Hello, I am currently using ConnectX-6 Dx Crypto enable card PN:MCX623106AC-CDAT to test the throughput of IPsec packet offload.
When I enable packet offload, the throughput stays at 58 Gbps across 4 to 32 CPUs.
Could you please advise on how to configure the settings to reach 90 Gbps?
According to the test data on this page " Extend XFRM core to allow packet offload configuration [LWN.net] ", my baseline matches the report’s findings. However, once IPsec packet offload is enabled, throughput is limited to 58 Gbps.
Linux version : 24.04 LST , kernel 6.18
setup NIC: ConnectX6-DX dual port, 100 Gbps each. Single port used in the tests.
MTU settings: ip link set dev enp1s0f0 mtu 9000
IRQ affinity: mlnx_tune -p HIGH_THROUGHPUT
