CUSVM CUDA MEX function compilation by VS2008 and unassigned output error .mexw64 cuda-svm training
I compiled the cuda version of support vector machine(cuSVM) using visual c++ 2008 and cuda toolkit 3.2, and the result is the *.mexw64 version of the svm trainig function.
after trying to use this function in MATLAB:
load heart_scale.mat;
data = heart_scale_inst;
    value = heart_scale_label;
C = 10;
    kernel = 0.5;
    stopcrit = 0.001;
[alphas, beta, svs] = cusvm_cuda_mex(value, data, C, kernel, [], stopcrit);
I got the following error:
??? One or more output arguments not assigned during call to "cusvm_cuda_mex".
But, it seems the mexFunction correctly assigned the outputs to plhss.
I don’t know what is the source of the problem. The building phase or the mexFunction code.
My operating system is windows 7 64-bit.
Your help and comments are greatly appreciated.
Here is the svmTrain.cpp (mexFuction code):
#include <mat.h>
#include <mex.h>
extern "C"
void SVMTrain(float *mexalpha,float* beta,float*y,float *x ,float C, float kernelwidth, int m, int n, float StoppingCrit);
extern "C"
void SVRTrain(float *mexalpha,float* beta,float*y,float *x ,float C, float kernelwidth, float eps, int m, int n, float StoppingCrit);
void mexFunction( int nlhs, mxArray *plhs[], int nrhs, const mxArray *prhs[] )
	if (nlhs>3)
		mexErrMsgTxt("cuSVMTrain has at most 3 outputs.");
	if (nrhs>6)
		mexErrMsgTxt("Too many input arguments.");
	if (nrhs<5)
		mexErrMsgTxt("Too few input arguments.");
	if (mxIsClass(prhs[0], "single") + mxIsClass(prhs[1], "single")!=2)
		mexErrMsgTxt("Both the target vector and feature matrix must consist of single precision floats.");
	int n=mxGetN(prhs[1]);
	int m=mxGetM(prhs[1]);
	if (mxGetM(prhs[0])!=m)
		mexErrMsgTxt("The target vector and feature matrix must have the same number of rows.");
	if (mxGetN(prhs[0])!=1)
		mexErrMsgTxt("The target vector must only have one column.");
	if ((mxGetM(prhs[2])!=1) | (mxGetN(prhs[2])!=1)|(mxGetM(prhs[3])!=1) | (mxGetN(prhs[3])!=1)|((nrhs>=5&&(mxIsEmpty(prhs[4])!=1))?(mxGetM(prhs[4])!=1) | (mxGetN(prhs[4])!=1):0)|(nrhs==6?(mxGetM(prhs[5])!=1) | (mxGetN(prhs[5])!=1):0))
		mexErrMsgTxt("The regularization parameter (C), the kernel width, epsilon, and the stopping criterion (if specified) all must be scalars.");
	float C;
	float kernelwidth;
	float eps;
	if (mxIsClass(prhs[2],"double")==1)
		C=(float)*(double *)mxGetData(prhs[2]);
	else if (mxIsClass(prhs[2],"single")==1)
		C=*(float *)mxGetData(prhs[2]);
	else
		mexErrMsgTxt("The regularization parameter (C), the kernel width, epsilon, and the stopping criterion (if specified) all must be either single or double precision floats.");
	if (mxIsClass(prhs[3],"double")==1)
		kernelwidth=(float)*(double *)mxGetData(prhs[3]);
	else if (mxIsClass(prhs[3],"single")==1)
		kernelwidth=*(float *)mxGetData(prhs[3]);
	else
	if (kernelwidth<=0)
		mexErrMsgTxt("The kernel width must be greater than zero.");
	int IsRegression=0;
	if (mxIsEmpty(prhs[4])!=1)
		IsRegression=1;
		if (mxIsClass(prhs[4],"double")==1)
			eps=(float)*(double *)mxGetData(prhs[4]);
		else if (mxIsClass(prhs[4],"single")==1)
			eps=*(float *)mxGetData(prhs[4]);
		else
	float StoppingCrit=0.001;
	if (nrhs==6)
		if (mxIsClass(prhs[5],"double")==1)
			StoppingCrit=(float)*(double *)mxGetData(prhs[5]);
		else if (mxIsClass(prhs[5],"single")==1)
			StoppingCrit=*(float *)mxGetData(prhs[5]);
		else
		if ((StoppingCrit<=0) | (StoppingCrit>=.5) )
			mexErrMsgTxt("The stopping criterion must be greater than zero and less than .5.");
	float* y=(float *)mxGetData(prhs[0]);
	float* x=(float *)mxGetData(prhs[1]);
	plhs[1]=mxCreateNumericMatrix(1, 1,mxSINGLE_CLASS, mxREAL);
	float *beta=(float*)mxGetData(plhs[1]);
	float *alpha=new float [m];
	if (IsRegression)
		SVRTrain(alpha,beta,y,x ,C,kernelwidth,eps ,m,n,StoppingCrit);
	else
		int JustOneClassError=1;
		int NotOneorNegOneError=0;
		float FirstY=y[0];
		for(int k=0;k<m;k++)
			if(y[k]!=FirstY) {JustOneClassError=0;}
			if((y[k]!=1.0) && (y[k]!=-1.0) ){NotOneorNegOneError=1;}
		if (JustOneClassError==1)
			mexErrMsgTxt("All training labels are of the same class.  There must of course be two classes");
		if (NotOneorNegOneError==1)
			mexErrMsgTxt("Training labels must be either 1 or -1.");
		SVMTrain(alpha,beta,y,x ,C,kernelwidth,m,n,StoppingCrit);
	int numSVs=0;
	int numPosSVs=0;
		if(alpha[k]!=0)
			if(IsRegression==0)
				alpha[k]*=y[k];
				if(y[k]>0) {numPosSVs++;}
			numSVs++;
	plhs[0]=mxCreateNumericMatrix(numSVs, 1,mxSINGLE_CLASS, mxREAL);
	float *SvAlphas=(float*)mxGetData(plhs[0]);
	plhs[2]=mxCreateNumericMatrix(numSVs, n,mxSINGLE_CLASS, mxREAL);
	float *Svs=(float*)mxGetData(plhs[2]);
	if(IsRegression==0)
		int PosSvIndex=0;
		int NegSvIndex=0;
			if(alpha[k]!=0)
				if(y[k]>0)
					SvAlphas[PosSvIndex]=alpha[k];
					for(int j=0;j<n;j++)
					{Svs[PosSvIndex+j*numSVs]=x[k+j*m];}
					PosSvIndex++;
				else
					SvAlphas[NegSvIndex+numPosSVs]=alpha[k];
					{Svs[NegSvIndex+numPosSVs+j*numSVs]=x[k+j*m];}
					NegSvIndex++;
	else
		int svindex=0;
			if(alpha[k]!=0)
				SvAlphas[svindex]=alpha[k];
				{Svs[svindex+j*numSVs]=x[k+j*m];}
				svindex++;
	return;
Here is the summary of steps that I followed to compile cuSVM in visual studio 2008.
I wonder if I missed any necessary step. :ermm:
