im having a little trouble comparing float arrays , the CPU one vs the GPU one. using this struct (used in programming guide)
typedef struct {
int width;
int height;
int stride;
float* elements;
} Matrix;
im using the computeGold template and this is what i do:
CUTBoolean res = cutComparef( reference.elements, h_C.elements, h_C.width*h_C.height);
printf( "Test %s\n", (1 == res) ? "PASSED" : "FAILED");
the program receives sizes for Matrix A and Matrix B, then it generates random numbers for both, and finally computes A*B = C
when i print the result of CPU (Matrix reference)and GPU work (Matrix C), they are the same, this is my output when launching my program
(pd: Dont get confused on the GPU time result, here i used small data just for you to understand the problem with the outputs printed. on big matrix GPU times blow CPU 200x even more.)
neoideo@neoideo-desktop:~/Nvidia_SDK/C/bin/linux/debug$ ./simpleMatrixShared 4x4 4x4
A=>4x4
B=>4x4
C=>4x4
ANTES DE RELLENAR ------- ------- DESPUES DE RELLENAR
GPU multiplicacion --- START --- Processing time: 56.550999 (ms) --- END
CPU multiplicacion --- START --- Processing Time: 0.00095367432 (ms) --- END
Test FAILED
-----IMPRIMIENDO MATRIZ-----A
0.366790 0.437543 0.236515 0.894392
0.026073 0.813584 0.102234 0.098250
0.382419 0.049658 0.267055 0.855136
0.579588 0.750424 0.332670 0.865555
-----IMPRIMIENDO MATRIZ-----B
0.988612 0.575575 0.618203 0.785277
0.648654 0.058282 0.159358 0.189566
0.483458 0.537688 0.400861 0.363449
0.818858 0.980238 0.142091 0.185648
-----IMPRIMIENDO MATRIZ-----C
1.493152 1.240504 0.518371 0.622978
0.683389 0.213702 0.200711 0.230098
1.239619 1.204834 0.472884 0.565533
1.929352 1.404655 0.734231 0.878989
-----IMPRIMIENDO MATRIZ-----referencia
-----COMPARANDO MATRIZ-----[Referencia] contra [h_C]
Referencia h_C Diferencia
1.493152 1.493152 0.000000
1.240504 1.240504 0.000000
0.518371 0.518371 0.000000
0.622978 0.622978 0.000000
0.683389 0.683389 0.000000
0.213702 0.213702 0.000000
0.200711 0.200711 0.000000
0.230098 0.230098 0.000000
1.239619 1.239619 0.000000
1.204834 1.204834 0.000000
0.472884 0.472884 0.000000
0.565533 0.565533 0.000000
1.929352 1.929352 0.000000
1.404655 1.404655 0.000000
0.734231 0.734231 0.000000
0.878989 0.878989 0.000000
Press ENTER to exit...
why does it report FAILED? i dont see the problem.
