Environment
Both hosts are identical in hardware, firmware and software.
| Item | Value |
| Hosts | 2 × compute nodes (source and destination) |
| NIC | ConnectX-7, MCX755106AS-HEA_Ax, dual-port QSFP112, 200GbE |
| PSID | MT_0000000834 (identical on both hosts) |
| Firmware | 28.47.2682 (identical on both hosts) |
| CPU | Intel Xeon Platinum 8457C (identical on both hosts) |
| OS | Rocky Linux 9.7 (Blue Onyx) |
| Kernel | 5.14.0-611.55.1.el9_7.x86_64 |
| DOCA-Host | doca-host-3.4.0-085000_26.04_rhel9 |
| OFED | OFED-internal-26.04-0.8.6 |
mlx5_core |
/lib/modules/5.14.0-611.55.1.el9_7.x86_64/extra/mlx5_core.ko.xz, version 26.04-0.8.6 |
mlx5_vfio_pci |
/lib/modules/5.14.0-611.55.1.el9_7.x86_64/extra/mlx5-vfio-pci.ko.xz |
| QEMU | 9.1.0 |
| libvirt | 10.10.0 |
| iproute2 | 6.14.0 |
| eswitch mode | switchdev on both PFs (pci/0000:38:00.0, pci/0000:38:00.1) |
| VFs | 16 per PF, NUM_OF_VFS=127, SRIOV_EN=True(1) |
VF_MIGRATION_MODE |
MIGRATION_ENABLED(2) on both hosts (set via mlxconfig, host rebooted afterwards) |
MULTI_PORT_VHCA_EN |
False(0) — VFs are regular single-port VFs, not MPV |
| Orchestration | OpenStack 2025.1 (nova 31.1.1) driving libvirt-managed live migration |
Note on the driver source: the mlx5 stack on these hosts is not the inbox kernel driver. Both
mlx5_core and mlx5_vfio_pci are provided by DOCA-Host / OFED 26.04 and live in
/lib/modules/$(uname -r)/extra/. The kernel tree contains no inbox mlx5 VFIO module
(/lib/modules/$(uname -r)/kernel/drivers/vfio/pci/mlx5/ does not exist).
Problem Summary
A live migration of a QEMU/KVM guest with one ConnectX-7 VF assigned via
<interface type='hostdev'> fails on the destination host. The VFIO migration protocol is
actually exercised — the device state is transferred and the destination attempts to load it — but
the firmware rejects the load.
The guest is unharmed; the migration aborts and rolls back cleanly to the source.
Exact Error
Destination host, kernel log:
mlx5_vfio_pci 0000:38:01.6: enabling device (0000 -> 0002)
mlx5_core 0000:38:00.0: mlx5_cmd_out_err:839:(pid 186047): LOAD_VHCA_STATE(0x119) op_mod(0x0) failed,
status bad parameter(0x3), syndrome (0xe9ecae), err(-22)
Destination host, QEMU:
qemu-kvm: error while loading state section id 105(0000:00:02.4:00.0/vfio)
qemu-kvm: load of migration failed: Invalid argument
Source host, libvirt:
operation failed: job 'migration out' failed: Sibling indicated error 1
This is 100% reproducible — reproduced on every attempt (7 attempts across two different guests).
