Hallo,
I patched PREEAMT-RT Kernel on my xavier.
I installed the rt tests with
sudo apt get install rt tests;
The Cyclictest is working. But if im trying to set my system uner load with the indructions in the fowllowing link. It dosent work.
https://wiki.linuxfoundation.org/realtime/documentation/howto/tools/worstcaselatency
Is thre any other way to make a Cyclictest under load on my nvidia xavier agx.
What do you mean set system under load with the indructions?
I try to get the cpu load up to 100% by doing the Cyclictest.
Is there a test that makes the CPU up to 100% and performs the Cyclictest which works for the xavier?
Thanks itś working.
Is there a test to set the USB Disk I/O under Stress and the Network as well?
I think you can have a google to search that. I believe there should have many tools to that for your choose.
