CXR 4 Unity Plugin - Support for Built-in render pipeline?
Thank you for CloudXR, extremely appreciated!
We are testing the Unity integration right now and discovered that the CXR4 Unity Plugin seems to only support URP as of now. Is there support for BIRP or HDRP planned?
There should be no issue. The rendering is done in sample code, not in the core plugin/SDK code, and while it may take some dev effort, there’s no reason Core RP or HDRP should not work (so long as they work for the platform in question).
