Hi.
I’ve made a custom kernel on a custom board. U-boot seems to work fine but when the kernel launches then when the mounting procedure starts it always fails with following error code:
[ 7.859612] EXT4-fs (mmcblk0p1): couldn't mount as ext3 due to feature incompatibilities
[ 7.871812] EXT4-fs (mmcblk0p1): couldn't mount as ext2 due to feature incompatibilities
[ 7.923758] EXT4-fs (mmcblk0p1): recovery complete
[ 7.931321] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 7.943206] VFS: Mounted root (ext4 filesystem) on device 179:1.
[ 7.952125] devtmpfs: error mounting -2
[ 7.958286] Freeing unused kernel memory: 508K (c0b0d000 - c0b8c000)
[ 17.206997] mmc1: Timeout waiting for hardware interrupt.
[ 17.214940] sdhci: =========== REGISTER DUMP (mmc1)===========
[ 17.223279] sdhci: Sys addr: 0x00000000 | Version: 0x00000303
[ 17.231617] sdhci: Blk size: 0x00000000 | Blk cnt: 0x00000000
[ 17.239907] sdhci: Argument: 0x00000c00 | Trn mode: 0x00000000
[ 17.248145] sdhci: Present: 0x01fb00f1 | Host ctl: 0x00000001
[ 17.256358] sdhci: Power: 0x0000000f | Blk gap: 0x00000000
[ 17.264521] sdhci: Wake-up: 0x00000000 | Clock: 0x00000407
[ 17.272637] sdhci: Timeout: 0x00000000 | Int stat: 0x00000000
[ 17.280673] sdhci: Int enab: 0x00ff0003 | Sig enab: 0x00fc0003
[ 17.288640] sdhci: AC12 err: 0x00000000 | Slot int: 0x00000000
[ 17.296530] sdhci: Caps: 0x376fd080 | Caps_1: 0x10002f73
[ 17.304433] sdhci: Cmd: 0x0000341a | Max curr: 0x00000000
[ 17.312312] sdhci: Host ctl2: 0x00003000
[ 17.318244] sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x00000000
[ 17.326078] sdhci: ===========================================
Below is the output log. Do you have any idea what it might be?
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2016.06.09 15:20:55 =~=~=~=~=~=~=~=~=~=~=~=
U-Boot SPL 2014.10-rc2-g32e5aa3-dirty (Jun 09 2016 - 12:52:57)
U-Boot 2014.10-rc2-g32e5aa3-dirty (Jun 09 2016 - 12:52:57)
TEGRA124
Board: Custom Tegra
I2C: ready
DRAM: 2 GiB
MMC: Tegra SD/MMC: 0, Tegra SD/MMC: 1
*** Warning - bad CRC, using default environment
tegra-pcie: PCI regions:
tegra-pcie: I/O: 0x12000000-0x12010000
tegra-pcie: non-prefetchable memory: 0x13000000-0x20000000
tegra-pcie: prefetchable memory: 0x20000000-0x40000000
tegra-pcie: 2x1, 1x1 configuration
tegra-pcie: probing port 0, using 2 lanes
tegra-pcie: link 0 down, retrying
tegra-pcie: link 0 down, ignoring
tegra-pcie: probing port 1, using 1 lanes
tegra-pcie: link 1 down, retrying
tegra-pcie: link 1 down, ignoring
In: serial
Out: serial
Err: serial
Net: No ethernet found.
Hit any key to stop autoboot: 2 1 0
Card did not respond to voltage select!
switch to partitions #0, OK
mmc0(part 0) is current device
Scanning mmc 0...
Found /boot/extlinux/extlinux.conf
Retrieving file: /boot/extlinux/extlinux.conf
786 bytes read in 91 ms (7.8 KiB/s)
Custom eMMC boot options
1:primary kernel
Enter choice: 1:primary kernel
Retrieving file: /boot/zImage
6030472 bytes read in 193 ms (29.8 MiB/s)
append: console=ttyS0,115200n8 console=tty1 no_console_suspend=1 lp0_vec=2064@0xf46ff000 mem=2015M@2048M memtype=255 ddr_die=2048M@2048M section=256M pmuboard=0x0177:0x0000:0x42:0x44:0x00 tsec=32M@3913M otf_key=c75e5bb91eb3bd947560357b64422f85 usbcore.old_scheme_first=1 core_edp_mv=1150 core_edp_ma=4000 tegraid=40.1.1.0.0 debug_uartport=lsport,3 power_supply=Adapter audio_codec=rt5640 modem_id=0 android.kerneltype=normal fbcon=map:1 commchip_id=0 usb_port_owner_info=0 lane_owner_info=6 emc_max_dvfs=0 touch_id=0@0 board_info=0x0177:0x0000:0x42:0x44:0x00 root=/dev/mmcblk0p1 rw rootwait tegraboot=sdmmc gpt
Retrieving file: /boot/tegra124-custom.dtb
53760 bytes read in 57 ms (920.9 KiB/s)
Kernel image @ 0x81000000 [ 0x000000 - 0x5c0488 ]
## Flattened Device Tree blob at 82000000
Booting using the fdt blob at 0x82000000
Using Device Tree in place at 82000000, end 820101ff
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Initializing cgroup subsys cpu
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 3.10.40-g96cd90e-dirty (dimtass@dimtass-ThinkPad-T520) (gcc version 4.9.2 (GCC) ) #2 SMP PREEMPT Thu Jun 9 15:13:04 BST 2016
[ 0.000000] CPU: ARMv7 Processor [413fc0f3] revision 3 (ARMv7), cr=10c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
[ 0.000000] Machine: jetson-tk1, model: NVIDIA Tegra124 PM375, serial: 0
[ 0.000000] Truncating memory at 0x80000000 to fit in 32-bit physical address space
[ 0.000000] Found tsec, start=0xf4900000 size=2000000
[ 0.000000] Tegra reserved memory:
[ 0.000000] LP0: f46ff000 - f46ff80f
[ 0.000000] Bootloader framebuffer: 00000000 - 00000000
[ 0.000000] Bootloader framebuffer2: 00000000 - 00000000
[ 0.000000] Framebuffer: f8500000 - f96fffff
[ 0.000000] 2nd Framebuffer: f9700000 - fdefffff
[ 0.000000] Carveout: 00000000 - 00000000
[ 0.000000] Vpr: 00000000 - 00000000
[ 0.000000] Tsec: f4900000 - f68fffff
[ 0.000000] cma: CMA: reserved 16 MiB at ae800000
[ 0.000000] Memory policy: ECC disabled, Data cache writealloc
[ 0.000000] DTS File Name: arch/arm/boot/dts/tegra124-custom.dts
[ 0.000000] Tegra12: CPU Speedo value 2276, Soc Speedo value 2219, Gpu Speedo value 2066
[ 0.000000] Tegra12: CPU Speedo ID 5, Soc Speedo ID 0, Gpu Speedo ID 1
[ 0.000000] Tegra12: CPU Process ID 0,Soc Process ID 1,Gpu Process ID 0
[ 0.000000] Tegra Revision: A01 SKU: 0x87 CPU Process: 0 Core Process: 1
[ 0.000000] tegra: PLLP fixed rate: 408000000
[ 0.000000] tegra_clk_shared_bus_user_init: c2bus client se left ON
[ 0.000000] tegra_clk_shared_bus_user_init: c4bus client vi left ON
[ 0.000000] Lowering cpu_lp maximum rate from 1350000000 to 1044000000
[ 0.000000] Lowering sbus maximum rate from 420000000 to 372000000
[ 0.000000] Lowering vic03 maximum rate from 900000000 to 756000000
[ 0.000000] Lowering tsec maximum rate from 900000000 to 756000000
[ 0.000000] Lowering msenc maximum rate from 600000000 to 480000000
[ 0.000000] Lowering se maximum rate from 600000000 to 480000000
[ 0.000000] Lowering vde maximum rate from 600000000 to 480000000
[ 0.000000] Lowering host1x maximum rate from 500000000 to 408000000
[ 0.000000] Lowering vi maximum rate from 700000000 to 600000000
[ 0.000000] Lowering isp maximum rate from 700000000 to 600000000
[ 0.000000] Lowering c4bus maximum rate from 700000000 to 600000000
[ 0.000000] Lowering pll_c maximum rate from 1400000000 to 1066000000
[ 0.000000] Lowering pll_c2 maximum rate from 1200000000 to 1066000000
[ 0.000000] Lowering pll_c3 maximum rate from 1200000000 to 1066000000
[ 0.000000] Lowering hdmi maximum rate from 594000000 to 297000000
[ 0.000000] Lowering sdmmc1 maximum rate from 208000000 to 204000000
[ 0.000000] Lowering sdmmc3 maximum rate from 208000000 to 204000000
[ 0.000000] Lowering gbus maximum rate from 1032000000 to 852000000
[ 0.000000] Lowering cpu_g maximum rate from 3000000000 to 2218500000
[ 0.000000] tegra dvfs: VDD_CPU nominal 1260mV, scaling enabled
[ 0.000000] tegra dvfs: VDD_CORE nominal 1150mV, scaling enabled
[ 0.000000] tegra dvfs: VDD_GPU nominal 1200mV, scaling enabled
[ 0.000000] Switching to timer-based delay loop
[ 0.000000] tegra_powergate_init: DONE
[ 0.000000] tegra12_plle_clk_enable: pll_e is already enabled
[ 0.000000] PERCPU: Embedded 9 pages/cpu @c1df1000 s15360 r8192 d13312 u36864
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 490768
[ 0.000000] Kernel command line: console=ttyS0,115200n8 console=tty1 no_console_suspend=1 lp0_vec=2064@0xf46ff000 mem=2015M@2048M memtype=255 ddr_die=2048M@2048M section=256M pmuboard=0x0177:0x0000:0x42:0x44:0x00 tsec=32M@3913M otf_key=c75e5bb91eb3bd947560357b64422f85 usbcore.old_scheme_first=1 core_edp_mv=1150 core_edp_ma=4000 tegraid=40.1.1.0.0 debug_uartport=lsport,3 power_supply=Adapter audio_codec=rt5640 modem_id=0 android.kerneltype=normal fbcon=map:1 commchip_id=0 usb_port_owner_info=0 lane_owner_info=6 emc_max_dvfs=0 touch_id=0@0 board_info=0x0177:0x0000:0x42:0x44:0x00 root=/dev/mmcblk0p1 rw rootwait tegraboot=sdmmc gpt
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Memory: 1923MB = 1923MB total
[ 0.000000] Memory: 1921008k/1921008k available, 142352k reserved, 1190908K highmem
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
[ 0.000000] vmalloc : 0xf0000000 - 0xff000000 ( 240 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xef800000 ( 760 MB)
[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
[ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
[ 0.000000] .text : 0xc0008000 - 0xc0b0cc7c (11284 kB)
[ 0.000000] .init : 0xc0b0d000 - 0xc0b8cc00 ( 511 kB)
[ 0.000000] .data : 0xc0b8e000 - 0xc0ce91e0 (1389 kB)
[ 0.000000] .bss : 0xc0ce91e0 - 0xc0d8404c ( 620 kB)
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] NR_IRQS:960
[ 0.000000] the number of interrupt controllers found is 5
[ 0.000000] Architected local timer running at 12.00MHz (phys).
[ 0.000000] sched_clock: 56 bits at 12MHz, resolution 83ns, wraps every 2863311536128ns
[ 0.000000] Ignoring duplicate/late registration of read_current_timer delay
[ 0.000000] Console: colour dummy device 80x30
[ 0.000000] console [tty1] enabled
[ 0.002825] Calibrating delay loop (skipped), value calculated using timer frequency.. lpj=12000
[ 0.002881] pid_max: default: 32768 minimum: 301
[ 0.003161] Mount-cache hash table entries: 512
[ 0.024079] Initializing cgroup subsys debug
[ 0.024116] Initializing cgroup subsys freezer
[ 0.024195] CPU: Testing write buffer coherency: ok
[ 0.024270] ftrace: allocating 30500 entries in 60 pages
[ 0.062259] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.062301] Setting up static identity map for 0xc07f71c0 - 0xc07f7254
[ 0.066280] ftrace: Allocated trace_printk buffers
[ 0.073907] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.076916] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[ 0.079954] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[ 0.080066] Brought up 4 CPUs
[ 0.080127] SMP: Total of 4 processors activated.
[ 0.080143] CPU: All CPU(s) started in SVC mode.
[ 0.081061] devtmpfs: initialized
[ 0.089784] pinctrl core: initialized pinctrl subsystem
[ 0.090103] regulator-dummy: no parameters
[ 0.090799] NET: Registered protocol family 16
[ 0.093097] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.094358] tegra_smmu tegra_smmu: Loaded Tegra IOMMU driver
[ 0.095378] console [pstore-1] enabled
[ 0.095416] ramoops: attached 0x200000@0xf8300000, ecc: 0/0
[ 0.095780] cpuidle: using governor ladder
[ 0.095801] cpuidle: using governor menu
[ 0.099631] ardbeg_camera_auxdata: update camera lookup table.
[ 0.108576] tegra-gpio 6000d000.gpio: Initialising GPIO state 0: name default
[ 0.109242] gpiochip_add: registered GPIOs 0 to 255 on device: tegra-gpio
[ 0.115965] Wake16 for irq=34
[ 0.118366] Wake58 for irq=81
[ 0.118416] Wake41 for irq=129
[ 0.118433] Wake43 for irq=129
[ 0.118478] Wake40 for irq=53
[ 0.118494] Wake42 for irq=53
[ 0.122601] board_info: id:sku:fab:major:minor = 0x0177:0x0000:0x42:0x44:0x00
[ 0.122699] board_info: id:sku:fab:major:minor = 0x0177:0x0000:0x42:0x44:0x00
[ 0.122784] Selecting UARTD as the debug console
[ 0.122830] The debug console clock name is uartd
[ 0.123237] ardbeg_modem_init: modem_id = 0
[ 0.125877] Clear bootloader IO dpd settings
[ 0.126102] Loading jetson TK1 EMC tables.
