I have a 2D image described as a cutensor and want to cut out a (smaller) subimage. Can it be done by creating a new tensor descriptor with stride = the original image, while having an extent of the subimage, and then by moving the pointer to the array storing the original image? I need to use multiple subimages from an original image, so I could simply declare a number of such tensors, without having to copy the data.
Is there any problem with aliasing the storage of multiple tensor descriptors where they are only used as input to subsequent calculations?
