4101 ] Assuming zero filled SBK key
[ 3.4128 ] Sha saved in br_bct_BR.sha
[ 3.4129 ] Warning: pub_key.key is not found
[ 3.4125 ] Updating BCT with signature
[ 3.4127 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesig bct_list_signed.xml
[ 3.4128 ] Offset :4608 Len :3584
[ 3.4132 ] Generating SHA2 Hash
[ 3.4137 ] tegrasign_v3.py --key None --list bct_list.xml --sha sha512
[ 3.4138 ] Assuming zero filled SBK key
[ 3.4162 ] Sha saved in br_bct_BR.sha
[ 3.4159 ] Updating BCT with SHA2 Hash
[ 3.4161 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesha bct_list_signed.xml
[ 3.4163 ] Offset :4608 Len :3584
[ 3.4168 ] Offset :68 Len :8124
[ 3.4170 ] Generating BCT backup image
[ 3.4170 ] dd if=/dev/zero of=bct_backup.img bs=1 count=32768
[ 3.4174 ] 32768+0 records in
[ 3.4504 ] 32768+0 records out
[ 3.4504 ] 32768 bytes (33 kB, 32 KiB) copied, 0,0323611 s, 1,0 MB/s
[ 3.4504 ]
[ 3.4504 ] Concatenating BCT for chain A to bct_backup.img
[ 3.4504 ] dd if=br_bct_BR.bct of=bct_backup.img bs=1 seek=0 conv=notrunc
[ 3.4511 ] 8192+0 records in
[ 3.4559 ] 8192+0 records out
[ 3.4559 ] 8192 bytes (8,2 kB, 8,0 KiB) copied, 0,00424795 s, 1,9 MB/s
[ 3.4559 ]
[ 3.4560 ] Concatenating BCT for chain B to bct_backup.img
[ 3.4560 ] dd if=br_bct_b_BR.bct of=bct_backup.img bs=1 seek=16384 conv=notrunc
[ 3.4564 ] 8192+0 records in
[ 3.4624 ] 8192+0 records out
[ 3.4624 ] 8192 bytes (8,2 kB, 8,0 KiB) copied, 0,0054352 s, 1,5 MB/s
[ 3.4624 ]
[ 3.4624 ] Generating coldboot mb1-bct
[ 3.4629 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct.cfg --misc tegra234-mb1-bct-misc-p3767-0000_cpp.dtb --wb0sdram tegra234-p3767-0001-wb0sdram-l4t_cpp.dtb --pinmux tegra234-mb1-bct-pinmux-p3767-dp-a03_cpp.dtb --pmc tegra234-mb1-bct-padvoltage-p3767-dp-a03_cpp.dtb --pmic tegra234-mb1-bct-pmic-p3767-0000-a02_cpp.dtb --brcommand tegra234-mb1-bct-reset-p3767-0000_cpp.dtb --prod tegra234-mb1-bct-prod-p3767-0000_cpp.dtb --gpioint tegra234-mb1-bct-gpioint-p3767-0000_cpp.dtb --uphy tegra234-mb1-bct-uphylane-si_cpp.dtb --device tegra234-mb1-bct-device-p3767-0000_cpp.dtb --deviceprod tegra234-mb1-bct-cprod-p3767-0000_cpp.dtb --minratchet tegra234-mb1-bct-ratchet-p3767-0000_cpp.dtb --ratchet_blob ratchet_blob.bin
[ 3.4633 ] MB1-BCT version: 0.13
[ 3.4649 ] Parsing config file :tegra234-mb1-bct-pinmux-p3767-dp-a03_cpp.dtb
[ 3.4656 ] Added Platform Config 0 data with size :- 2416
[ 3.4674 ] Parsing config file :tegra234-mb1-bct-padvoltage-p3767-dp-a03_cpp.dtb
[ 3.4676 ] WARNING: unknown node 'g2'
[ 3.4677 ] WARNING: unknown node 'g2'
[ 3.4677 ] WARNING: unknown node 'g9'
[ 3.4677 ] Added Platform Config 2 data with size :- 24
[ 3.4677 ]
[ 3.4677 ] Parsing config file :tegra234-mb1-bct-pmic-p3767-0000-a02_cpp.dtb
[ 3.4677 ] Added Platform Config 4 data with size :- 288
[ 3.4677 ]
[ 3.4677 ] Parsing config file :tegra234-mb1-bct-reset-p3767-0000_cpp.dtb
[ 3.4677 ] Added Platform Config 3 data with size :- 52
[ 3.4677 ]
[ 3.4677 ] Parsing config file :tegra234-mb1-bct-prod-p3767-0000_cpp.dtb
[ 3.4677 ] WARNING: unknown property 'major'
[ 3.4677 ] WARNING: unknown property 'minor'
[ 3.4677 ] Added Platform Config 5 data with size :- 512
[ 3.4677 ]
[ 3.4677 ] Parsing config file :tegra234-mb1-bct-gpioint-p3767-0000_cpp.dtb
[ 3.4677 ] Added Platform Config 7 data with size :- 380
[ 3.4677 ]
[ 3.4677 ] Parsing config file :tegra234-mb1-bct-uphylane-si_cpp.dtb
[ 3.4677 ] Added Platform Config 8 data with size :- 24
[ 3.4677 ]
[ 3.4677 ] Parsing config file :tegra234-mb1-bct-device-p3767-0000_cpp.dtb
[ 3.4677 ] Added Platform Config 9 data with size :- 100
[ 3.4677 ]
[ 3.4677 ] Parsing config file :tegra234-mb1-bct-cprod-p3767-0000_cpp.dtb
[ 3.4678 ] ModuleCount 0 NumProdNames 0
[ 3.4678 ] Added Platform Config 6 data with size :- 16
[ 3.4678 ]
[ 3.4678 ] Parsing config file :tegra234-mb1-bct-ratchet-p3767-0000_cpp.dtb
[ 3.4678 ] ERROR: /ratchet/atf is not supported
[ 3.4678 ]
[ 3.4678 ] Updating mb1-bct with firmware information
[ 3.4680 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo flash.xml.bin
[ 3.4689 ] tegrahost_v2 --chip 0x23 0 --align mb1_cold_boot_bct_MB1_aligned.bct
[ 3.4700 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --ratchet_blob ratchet_blob.bin --appendsigheader mb1_cold_boot_bct_MB1_aligned.bct zerosbk
[ 3.4703 ] adding BCH for mb1_cold_boot_bct_MB1_aligned.bct
[ 3.4716 ] tegrasign_v3.py --key None --list mb1_cold_boot_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[ 3.4717 ] Assuming zero filled SBK key
[ 3.4731 ] Warning: pub_key.key is not found
[ 3.4732 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_cold_boot_bct_MB1_aligned_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_aligned_sigheader.bct.hash zerosbk
[ 3.4740 ] Generating recovery mb1-bct
[ 3.4744 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct.cfg --misc tegra234-mb1-bct-misc-p3767-0000_cpp.dtb --wb0sdram tegra234-p3767-0001-wb0sdram-l4t_cpp.dtb --pinmux tegra234-mb1-bct-pinmux-p3767-dp-a03_cpp.dtb --pmc tegra234-mb1-bct-padvoltage-p3767-dp-a03_cpp.dtb --pmic tegra234-mb1-bct-pmic-p3767-0000-a02_cpp.dtb --brcommand tegra234-mb1-bct-reset-p3767-0000_cpp.dtb --prod tegra234-mb1-bct-prod-p3767-0000_cpp.dtb --gpioint tegra234-mb1-bct-gpioint-p3767-0000_cpp.dtb --uphy tegra234-mb1-bct-uphylane-si_cpp.dtb --device tegra234-mb1-bct-device-p3767-0000_cpp.dtb --deviceprod tegra234-mb1-bct-cprod-p3767-0000_cpp.dtb --minratchet tegra234-mb1-bct-ratchet-p3767-0000_cpp.dtb --ratchet_blob ratchet_blob.bin
[ 3.4746 ] MB1-BCT version: 0.13
[ 3.4762 ] Parsing config file :tegra234-mb1-bct-pinmux-p3767-dp-a03_cpp.dtb
[ 3.4764 ] Added Platform Config 0 data with size :- 2416
[ 3.4789 ] Parsing config file :tegra234-mb1-bct-padvoltage-p3767-dp-a03_cpp.dtb
[ 3.4793 ] WARNING: unknown node 'g2'
[ 3.4793 ] WARNING: unknown node 'g9'
[ 3.4793 ] Added Platform Config 2 data with size :- 24
[ 3.4793 ]
[ 3.4793 ] Parsing config file :tegra234-mb1-bct-pmic-p3767-0000-a02_cpp.dtb
[ 3.4793 ] Added Platform Config 4 data with size :- 288
[ 3.4793 ]
[ 3.4793 ] Parsing config file :tegra234-mb1-bct-reset-p3767-0000_cpp.dtb
[ 3.4793 ] Added Platform Config 3 data with size :- 52
[ 3.4793 ]
[ 3.4794 ] Parsing config file :tegra234-mb1-bct-prod-p3767-0000_cpp.dtb
[ 3.4794 ] WARNING: unknown property 'major'
[ 3.4794 ] WARNING: unknown property 'minor'
[ 3.4794 ] Added Platform Config 5 data with size :- 512
[ 3.4794 ]
[ 3.4794 ] Parsing config file :tegra234-mb1-bct-gpioint-p3767-0000_cpp.dtb
[ 3.4794 ] Added Platform Config 7 data with size :- 380
[ 3.4794 ]
[ 3.4794 ] Parsing config file :tegra234-mb1-bct-uphylane-si_cpp.dtb
[ 3.4794 ] Added Platform Config 8 data with size :- 24
[ 3.4794 ]
[ 3.4794 ] Parsing config file :tegra234-mb1-bct-device-p3767-0000_cpp.dtb
[ 3.4794 ] Added Platform Config 9 data with size :- 100
[ 3.4794 ]
[ 3.4794 ] Parsing config file :tegra234-mb1-bct-cprod-p3767-0000_cpp.dtb
[ 3.4794 ] ModuleCount 0 NumProdNames 0
[ 3.4795 ] Added Platform Config 6 data with size :- 16
[ 3.4795 ]
[ 3.4795 ] Parsing config file :tegra234-mb1-bct-ratchet-p3767-0000_cpp.dtb
[ 3.4795 ] ERROR: /ratchet/atf is not supported
[ 3.4795 ]
[ 3.4795 ] Updating mb1-bct with firmware information
[ 3.4800 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct_MB1.bct --recov --updatefwinfo flash.xml.bin
[ 3.4806 ] tegrahost_v2 --chip 0x23 0 --align mb1_bct_MB1_aligned.bct
[ 3.4809 ] Generating SHA2 Hash for mb1bct
[ 3.4822 ] Sha saved in mb1_bct_MB1_aligned.sha
[ 3.4820 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --ratchet_blob ratchet_blob.bin --appendsigheader mb1_bct_MB1_aligned.bct zerosbk
[ 3.4823 ] adding BCH for mb1_bct_MB1_aligned.bct
[ 3.4835 ] tegrasign_v3.py --key None --list mb1_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[ 3.4835 ] Assuming zero filled SBK key
[ 3.4843 ] Warning: pub_key.key is not found
[ 3.4841 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_bct_MB1_aligned_sigheader.bct.encrypt mb1_bct_MB1_aligned_sigheader.bct.hash zerosbk
[ 3.4845 ] Generating coldboot mem-bct
[ 3.4847 ] tegrabct_v2 --chip 0x23 0 --sdram tegra234-p3767-0001-sdram-l4t_cpp.dtb --wb0sdram tegra234-p3767-0001-wb0sdram-l4t_cpp.dtb --membct tegra234-p3767-0001-sdram-l4t_cpp_1.bct tegra234-p3767-0001-sdram-l4t_cpp_2.bct tegra234-p3767-0001-sdram-l4t_cpp_3.bct tegra234-p3767-0001-sdram-l4t_cpp_4.bct
[ 3.4848 ] packing sdram params with Wb0 file tegra234-p3767-0001-wb0sdram-l4t_cpp.dtb
[ 3.5567 ] Packing sdram param for instance[0]
[ 3.5568 ] Packing sdram param for instance[1]
[ 3.5568 ] Packing sdram param for instance[2]
[ 3.5569 ] Packing sdram param for instance[3]
[ 3.5570 ] Packing sdram param for instance[4]
[ 3.5571 ] Packing sdram param for instance[5]
[ 3.5571 ] Packing sdram param for instance[6]
[ 3.5572 ] Packing sdram param for instance[7]
[ 3.5573 ] Packing sdram param for instance[8]
[ 3.5574 ] Packing sdram param for instance[9]
[ 3.5575 ] Packing sdram param for instance[10]
[ 3.5575 ] Packing sdram param for instance[11]
[ 3.5576 ] Packing sdram param for instance[12]
[ 3.5577 ] Packing sdram param for instance[13]
[ 3.5578 ] Packing sdram param for instance[14]
[ 3.5579 ] Packing sdram param for instance[15]
[ 3.6245 ] Getting sector size from pt
[ 3.6254 ] tegraparser_v2 --getsectorsize flash.xml.bin sector_info.bin
[ 3.6267 ] BlockSize read from layout is 0x200
[ 3.6275 ] tegrahost_v2 --chip 0x23 0 --blocksize 512 --magicid MEMB --addsigheader_multi tegra234-p3767-0001-sdram-l4t_cpp_1.bct tegra234-p3767-0001-sdram-l4t_cpp_2.bct tegra234-p3767-0001-sdram-l4t_cpp_3.bct tegra234-p3767-0001-sdram-l4t_cpp_4.bct
[ 3.6282 ] Binary 0 length is 58752
[ 3.6285 ] Binary 0 align length is 58880
[ 3.6297 ] Binary 1 length is 58752
[ 3.6298 ] Binary 1 align length is 58880
[ 3.6303 ] Binary 2 length is 58752
[ 3.6304 ] Binary 2 align length is 58880
[ 3.6310 ] Binary 3 length is 58752
[ 3.6311 ] Binary 3 align length is 58880
[ 3.6316 ] Buffer length is 235520
[ 3.6316 ] adding BCH for tegra234-p3767-0001-sdram-l4t_cpp_1.bct
[ 3.6319 ] new length is 243712
[ 3.6319 ]
[ 3.6325 ] tegrahost_v2 --chip 0x23 0 --align mem_coldboot_aligned.bct
[ 3.6336 ] tegrahost_v2 --chip 0x23 0 --magicid MEMB --ratchet_blob ratchet_blob.bin --appendsigheader mem_coldboot_aligned.bct zerosbk
[ 3.6339 ] Header already present for mem_coldboot_aligned.bct
[ 3.6350 ] tegrasign_v3.py --key None --list mem_coldboot_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[ 3.6351 ] Assuming zero filled SBK key
[ 3.6362 ] Warning: pub_key.key is not found
[ 3.6360 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mem_coldboot_aligned_sigheader.bct.encrypt mem_coldboot_aligned_sigheader.bct.hash zerosbk
[ 3.6383 ] Generating recovery mem-bct
[ 3.6386 ] tegrabct_v2 --chip 0x23 0 --sdram tegra234-p3767-0001-sdram-l4t_cpp.dtb --wb0sdram tegra234-p3767-0001-wb0sdram-l4t_cpp.dtb --membct tegra234-p3767-0001-sdram-l4t_cpp_1.bct tegra234-p3767-0001-sdram-l4t_cpp_2.bct tegra234-p3767-0001-sdram-l4t_cpp_3.bct tegra234-p3767-0001-sdram-l4t_cpp_4.bct
