cv2.VideoWriter[Gstreamer + Opencv] using Hardware Encoder with python code
Hi all,
1- I used the below gstreamer element for using HW Decoder of jetson nano for RTSP stream:
gstream_elemets = (
                'rtspsrc location={rtps} latency=300 !'
                'rtph264depay ! h264parse !'
                'queue max-size-buffers=100, leaky=2 !'
                'omxh264dec enable-max-performance=1 enable-low-outbuffer=1 !'
                'video/x-raw(memory:NVMM),format=(string)NV12 !'
                'nvvidconv ! video/x-raw , format=(string)BGRx !'
                'videoconvert ! '
                'appsink').
cv2.VideoCapture(gstream_elemets, cv2.CAP_GSTREAMER)
and this part is corrctly work and use NVDEC. I capture the frames and do some processing on frames and then I want to save the frames in video file in disk using HW Encoder of jetson nano, How I can do this with gstremaer + opencv using python code?
2- If I have video file in disk and I want to open with opencv python and then using HW decoder for decoding the frames, How do I can like the above RTSP for source file?
For 1.:
You would use a gstreamer pipeline in a cv2.VideoWriter, specifying cv2.CAP_GSTREAMER api:
... # assuming your gstreamer input defines caps for width, height and fps
cap = cv2.VideoCapture(gstream_elements, cv2.CAP_GSTREAMER)
if not cap.isOpened() :
    print("capture failed")
    exit()
w = cap.get(cv2.CAP_PROP_FRAME_WIDTH)
h = cap.get(cv2.CAP_PROP_FRAME_HEIGHT)
fps = cap.get(cv2.CAP_PROP_FPS)
print('Src opened, %dx%d @ %d fps' % (w, h, fps))
gst_out = "appsrc ! video/x-raw, format=BGR ! queue ! nvvidconv ! omxh264enc ! h264parse ! qtmux ! filesink location=test.mov "
out= cv2.VideoWriter(gst_out, cv2.CAP_GSTREAMER, 0, float(fps), (int(w), int(h)))
if not out.isOpened():
    print("Failed to open output")
    exit()
while True:
    _, frame = cap.read()
    out.write(frame)
    cv2.waitKey(1)
For 2: use a gstreamer pipeline starting with filesrc (here displaying into X):
gst-launch-1.0 filesrc location=test.mov ! qtdemux ! video/x-h264 ! omxh264dec ! nvvidconv ! videoconvert ! xvimagesink
This is the sudo tegrastatus output, but I don’t see NVENC, the encoder is done on CPU.
RAM 685/3964MB (lfb 500x4MB) SWAP 0/10174MB (cached 0MB) IRAM 0/252kB(lfb 252kB) CPU [29%@1428,9%@1428,22%@1428,26%@1428] EMC_FREQ 1%@1600 GR3D_FREQ 0%@76 APE 25 PLL@36.5C CPU@40C PMIC@100C GPU@38.5C AO@44C thermal@39C POM_5V_IN 2378/2037 POM_5V_GPU 0/0 POM_5V_CPU 807/557
RAM 682/3964MB (lfb 500x4MB) SWAP 0/10174MB (cached 0MB) IRAM 0/252kB(lfb 252kB) CPU [27%@1224,21%@1224,21%@1224,15%@1224] EMC_FREQ 1%@1600 GR3D_FREQ 0%@76 APE 25 PLL@36.5C CPU@40C PMIC@100C GPU@38.5C AO@44C thermal@39C POM_5V_IN 2025/2037 POM_5V_GPU 0/0 POM_5V_CPU 687/560
RAM 683/3964MB (lfb 500x4MB) SWAP 0/10174MB (cached 0MB) IRAM 0/252kB(lfb 252kB) CPU [30%@403,12%@403,17%@403,20%@403] EMC_FREQ 1%@1600 GR3D_FREQ 0%@76 APE 25 PLL@36C CPU@39.5C PMIC@100C GPU@38C AO@44C thermal@39.25C POM_5V_IN 1869/2034 POM_5V_GPU 0/0 POM_5V_CPU 447/557
RAM 683/3964MB (lfb 500x4MB) SWAP 0/10174MB (cached 0MB) IRAM 0/252kB(lfb 252kB) CPU [27%@518,11%@518,26%@518,25%@518] EMC_FREQ 1%@1600 GR3D_FREQ 0%@76 APE 25 PLL@36.5C CPU@40C PMIC@100C GPU@38.5C AO@43.5C thermal@39C POM_5V_IN 1907/2031 POM_5V_GPU 0/0 POM_5V_CPU 447/555
RAM 684/3964MB (lfb 500x4MB) SWAP 0/10174MB (cached 0MB) IRAM 0/252kB(lfb 252kB) CPU [28%@518,14%@403,21%@518,23%@518] EMC_FREQ 1%@1600 GR3D_FREQ 0%@76 APE 25 PLL@36.5C CPU@39.5C PMIC@100C GPU@38.5C AO@43.5C thermal@39C POM_5V_IN 1907/2029 POM_5V_GPU 0/0 POM_5V_CPU 446/553
RAM 683/3964MB (lfb 500x4MB) SWAP 0/10174MB (cached 0MB) IRAM 0/252kB(lfb 252kB) CPU [29%@518,32%@518,18%@518,11%@518] EMC_FREQ 1%@1600 GR3D_FREQ 0%@76 APE 25 PLL@36.5C CPU@39.5C PMIC@100C GPU@38.5C AO@44C thermal@39.25C POM_5V_IN 1947/2027 POM_5V_GPU 0/0 POM_5V_CPU 486/552
RAM 684/3964MB (lfb 500x4MB) SWAP 0/10174MB (cached 0MB) IRAM 0/252kB(lfb 252kB) CPU [28%@518,14%@518,15%@518,26%@518] EMC_FREQ 1%@1600 GR3D_FREQ 0%@76 APE 25 PLL@36.5C CPU@40C PMIC@100C GPU@38.5C AO@44C thermal@39.25C POM_5V_IN 1947/2026 POM_5V_GPU 0/0 POM_5V_CPU 446/550
and another problem is also there, the output file size is zeros. why?
and the solution 2 for filesrc also doesn’t give me frames and hang up.
Please try
gst_out = "appsrc ! video/x-raw, format=BGR ! queue ! videoconvert ! video/x-raw,format=RGBA ! nvvidconv ! nvv4l2h264enc ! h264parse ! qtmux ! filesink location=test.mov "
BGR is not supported by nvvidconv. Please use videoconvert to convert it to RGBA and then send to nvvidconv.
This config is work, and the output file is all frames frames, why? I used .mp4 for input and output format.
I also want a config gstreamer for reading cv2.VideoCapture[opencv+gstreamer] with HW NVDEC.
This might help:
