CX8 Device lspci information
During our PCIe device inspection using the lspci command, we encountered an unexpected scenario. While checking device information, we identified a device labeled as Device 3. However, there was no information about Device 1 or Device 2 in the lspci output.
Additionally, the target link width for Device 3 was displayed as x1, which caused confusion regarding the actual connection speed. The absence of the earlier devices and the seemingly limited link width raised questions:
  • What happened to Device 1 and Device 2?
  • Is the reported link width of x1 correct, or is there a misconfiguration?
  • Could this affect device performance or system behavior?
Please make sure the devices are physically installed and properly seated in the PCIe slot.
Also, verify that they are enabled in BIOS/UEFI and no lanes are disabled due to resource limitation.
I would also suggest reviewing dmesg for any pci related errors that might indicate why the devices did not enumerate.
If the issue still persists, please open a case directly with Enterprise Support and it will be handled based on entitlement.
Thanks,
Jonathan.
Thank you for your advice — it was very helpful. The issue has been resolved.”
It would be helpful if you provide the solution that was implemented to fix the issue so that it would be helpful to others.
