Thank you for the suggestions. Here are the code and test results:
code snippet 1:
RCLCPP_INFO(get_logger(), "camera_images size: %ld", camera_images.size());
for (size_t idx = 0; idx < camera_images.size(); ++idx)
std::string step_full;
for (int i = 0; i < camera_images[idx].image.dims; ++i) {
if (i > 0) step_full += " x ";
step_full += std::to_string(camera_images[idx].image.step[i]);
RCLCPP_INFO(get_logger(), "idx: %ld, sensor_id: %d, dimensions: %dx%d, channels: %d, type: %d, isEmpty: %d, step: [%s]",
idx, camera_images[idx].camera_id, camera_images[idx].image.rows, camera_images[idx].image.cols,
camera_images[idx].image.channels(), (int)camera_images[idx].image.type(), camera_images[idx].image.empty(),
step_full.c_str());
const auto status = cuvgl_->Localize(camera_images, localization_pose);
code snippet 2:
bool VisualGlobalLocalizationNode::convertImageMessage(
const std::shared_ptr<ImageType> & image,
uint32_t sensor_id,
isaac::visual::cuvgl::CameraImage & camera_image)
RCLCPP_INFO(get_logger(), "convertImage, sensor_id: %d, frame_id: %s, encoding: %s, image dimensions: %dx%d",
sensor_id, image->GetFrameId().c_str(), image->GetEncoding().c_str(), image->GetWidth(), image->GetHeight());
// Convert the NitrosImage to sensor_msgs::msg::Image
sensor_msgs::msg::Image img_msg;
img_msg.header.frame_id = image->GetFrameId();
img_msg.header.stamp.sec = image->GetTimestampSeconds();
img_msg.header.stamp.nanosec = image->GetTimestampNanoseconds();
img_msg.height = image->GetHeight();
img_msg.width = image->GetWidth();
img_msg.encoding = image->GetEncoding();
img_msg.step = image->GetSizeInBytes() / image->GetHeight();
img_msg.data.resize(image->GetSizeInBytes());
cudaMemcpy(
img_msg.data.data(), image->GetGpuData(),
image->GetSizeInBytes(), cudaMemcpyDefault);
// Note: the image is only support in RGB8/BGR8 format. Check CameraFrameToMat in camera_data_utils.cc
cv_bridge::CvImagePtr rgb_cv_ptr =
cv_bridge::toCvCopy(img_msg, sensor_msgs::image_encodings::MONO8);
if (!rgb_cv_ptr || rgb_cv_ptr->image.empty()) {
RCLCPP_ERROR(get_logger(),
"toCvCopy failed or returned empty image, encoding=%s, w=%d, h=%d",
img_msg.encoding.c_str(), img_msg.width, img_msg.height);
return false;
RCLCPP_INFO(get_logger(), "toCvCopy success: %dx%d",
rgb_cv_ptr->image.cols, rgb_cv_ptr->image.rows);
if (enable_rectify_images_) {
if (image_rectifiers_[image->GetFrameId()] == nullptr) {
RCLCPP_ERROR(get_logger(), "Image rectifier is not initialized");
return false;
// Rectify the image
cv::Mat rectified_image;
image_rectifiers_[image->GetFrameId()]->Rectify(rgb_cv_ptr->image, rectified_image);
rgb_cv_ptr->image = rectified_image;
if (publish_rectified_images_) {
rectified_image_pubs_[sensor_id]->publish(*(rgb_cv_ptr->toImageMsg()));
rectified_camera_info_pubs_[sensor_id]->publish(rectified_camera_infos_[image->GetFrameId()]);
camera_image.camera_id = sensor_id;
camera_image.image = rgb_cv_ptr->image;
camera_image.timestamp_microseconds = GetImageTimestampInMicros(*image);
for (int i = 0; i < camera_image.image.dims; ++i) {
step_full += std::to_string(camera_image.image.step[i]);
RCLCPP_INFO(get_logger(), "to camera, sensor_id: %d, dimensions: %dx%d, channels: %d, type: %d, isEmpty: %d, step: [%s]",
camera_image.camera_id, camera_image.image.rows, camera_image.image.cols,
camera_image.image.channels(), (int)camera_image.image.type(), camera_image.image.empty(), step_full.c_str());
return true;
log:
[component_container_mt-3] I0602 09:43:41.629889 65311 keypoint_matcher.cc:41] Matcher will use sift_cv_cuda.