[ 0.126347] tegra: pll_m is selected as scalable EMC clock source
[ 0.126389] Lowering emc maximum rate from 1200000000 to 924000000
[ 0.126416] tegra: validated EMC DFS table
[ 0.126542] ardbeg_edp_init: CPU regulator 11000 mA
[ 0.407831] ardbeg_edp_init: GPU regulator 11400 mA
[ 0.408777] swapper/0 isomgr_init(): iso emc max clk=924000KHz
[ 0.408798] swapper/0 isomgr_init(): max_iso_bw=7392000KB[ 0.409150] ardbeg_touch_init init raydium touch
[ 0.409301] Raydium - touch platform_id : 8
[ 0.492151] platform tegradc.0: IOVA linear map 0xf8500000(1200000)
[ 0.495453] platform tegradc.0: IOVA linear map 0xf9700000(4800000)
[ 0.500456] platform tegradc.1: IOVA linear map 0xf8500000(1200000)
[ 0.503751] platform tegradc.1: IOVA linear map 0xf9700000(4800000)
[ 0.504176] FUSE: cp_rev 0 ft_rev 0
[ 0.504347] tegra11_soctherem_oc_int_init(): OC interrupts are not enabled
[ 0.504756] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.504786] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.505057] mc-err: Started MC error interface!
[ 0.515663] bio: create slab <bio-0> at 0
[ 0.517501] reg-fixed-voltage 0.regulator: Consumer c1 does not have device name
[ 0.517554] reg-fixed-voltage 0.regulator: Consumer c2 does not have device name
[ 0.517679] vdd-ac-bat: 8400 mV
[ 0.517816] reg-fixed-voltage 1.regulator: Consumer c1 does not have device name
[ 0.517849] reg-fixed-voltage 1.regulator: Consumer c2 does not have device name
[ 0.517970] vdd-3v3-aon: 3300 mV
[ 0.518123] reg-fixed-voltage 8.regulator: Consumer c1 does not have device name
[ 0.518156] reg-fixed-voltage 8.regulator: Consumer c2 does not have device name
[ 0.518187] reg-fixed-voltage 8.regulator: Consumer c3 does not have device name
[ 0.518222] reg-fixed-voltage 8.regulator: Consumer c6 does not have device name
[ 0.518252] reg-fixed-voltage 8.regulator: Consumer c7 does not have device name
[ 0.518282] reg-fixed-voltage 8.regulator: Consumer c8 does not have device name
[ 0.518311] reg-fixed-voltage 8.regulator: Consumer c9 does not have device name
[ 0.518341] reg-fixed-voltage 8.regulator: Consumer c10 does not have device name
[ 0.518371] reg-fixed-voltage 8.regulator: Consumer c11 does not have device name
[ 0.518400] reg-fixed-voltage 8.regulator: Consumer c12 does not have device name
[ 0.518531] reg-3v3-supply: 3300 mV
[ 0.520147] vgaarb: loaded
[ 0.520775] SCSI subsystem initialized
[ 0.521143] usbcore: registered new interface driver usbfs
[ 0.521213] usbcore: registered new interface driver hub
[ 0.521318] usbcore: registered new device driver usb
[ 0.524141] as3722 4-0040: AS3722 ID: ID1:ID2:ID3 = 0x0c:0x01:0x15
[ 0.524170] as3722 4-0040: Final OTP version 1V21
[ 0.529602] gpiochip_add: registered GPIOs 1016 to 1023 on device: as3722-gpio
[ 0.529826] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
[ 0.529885] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
[ 0.529936] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
[ 0.529967] as3722-regulator as3722-regulator.0: Consumer c2 does not have device name
[ 0.529997] as3722-regulator as3722-regulator.0: Consumer c3 does not have device name
[ 0.530028] as3722-regulator as3722-regulator.0: Consumer c4 does not have device name
[ 0.530085] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
[ 0.530115] as3722-regulator as3722-regulator.0: Consumer c2 does not have device name
[ 0.530146] as3722-regulator as3722-regulator.0: Consumer c3 does not have device name
[ 0.530176] as3722-regulator as3722-regulator.0: Consumer c4 does not have device name
[ 0.530206] as3722-regulator as3722-regulator.0: Consumer c5 does not have device name
[ 0.530236] as3722-regulator as3722-regulator.0: Consumer c6 does not have device name
[ 0.530266] as3722-regulator as3722-regulator.0: Consumer c7 does not have device name
[ 0.530331] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
[ 0.530361] as3722-regulator as3722-regulator.0: Consumer c2 does not have device name
[ 0.530391] as3722-regulator as3722-regulator.0: Consumer c3 does not have device name
[ 0.530421] as3722-regulator as3722-regulator.0: Consumer c4 does not have device name
[ 0.530453] as3722-regulator as3722-regulator.0: Consumer c6 does not have device name
[ 0.530486] as3722-regulator as3722-regulator.0: Consumer c8 does not have device name
[ 0.530516] as3722-regulator as3722-regulator.0: Consumer c9 does not have device name
[ 0.530546] as3722-regulator as3722-regulator.0: Consumer c10 does not have device name
[ 0.530577] as3722-regulator as3722-regulator.0: Consumer c11 does not have device name
[ 0.530607] as3722-regulator as3722-regulator.0: Consumer c12 does not have device name
[ 0.530638] as3722-regulator as3722-regulator.0: Consumer c13 does not have device name
[ 0.530668] as3722-regulator as3722-regulator.0: Consumer c14 does not have device name
[ 0.530717] as3722-regulator as3722-regulator.0: Consumer c15 does not have device name
[ 0.530773] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
[ 0.530804] as3722-regulator as3722-regulator.0: Consumer c2 does not have device name
[ 0.530856] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
[ 0.530887] as3722-regulator as3722-regulator.0: Consumer c2 does not have device name
[ 0.530917] as3722-regulator as3722-regulator.0: Consumer c3 does not have device name
[ 0.530947] as3722-regulator as3722-regulator.0: Consumer c4 does not have device name
[ 0.530976] as3722-regulator as3722-regulator.0: Consumer c5 does not have device name
[ 0.531006] as3722-regulator as3722-regulator.0: Consumer c6 does not have device name
[ 0.531037] as3722-regulator as3722-regulator.0: Consumer c7 does not have device name
[ 0.531067] as3722-regulator as3722-regulator.0: Consumer c8 does not have device name
[ 0.531096] as3722-regulator as3722-regulator.0: Consumer c9 does not have device name
[ 0.531153] as3722-regulator as3722-regulator.0: Consumer c2 does not have device name
[ 0.531184] as3722-regulator as3722-regulator.0: Consumer c3 does not have device name
[ 0.531271] as3722-regulator as3722-regulator.0: Consumer c8 does not have device name
[ 0.531302] as3722-regulator as3722-regulator.0: Consumer c9 does not have device name
[ 0.531332] as3722-regulator as3722-regulator.0: Consumer c10 does not have device name
[ 0.531386] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
[ 0.531435] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