[ 3.6389 ] packing sdram params with Wb0 file tegra234-p3767-0001-wb0sdram-l4t_cpp.dtb
[ 3.7063 ] Packing sdram param for instance[0]
[ 3.7065 ] Packing sdram param for instance[1]
[ 3.7066 ] Packing sdram param for instance[2]
[ 3.7067 ] Packing sdram param for instance[3]
[ 3.7068 ] Packing sdram param for instance[4]
[ 3.7070 ] Packing sdram param for instance[5]
[ 3.7071 ] Packing sdram param for instance[6]
[ 3.7072 ] Packing sdram param for instance[7]
[ 3.7074 ] Packing sdram param for instance[8]
[ 3.7075 ] Packing sdram param for instance[9]
[ 3.7076 ] Packing sdram param for instance[10]
[ 3.7078 ] Packing sdram param for instance[11]
[ 3.7079 ] Packing sdram param for instance[12]
[ 3.7080 ] Packing sdram param for instance[13]
[ 3.7082 ] Packing sdram param for instance[14]
[ 3.7083 ] Packing sdram param for instance[15]
[ 3.7746 ] Reading ramcode from backup chip_info.bin file
[ 3.7746 ] RAMCODE Read from Device: 2
[ 3.7746 ] Using ramcode 0
[ 3.7747 ] Disabled BPMP dtb trim, using default dtb
[ 3.7747 ]
[ 3.7755 ] tegrahost_v2 --chip 0x23 0 --align mem_rcm_aligned.bct
[ 3.7762 ] tegrahost_v2 --chip 0x23 0 --magicid MEM0 --ratchet_blob ratchet_blob.bin --appendsigheader mem_rcm_aligned.bct zerosbk
[ 3.7766 ] adding BCH for mem_rcm_aligned.bct
[ 3.7794 ] tegrasign_v3.py --key None --list mem_rcm_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[ 3.7795 ] Assuming zero filled SBK key
[ 3.7807 ] Warning: pub_key.key is not found
[ 3.7805 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mem_rcm_aligned_sigheader.bct.encrypt mem_rcm_aligned_sigheader.bct.hash zerosbk
[ 3.7814 ] Copying signatures
[ 3.7818 ] tegrahost_v2 --chip 0x23 0 --partitionlayout flash.xml.bin --updatesig images_list_signed.xml
[ 3.8180 ] tegraparser_v2 --generategpt --pt flash.xml.bin
[ 3.8185 ] gpt_secondary_3_0.bin:
[ 3.8187 ] partition_id partition_name StartingLba EndingLba
[ 3.8188 ] 1 BCT 0 2047
[ 3.8190 ] 2 A_mb1 2048 3071
[ 3.8191 ] 3 A_psc_bl1 3072 3583
[ 3.8192 ] 4 A_MB1_BCT 3584 3839
[ 3.8194 ] 5 A_MEM_BCT 3840 4351
[ 3.8195 ] 6 A_tsec-fw 4352 6399
[ 3.8197 ] 7 A_nvdec 6400 8447
[ 3.8198 ] 8 A_mb2 8448 9471
[ 3.8200 ] 9 A_xusb-fw 9472 9983
[ 3.8201 ] 10 A_bpmp-fw 9984 13055
[ 3.8202 ] 11 A_bpmp-fw-dtb 13056 21247
[ 3.8202 ] 12 A_psc-fw 21248 22783
[ 3.8202 ] 13 A_mts-mce 22784 23807
[ 3.8202 ] 14 A_sc7 23808 24191
[ 3.8202 ] 15 A_pscrf 24192 24575
[ 3.8202 ] 16 A_mb2rf 24576 24831
[ 3.8202 ] 17 A_cpu-bootloader 24832 31999
[ 3.8202 ] 18 A_secure-os 32000 40191
[ 3.8202 ] 19 A_smm-fw 40192 44287
[ 3.8202 ] 20 A_eks 44288 44799
[ 3.8202 ] 21 A_dce-fw 44800 55039
[ 3.8202 ] 22 A_spe-fw 55040 56191
[ 3.8202 ] 23 A_rce-fw 56192 58239
[ 3.8202 ] 24 A_adsp-fw 58240 62335
[ 3.8202 ] 25 A_pva-fw 62336 62847
[ 3.8202 ] 26 A_reserved_on_boot 62848 65023
[ 3.8202 ] 27 B_mb1 65024 66047
[ 3.8202 ] 28 B_psc_bl1 66048 66559
[ 3.8202 ] 29 B_MB1_BCT 66560 66815
[ 3.8202 ] 30 B_MEM_BCT 66816 67327
[ 3.8202 ] 31 B_tsec-fw 67328 69375
[ 3.8202 ] 32 B_nvdec 69376 71423
[ 3.8202 ] 33 B_mb2 71424 72447
[ 3.8203 ] 34 B_xusb-fw 72448 72959
[ 3.8203 ] 35 B_bpmp-fw 72960 76031
[ 3.8203 ] 36 B_bpmp-fw-dtb 76032 84223
[ 3.8203 ] 37 B_psc-fw 84224 85759
[ 3.8203 ] 38 B_mts-mce 85760 86783
[ 3.8203 ] 39 B_sc7 86784 87167
[ 3.8203 ] 40 B_pscrf 87168 87551
[ 3.8203 ] 41 B_mb2rf 87552 87807
[ 3.8203 ] 42 B_cpu-bootloader 87808 94975
[ 3.8203 ] 43 B_secure-os 94976 103167
[ 3.8203 ] 44 B_smm-fw 103168 107263
[ 3.8203 ] 45 B_eks 107264 107775
[ 3.8203 ] 46 B_dce-fw 107776 118015
[ 3.8203 ] 47 B_spe-fw 118016 119167
[ 3.8203 ] 48 B_rce-fw 119168 121215
[ 3.8203 ] 49 B_adsp-fw 121216 125311
[ 3.8203 ] 50 B_pva-fw 125312 125823
[ 3.8203 ] 51 B_reserved_on_boot 125824 127999
[ 3.8203 ] 52 uefi_variables 128000 128511
[ 3.8203 ] 53 uefi_ftw 128512 129535
[ 3.8203 ] 54 reserved 129536 129919
[ 3.8203 ] 55 worm 129920 130303
[ 3.8203 ] 56 BCT-boot-chain_backup 130304 130431
[ 3.8203 ] 57 reserved_partition 130432 130559
[ 3.8203 ] 58 secondary_gpt_backup 130560 130687
[ 3.8203 ] 59 B_VER 130688 130815
[ 3.8203 ] 60 A_VER 130816 130943
[ 3.8203 ] gpt_primary_6_0.bin:
[ 3.8203 ] partition_id partition_name StartingLba EndingLba
[ 3.8203 ] 1 APP 3050048 119537623
[ 3.8203 ] 2 A_kernel 40 262183
[ 3.8203 ] 3 A_kernel-dtb 262184 263719
[ 3.8203 ] 4 A_reserved_on_user 263720 328487
[ 3.8203 ] 5 B_kernel 328488 590631
[ 3.8203 ] 6 B_kernel-dtb 590632 592167
[ 3.8203 ] 7 B_reserved_on_user 592168 656935
[ 3.8204 ] 8 recovery 656936 820775
[ 3.8204 ] 9 recovery-dtb 820776 821799
[ 3.8204 ] 10 esp 821800 952871
[ 3.8204 ] 11 recovery_alt 952872 1116711
[ 3.8204 ] 12 recovery-dtb_alt 1116712 1117735
[ 3.8204 ] 13 esp_alt 1117736 1248807
[ 3.8204 ] 14 UDA 1248832 2068031
[ 3.8204 ] 15 reserved 2068032 3050047
[ 3.8204 ] gpt_secondary_6_0.bin:
[ 3.8204 ] partition_id partition_name StartingLba EndingLba
[ 3.8204 ] 1 APP 3050048 119537623
[ 3.8204 ] 2 A_kernel 40 262183
[ 3.8204 ] 3 A_kernel-dtb 262184 263719
[ 3.8204 ] 4 A_reserved_on_user 263720 328487
[ 3.8204 ] 5 B_kernel 328488 590631
[ 3.8204 ] 6 B_kernel-dtb 590632 592167
[ 3.8204 ] 7 B_reserved_on_user 592168 656935
[ 3.8204 ]
[ 3.8215 ] Get magic id
[ 3.8219 ] tegraparser_v2 --get_magic psc_fw
[ 3.8222 ] PFWP
[ 3.8223 ] partition type psc_fw, magic id = PFWP
[ 3.8230 ] tegrahost_v2 --chip 0x23 0 --align pscfw_t234_prod_aligned.bin