[component_container_mt-3] I0602 09:43:41.630048 65311 keypoint_detector.cc:124] SIFT_CV_CUDA Detector created.
[component_container_mt-3] I0602 09:43:41.630215 65311 base_visual_localizer.cc:400] Stereo pairs: 1
[component_container_mt-3] I0602 09:43:41.630235 65311 multiple_stereo_localizer.cc:403] Setting localization precision level to2
[component_container_mt-3] [INFO] [1780364621.630288239] [visual_localization_node]: VisualGlobalLocalizationNode::subscribeToTopics() (subscribeToTopics:211)
[component_container_mt-3] [INFO] [1780364621.637346177] [visual_localization_node.ManagedNitrosSubscriber]: Starting Managed Nitros Subscriber (ManagedNitrosSubscriber:74)
[component_container_mt-3] [INFO] [1780364621.643275130] [visual_localization_node.ManagedNitrosSubscriber]: Starting Managed Nitros Subscriber (ManagedNitrosSubscriber:74)
[component_container_mt-3] [INFO] [1780364621.648103066] [visual_localization_node]: VisualGlobalLocalizationNode::advertiseServices() (advertiseServices:241)
[INFO] [launch_ros.actions.load_composable_nodes]: Loaded node '/visual_localization_node' in container 'nvblox_container'
[component_container_mt-3] [INFO] [1780364621.656216868] [visual_localization_node]: camera_ids : (processImages:382)
[component_container_mt-3] [ERROR] [1780364621.656328964] [visual_localization_node]: Camera info for : camera_right_ir_optical_frame is not loaded yet (processImages:385)
[component_container_mt-3] I0602 09:43:41.658169 65311 base_visual_localizer.cc:436] add camera_id:0
[component_container_mt-3] I0602 09:43:41.659626 65315 base_visual_localizer.cc:436] add camera_id:1
[component_container_mt-3] I0602 09:43:41.659690 65315 multiple_stereo_localizer.cc:346] left2right transform:t(m): [-0.095 0.000 0.000], quat(x,y,z,w): [0.000, 0.000, 0.000, 1.000]
[component_container_mt-3] I0602 09:43:41.659731 65315 multiple_stereo_localizer.cc:363] Stereo Camera: 0, 1, baseline:0.0950476
[component_container_mt-3] [INFO] [1780364621.685102566] [visual_localization_node]: convertImage, sensor_id: 1, frame_id: camera_right_ir_optical_frame, encoding: mono8, image dimensions: 640x480 (convertImageMessage:607)
[component_container_mt-3] [INFO] [1780364621.685682402] [visual_localization_node]: toCvCopy success: 640x480 (convertImageMessage:634)
[component_container_mt-3] [INFO] [1780364621.685760322] [visual_localization_node]: to camera, sensor_id: 1, dimensions: 480x640, channels: 1, type: 0, isEmpty: 0, step: [640 x 1] (convertImageMessage:662)
[component_container_mt-3] [INFO] [1780364621.685831809] [visual_localization_node]: convertImage, sensor_id: 0, frame_id: camera_left_ir_optical_frame, encoding: mono8, image dimensions: 640x480 (convertImageMessage:607)
[component_container_mt-3] [INFO] [1780364621.687335576] [visual_localization_node]: toCvCopy success: 640x480 (convertImageMessage:634)
[component_container_mt-3] [INFO] [1780364621.687427095] [visual_localization_node]: to camera, sensor_id: 0, dimensions: 480x640, channels: 1, type: 0, isEmpty: 0, step: [640 x 1] (convertImageMessage:662)
[component_container_mt-3] [INFO] [1780364621.687458519] [visual_localization_node]: camera_images size: 2 (processImages:439)
[component_container_mt-3] [INFO] [1780364621.687481495] [visual_localization_node]: idx: 0, sensor_id: 1, dimensions: 480x640, channels: 1, type: 0, isEmpty: 0, step: [640 x 1] (processImages:447)