[ 0.531465] as3722-regulator as3722-regulator.0: Consumer c2 does not have device name
[ 0.531495] as3722-regulator as3722-regulator.0: Consumer c3 does not have device name
[ 0.531549] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
[ 0.531579] as3722-regulator as3722-regulator.0: Consumer c2 does not have device name
[ 0.531635] as3722-regulator as3722-regulator.0: Consumer c2 does not have device name
[ 0.531688] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
[ 0.531736] as3722-regulator as3722-regulator.0: Consumer c2 does not have device name
[ 0.531810] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
[ 0.531841] as3722-regulator as3722-regulator.0: Consumer c2 does not have device name
[ 0.531871] as3722-regulator as3722-regulator.0: Consumer c3 does not have device name
[ 0.532784] vdd-cpu: 650 <--> 1300 mV at 1000 mV 3500 mA
[ 0.533536] vdd-core: applied init 1000000uV constraint
[ 0.534132] vdd-core: 700 <--> 1350 mV at 1000 mV 3500 mA
[ 0.535315] vddio-ddr: at 1350 mV
[ 0.535638] as3722-sd3: no parameters
[ 0.536232] avdd-pll-pex: 1050 mV
[ 0.537416] vdd-1v8: at 1800 mV
[ 0.537750] vdd-gpu: applied init 1000000uV constraint
[ 0.538638] vdd-gpu: 650 <--> 1200 mV at 1000 mV 3500 mA
[ 0.539172] avdd-pll: at 1050 mV at 300 mA
[ 0.540444] vdd-cam: 1800 mV at 150 mA
[ 0.541107] avdd-dsi-csi: at 1200 mV at 150 mA
[ 0.542323] vdd-rtc: 800 mV at 150 mA
[ 0.542789] avdd-cam: 2800 mV at 150 mA
[ 0.543288] vdd-1v2-cam: 1175 mV at 150 mA
[ 0.543649] vddio-sdmmc-2: 1800 <--> 3300 mV at 150 mA
[ 0.544138] vdd-1v1-cam: 1275 mV at 150 mA
[ 0.545089] avdd-spi: 3300 mV at 150 mA
[ 0.545579] vdd-2v7-cam: 2800 mV at 150 mA
[ 0.546078] vpp-fuse: 1800 mV at 150 mA
[ 0.547155] Linux video capture interface: v2.00
[ 0.548248] Advanced Linux Sound Architecture Driver Initialized.
[ 0.548679] ardbeg_wifi_power: 1
[ 0.649026] usb0-vbus: 5000 mV
[ 0.649329] usb1-usb2-vbus: 5000 mV
[ 0.649635] vdd-hdmi: 5000 mV
[ 0.649915] avdd-hdmi-pll: 3300 mV
[ 0.649963] avdd-hdmi-pll: supplied by avdd-pll-pex
[ 0.650130] reg-fixed-sync-voltage 6.regulator: Consumer c1 does not have device name
[ 0.650270] vdd-lcd-bl: 3300 mV
[ 0.650445] reg-fixed-sync-voltage 7.regulator: Consumer c1 does not have device name
[ 0.650614] vdd-lcd-bl-en: 5000 mV
[ 0.650764] reg-fixed-sync-voltage 9.regulator: Consumer c3 does not have device name
[ 0.650884] reg-5v0-supply: 5000 mV
[ 0.651047] reg-fixed-sync-voltage a.regulator: Consumer c1 does not have device name
[ 0.651080] reg-fixed-sync-voltage a.regulator: Consumer c2 does not have device name
[ 0.651111] reg-fixed-sync-voltage a.regulator: Consumer c3 does not have device name
[ 0.651158] reg-fixed-sync-voltage a.regulator: Consumer c10 does not have device name
[ 0.651188] reg-fixed-sync-voltage a.regulator: Consumer c11 does not have device name
[ 0.651218] reg-fixed-sync-voltage a.regulator: Consumer c12 does not have device name
[ 0.651248] reg-fixed-sync-voltage a.regulator: Consumer c13 does not have device name
[ 0.651278] reg-fixed-sync-voltage a.regulator: Consumer c14 does not have device name
[ 0.651308] reg-fixed-sync-voltage a.regulator: Consumer c15 does not have device name
[ 0.651447] reg-1v8-supply: 1800 mV
[ 0.651774] reg-fixed-sync-voltage b.regulator: Consumer c1 does not have device name
[ 0.651925] reg-dcdc-1v2: 1200 mV
[ 0.652101] reg-fixed-sync-voltage c.regulator: Consumer c7 does not have device name
[ 0.652134] reg-fixed-sync-voltage c.regulator: Consumer c8 does not have device name
[ 0.652688] as3722-gpio2-supply: 3300 mV
[ 0.652894] reg-fixed-sync-voltage d.regulator: Consumer c1 does not have device name
[ 0.653401] as3722-gpio4-supply: 3300 mV
[ 0.653706] sdmmc-en-supply: 3300 mV
[ 0.653956] vdd-cdc-1v2-aud: 1200 mV
[ 0.654113] reg-fixed-sync-voltage 10.regulator: Consumer c1 does not have device name
[ 0.654146] reg-fixed-sync-voltage 10.regulator: Consumer c2 does not have device name
[ 0.654177] reg-fixed-sync-voltage 10.regulator: Consumer c3 does not have device name
[ 0.654296] reg-aon-1v8: 1800 mV
[ 0.654453] reg-fixed-sync-voltage 11.regulator: Consumer c1 does not have device name
[ 0.654574] reg-aon-1v2: 1200 mV
[ 0.657573] as3722-adc-extcon as3722-adc-extcon.2: USB-Host is disconnected
[ 0.660870] tegra: started io power detection dynamic control
[ 0.660896] tegra: NO_IO_POWER setting 0x0
[ 0.660921] Switching to clocksource arch_sys_counter
[ 0.682154] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 0.682343] nvmap_page_pool_init: Total MB RAM: 1891
[ 0.682366] nvmap_page_pool_init: nvmap page pool size: 60543 pages (236 MB)
[ 0.682521] nvmap_background_zero_thread: PP zeroing thread starting.
[ 0.682686] iram: dma coherent mem declare 0x40001000,258048
[ 0.683529] misc nvmap: created heap iram base 0x40001000 size (252KiB)
[ 0.683688] nvmap:inner cache maint threshold=2097152
[ 0.692961] Wake39 for irq=52
[ 0.693075] tegra-otg tegra-otg: otg transceiver registered
[ 0.693411] NET: Registered protocol family 2
[ 0.694083] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.694298] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.694490] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.694548] TCP: reno registered
[ 0.694572] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.694627] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.694925] NET: Registered protocol family 1
[ 0.695319] RPC: Registered named UNIX socket transport module.
[ 0.695343] RPC: Registered udp transport module.
[ 0.695362] RPC: Registered tcp transport module.
[ 0.695380] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.695659] tegra-fuse tegra-fuse: Fuse driver initialized succesfully
[ 0.701098] host1x host1x: initialized
[ 0.702346] CPU PMU: probing PMU on CPU 0
[ 0.702380] hw perfevents: enabled with ARMv7 Cortex-A15 PMU driver, 7 counters available
[ 0.702996] tegra_throttle : init passed
[ 0.703113] Tegra cpuquiet initialized: disabled
[ 0.703242] cpu-tegra: init EDP limit: 2218 MHz
[ 0.704216] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type CPU-therm
[ 0.704585] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type GPU-therm
[ 0.704809] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type MEM-therm
[ 0.705074] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[ 0.706542] bounce pool size: 64 pages
[ 0.707965] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[ 0.708267] NTFS driver 2.1.30 [Flags: R/O].
