Hello again,
This is the output after flashing with normal kernel
root@tegra-ubuntu:/home/ubuntu# uname -a
Linux tegra-ubuntu 3.10.40-gdacac96 #1 SMP PREEMPT Thu Jun 25 15:25:11 PDT 2015 armv7l armv7l armv7l GNU/Linux
the pcie devices:
root@tegra-ubuntu:/home/ubuntu# lspci
00:00.0 PCI bridge: NVIDIA Corporation Device 0e12 (rev a1)
01:00.0 Network controller: Intel Corporation PRO/Wireless 5100 AGN [Shiloh] Network Connection
02:00.0 PCI bridge: NVIDIA Corporation Device 0e13 (rev a1)
03:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 0c)
root@tegra-ubuntu:/home/ubuntu# lspci -s '01:00.0' -vvv
Subsystem: Intel Corporation WiFi Link 5100 AGN
Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr+ Stepping- SERR+ FastB2B- DisINTx-
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 0, Cache Line Size: 64 bytes
Interrupt: pin A routed to IRQ 130
Region 0: Memory at 32200000 (64-bit, non-prefetchable)
Capabilities: [c8] Power Management version 3
Flags: PMEClk- DSI+ D1- D2- AuxCurrent=0mA PME(D0+,D1-,D2-,D3hot+,D3cold+)
Status: D0 NoSoftRst- PME-Enable- DSel=0 DScale=0 PME-
Capabilities: [d0] MSI: Enable- Count=1/1 Maskable- 64bit+
Address: 00000000ad778000 Data: 0003
Capabilities: [e0] Express (v1) Endpoint, MSI 00
DevCap: MaxPayload 128 bytes, PhantFunc 0, Latency L0s <512ns, L1 unlimited
ExtTag- AttnBtn- AttnInd- PwrInd- RBE+ FLReset+
DevCtl: Report errors: Correctable- Non-Fatal- Fatal- Unsupported-
RlxdOrd+ ExtTag- PhantFunc- AuxPwr- NoSnoop+ FLReset-
MaxPayload 128 bytes, MaxReadReq 128 bytes
DevSta: CorrErr- UncorrErr- FatalErr- UnsuppReq- AuxPwr+ TransPend-
LnkCap: Port #0, Speed 2.5GT/s, Width x1, ASPM L0s L1, Exit Latency L0s <128ns, L1 <32us
ClockPM+ Surprise- LLActRep- BwNot-
LnkCtl: ASPM L1 Enabled; RCB 64 bytes Disabled- CommClk+
ExtSynch- ClockPM- AutWidDis- BWInt- AutBWInt-
LnkSta: Speed 2.5GT/s, Width x1, TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
Capabilities: [100 v1] Advanced Error Reporting
UESta: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
UEMsk: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
UESvrt: DLP+ SDES- TLP- FCP+ CmpltTO- CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC- UnsupReq- ACSViol-
CESta: RxErr+ BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr-
CEMsk: RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr+
AERCap: First Error Pointer: 00, GenCap- CGenEn- ChkCap- ChkEn-
Capabilities: [140 v1] Device Serial Number 00-21-6b-ff-ff-5f-4b-88
Kernel modules: iwlwifi
other information (might be useful):
root@tegra-ubuntu:/home/ubuntu# iwconfig
rmnetctl no wireless extensions.
sit0 no wireless extensions.
dummy0 no wireless extensions.
lo no wireless extensions.
eth0 no wireless extensions.
ip6tnl0 no wireless extensions.
root@tegra-ubuntu:/home/ubuntu# lsmod
Module Size Used by
dm_crypt 13259 0
dm_mod 73887 1 dm_crypt
rfcomm 38359 0
bnep 10469 2
bluetooth 307068 10 bnep,rfcomm
iwlwifi 83371 0
cfg80211 367964 1 iwlwifi
rfkill 10365 4 cfg80211,bluetooth
nvhost_vi 3064 0
root@tegra-ubuntu:/home/ubuntu# dmesg | grep iwlwifi
[ 10.142739] iwlwifi 0000:01:00.0: request for firmware file 'iwlwifi-5000-5.ucode' failed.
[ 10.185835] iwlwifi 0000:01:00.0: request for firmware file 'iwlwifi-5000-4.ucode' failed.
[ 10.216445] iwlwifi 0000:01:00.0: request for firmware file 'iwlwifi-5000-3.ucode' failed.
[ 10.239182] iwlwifi 0000:01:00.0: request for firmware file 'iwlwifi-5000-2.ucode' failed.
[ 10.265336] iwlwifi 0000:01:00.0: request for firmware file 'iwlwifi-5000-1.ucode' failed.
[ 10.282217] iwlwifi 0000:01:00.0: no suitable firmware found!
root@tegra-ubuntu:/home/ubuntu# ls /lib/firmware/
hp nvavp_os_0ff00000.bin nvavp_os_8ff00000.bin nvavp_os_eff00000.bin nvavp_os_f7e00000.bin nvavp_vid_ucode_alt.bin tegra12x tegra_xusb_firmware
Would you have any suggestions?
Best regards
R.