[component_container_mt-3] [INFO] [1780364621.687501014] [visual_localization_node]: idx: 1, sensor_id: 0, dimensions: 480x640, channels: 1, type: 0, isEmpty: 0, step: [640 x 1] (processImages:447)
[component_container_mt-3] terminate called after throwing an instance of 'nvcv::Exception'
[component_container_mt-3] what(): NVCV_ERROR_INVALID_ARGUMENT: Operator constructor arg. maxShape (W=0 H=0 N=1) must have W and H >= 2 and N in [1, 65535]
[component_container_mt-3] Received signal: 6
stack trace:
Received signal: 6
Stack trace (most recent call last) in thread 65309:
#31 Object "/opt/ros/humble/lib/librclcpp.so", at 0xffff943e94eb, in rclcpp::Executor::execute_any_executable(rclcpp::AnyExecutable&)
#30 Object "/opt/ros/humble/lib/librclcpp.so", at 0xffff943e8ccf, in rclcpp::Executor::execute_subscription(std::shared_ptr<rclcpp::SubscriptionBase>)
#29 Object "/home/nvidia/workspaces/install/isaac_ros_visual_global_localization/lib/libvisual_global_localization_node.so", at 0xfffe64ad95df, in rclcpp::Subscription<nvidia::isaac_ros::nitros::NitrosImage, std::allocator<void>, nvidia::isaac_ros::nitros::NitrosImage, sensor_msgs::msg::Image_<std::allocator<void> >, rclcpp::message_memory_strategy::MessageMemoryStrategy<sensor_msgs::msg::Image_<std::allocator<void> >, std::allocator<void> > >::handle_message(std::shared_ptr<void>&, rclcpp::MessageInfo const&)
#28 Object "/home/nvidia/workspaces/isaac_ros-dev/install/isaac_ros_visual_slam/lib/libvisual_slam_node.so", at 0xfffef56586bf, in std::__detail::__variant::__gen_vtable_impl<std::__detail::__variant::_Multi_array<std::__detail::__variant::__deduce_visit_result<void> (*)(rclcpp::AnySubscriptionCallback<nvidia::isaac_ros::nitros::NitrosImage, std::allocator<void> >::dispatch(std::shared_ptr<sensor_msgs::msg::Image_<std::allocator<void> > >, rclcpp::MessageInfo const&)::{lambda(auto:1&&)#1}&&, std::variant<std::function<void (nvidia::isaac_ros::nitros::NitrosImage const&)>, std::function<void (sensor_msgs::msg::Image_<std::allocator<void> > const&)>, std::function<void (nvidia::isaac_ros::nitros::NitrosImage const&, rclcpp::MessageInfo const&)>, std::function<void (sensor_msgs::msg::Image_<std::allocator<void> > const&, rclcpp::MessageInfo const&)>, std::function<void (rclcpp::SerializedMessage const&)>, std::function<void (rclcpp::SerializedMessage const&, rclcpp::MessageInfo const&)>, std::function<void (std::unique_ptr<nvidia::isaac_ros::nitros::NitrosImage, std::default_delete<nvidia::isaac_ros::nitros::NitrosImage> >)>, std::function<void (std::unique_ptr<sensor_msgs::msg::Image_<std::allocator<void> >, std::default_delete<sensor_msgs::msg::Image_<std::allocator<void> > > >)>, std::function<void (std::unique_ptr<nvidia::isaac_ros::nitros::NitrosImage, std::default_delete<nvidia::isaac_ros::nitros::NitrosImage> >, rclcpp::MessageInfo const&)>, std::function<void (std::unique_ptr<sensor_msgs::msg::Image_<std::allocator<void> >, std::default_delete<sensor_msgs::msg::Image_<std::allocator<void> > > >, rclcpp::MessageInfo const&)>, std::function<void (std::unique_ptr<rclcpp::SerializedMessage, std::default_delete<rclcpp::SerializedMessage> >)>, std::function<void (std::unique_ptr<rclcpp::SerializedMessage, std::default_delete<rclcpp::SerializedMessage> >, rclcpp::MessageInfo const&)>, std::function<void (std::shared_ptr<nvidia::isaac_ros::nitros::NitrosImage const>)>, std::function<void (std::shared_ptr<sensor_msgs::msg::Image_<std::allocator<void> > const>)>, std::function<void (std::shared_ptr<nvidia::isaac_ros::nitros::NitrosImage const>, rclcpp::MessageInfo const&)>, std::function<void (std::shared_ptr<sensor_msgs::msg::Image_<std::allocator<void> > const>, rclcpp::MessageInfo const&)>, std::function<void (std::shared_ptr<rclcpp::SerializedMessage const>)>, std::function<void (std::shared_ptr<rclcpp::SerializedMessage const>, rclcpp::MessageInfo const&)>, std::function<void (std::shared_ptr<nvidia::isaac_ros::nitros::NitrosImage const> const&)>, std::function<void (std::shared_ptr<sensor_msgs::msg::Image_<std::allocator<void> > const> const&)>, std::function<void (std::shared_ptr<nvidia::isaac_ros::nitros::NitrosImage const> const&, rclcpp::MessageInfo const&)>, std::function<void (std::shared_ptr<sensor_msgs::msg::Image_<std::allocator<void> > const> const&, rclcpp::MessageInfo const&)>, std::function<void (std::shared_ptr<rclcpp::SerializedMessage const> const&)>, std::function<void (std::shared_ptr<rclcpp::SerializedMessage const> const&, rclcpp::MessageInfo const&)>, std::function<void (std::shared_ptr<nvidia::isaac_ros::nitros::NitrosImage>)>, std::function<void (std::shared_ptr<sensor_msgs::msg::Image_<std::allocator<void> > >)>, std::function<void (std::shared_ptr<nvidia::isaac_ros::nitros::NitrosImage>, rclcpp::MessageInfo const&)>, std::function<void (std::shared_ptr<sensor_msgs::msg::Image_<std::allocator<void> > >, rclcpp::MessageInfo const&)>, std::function<void (std::shared_ptr<rclcpp::SerializedMessage>)>, std::function<void (std::shared_ptr<rclcpp::SerializedMessage>, rclcpp::MessageInfo const&)> >&)>, std::integer_sequence<unsigned long, 12ul> >::__visit_invoke(rclcpp::AnySubscriptionCallback<nvidia::isaac_ros::nitros::NitrosImage, std::allocator<void> >::dispatch(std::shared_ptr<sensor_msgs::msg::Image_<std::allocator<void> > >, rclcpp::MessageInfo const&)::{lambda(auto:1&&)#1}&&, std::variant<std::function<void (nvidia::isaac_ros::nitros::NitrosImage const&)>, std::function<void (sensor_msgs::msg::Image_<std::allocator<void> > const&)>, std::function<void (nvidia::isaac_ros::nitros::NitrosImage const&, rclcpp::MessageInfo const&)>, std::function<void (sensor_msgs::msg::Image_<std::allocator<void> > const&, rclcpp::MessageInfo const&)>, std::function<void (rclcpp::SerializedMessage const&)>, std::function<void (rclcpp::SerializedMessage const&, rclcpp::MessageInfo const&)>, std::function<void (std::unique_ptr<nvidia::isaac_ros::nitros::NitrosImage, std::default_delete<nvidia::isaac_ros::nitros::NitrosImage> >)>, std::function<void (std::unique_ptr<sensor_msgs::msg::Image_<std::allocator<void> >, std::default_delete<sensor_msgs::msg::Image_<std::allocator<void> > > >)>, std::function<void (std::unique_ptr<nvidia::isaac_ros::nitros::NitrosImage, std::default_delete<nvidia::isaac_ros::nitros::NitrosImage> >, rclcpp::MessageInfo const&)>, std::function<void (std::unique_ptr<sensor_msgs::msg::Image_<std::allocator<void> >, std::default_delete<sensor_msgs::msg::Image_<std::allocator<void> > > >, rclcpp::MessageInfo const&)>, std::function<void (std::unique_ptr<rclcpp::SerializedMessage, std::default_delete<rclcpp::SerializedMessage> >)>, std::function<void (std::unique_ptr<rclcpp::SerializedMessage, std::default_delete<rclcpp::SerializedMessage> >, rclcpp::MessageInfo const&)>, std::function<void (std::shared_ptr<nvidia::isaac_ros::nitros::NitrosImage const>)>, std::function<void (std::shared_ptr<sensor_msgs::msg::Image_<std::allocator<void> > const>)>, std::function<void (std::shared_ptr<nvidia::isaac_ros::nitros::NitrosImage const>, rclcpp::MessageInfo const&)>, std::function<void (std::shared_ptr<sensor_msgs::msg::Image_<std::allocator<void> > const>, rclcpp::MessageInfo const&)>, std::function<void (std::shared_ptr<rclcpp::SerializedMessage const>)>, std::function<void (std::shared_ptr<rclcpp::SerializedMessage const>, rclcpp::MessageInfo const&)>, std::function<void (std::shared_ptr<nvidia::isaac_ros::nitros::NitrosImage const> const&)>, std::function<void (std::shared_ptr<sensor_msgs::msg::Image_<std::allocator<void> > const> const&)>, std::function<void (std::shared_ptr<nvidia::isaac_ros::nitros::NitrosImage const> const&, rclcpp::MessageInfo const&)>, std::function<void (std::shared_ptr<sensor_msgs::msg::Image_<std::allocator<void> > const> const&, rclcpp::MessageInfo const&)>, std::function<void (std::shared_ptr<rclcpp::SerializedMessage const> const&)>, std::function<void (std::shared_ptr<rclcpp::SerializedMessage const> const&, rclcpp::MessageInfo const&)>, std::function<void (std::shared_ptr<nvidia::isaac_ros::nitros::NitrosImage>)>, std::function<void (std::shared_ptr<sensor_msgs::msg::Image_<std::allocator<void> > >)>, std::function<void (std::shared_ptr<nvidia::isaac_ros::nitros::NitrosImage>, rclcpp::MessageInfo const&)>, std::function<void (std::shared_ptr<sensor_msgs::msg::Image_<std::allocator<void> > >, rclcpp::MessageInfo const&)>, std::function<void (std::shared_ptr<rclcpp::SerializedMessage>)>, std::function<void (std::shared_ptr<rclcpp::SerializedMessage>, rclcpp::MessageInfo const&)> >&)
#27 Object "/home/nvidia/workspaces/install/isaac_ros_visual_global_localization/lib/libvisual_global_localization_node.so", at 0xfffe64a671b7, in std::_Function_handler<void (std::shared_ptr<nvidia::isaac_ros::nitros::NitrosImage const>), std::_Bind<void (*(std::_Placeholder<1>, std::function<void (nvidia::isaac_ros::nitros::NitrosTypeBase&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >)>))(std::shared_ptr<nvidia::isaac_ros::nitros::NitrosImage const>, std::function<void (nvidia::isaac_ros::nitros::NitrosTypeBase&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >)>)> >::_M_invoke(std::_Any_data const&, std::shared_ptr<nvidia::isaac_ros::nitros::NitrosImage const>&&)
#26 Object "/home/nvidia/workspaces/install/isaac_ros_visual_global_localization/lib/libvisual_global_localization_node.so", at 0xfffe64a3d2ab, in nvidia::isaac_ros::nitros::NitrosFormatAgent<nvidia::isaac_ros::nitros::nitros_image_rgb8_t>::subscriberCallback(std::shared_ptr<nvidia::isaac_ros::nitros::NitrosImage const>, std::function<void (nvidia::isaac_ros::nitros::NitrosTypeBase&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >)>)
#25 Object "/home/nvidia/workspaces/isaac_ros-dev/install/isaac_ros_nitros/lib/libisaac_ros_nitros.so", at 0xffff0c655c2f, in std::_Function_handler<void (nvidia::isaac_ros::nitros::NitrosTypeBase&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >), std::_Bind<void (nvidia::isaac_ros::nitros::NitrosSubscriber::*(nvidia::isaac_ros::nitros::NitrosSubscriber*, std::_Placeholder<1>, std::_Placeholder<2>))(nvidia::isaac_ros::nitros::NitrosTypeBase&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >)> >::_M_invoke(std::_Any_data const&, nvidia::isaac_ros::nitros::NitrosTypeBase&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >&&)