[ 0.708412] fuse init (API version 7.22)
[ 0.708648] msgmni has been set to 1457
[ 0.710004] io scheduler noop registered (default)
[ 0.911362] PCIE: port 0: link down, retrying
[ 1.111487] PCIE: port 0: link down, retrying
[ 1.311610] PCIE: port 0: link down, retrying
[ 1.311631] PCIE: port 0: link down, ignoring
[ 1.511757] PCIE: port 1: link down, retrying
[ 1.711879] PCIE: port 1: link down, retrying
[ 1.912029] PCIE: port 1: link down, retrying
[ 1.912050] PCIE: port 1: link down, ignoring
[ 1.912068] PCIE: no ports detected
[ 1.913512] pwm-backlight pwm-backlight: unable to request PWM, trying legacy API
[ 1.913617] sysedp_create_consumer: unable to create pwm-backlight, no consumer_data for pwm-backlight found
[ 1.914540] tsec tsec: initialized
[ 1.915974] isp isp.0: initialized
[ 1.916937] isp isp.1: initialized
[ 1.918521] falcon vic03.0: initialized
[ 1.919716] falcon msenc: initialized
[ 1.920528] tegradc tegradc.0: DSI: HS clock rate is 464500
[ 1.921845] p,wuxga-10-1 panel dt support not available
[ 2.202497] tegradc tegradc.0: nominal-pclk:154700000 parent:154500000 div:1.0 pclk:154500000 153153000~168623000
[ 2.292155] tegradc tegradc.0: DSI pad calibration done
[ 2.299305] tegradc tegradc.0: probed
[ 2.299759] tegradc tegradc.0: fb registered
[ 2.299785] tegradc tegradc.0: nominal-pclk:154679000 parent:463500000 div:3.0 pclk:154500000 153132210~168600110
[ 2.305610] gpio wake4 for gpio=111
[ 2.305892] tegra-i2c tegra12-i2c.3: no acknowledge from address 0x50
[ 2.306860] tegradc tegradc.1: probed
[ 2.310975] Console: switching to colour frame buffer device 80x30
[ 2.315800] tegradc tegradc.1: fb registered
[ 2.317608] hdmi_state_machine_worker (tid edafd580): state 7 (Takeover from bootloader), hpd 0, pending_hpd_evt 1
[ 2.321264] hdmi_state_machine_set_state_l: switching from state 7 (Takeover from bootloader) to state 0 (Reset)
[ 2.324702] tegra-apbdma tegra-apbdma: Tegra20 APB DMA driver register 32 channels
[ 2.325462] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 2.326744] serial8250.0: ttyS0 at MMIO 0x70006300 (irq = 122) is a Tegra
[ 2.372035] hdmi_state_machine_worker (tid edafd580): state 0 (Reset), hpd 0, pending_hpd_evt 0
[ 2.372039] hdmi_disable_l: audio_switch 0
[ 2.372042] hdmi_disable_l: hpd_switch 0
[ 2.372048] hdmi_state_machine_set_state_l: switching from state 0 (Reset) to state 1 (Check Plug)
[ 2.382024] hdmi_state_machine_worker (tid edafd580): state 1 (Check Plug), hpd 0, pending_hpd_evt 0
[ 2.382027] hdmi_disable_l: audio_switch 0
[ 2.382030] hdmi_disable_l: hpd_switch 0
[ 2.382035] hdmi_state_machine_set_state_l: switching from state 1 (Check Plug) to state 3 (Disabled)
[ 4.529508] console [ttyS0] enabled
[ 4.535539] serial-tegra.0: ttyTHS0 at MMIO 0x70006000 (irq = 68) is a SERIAL_TEGRA
[ 4.547700] serial-tegra.1: ttyTHS1 at MMIO 0x70006040 (irq = 69) is a SERIAL_TEGRA
[ 4.559955] serial-tegra.2: ttyTHS2 at MMIO 0x70006200 (irq = 78) is a SERIAL_TEGRA
[ 4.577081] loop: module loaded
[ 4.582698] nct1008_nct72 0-004c: success in enabling rail vdd_nct72
[ 4.591468] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x4c
[ 4.600360] nct1008_nct72 0-004c: nct1008_read_reg: err -121
[ 4.608326] NCT72: ERR: remote sensor circuit is open (0xffffff87)
[ 4.616927] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x4c
[ 4.625821] nct1008_nct72 0-004c: nct1008_write_reg: err -121
[ 4.633909] nct1008_nct72 0-004c:
[ 4.633909] exit nct1008_configure_sensor, err=-121
[ 4.646888] nct1008_nct72 0-004c:
[ 4.646888] error file: drivers/misc/nct1008.c : nct1008_probe(), line=1453
[ 4.661858] nct1008_nct72 0-004c:
[ 4.661858] exit nct1008_probe, err=-121
[ 4.673667] nct1008_nct72 0-004c: success in disabling rail vdd_nct72
[ 4.682313] nct1008_nct72: probe of 0-004c failed with error -121
[ 4.691055] tegra_profiler: Branch: Dev
[ 4.697010] tegra_profiler: Version: 1.103
[ 4.703129] tegra_profiler: Samples version: 34
[ 4.709643] tegra_profiler: IO version: 18
[ 4.715630] armv7_pmu: arch: Cortex A15, type: 4, ver: 0
[ 4.723022] tegra_profiler: auth: init
[ 4.728888] GPS: mt3332_gps_mod_init: platform_driver_register ret = 0
[ 4.738601] tegra-sata tegra-sata.0: AHCI 0001.0301 32 slots 2 ports 3 Gbps 0x1 impl TEGRA-SATA mode
[ 4.751330] tegra-sata tegra-sata.0: flags: 64bit ncq sntf pm led pmp pio slum part sadm apst
[ 4.764670] scsi0 : tegra-sata
[ 4.769895] scsi1 : tegra-sata
[ 4.774900] ata1: SATA max UDMA/133 irq 55
[ 4.780719] ata2: DUMMY
[ 4.786612] tun: Universal TUN/TAP device driver, 1.6
[ 4.793348] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 4.801535] usbcore: registered new interface driver asix
[ 4.808728] usbcore: registered new interface driver ax88179_178a
[ 4.816568] usbcore: registered new interface driver cdc_ether
[ 4.824132] usbcore: registered new interface driver smsc95xx
[ 4.831487] usbcore: registered new interface driver cdc_subset
[ 4.839053] usbcore: registered new interface driver cdc_ncm
[ 4.846236] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 4.854471] tegra USB phy - inst[1] platform info:
[ 4.860758] port_otg: no
[ 4.864779] has_hostpc: yes
[ 4.869084] phy_interface: USB_PHY_INTF_UTMI
[ 4.874888] op_mode: TEGRA_USB_OPMODE_HOST
[ 4.880489] qc2_voltage: 0
[ 4.884659] vbus_gpio: -1
[ 4.888692] hot_plug: disabled
[ 4.893126] remote_wakeup: enabled
[ 4.899322] tegra-ehci tegra-ehci.1: Tegra EHCI Host Controller
[ 4.906580] tegra-ehci tegra-ehci.1: new USB bus registered, assigned bus number 1
[ 4.916772] Wake40 for irq=53
[ 4.921038] Wake42 for irq=53
[ 4.925304] tegra-ehci tegra-ehci.1: irq 53, io mem 0x7d004000
[ 4.938014] tegra-ehci tegra-ehci.1: USB 2.0 started, EHCI 1.10