[ 3.8236 ] tegrahost_v2 --chip 0x23 0 --magicid PFWP --ratchet_blob ratchet_blob.bin --appendsigheader pscfw_t234_prod_aligned.bin zerosbk
[ 3.8238 ] Header already present for pscfw_t234_prod_aligned.bin
[ 3.8286 ] tegrasign_v3.py --key None --list pscfw_t234_prod_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[ 3.8288 ] Assuming zero filled SBK key
[ 3.8312 ] Warning: pub_key.key is not found
[ 3.8312 ] tegrahost_v2 --chip 0x23 0 --updatesigheader pscfw_t234_prod_aligned_sigheader.bin.encrypt pscfw_t234_prod_aligned_sigheader.bin.hash zerosbk
[ 3.8323 ] Get magic id
[ 3.8325 ] tegraparser_v2 --get_magic mts_mce
[ 3.8327 ] MTSM
[ 3.8328 ] partition type mts_mce, magic id = MTSM
[ 3.8333 ] tegrahost_v2 --chip 0x23 0 --align mce_flash_o10_cr_prod_aligned.bin
[ 3.8342 ] tegrahost_v2 --chip 0x23 0 --magicid MTSM --ratchet_blob ratchet_blob.bin --appendsigheader mce_flash_o10_cr_prod_aligned.bin zerosbk
[ 3.8345 ] Header already present for mce_flash_o10_cr_prod_aligned.bin
[ 3.8376 ] tegrasign_v3.py --key None --list mce_flash_o10_cr_prod_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[ 3.8377 ] Assuming zero filled SBK key
[ 3.8390 ] Warning: pub_key.key is not found
[ 3.8390 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mce_flash_o10_cr_prod_aligned_sigheader.bin.encrypt mce_flash_o10_cr_prod_aligned_sigheader.bin.hash zerosbk
[ 3.8403 ] Get magic id
[ 3.8406 ] tegraparser_v2 --get_magic tsec_fw
[ 3.8408 ] TSEC
[ 3.8409 ] partition type tsec_fw, magic id = TSEC
[ 3.8414 ] tegrahost_v2 --chip 0x23 0 --align tsec_t234_aligned.bin
[ 3.8422 ] tegrahost_v2 --chip 0x23 0 --magicid TSEC --ratchet_blob ratchet_blob.bin --appendsigheader tsec_t234_aligned.bin zerosbk
[ 3.8425 ] Header already present for tsec_t234_aligned.bin
[ 3.8460 ] tegrasign_v3.py --key None --list tsec_t234_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[ 3.8461 ] Assuming zero filled SBK key
[ 3.8473 ] Warning: pub_key.key is not found
[ 3.8471 ] tegrahost_v2 --chip 0x23 0 --updatesigheader tsec_t234_aligned_sigheader.bin.encrypt tsec_t234_aligned_sigheader.bin.hash zerosbk
[ 3.8486 ] Get magic id
[ 3.8490 ] tegraparser_v2 --get_magic mb2_applet
[ 3.8493 ] MB2A
[ 3.8497 ] partition type mb2_applet, magic id = MB2A
[ 3.8502 ] tegrahost_v2 --chip 0x23 0 --align applet_t234_aligned.bin
[ 3.8507 ] tegrahost_v2 --chip 0x23 0 --magicid MB2A --ratchet_blob ratchet_blob.bin --appendsigheader applet_t234_aligned.bin zerosbk
[ 3.8509 ] adding BCH for applet_t234_aligned.bin
[ 3.8580 ] tegrasign_v3.py --key None --list applet_t234_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[ 3.8581 ] Assuming zero filled SBK key
[ 3.8594 ] Warning: pub_key.key is not found
[ 3.8592 ] tegrahost_v2 --chip 0x23 0 --updatesigheader applet_t234_aligned_sigheader.bin.encrypt applet_t234_aligned_sigheader.bin.hash zerosbk
[ 3.8626 ] Generating recovery mb2-bct
[ 3.8626 ] tegrabct_v2 --chip 0x23 0 --mb2bct mb2_bct.cfg --recov --mb2bctcfg tegra234-mb2-bct-misc-p3767-0000_cpp.dtb --scr tegra234-mb2-bct-scr-p3767-0000_cpp.dtb
[ 3.8629 ] ERROR: value 0x31 is out of range
[ 3.8641 ] ERROR: value 0x31 is out of range
[ 3.8642 ] ERROR: value 0x31 is out of range
[ 3.8643 ] WARNING: unknown property 'tfc_version'
[ 3.8646 ] WARNING: unknown property 'addr_header_version'
[ 3.8725 ] Updating mb2-bct with storage information for RCM
[ 3.8728 ] tegrabct_v2 --chip 0x23 0 --mb2bct mb2_bct_MB2.bct --updatestorageinfo flash.xml.bin
[ 3.8737 ] Concatenating mb2-bct to mb2 binary
[ 3.8737 ] mb2_bin_file = mb2_t234.bin
[ 3.8737 ] mb2_bct_file = mb2_bct_MB2.bct
[ 3.8742 ] Get magic id
[ 3.8746 ] tegraparser_v2 --get_magic mb2_bootloader
[ 3.8750 ] MB2B
[ 3.8752 ] partition type mb2_bootloader, magic id = MB2B
[ 3.8759 ] tegrahost_v2 --chip 0x23 0 --align mb2_t234_with_mb2_bct_MB2_aligned.bin
[ 3.8764 ] tegrahost_v2 --chip 0x23 0 --magicid MB2B --ratchet_blob ratchet_blob.bin --appendsigheader mb2_t234_with_mb2_bct_MB2_aligned.bin zerosbk
[ 3.8766 ] adding BCH for mb2_t234_with_mb2_bct_MB2_aligned.bin
[ 3.8873 ] tegrasign_v3.py --key None --list mb2_t234_with_mb2_bct_MB2_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[ 3.8875 ] Assuming zero filled SBK key
[ 3.8895 ] Warning: pub_key.key is not found
[ 3.8895 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb2_t234_with_mb2_bct_MB2_aligned_sigheader.bin.encrypt mb2_t234_with_mb2_bct_MB2_aligned_sigheader.bin.hash zerosbk
[ 3.8916 ] Get magic id
[ 3.8919 ] tegraparser_v2 --get_magic xusb_fw
[ 3.8925 ] XUSB
[ 3.8926 ] partition type xusb_fw, magic id = XUSB
[ 3.8931 ] tegrahost_v2 --chip 0x23 0 --align xusb_t234_prod_aligned.bin
[ 3.8938 ] tegrahost_v2 --chip 0x23 0 --magicid XUSB --ratchet_blob ratchet_blob.bin --appendsigheader xusb_t234_prod_aligned.bin zerosbk
[ 3.8941 ] adding BCH for xusb_t234_prod_aligned.bin
[ 3.8995 ] tegrasign_v3.py --key None --list xusb_t234_prod_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[ 3.8997 ] Assuming zero filled SBK key
[ 3.9010 ] Warning: pub_key.key is not found
[ 3.9008 ] tegrahost_v2 --chip 0x23 0 --updatesigheader xusb_t234_prod_aligned_sigheader.bin.encrypt xusb_t234_prod_aligned_sigheader.bin.hash zerosbk
[ 3.9029 ] Get magic id
[ 3.9033 ] tegraparser_v2 --get_magic pva_fw
[ 3.9037 ] PVAF
[ 3.9039 ] partition type pva_fw, magic id = PVAF
[ 3.9058 ] tegrahost_v2 --chip 0x23 0 --align nvpva_020_aligned.fw
[ 3.9065 ] tegrahost_v2 --chip 0x23 0 --magicid PVAF --ratchet_blob ratchet_blob.bin --appendsigheader nvpva_020_aligned.fw zerosbk
[ 3.9067 ] adding BCH for nvpva_020_aligned.fw
