• Hardware Platform: GPU (NVIDIA L40S)
• DeepStream Version: 7.1
• CUDA Version: 12.6
• NVIDIA GPU Driver Version: 535.183.06
• Issue Type: Feature request / customization
According to the official DeepStream documentation for the nvdsanalytics plugin:
“For all the analytics calculations, the bottom center coordinate of the bounding box of an object is being used. If the bounding box is defined as
(x_left, y_top, width, height), then the bottom center coordinate would be(x_left + width/2, y_top + height).”
This behavior applies to all analytics features — including ROI-based detections (like region entry/exit, counting, etc.).
In our use case, we’d like the ability to customize the point used for these calculations. Specifically, we’d like to define a relative point in the bounding box.
My questions:
- Is it currently possible to configure this directly within the
nvdsanalyticsplugin? - If not, is the source code available so that this behavior could be modified manually?
Thanks,
Yassin