[ 4.945344] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 4.953511] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 4.963394] usb usb1: Product: Tegra EHCI Host Controller
[ 4.970248] usb usb1: Manufacturer: Linux 3.10.40-g96cd90e-dirty ehci_hcd
[ 4.978555] usb usb1: SerialNumber: tegra-ehci.1
[ 4.985237] hub 1-0:1.0: USB hub found
[ 4.990583] hub 1-0:1.0: 1 port detected
[ 4.996352] tegra USB phy - inst[2] platform info:
[ 5.002642] port_otg: no
[ 5.006673] has_hostpc: yes
[ 5.010934] phy_interface: USB_PHY_INTF_UTMI
[ 5.016689] op_mode: TEGRA_USB_OPMODE_HOST
[ 5.022275] qc2_voltage: 0
[ 5.026467] vbus_gpio: -1
[ 5.030551] hot_plug: disabled
[ 5.035077] remote_wakeup: enabled
[ 5.041397] tegra-ehci tegra-ehci.2: Tegra EHCI Host Controller
[ 5.048882] tegra-ehci tegra-ehci.2: new USB bus registered, assigned bus number 2
[ 5.059498] Wake41 for irq=129
[ 5.064008] Wake43 for irq=129
[ 5.068579] tegra-ehci tegra-ehci.2: irq 129, io mem 0x7d008000
[ 5.082016] tegra-ehci tegra-ehci.2: USB 2.0 started, EHCI 1.10
[ 5.089558] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 5.092041] ata1: SATA link down (SStatus 0 SControl 300)
[ 5.104863] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 5.115123] usb usb2: Product: Tegra EHCI Host Controller
[ 5.122115] usb usb2: Manufacturer: Linux 3.10.40-g96cd90e-dirty ehci_hcd
[ 5.130484] usb usb2: SerialNumber: tegra-ehci.2
[ 5.137157] hub 2-0:1.0: USB hub found
[ 5.142507] hub 2-0:1.0: 1 port detected
[ 5.148297] ehci-pci: EHCI PCI platform driver
[ 5.154544] tegra_xusb_read_usb_calib: usb_calib0 = 0x0285038a
[ 5.162237] usbcore: registered new interface driver usb-storage
[ 5.170012] usbcore: registered new interface driver usbserial
[ 5.177495] usbcore: registered new interface driver option
[ 5.184702] usbserial: USB Serial support registered for GSM modem (1-port)
[ 5.193437] usbcore: registered new interface driver pl2303
[ 5.200730] usbserial: USB Serial support registered for pl2303
[ 5.208429] Nvidia Tegra High-Speed USB Device Controller driver (Apr 30, 2012)
[ 5.219330] tegra USB phy - inst[0] platform info:
[ 5.225871] port_otg: yes
[ 5.230239] has_hostpc: yes
[ 5.234778] phy_interface: USB_PHY_INTF_UTMI
[ 5.240795] op_mode: TEGRA_USB_OPMODE_DEVICE
[ 5.246810] qc2_voltage: 0
[ 5.251248] vbus_pmu_irq: 0
[ 5.255680] vbus_gpio: -1
[ 5.259852] charging: enabled
[ 5.264304] remote_wakeup: disabled
[ 5.271971] tegra-udc tegra-udc.0: usb_bat_chg regulator not registered: USB charging will not be enabled
[ 5.287529] as3722-rtc as3722-rtc.1: rtc core: registered as3722 as rtc0
[ 5.295875] as3722-rtc as3722-rtc.1: RTC interrupt 449
[ 5.305325] i2c /dev entries driver
[ 5.311437] virtual_init
[ 5.317413] nvavp nvavp: allocated IOVA at 8ff00000 for AVP os
[ 5.325586] tegra_dtv_probe: probing dtv.
[ 5.331292] setup_stream: bufsize = 4096, bufnum = 4
[ 5.336447] ar0832_init: ++
[ 5.342929] i2c-core: driver [max77387] using legacy suspend method
[ 5.350854] i2c-core: driver [max77387] using legacy resume method
[ 5.358734] i2c-core: driver [as364x] using legacy suspend method
[ 5.366397] i2c-core: driver [as364x] using legacy resume method
[ 5.374052] [IMX135] sensor driver loading
[ 5.379692] [IMX179] sensor driver loading
[ 5.385288] [IMX185] sensor driver loading
[ 5.390857] [imx132] sensor driver loading
[ 5.396374] [AR0330] sensor driver loading
[ 5.401884] [ar0261] sensor driver loading
[ 5.407358] [AR1335] sensor driver loading
[ 5.412796] [ov4689] sensor driver loading
[ 5.418403] usbcore: registered new interface driver uvcvideo
[ 5.425548] USB Video Class driver (1.1.1)
[ 5.431772] zram: Created 1 device(s) ...
[ 5.437140] otg state changed: SUSPEND --> PERIPHERAL
[ 5.444550] tegra_wdt tegra_wdt.0: last reset is due to power on reset
[ 5.452525] tegra_wdt_probe done
[ 5.457407] sdhci: Secure Digital Host Controller Interface driver
[ 5.464926] sdhci: Copyright(c) Pierre Ossman
[ 5.470680] sdhci-pltfm: SDHCI platform and OF driver helper
[ 5.478043] sdhci-tegra sdhci-tegra.3: vddio_sd_slot regulator not found: -517. Assuming vddio_sd_slot is not required.
[ 5.491763] sdhci-tegra sdhci-tegra.3: Speedo value 2219
[ 5.498635] sdhci-tegra sdhci-tegra.3: Tuning constraints: nom_mv 1150, boot_mv 1150, min_or_mv 1100
[ 5.511147] mmc0: no vqmmc regulator found
[ 5.516729] mmc0: no vmmc regulator found
[ 5.522204] mmc0: Invalid maximum block size, assuming 512 bytes
[ 5.529715] sysedp_create_consumer: unable to create sdhci-tegra.3, no consumer_data for sdhci-tegra.3 found
[ 5.565023] mmc0: SDHCI controller on sdhci-tegra.3 [sdhci-tegra.3] using ADMA
[ 5.578209] sdhci-tegra sdhci-tegra.2: Speedo value 2219
[ 5.585420] sdhci-tegra sdhci-tegra.2: Tuning constraints: nom_mv 1150, boot_mv 1150, min_or_mv 1100
[ 5.600906] mmc1: no vqmmc regulator found
[ 5.607086] mmc1: no vmmc regulator found
[ 5.613039] mmc1: Invalid maximum block size, assuming 512 bytes
[ 5.621117] sysedp_create_consumer: unable to create sdhci-tegra.2, no consumer_data for sdhci-tegra.2 found[ 5.646194] mmc0: BKOPS_EN bit is not set
[ 5.656017] mmc1: SDHCI controller on sdhci-tegra.2 [sdhci-tegra.2] using ADMA
[ 5.657720] sdhci-tegra sdhci-tegra.3: Found T2T coeffs data
[ 5.657728] sdhci-tegra sdhci-tegra.3: 200MHz tap hole coeffs found
[ 5.685820] gpio wake56 for gpio=170
[ 5.694516] tegra-se tegra12-se: tegra_se_probe: complete
[ 5.704453] usbcore: registered new interface driver usbhid
[ 5.712131] usbhid: USB HID core driver
[ 5.718425] tegra-hier-ictlr tegra-hier-ictlr: probed
[ 5.804612] usbcore: registered new interface driver snd-usb-audio
[ 5.813407] MAX98090 driver built on Jun 9 2016 at 10:52:21
[ 5.821832] tegra_offload_platform probe successfull.
