I’d be happy to help you with your question.
It seems like you’re experiencing an issue with your Jetson AGX Orin SOM and TPM module on your custom carrier board. Specifically, you’ve noticed that the TPM module works fine when you disable cvmeepromread, but it times out when cvmeepromread is enabled.
To provide some guidance, let’s break down the components involved and their relationships:
- Jetson AGX Orin SOM: This is the System-on-Module (SOM) that contains the NVIDIA Jetson AGX Orin processor, memory, and other essential components.
- Custom Carrier Board: This is your own design board that connects to the Jetson AGX Orin SOM and provides additional functionality, such as the TPM module.
- TPM Module: This is a Trusted Platform Module (TPM) that provides an additional layer of security for your system.
- SPI3: This is a Serial Peripheral Interface (SPI) bus that connects the TPM module to the Jetson AGX Orin SOM.
- cvmeepromread: This is a command that reads the EEPROM (Electrically Erasable Programmable Read-Only Memory) on the Jetson AGX Orin SOM.
Now, let’s try to understand how these components might interact with each other:
- When you disable
cvmeepromread, the TPM module works fine, suggesting that the issue is related to the EEPROM read operation.
- When you enable
cvmeepromread, the TPM module times out, indicating that the EEPROM read operation is interfering with the TPM module’s functionality.
Here are a few possible explanations for this behavior:
- EEPROM Read Collision: It’s possible that the
cvmeepromread command is accessing the EEPROM at the same time as the TPM module is trying to communicate with the Jetson AGX Orin SOM over the SPI3 bus. This collision could be causing the TPM module to timeout.
- SPI Bus Conflict: Another possibility is that the
cvmeepromread command is using the SPI bus to access the EEPROM, which is also used by the TPM module to communicate with the Jetson AGX Orin SOM. This conflict could be causing the TPM module to timeout.
To resolve this issue, you could try the following:
- Check the SPI Bus Configuration: Verify that the SPI bus is properly configured to support both the TPM module and the EEPROM read operation.
- Use a Different SPI Bus: If possible, consider using a different SPI bus for the TPM module to avoid conflicts with the EEPROM read operation.
- Modify the cvmeepromread Command: You could try modifying the
cvmeepromread command to avoid accessing the EEPROM during the TPM module’s communication with the Jetson AGX Orin SOM.
I hope this helps you understand the issue and provides a starting point for resolving the problem. If you have any further questions or need more specific guidance, feel free to ask.
In comparison to other Jetson modules, the Jetson AGX Orin SOM has a similar architecture, but with some differences in terms of the components and interfaces used. For example:
- Jetson AGX Xavier Series: This series uses a different SOM architecture and has a different set of components and interfaces. However, the principles of SPI bus configuration and EEPROM read operations are similar.
- Jetson Orin NX Series: This series uses a similar SOM architecture to the Jetson AGX Orin SOM, but with some differences in terms of the components and interfaces used.
In terms of software, the JetPack 6.2.3-3643 version you’re using is a specific release of the NVIDIA JetPack SDK, which provides a set of tools and libraries for developing applications on NVIDIA Jetson modules. The SDK includes support for various components, including the TPM module, and provides a set of APIs for accessing these components.
I hope this comparison helps you understand the context of your issue and provides a broader perspective on the Jetson ecosystem.