[ 3.9577 ] tegrasign_v3.py --key None --list nvpva_020_aligned_sigheader.fw_list.xml --pubkeyhash pub_key.key --sha sha512
[ 3.9578 ] Assuming zero filled SBK key
[ 3.9614 ] Warning: pub_key.key is not found
[ 3.9613 ] tegrahost_v2 --chip 0x23 0 --updatesigheader nvpva_020_aligned_sigheader.fw.encrypt nvpva_020_aligned_sigheader.fw.hash zerosbk
[ 3.9655 ] Kernel DTB used: kernel_tegra234-p3768-0000+p3767-0005-nv.dtb
[ 3.9655 ] Concatenating kernel-dtb to dce-fw binary
[ 3.9655 ] dce_bin = display-t234-dce.bin
[ 3.9655 ] kernel_dtb = kernel_tegra234-p3768-0000+p3767-0005-nv.dtb
[ 3.9655 ] dce_with_dtb = display-t234-dce_with_kernel_tegra234-p3768-0000+p3767-0005-nv.bin
[ 3.9748 ] Get magic id
[ 3.9753 ] tegraparser_v2 --get_magic dce_fw
[ 3.9757 ] DCEF
[ 3.9758 ] partition type dce_fw, magic id = DCEF
[ 3.9854 ] tegrahost_v2 --chip 0x23 0 --align display-t234-dce_with_kernel_tegra234-p3768-0000+p3767-0005-nv_aligned.bin
[ 3.9862 ] tegrahost_v2 --chip 0x23 0 --magicid DCEF --ratchet_blob ratchet_blob.bin --appendsigheader display-t234-dce_with_kernel_tegra234-p3768-0000+p3767-0005-nv_aligned.bin zerosbk compress
[ 3.9864 ] INFO: compressing display-t234-dce_with_kernel_tegra234-p3768-0000+p3767-0005-nv_aligned_aligned.bin
[ 4.1302 ] INFO: complete compression, display-t234-dce_with_kernel_tegra234-p3768-0000+p3767-0005-nv_aligned_aligned.bin, ratio = 6%
[ 4.1457 ] adding BCH for display-t234-dce_with_kernel_tegra234-p3768-0000+p3767-0005-nv_aligned_aligned_blob_w_bin.bin
[ 4.1696 ] tegrasign_v3.py --key None --list display-t234-dce_with_kernel_tegra234-p3768-0000+p3767-0005-nv_aligned_aligned_blob_w_bin_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[ 4.1697 ] Assuming zero filled SBK key
[ 4.1723 ] Warning: pub_key.key is not found
[ 4.1724 ] tegrahost_v2 --chip 0x23 0 --updatesigheader display-t234-dce_with_kernel_tegra234-p3768-0000+p3767-0005-nv_aligned_aligned_blob_w_bin_sigheader.bin.encrypt display-t234-dce_with_kernel_tegra234-p3768-0000+p3767-0005-nv_aligned_aligned_blob_w_bin_sigheader.bin.hash zerosbk
[ 4.1764 ] Get magic id
[ 4.1766 ] tegraparser_v2 --get_magic nvdec
[ 4.1768 ] NDEC
[ 4.1770 ] partition type nvdec, magic id = NDEC
[ 4.1778 ] tegrahost_v2 --chip 0x23 0 --align nvdec_t234_prod_aligned.fw
[ 4.1788 ] tegrahost_v2 --chip 0x23 0 --magicid NDEC --ratchet_blob ratchet_blob.bin --appendsigheader nvdec_t234_prod_aligned.fw zerosbk
[ 4.1790 ] Header already present for nvdec_t234_prod_aligned.fw
[ 4.1842 ] tegrasign_v3.py --key None --list nvdec_t234_prod_aligned_sigheader.fw_list.xml --pubkeyhash pub_key.key --sha sha512
[ 4.1843 ] Assuming zero filled SBK key
[ 4.1857 ] Warning: pub_key.key is not found
[ 4.1856 ] tegrahost_v2 --chip 0x23 0 --updatesigheader nvdec_t234_prod_aligned_sigheader.fw.encrypt nvdec_t234_prod_aligned_sigheader.fw.hash zerosbk
[ 4.1870 ] Get magic id
[ 4.1873 ] tegraparser_v2 --get_magic bpmp_fw
[ 4.1875 ] BPMF
[ 4.1876 ] partition type bpmp_fw, magic id = BPMF
[ 4.1886 ] tegrahost_v2 --chip 0x23 0 --align bpmp_t234-TE950M-A1_prod_aligned.bin
[ 4.1893 ] tegrahost_v2 --chip 0x23 0 --magicid BPMF --ratchet_blob ratchet_blob.bin --appendsigheader bpmp_t234-TE950M-A1_prod_aligned.bin zerosbk
[ 4.1898 ] Header already present for bpmp_t234-TE950M-A1_prod_aligned.bin
[ 4.2033 ] tegrasign_v3.py --key None --list bpmp_t234-TE950M-A1_prod_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[ 4.2035 ] Assuming zero filled SBK key
[ 4.2060 ] Warning: pub_key.key is not found
[ 4.2061 ] tegrahost_v2 --chip 0x23 0 --updatesigheader bpmp_t234-TE950M-A1_prod_aligned_sigheader.bin.encrypt bpmp_t234-TE950M-A1_prod_aligned_sigheader.bin.hash zerosbk
[ 4.2086 ] Using bpmp-dtb concatenated with odmdata
[ 4.2086 ] Get magic id
[ 4.2091 ] tegraparser_v2 --get_magic bpmp_fw_dtb
[ 4.2094 ] BPMD
[ 4.2100 ] partition type bpmp_fw_dtb, magic id = BPMD
[ 4.2110 ] tegrahost_v2 --chip 0x23 0 --align tegra234-bpmp-3767-0003-3509-a02_with_odm_aligned.dtb
[ 4.2117 ] tegrahost_v2 --chip 0x23 0 --magicid BPMD --ratchet_blob ratchet_blob.bin --appendsigheader tegra234-bpmp-3767-0003-3509-a02_with_odm_aligned.dtb zerosbk
[ 4.2120 ] adding BCH for tegra234-bpmp-3767-0003-3509-a02_with_odm_aligned.dtb
[ 4.2179 ] tegrasign_v3.py --key None --list tegra234-bpmp-3767-0003-3509-a02_with_odm_aligned_sigheader.dtb_list.xml --pubkeyhash pub_key.key --sha sha512
[ 4.2182 ] Assuming zero filled SBK key
[ 4.2200 ] Warning: pub_key.key is not found
[ 4.2199 ] tegrahost_v2 --chip 0x23 0 --updatesigheader tegra234-bpmp-3767-0003-3509-a02_with_odm_aligned_sigheader.dtb.encrypt tegra234-bpmp-3767-0003-3509-a02_with_odm_aligned_sigheader.dtb.hash zerosbk
[ 4.2213 ] Get magic id
[ 4.2217 ] tegraparser_v2 --get_magic rce_fw
[ 4.2222 ] RCEF
[ 4.2223 ] partition type rce_fw, magic id = RCEF
[ 4.2229 ] tegrahost_v2 --chip 0x23 0 --align camera-rtcpu-t234-rce_aligned.img
[ 4.2234 ] tegrahost_v2 --chip 0x23 0 --magicid RCEF --ratchet_blob ratchet_blob.bin --appendsigheader camera-rtcpu-t234-rce_aligned.img zerosbk
[ 4.2236 ] adding BCH for camera-rtcpu-t234-rce_aligned.img
[ 4.2356 ] tegrasign_v3.py --key None --list camera-rtcpu-t234-rce_aligned_sigheader.img_list.xml --pubkeyhash pub_key.key --sha sha512
[ 4.2358 ] Assuming zero filled SBK key
[ 4.2380 ] Warning: pub_key.key is not found
[ 4.2380 ] tegrahost_v2 --chip 0x23 0 --updatesigheader camera-rtcpu-t234-rce_aligned_sigheader.img.encrypt camera-rtcpu-t234-rce_aligned_sigheader.img.hash zerosbk