#24 Object "/home/nvidia/workspaces/isaac_ros-dev/install/isaac_ros_nitros/lib/libisaac_ros_nitros.so", at 0xffff0c654a37, in nvidia::isaac_ros::nitros::NitrosSubscriber::subscriberCallback(nvidia::isaac_ros::nitros::NitrosTypeBase&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >)
#23 Object "/home/nvidia/workspaces/install/isaac_ros_visual_global_localization/lib/libvisual_global_localization_node.so", at 0xfffe64a75ef7, in std::_Function_handler<void (void*, nvidia::isaac_ros::nitros::NitrosTypeBase&), nvidia::isaac_ros::nitros::ManagedNitrosSubscriber<nvidia::isaac_ros::nitros::NitrosImageView>::ManagedNitrosSubscriber(rclcpp::Node*, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::function<void (nvidia::isaac_ros::nitros::NitrosImageView const&)>, nvidia::isaac_ros::nitros::NitrosDiagnosticsConfig const&, rclcpp::QoS)::{lambda(void*, nvidia::isaac_ros::nitros::NitrosTypeBase&)#1}>::_M_invoke(std::_Any_data const&, void*&&, nvidia::isaac_ros::nitros::NitrosTypeBase&)
#22 Object "/home/nvidia/workspaces/install/isaac_ros_visual_global_localization/lib/libvisual_global_localization_node.so", at 0xfffe64a33077, in nvidia::isaac_ros::visual_global_localization::VisualGlobalLocalizationNode::inputImageCallback(nvidia::isaac_ros::nitros::NitrosImageView const&, int)
#21 Object "/home/nvidia/workspaces/install/isaac_ros_visual_global_localization/lib/libvisual_global_localization_node.so", at 0xfffe64a9a177, in nvidia::isaac_common::messaging::MessageStreamSynchronizer<nvidia::isaac_ros::nitros::NitrosImageView>::PopBuffersAndTriggerCallback()
#20 Object "/home/nvidia/workspaces/install/isaac_ros_visual_global_localization/lib/libvisual_global_localization_node.so", at 0xfffe64a99a73, in nvidia::isaac_common::messaging::MessageStreamSynchronizer<nvidia::isaac_ros::nitros::NitrosImageView>::TriggerCallbackWithMessages(std::vector<int, std::allocator<int> > const&)
#19 Object "/home/nvidia/workspaces/install/isaac_ros_visual_global_localization/lib/libvisual_global_localization_node.so", at 0xfffe64a2ffe7, in nvidia::isaac_ros::visual_global_localization::VisualGlobalLocalizationNode::callbackSynchronizedImages(std::vector<std::pair<int, nvidia::isaac_ros::nitros::NitrosImageView>, std::allocator<std::pair<int, nvidia::isaac_ros::nitros::NitrosImageView> > > const&)
#18 Object "/home/nvidia/workspaces/install/isaac_ros_visual_global_localization/lib/libvisual_global_localization_node.so", at 0xfffe64a3143f, in nvidia::isaac_ros::visual_global_localization::VisualGlobalLocalizationNode::processImages(std::unordered_map<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::shared_ptr<nvidia::isaac_ros::nitros::NitrosImageView>, std::hash<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > >, std::equal_to<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > >, std::allocator<std::pair<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const, std::shared_ptr<nvidia::isaac_ros::nitros::NitrosImageView> > > > const&, rclcpp::Time&, nvidia::isaac::common::transform::SE3Transform<double>&)
#17 Object "/home/nvidia/workspaces/install/isaac_ros_visual_global_localization/lib/libvisual_global_localization_node.so", at 0xfffe64afc2d7, in nvidia::isaac::visual::cuvgl::cuVGL::Localize(std::vector<nvidia::isaac::visual::cuvgl::CameraImage, std::allocator<nvidia::isaac::visual::cuvgl::CameraImage> > const&, nvidia::isaac::common::transform::SE3Transform<double>&) const