Prerequisites — all verified present
Every item in the SR-IOV Live Migration setup procedure (DOCA 3.4 documentation) has been
performed and individually verified on the live system:
| Documented requirement | Verified state |
mlxconfig ... VF_MIGRATION_MODE=2 + reboot |
VF_MIGRATION_MODE = MIGRATION_ENABLED(2) on both hosts. Before the reboot devlink port show reported no migratable attribute at all; after the reboot the attribute appears on all 32 VF ports, confirming the firmware setting took effect |
PF in switchdev mode |
pci/0000:38:00.0: mode switchdev inline-mode none encap-mode basic (both PFs, both hosts) |
| VFs created | 16 VFs per PF |
VF unbound from mlx5_core before setting migratable |
Done. Note: setting migratable on a bound VF fails with Failed setting HCA migratable cap. kernel answers: Invalid argument; unbind → set → rebind works and the setting persists across the rebind |
devlink port function set ... migratable enable |
Confirmed "migratable": "enable" on the specific source VF used by the guest and on every free VF on the destination host |
VF bound to mlx5_vfio_pci (not generic vfio-pci) |
Confirmed on both ends via kernel log (mlx5_vfio_pci 0000:38:01.x: enabling device) and /sys/bus/pci/devices/<VF>/driver. libvirt selects the variant driver automatically with managed='yes' |
| Same PSID and firmware on both hosts | MT_0000000834 / 28.47.2682 |
migrate_set_capability return-path on / switchover-ack on |
Confirmed enabled by libvirt on both source and destination. Captured from the QMP traffic: {"capability":"switchover-ack","state":true} is sent at migration start on both ends and reset to false only after the migration aborts |
| Destination VF administrative MAC | Confirmed correct during the migration. Sampled devlink port show at 200 ms intervals on the destination while migrating: the claimed VF carries the guest’s MAC (fa:16:3e:6b:e4:1e, matching the source VF) at the time the state is loaded. It is reverted to a random address only after the rollback |
| ≤ 4 parallel VF migrations | Only one VF is being migrated |
| MPV restriction (“MPV VFs traffic cannot be configured with OVS”) | Does not apply — MULTI_PORT_VHCA_EN = False(0), these are regular single-port VFs |
Ruled out by experiment
| Hypothesis | Result |
switchover-ack / return-path not enabled |
Ruled out — QMP capture shows both true on both ends |
| Destination VF MAC not programmed | Ruled out — live sampling during migration shows the correct MAC |
| Destination VF not migration-capable | Ruled out — after explicitly enabling migratable on all free destination VFs the same error still occurs |
Generic vfio-pci bound instead of the variant driver |
Ruled out — kernel log shows mlx5_vfio_pci on both ends |
| Guest has a mixed NIC configuration | Ruled out — a guest with a single interface, the VFIO one and nothing else, fails identically |
| Hardware / firmware mismatch between hosts | Ruled out — identical part number, PSID and firmware |
| eswitch in legacy mode | Ruled out — both PFs are in switchdev, as the documentation requires |
Reproduction
- Two identical CX-7 hosts as described above, PFs in
switchdev,VF_MIGRATION_MODE=2, rebooted. - On both hosts, for the VFs to be used: unbind from
mlx5_core,
devlink port function set pci/0000:38:00.0/<port> migratable enable, rebind. - Start a guest on the source with one VF assigned as
<interface type='hostdev' managed='yes'>with a<mac>element. - Live migrate the guest to the destination (libvirt-managed, peer-to-peer, not tunnelled).
- The migration aborts; the destination kernel log shows the
LOAD_VHCA_STATEfailure above.
The VF representor is attached to an OVS bridge (OVN-managed, VLAN access port with offloaded
flows) on both hosts. We could not find any documented restriction against this for non-MPV VFs,
but it is the one aspect of our setup that differs from the plain example in the documentation.
Questions
What does
LOAD_VHCA_STATEsyndrome0xe9ecae(statusbad parameter (0x3)) indicate?
This is the single most useful piece of information — it should point directly at whichever
parameter or device-state field the firmware is rejecting. -
Is SR-IOV Live Migration supported when the mlx5 stack is supplied by DOCA-Host / OFED 26.04
on a RHEL/Rocky 9 kernel (5.14)? The documented requirement is “Kernel Linux v6.7 or newer”,
which we read as applying to the inbox driver. The documentation does not state what the
requirement is when DOCA-Host providesmlx5_coreandmlx5_vfio_pcias out-of-tree modules,
which is our case. Note that RHEL/Rocky 9 cannot reach kernel 6.7 at all — the newest kernel in
the Rocky 9 repositories is5.14.0-687.42.1.el9_8— so if a ≥6.7 kernel is genuinely required,
this feature is unavailable on RHEL 9 derivatives regardless of DOCA-Host, and we would like that
confirmed explicitly. -
Is there a supported firmware ↔ driver compatibility matrix for this feature?
We run firmware28.47.2682with OFED26.04-0.8.6. The documentation only states a firmware
floor (28.41.1000). -
Is any per-VF configuration required beyond
migratable enable? In particular, must RoCE be
disabled on the VF before migration? Our VFs report"roce": "enable"alongside
"migratable": "enable", and the documentation does not mention the interaction. -
Does attaching the VF representor to an OVS bridge with offloaded flows affect VHCA state
migration for non-MPV VFs? The documentation only restricts this for MPV VFs.
Data available on request
- Full destination
dmesgand/var/log/libvirt/libvirtd.logaround the failure - Full QMP trace of the migration (libvirt
qemu_monitordebug log, both ends) mlxconfig -d <PF> qanddevlink port show -jpoutput from both hosts- Guest domain XML (source) and the destination XML generated for the migration
mstflint/mlxlinkoutput if required