[ 4.2404 ] Get magic id
[ 4.2407 ] tegraparser_v2 --get_magic ape_fw
[ 4.2409 ] APEF
[ 4.2410 ] partition type ape_fw, magic id = APEF
[ 4.2417 ] tegrahost_v2 --chip 0x23 0 --align adsp-fw_aligned.bin
[ 4.2428 ] tegrahost_v2 --chip 0x23 0 --magicid APEF --ratchet_blob ratchet_blob.bin --appendsigheader adsp-fw_aligned.bin zerosbk
[ 4.2430 ] adding BCH for adsp-fw_aligned.bin
[ 4.2544 ] tegrasign_v3.py --key None --list adsp-fw_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[ 4.2547 ] Assuming zero filled SBK key
[ 4.2568 ] Warning: pub_key.key is not found
[ 4.2566 ] tegrahost_v2 --chip 0x23 0 --updatesigheader adsp-fw_aligned_sigheader.bin.encrypt adsp-fw_aligned_sigheader.bin.hash zerosbk
[ 4.2582 ] Get magic id
[ 4.2587 ] tegraparser_v2 --get_magic spe_fw
[ 4.2594 ] SPEF
[ 4.2596 ] partition type spe_fw, magic id = SPEF
[ 4.2602 ] tegrahost_v2 --chip 0x23 0 --align spe_t234_aligned.bin
[ 4.2608 ] tegrahost_v2 --chip 0x23 0 --magicid SPEF --ratchet_blob ratchet_blob.bin --appendsigheader spe_t234_aligned.bin zerosbk
[ 4.2609 ] adding BCH for spe_t234_aligned.bin
[ 4.2681 ] tegrasign_v3.py --key None --list spe_t234_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[ 4.2682 ] Assuming zero filled SBK key
[ 4.2696 ] Warning: pub_key.key is not found
[ 4.2694 ] tegrahost_v2 --chip 0x23 0 --updatesigheader spe_t234_aligned_sigheader.bin.encrypt spe_t234_aligned_sigheader.bin.hash zerosbk
[ 4.2706 ] Get magic id
[ 4.2709 ] tegraparser_v2 --get_magic tos
[ 4.2712 ] TOSB
[ 4.2713 ] partition type tos, magic id = TOSB
[ 4.2728 ] tegrahost_v2 --chip 0x23 0 --align tos-optee_t234_aligned.img
[ 4.2733 ] tegrahost_v2 --chip 0x23 0 --magicid TOSB --ratchet_blob ratchet_blob.bin --appendsigheader tos-optee_t234_aligned.img zerosbk
[ 4.2735 ] adding BCH for tos-optee_t234_aligned.img
[ 4.3058 ] tegrasign_v3.py --key None --list tos-optee_t234_aligned_sigheader.img_list.xml --pubkeyhash pub_key.key --sha sha512
[ 4.3060 ] Assuming zero filled SBK key
[ 4.3082 ] Warning: pub_key.key is not found
[ 4.3082 ] tegrahost_v2 --chip 0x23 0 --updatesigheader tos-optee_t234_aligned_sigheader.img.encrypt tos-optee_t234_aligned_sigheader.img.hash zerosbk
[ 4.3121 ] Get magic id
[ 4.3125 ] tegraparser_v2 --get_magic eks
[ 4.3127 ] EKSB
[ 4.3128 ] partition type eks, magic id = EKSB
[ 4.3134 ] tegrahost_v2 --chip 0x23 0 --align eks_t234_aligned.img
[ 4.3142 ] tegrahost_v2 --chip 0x23 0 --magicid EKSB --ratchet_blob ratchet_blob.bin --appendsigheader eks_t234_aligned.img zerosbk
[ 4.3144 ] adding BCH for eks_t234_aligned.img
[ 4.3153 ] tegrasign_v3.py --key None --list eks_t234_aligned_sigheader.img_list.xml --pubkeyhash pub_key.key --sha sha512
[ 4.3154 ] Assuming zero filled SBK key
[ 4.3164 ] Warning: pub_key.key is not found
[ 4.3164 ] tegrahost_v2 --chip 0x23 0 --updatesigheader eks_t234_aligned_sigheader.img.encrypt eks_t234_aligned_sigheader.img.hash zerosbk
[ 4.3197 ] tegrahost_v2 --chip 0x23 0 --align uefi_jetson_with_dtb_aligned.bin
[ 4.3203 ] tegrahost_v2 --chip 0x23 0 --magicid CPBL --ratchet_blob ratchet_blob.bin --appendsigheader uefi_jetson_with_dtb_aligned.bin zerosbk
[ 4.3205 ] adding BCH for uefi_jetson_with_dtb_aligned.bin
[ 4.3980 ] tegrasign_v3.py --key None --list uefi_jetson_with_dtb_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[ 4.3982 ] Assuming zero filled SBK key
[ 4.4039 ] Warning: pub_key.key is not found
[ 4.4040 ] tegrahost_v2 --chip 0x23 0 --updatesigheader uefi_jetson_with_dtb_aligned_sigheader.bin.encrypt uefi_jetson_with_dtb_aligned_sigheader.bin.hash zerosbk
[ 4.4124 ] Copying enc\/signed file in /tmp/jetson-builder/build/Linux_for_Tegra/bootloader/signed
[ 4.4280 ] Copying br bct for multi chains
[ 4.4281 ] Signed BCT for boot chain A is copied to /tmp/jetson-builder/build/Linux_for_Tegra/bootloader/signed/br_bct_BR.bct
[ 4.4282 ] Signed BCT for boot chain B is copied to /tmp/jetson-builder/build/Linux_for_Tegra/bootloader/signed/br_bct_b_BR.bct
[ 4.4282 ] Copying BCT backup image bct_backup.img to /tmp/jetson-builder/build/Linux_for_Tegra/bootloader/signed/bct_backup.img
[ 4.4309 ] Copying pscfw_t234_prod_sigheader.bin.encrypt to /tmp/jetson-builder/build/Linux_for_Tegra/bootloader/signed
[ 4.4312 ] Signed file: /tmp/jetson-builder/build/Linux_for_Tegra/bootloader/signed/pscfw_t234_prod_sigheader.bin.encrypt
[ 4.4312 ] Copying mce_flash_o10_cr_prod_sigheader.bin.encrypt to /tmp/jetson-builder/build/Linux_for_Tegra/bootloader/signed
[ 4.4315 ] Signed file: /tmp/jetson-builder/build/Linux_for_Tegra/bootloader/signed/mce_flash_o10_cr_prod_sigheader.bin.encrypt
[ 4.4315 ] Copying tsec_t234_sigheader.bin.encrypt to /tmp/jetson-builder/build/Linux_for_Tegra/bootloader/signed
[ 4.4316 ] Signed file: /tmp/jetson-builder/build/Linux_for_Tegra/bootloader/signed/tsec_t234_sigheader.bin.encrypt
[ 4.4316 ] Copying applet_t234_sigheader.bin.encrypt to /tmp/jetson-builder/build/Linux_for_Tegra/bootloader/signed
[ 4.4318 ] Signed file: /tmp/jetson-builder/build/Linux_for_Tegra/bootloader/signed/applet_t234_sigheader.bin.encrypt
[ 4.4318 ] Copying mb2_t234_with_mb2_bct_MB2_sigheader.bin.encrypt to /tmp/jetson-builder/build/Linux_for_Tegra/bootloader/signed
[ 4.4321 ] Signed file: /tmp/jetson-builder/build/Linux_for_Tegra/bootloader/signed/mb2_t234_with_mb2_bct_MB2_sigheader.bin.encrypt
[ 4.4321 ] Copying xusb_t234_prod_sigheader.bin.encrypt to /tmp/jetson-builder/build/Linux_for_Tegra/bootloader/signed