#16 Object "/home/nvidia/workspaces/install/isaac_ros_visual_global_localization/lib/libvisual_global_localization_node.so", at 0xfffe64b69f4f, in nvidia::isaac::visual::cuvgl::BaseVisualLocalizer::Localize(std::vector<nvidia::isaac::visual::cuvgl::CameraImage, std::allocator<nvidia::isaac::visual::cuvgl::CameraImage> > const&, nvidia::isaac::common::transform::SE3Transform<double>&) const
#15 Object "/home/nvidia/workspaces/install/isaac_ros_visual_global_localization/lib/libvisual_global_localization_node.so", at 0xfffe64b67b03, in nvidia::isaac::visual::cuvgl::BaseVisualLocalizer::Localize(std::vector<nvidia::isaac::visual::cuvgl::CameraImage, std::allocator<nvidia::isaac::visual::cuvgl::CameraImage> > const&, nvidia::isaac::visual::cuvgl::LocalizationResult&) const
#14 Object "/home/nvidia/workspaces/install/isaac_ros_visual_global_localization/lib/libvisual_global_localization_node.so", at 0xfffe64b0cecf, in nvidia::isaac::visual::cuvgl::MultipleStereoLocalizer::LocalizeImpl(std::vector<nvidia::isaac::visual::cuvgl::CameraImage, std::allocator<nvidia::isaac::visual::cuvgl::CameraImage> > const&, nvidia::isaac::visual::cuvgl::LocalizationResult&) const
#13 Object "/home/nvidia/workspaces/install/isaac_ros_visual_global_localization/lib/libvisual_global_localization_node.so", at 0xfffe64b0b86b, in nvidia::isaac::visual::cuvgl::MultipleStereoLocalizer::RunStereo(std::vector<nvidia::isaac::visual::cuvgl::CameraImage, std::allocator<nvidia::isaac::visual::cuvgl::CameraImage> > const&, int, int, nvidia::isaac::visual::cuvgl::MultipleStereoLocalizer::StereoCalibrationParam const&, nvidia::isaac::visual::cuvgl::MultipleStereoLocalizer::StereoResult&) const
#12 Object "/home/nvidia/workspaces/install/isaac_ros_visual_global_localization/lib/libvisual_global_localization_node.so", at 0xfffe64b689a3, in nvidia::isaac::visual::cuvgl::BaseVisualLocalizer::ExtractFrame(nvidia::isaac::visual::cuvgl::CameraImage const&) const
#11 Object "/home/nvidia/workspaces/install/isaac_ros_visual_global_localization/lib/libvisual_global_localization_node.so", at 0xfffe64ba0993, in nvidia::isaac::common::image::KeypointDetector::DetectAndComputeSiftCvCuda(cv::Mat const&, nvidia::isaac::common::image::KeypointVector*, cv::Mat const&, cv::Mat*) const
#10 Object "/home/nvidia/workspaces/install/isaac_ros_visual_global_localization/lib/libvisual_global_localization_node.so", at 0xfffe64bf492b, in nvidia::isaac::common::image::feature::SiftCvCuda::detectAndCompute(cv::_InputArray const&, cv::_InputArray const&, std::vector<cv::KeyPoint, std::allocator<cv::KeyPoint> >&, cv::_OutputArray const&, bool)
#9 Object "/home/nvidia/workspaces/install/isaac_ros_visual_global_localization/lib/libvisual_global_localization_node.so", at 0xfffe64bf5f83, in nvcv::detail::ThrowException(NVCVStatus)
#8 Object "/lib/aarch64-linux-gnu/libstdc++.so.6", at 0xffff94132e93, in __cxa_throw
#7 Object "/lib/aarch64-linux-gnu/libstdc++.so.6", at 0xffff94132baf, in std::terminate()
#6 Object "/lib/aarch64-linux-gnu/libstdc++.so.6", at 0xffff94132b4b, in
#5 Object "/lib/aarch64-linux-gnu/libstdc++.so.6", at 0xffff941353cf, in __gnu_cxx::__verbose_terminate_handler()
#4 Object "/lib/aarch64-linux-gnu/libc.so.6", at 0xffff93ed712f, in abort
#3 Object "/lib/aarch64-linux-gnu/libc.so.6", at 0xffff93eea67b, in raise
#2 Object "/lib/aarch64-linux-gnu/libc.so.6", at 0xffff93f2f1f0, in
#1 Object "linux-vdso.so.1", at 0xffff9459479b, in
#0 Object "/home/nvidia/workspaces/orbbec-dev/install/orbbec_camera/lib/liborbbec_camera.so", at 0xffff8c47e693, in signalHandler(int)