[ 5.829727] succefully registered offload opstegra30_avp_audio_platform_probe successful.
[ 6.093002] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 6.103805] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 6.123102] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 6.131650] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 6.140105] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 6.148418] rt5639 0-001c: read 0xfd=0xffffffff
[ 6.154849] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 6.163305] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 6.171678] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 6.179951] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 6.188159] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 6.196271] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 6.204278] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 6.207557] **********Auto tuning windows*************
[ 6.207560] WIN_ATTR legend: 0-BOUN_ST, 1-BOUN_END, 2-HOLE
[ 6.207567] win[0]: 0(0) - 59(1)
[ 6.207572] win[1]: 66(0) - 124(1)
[ 6.207576] win[2]: 131(0) - 193(1)
[ 6.207581] win[3]: 197(0) - 255(1)
[ 6.207584] ***************************************
[ 6.207600] ********tuning windows after inserting holes*****
[ 6.207603] WIN_ATTR legend: 0-BOUN_ST, 1-BOUN_END, 2-HOLE
[ 6.207607] win[0]:-1(0) - 29(2)
[ 6.207612] win[1]:31(2) - 59(1)
[ 6.207616] win[2]:66(0) - 96(2)
[ 6.207620] win[3]:98(2) - 124(1)
[ 6.207624] win[4]:131(0) - 163(2)
[ 6.207628] win[5]:165(2) - 193(1)
[ 6.207631] win[6]:197(0) - 230(2)
[ 6.207635] win[7]:232(2) - 255(1)
[ 6.207638] ***********************************************
[ 6.207642] **********Tuning values*********
[ 6.207645] **estimated values**
[ 6.207651] T2T_Vmax 58, T2T_Vmin 81, 1'st_hole_Vmax 46, UI_Vmax 86
[ 6.207654] **Calculated values**
[ 6.207659] T2T_Vmax 74, 1'st_hole_Vmax 30, UI_Vmax 67
[ 6.207663] T2T_Vmin 74, 1'st_hole_Vmin 30, UI_Vmin 67
[ 6.207665] ***********************************
[ 6.207672] ***********final tuning windows**********
[ 6.207676] win[0]: 12 - 22
[ 6.207679] win[1]: 39 - 46
[ 6.207682] win[2]: 79 - 85
[ 6.207686] win[3]: 110 - 111
[ 6.207689] win[4]: 144 - 147
[ 6.207692] win[5]: 182 - 180
[ 6.207695] win[6]: 210 - 209
[ 6.207698] win[7]: 254 - 242
[ 6.207701] ********************************
[ 6.207705] best tap win - (12-22), best tap value 17 prev_best_tap 0
[ 6.393586] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 6.401304] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 6.409014] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 6.416688] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 6.424365] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 6.432033] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 6.439643] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 6.447199] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 6.454729] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 6.462195] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 6.469578] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 6.476928] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 6.484255] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 6.491544] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 6.498809] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 6.506027] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 6.513218] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 6.520424] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 6.527635] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 6.534805] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 6.542002] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 6.549157] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 6.556321] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 6.563452] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 6.570492] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 6.577467] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 6.584447] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 6.591421] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 6.598381] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 6.605374] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 6.612332] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 6.619296] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 6.626290] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 6.633251] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 6.640233] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 6.647216] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 6.654177] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 6.661162] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 6.668071] rt5639 0-001c: Failed to set private addr: -121
[ 6.674165] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 6.681275] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 6.692974] rt5639 0-001c: ASoC: mux INR Mux has no paths
[ 6.698967] rt5639 0-001c: ASoC: mux INL Mux has no paths
[ 6.705564] gpio wake49 for gpio=143
[ 6.709922] rt5639 0-001c: rt5639_headset_detect jack_type = 1
[ 6.716788] tegra-snd-rt5639 tegra-snd-rt5639.0: rt5639-aif1 <-> tegra30-i2s.1 mapping ok
[ 6.727096] tegra-snd-rt5639 tegra-snd-rt5639.0: dit-hifi <-> tegra30-spdif mapping ok
[ 6.737609] tegra-snd-rt5639 tegra-snd-rt5639.0: dit-hifi <-> tegra30-i2s.3 mapping ok
[ 6.748525] tegra-snd-rt5639 tegra-snd-rt5639.0: rt5639-aif1 <-> dit-hifi mapping ok
[ 6.759633] tegra-snd-rt5639 tegra-snd-rt5639.0: dit-hifi <-> dit-hifi mapping ok
[ 6.759708] **********Auto tuning windows*************
[ 6.759711] WIN_ATTR legend: 0-BOUN_ST, 1-BOUN_END, 2-HOLE
[ 6.759718] win[0]: 0(0) - 59(1)
[ 6.759722] win[1]: 65(0) - 125(1)
[ 6.759727] win[2]: 131(0) - 193(1)
[ 6.759731] win[3]: 198(0) - 255(1)
[ 6.759733] ***************************************
[ 6.759742] ********tuning windows after inserting holes*****
[ 6.759744] WIN_ATTR legend: 0-BOUN_ST, 1-BOUN_END, 2-HOLE
[ 6.759749] win[0]:-2(0) - 29(2)