[ 4.4323 ] Signed file: /tmp/jetson-builder/build/Linux_for_Tegra/bootloader/signed/xusb_t234_prod_sigheader.bin.encrypt
[ 4.4323 ] Copying nvpva_020_sigheader.fw.encrypt to /tmp/jetson-builder/build/Linux_for_Tegra/bootloader/signed
[ 4.4335 ] Signed file: /tmp/jetson-builder/build/Linux_for_Tegra/bootloader/signed/nvpva_020_sigheader.fw.encrypt
[ 4.4335 ] Copying display-t234-dce_sigheader.bin.encrypt to /tmp/jetson-builder/build/Linux_for_Tegra/bootloader/signed
[ 4.4340 ] Signed file: /tmp/jetson-builder/build/Linux_for_Tegra/bootloader/signed/display-t234-dce_sigheader.bin.encrypt
[ 4.4340 ] Copying display-t234-dce_with_kernel_tegra234-p3768-0000+p3767-0005-nv_blob_w_bin_sigheader.bin.encrypt to /tmp/jetson-builder/build/Linux_for_Tegra/bootloader/signed
[ 4.4345 ] Signed file: /tmp/jetson-builder/build/Linux_for_Tegra/bootloader/signed/display-t234-dce_with_kernel_tegra234-p3768-0000+p3767-0005-nv_blob_w_bin_sigheader.bin.encrypt
[ 4.4345 ] Copying nvdec_t234_prod_sigheader.fw.encrypt to /tmp/jetson-builder/build/Linux_for_Tegra/bootloader/signed
[ 4.4347 ] Signed file: /tmp/jetson-builder/build/Linux_for_Tegra/bootloader/signed/nvdec_t234_prod_sigheader.fw.encrypt
[ 4.4347 ] Copying bpmp_t234-TE950M-A1_prod_sigheader.bin.encrypt to /tmp/jetson-builder/build/Linux_for_Tegra/bootloader/signed
[ 4.4355 ] Signed file: /tmp/jetson-builder/build/Linux_for_Tegra/bootloader/signed/bpmp_t234-TE950M-A1_prod_sigheader.bin.encrypt
[ 4.4355 ] Copying tegra234-bpmp-3767-0003-3509-a02_with_odm_sigheader.dtb.encrypt to /tmp/jetson-builder/build/Linux_for_Tegra/bootloader/signed
[ 4.4357 ] Signed file: /tmp/jetson-builder/build/Linux_for_Tegra/bootloader/signed/tegra234-bpmp-3767-0003-3509-a02_with_odm_sigheader.dtb.encrypt
[ 4.4357 ] Copying camera-rtcpu-t234-rce_sigheader.img.encrypt to /tmp/jetson-builder/build/Linux_for_Tegra/bootloader/signed
[ 4.4368 ] Signed file: /tmp/jetson-builder/build/Linux_for_Tegra/bootloader/signed/camera-rtcpu-t234-rce_sigheader.img.encrypt
[ 4.4369 ] Copying adsp-fw_sigheader.bin.encrypt to /tmp/jetson-builder/build/Linux_for_Tegra/bootloader/signed
[ 4.4373 ] Signed file: /tmp/jetson-builder/build/Linux_for_Tegra/bootloader/signed/adsp-fw_sigheader.bin.encrypt
[ 4.4373 ] Copying spe_t234_sigheader.bin.encrypt to /tmp/jetson-builder/build/Linux_for_Tegra/bootloader/signed
[ 4.4376 ] Signed file: /tmp/jetson-builder/build/Linux_for_Tegra/bootloader/signed/spe_t234_sigheader.bin.encrypt
[ 4.4376 ] Copying tos-optee_t234_sigheader.img.encrypt to /tmp/jetson-builder/build/Linux_for_Tegra/bootloader/signed
[ 4.4386 ] Signed file: /tmp/jetson-builder/build/Linux_for_Tegra/bootloader/signed/tos-optee_t234_sigheader.img.encrypt
[ 4.4386 ] Copying eks_t234_sigheader.img.encrypt to /tmp/jetson-builder/build/Linux_for_Tegra/bootloader/signed
[ 4.4386 ] Signed file: /tmp/jetson-builder/build/Linux_for_Tegra/bootloader/signed/eks_t234_sigheader.img.encrypt
[ 4.4386 ] Copying uefi_jetson_with_dtb_sigheader.bin.encrypt to /tmp/jetson-builder/build/Linux_for_Tegra/bootloader/signed
[ 4.4408 ] Signed file: /tmp/jetson-builder/build/Linux_for_Tegra/bootloader/signed/uefi_jetson_with_dtb_sigheader.bin.encrypt
[ 4.4424 ] tegraparser_v2 --pt flash.xml.bin --generateflashindex /tmp/jetson-builder/build/Linux_for_Tegra/bootloader/signed/flash.xml.tmp flash.idx
Using bpmp-dtb concatenated with odmdata in blob for t23x
./tegraflash.py --bl uefi_jetson_with_dtb_sigheader.bin.encrypt --bct br_bct_BR.bct --securedev --bldtb tegra234-p3768-0000+p3767-0005-nv.dtb --applet rcm_2_encrypt.rcm --applet_softfuse rcm_1_encrypt.rcm --cmd "rcmboot" --cfg secureflash.xml --chip 0x23 --mb1_bct mb1_bct_MB1_sigheader.bct.encrypt --mem_bct mem_rcm_sigheader.bct.encrypt --mb1_cold_boot_bct mb1_cold_boot_bct_MB1_sigheader.bct.encrypt --mb1_bin mb1_t234_prod_aligned_sigheader.bin.encrypt --psc_bl1_bin psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --mem_bct_cold_boot mem_coldboot_sigheader.bct.encrypt --bins "psc_fw pscfw_t234_prod_sigheader.bin.encrypt; mts_mce mce_flash_o10_cr_prod_sigheader.bin.encrypt; tsec_fw tsec_t234_sigheader.bin.encrypt; mb2_applet applet_t234_sigheader.bin.encrypt; mb2_bootloader mb2_t234_with_mb2_cold_boot_bct_MB2_sigheader.bin.encrypt; xusb_fw xusb_t234_prod_sigheader.bin.encrypt; pva_fw nvpva_020_sigheader.fw.encrypt; dce_fw display-t234-dce_sigheader.bin.encrypt; nvdec nvdec_t234_prod_sigheader.fw.encrypt; bpmp_fw bpmp_t234-TE950M-A1_prod_sigheader.bin.encrypt; bpmp_fw_dtb tegra234-bpmp-3767-0003-3509-a02_with_odm_sigheader.dtb.encrypt; rce_fw camera-rtcpu-t234-rce_sigheader.img.encrypt; ape_fw adsp-fw_sigheader.bin.encrypt; spe_fw spe_t234_sigheader.bin.encrypt; tos tos-optee_t234_sigheader.img.encrypt; eks eks_t234_sigheader.img.encrypt; kernel boot.img; kernel_dtb tegra234-p3768-0000+p3767-0005-nv.dtb" --bct_backup
saving flash command in flashcmd.txt
*** no-flash flag enabled. Exiting now... ***
User can run above saved command in factory environment without
providing pkc and sbk keys to flash a device
Example:
$ cd bootloader
$ sudo bash ./flashcmd.txt
Save initrd flashing command parameters to /tmp/jetson-builder/build/Linux_for_Tegra/tools/kernel_flash/initrdflashparam.txt
/tmp/tmp.xVr8N9zFlL /tmp/jetson-builder/build/Linux_for_Tegra
writing boot image config in bootimg.cfg
extracting kernel in zImage
extracting ramdisk in initrd.img
/tmp/tmp.xVr8N9zFlL/initrd /tmp/tmp.xVr8N9zFlL /tmp/jetson-builder/build/Linux_for_Tegra
79521 blocks
220146 blocks
flashimg0=boot0.img
Success
Cleaning up...