[ 6.759753] win[1]:31(2) - 59(1)
[ 6.759757] win[2]:65(0) - 96(2)
[ 6.759760] win[3]:98(2) - 125(1)
[ 6.759764] win[4]:131(0) - 163(2)
[ 6.759767] win[5]:165(2) - 193(1)
[ 6.759770] win[6]:198(0) - 230(2)
[ 6.759774] win[7]:232(2) - 255(1)
[ 6.759776] ***********************************************
[ 6.759780] **********Tuning values*********
[ 6.759782] **estimated values**
[ 6.759787] T2T_Vmax 58, T2T_Vmin 81, 1'st_hole_Vmax 46, UI_Vmax 86
[ 6.759789] **Calculated values**
[ 6.759792] T2T_Vmax 74, 1'st_hole_Vmax 30, UI_Vmax 67
[ 6.759796] T2T_Vmin 74, 1'st_hole_Vmin 30, UI_Vmin 67
[ 6.759798] ***********************************
[ 6.759804] ***********final tuning windows**********
[ 6.759807] win[0]: 11 - 22
[ 6.759810] win[1]: 39 - 46
[ 6.759812] win[2]: 78 - 85
[ 6.759815] win[3]: 110 - 112
[ 6.759818] win[4]: 144 - 147
[ 6.759821] win[5]: 182 - 180
[ 6.759824] win[6]: 211 - 209
[ 6.759827] win[7]: 254 - 242
[ 6.759829] ********************************
[ 6.759833] best tap win - (11-22), best tap value 17 prev_best_tap 17
[ 6.759843] sdhci-tegra sdhci-tegra.3: sdhci_tegra_verify_best_tap: tuning freq 200000000hz, best tap 17
[ 6.977121] mmc0: new HS200 MMC card at address 0001
[ 6.977194] tegra-snd-rt5639 tegra-snd-rt5639.0: Allocating for stream playback
[ 6.977302] tegra-snd-rt5639 tegra-snd-rt5639.0: Allocating for stream capture
[ 6.977406] tegra-snd-rt5639 tegra-snd-rt5639.0: snd-soc-dummy-dai <-> tegra-offload-pcm mapping ok
[ 6.977764] compress asoc: snd-soc-dummy-dai <-> tegra-offload-compr mapping ok
[ 6.978210] tegra-snd-rt5639 tegra-snd-rt5639.0: Allocating for stream playback
[ 6.978315] tegra-snd-rt5639 tegra-snd-rt5639.0: Allocating for stream capture
[ 6.978419] tegra-snd-rt5639 tegra-snd-rt5639.0: snd-soc-dummy-dai <-> tegra-offload-pcm mapping ok
[ 6.978781] tegra-snd-rt5639 tegra-snd-rt5639.0: rt5639-aif1 <-> tegra30-i2s.1 mapping ok
[ 6.982470] input: tegra-rt5639 Headphone Jack as /devices/platform/tegra-snd-rt5639.0/sound/card1/input0
[ 6.984286] sysedp_create_consumer: unable to create speaker, no consumer_data for speaker found
[ 6.984287] oprofile: using timer interrupt.
[ 7.107506] GACT probability NOT on
[ 7.107765] mmcblk mmc0:0001: Card claimed for testing.
[ 7.107950] mmcblk0: mmc0:0001 SEM16G 14.6 GiB
[ 7.108119] mmcblk0rpmb: mmc0:0001 SEM16G partition 3 4.00 MiB
[ 7.136323] Mirror/redirect action on
[ 7.142396] u32 classifier
[ 7.147409] Actions configured
[ 7.153074] Netfilter messages via NETLINK v0.30.
[ 7.160158] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[ 7.166435] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9
[ 7.175708] NF_TPROXY: Transparent proxy support initialized, version 4.1.0
[ 7.184856] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
[ 7.193196] xt_time: kernel timezone is -0000
[ 7.199922] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 7.207426] arp_tables: (C) 2002 David S. Miller
[ 7.214088] TCP: cubic registered
[ 7.219528] NET: Registered protocol family 10
[ 7.226618] mip6: Mobile IPv6
[ 7.231456] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 7.238828] sit: IPv6 over IPv4 tunneling driver
[ 7.246122] NET: Registered protocol family 17
[ 7.252338] NET: Registered protocol family 15
[ 7.258498] NET: Registered protocol family 35
[ 7.264580] NET: Registered protocol family 37
[ 7.270522] NET: Registered protocol family 41
[ 7.277714] VFP support v0.3: implementor 41 architecture 4 part 30 variant f rev 0
[ 7.311641] Registering SWP/SWPB emulation handler
[ 7.317996] last reset is due to power on reset
[ 7.317996]
[ 7.327000] Disabling clocks left on by bootloader:
[ 7.333408] audio_2x
[ 7.337372] audio
[ 7.341000] audio4
[ 7.344650] audio3
[ 7.348216] audio2
[ 7.351714] audio1
[ 7.355151] audio0
[ 7.358609] hdmi_audio
[ 7.362301] entropy
[ 7.365700] dsi2-fixed
[ 7.369326] dsi1-fixed
[ 7.372924] nor
[ 7.375850] trace
[ 7.378901] sdmmc4_ddr
[ 7.382357] sdmmc3_ddr
[ 7.385847] cclk_lp
[ 7.389053] pll_x_out0
[ 7.392541] pll_m_out1
[ 7.396134] tegra_dvfs: vdd_cpu connected to regulator
[ 7.402204] tegra_dvfs: vdd_core connected to regulator
[ 7.408286] tegra_dvfs: vdd_gpu connected to regulator
[ 7.415366] Tegra CPU DFLL is initialized with use_dfll = 1
[ 7.421807] CPU rate: 696 MHz
[ 7.425707] cpu_cold cooling device is registered
[ 7.431318] cpu_hot cooling device is registered
[ 7.649607] tegra dvfs: tegra sysfs cap interface is initialized
[ 7.656581] tegra dvfs: tegra sysfs gpu & emc interface is initialized
[ 7.664605] tegra_actmon.emc: Completed initialization (0)
[ 7.671320] tegra_actmon.avp: Completed initialization (0)
[ 7.677936] tegra_mon.cpu_emc: Completed initialization (0)
[ 7.687659] reg-aon-1v2: incomplete constraints, leaving on
[ 7.694331] reg-aon-1v8: incomplete constraints, leaving on
[ 7.701060] reg-dcdc-1v2: incomplete constraints, leaving on
[ 7.707848] reg-5v0-supply: incomplete constraints, leaving on
[ 7.714906] avdd-hdmi-pll: incomplete constraints, leaving on
[ 7.721894] usb0-vbus: incomplete constraints, leaving on
[ 7.728730] vpp-fuse: incomplete constraints, leaving on
[ 7.735421] vdd-2v7-cam: incomplete constraints, leaving on
[ 7.742472] avdd-spi: incomplete constraints, leaving on
[ 7.749233] vdd-1v1-cam: incomplete constraints, leaving on
[ 7.756303] vdd-1v2-cam: incomplete constraints, leaving on
[ 7.763357] avdd-cam: incomplete constraints, leaving on
[ 7.770205] vdd-cam: incomplete constraints, leaving on
[ 7.776968] as3722-sd3: incomplete constraints, leaving on
[ 7.784018] reg-3v3-supply: incomplete constraints, leaving on
[ 7.791449] vdd-3v3-aon: incomplete constraints, leaving on
[ 7.798635] vdd-ac-bat: incomplete constraints, leaving on
[ 7.805725] regulator-dummy: incomplete constraints, leaving on
[ 7.814060] gpio wake51 for gpio=128
[ 7.819487] input: gpio-keys.4 as /devices/platform/gpio-keys.4/input/input1
[ 7.829057] as3722-rtc as3722-rtc.1: setting system clock to 2000-01-01 00:00:18 UTC (946684818)
[ 7.842197] ALSA device list:
[ 7.846776] #0: HDA NVIDIA Tegra at 0x70038000 irq 113
[ 7.853824] #1: tegra-rt5639