Finish generating flash package.
/tmp/jetson-builder/build/Linux_for_Tegra/tools/kernel_flash/l4t_initrd_flash_internal.sh --usb-instance 3-13 --device-instance 0 --flash-only --external-device mmcblk0p1 -c "tools/kernel_flash/flash_l4t_external.xml" --network usb0 jetson-orin-nano-devkit internal
* Step 1: Build the flashing environment *
Create flash environment 0
Finish creating flash environment 0.
* Step 2: Boot the device with flash initrd image *
/tmp/jetson-builder/build/Linux_for_Tegra/temp_initrdflash/bootloader0 /tmp/jetson-builder/build/Linux_for_Tegra
./tegraflash.py --bl uefi_jetson_with_dtb_sigheader.bin.encrypt --bct br_bct_BR.bct --securedev --bldtb tegra234-p3768-0000+p3767-0005-nv.dtb --applet rcm_2_encrypt.rcm --applet_softfuse rcm_1_encrypt.rcm --cmd "rcmboot" --cfg secureflash.xml --chip 0x23 --mb1_bct mb1_bct_MB1_sigheader.bct.encrypt --mem_bct mem_rcm_sigheader.bct.encrypt --mb1_cold_boot_bct mb1_cold_boot_bct_MB1_sigheader.bct.encrypt --mb1_bin mb1_t234_prod_aligned_sigheader.bin.encrypt --psc_bl1_bin psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --mem_bct_cold_boot mem_coldboot_sigheader.bct.encrypt --bins "psc_fw pscfw_t234_prod_sigheader.bin.encrypt; mts_mce mce_flash_o10_cr_prod_sigheader.bin.encrypt; tsec_fw tsec_t234_sigheader.bin.encrypt; mb2_applet applet_t234_sigheader.bin.encrypt; mb2_bootloader mb2_t234_with_mb2_cold_boot_bct_MB2_sigheader.bin.encrypt; xusb_fw xusb_t234_prod_sigheader.bin.encrypt; pva_fw nvpva_020_sigheader.fw.encrypt; dce_fw display-t234-dce_sigheader.bin.encrypt; nvdec nvdec_t234_prod_sigheader.fw.encrypt; bpmp_fw bpmp_t234-TE950M-A1_prod_sigheader.bin.encrypt; bpmp_fw_dtb tegra234-bpmp-3767-0003-3509-a02_with_odm_sigheader.dtb.encrypt; rce_fw camera-rtcpu-t234-rce_sigheader.img.encrypt; ape_fw adsp-fw_sigheader.bin.encrypt; spe_fw spe_t234_sigheader.bin.encrypt; tos tos-optee_t234_sigheader.img.encrypt; eks eks_t234_sigheader.img.encrypt; kernel boot0.img; kernel_dtb tegra234-p3768-0000+p3767-0005-nv.dtb" --bct_backup --instance 3-13
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
Entering RCM boot
[ 0.0273 ] mb1_t234_prod_aligned_sigheader.bin.encrypt filename is from --mb1_bin
[ 0.0273 ] psc_bl1_t234_prod_aligned_sigheader.bin.encrypt filename is from --psc_bl1_bin
[ 0.0273 ] rcm boot with presigned binaries
[ 0.0278 ] tegrarcm_v2 --instance 3-13 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
[ 0.0281 ] BR_CID: 0x80012344705DE7452C00000002FF01C0
[ 0.0418 ] Sending bct_br
[ 0.0536 ] Sending mb1
[ 0.0541 ] Sending psc_bl1
[ 0.0709 ] Sending bct_mb1
[ 0.0808 ] Generating blob for T23x
[ 0.0819 ] tegrahost_v2 --chip 0x23 0 --generateblob blob.xml blob.bin
[ 0.0822 ] The number of images in blob is 19
[ 0.0824 ] blobsize is 94111243
[ 0.0825 ] Added binary blob_uefi_jetson_with_dtb_sigheader.bin.encrypt of size 3481664
[ 0.1131 ] Added binary blob_pscfw_t234_prod_sigheader.bin.encrypt of size 310768
[ 0.1137 ] Added binary blob_mce_flash_o10_cr_prod_sigheader.bin.encrypt of size 187120
[ 0.1139 ] Added binary blob_tsec_t234_sigheader.bin.encrypt of size 176128
[ 0.1140 ] Added binary blob_applet_t234_sigheader.bin.encrypt of size 279616
[ 0.1141 ] Not supported type: mb2_applet
[ 0.1142 ] Added binary blob_mb2_t234_with_mb2_cold_boot_bct_MB2_sigheader.bin.encrypt of size 440576
[ 0.1143 ] Added binary blob_xusb_t234_prod_sigheader.bin.encrypt of size 164864
[ 0.1144 ] Added binary blob_nvpva_020_sigheader.fw.encrypt of size 2164640
[ 0.1154 ] Added binary blob_display-t234-dce_sigheader.bin.encrypt of size 779040
[ 0.1158 ] Added binary blob_nvdec_t234_prod_sigheader.fw.encrypt of size 294912
[ 0.1161 ] Added binary blob_bpmp_t234-TE950M-A1_prod_sigheader.bin.encrypt of size 1040512
[ 0.1164 ] Added binary blob_tegra234-bpmp-3767-0003-3509-a02_with_odm_sigheader.dtb.encrypt of size 204672
[ 0.1167 ] Added binary blob_camera-rtcpu-t234-rce_sigheader.img.encrypt of size 458096
[ 0.1169 ] Added binary blob_adsp-fw_sigheader.bin.encrypt of size 415200
[ 0.1171 ] Added binary blob_spe_t234_sigheader.bin.encrypt of size 270336
[ 0.1172 ] Added binary blob_tos-optee_t234_sigheader.img.encrypt of size 1317904
[ 0.1175 ] Added binary blob_eks_t234_sigheader.img.encrypt of size 9232
[ 0.1177 ] Added binary blob_boot0.img of size 81872896
[ 0.1549 ] Added binary blob_tegra234-p3768-0000+p3767-0005-nv.dtb of size 241963
[ 0.2145 ] tegrarcm_v2 --instance 3-13 --chip 0x23 0 --pollbl --download bct_mem mem_rcm_sigheader.bct.encrypt --download blob blob.bin
[ 0.2150 ] BL: version 1.4.0.1-t234-54845784-08e631ca last_boot_error: 0
[ 0.3408 ] Sending bct_mem
[ 0.3530 ] Sending blob
[ 5.8777 ] RCM-boot started
* Step 3: Start the flashing process *
Waiting for target to boot-up...
Waiting for device to expose ssh ......RTNETLINK answers: File exists
Waiting for device to expose ssh ...Run command: flash on fc00:1:1:0::2
SSH ready
blockdev: cannot open /dev/mmcblk3boot0: No such file or directory
[ 0]: l4t_flash_from_kernel: Starting to create gpt for emmc
Active index file is /mnt/internal/flash.idx
Number of lines is 79
max_index=78
writing item=62, 6:0:primary_gpt, 512, 19968, gpt_primary_6_0.bin, 16896, fixed-<reserved>-0, def5d5f2b5994006858a4222b981d993564c1c81
Error: Could not stat device /dev/mmcblk3 - No such file or directory.
Flash failure
Cleaning up...
