Since jetson is running k4.9, it may not be compatible.
There is one more sdk cypress-fmac-v4.14.77-2020_0115, it also contains the same folder structure.
If this can be integrated to tx2 kernel-4.9, then please suggesst how can i integrate it?
I don’t know whether it can be integrated to k4.9 or not. Maybe some functions are not compatible.
You can follow the l4t developer guide from our download center and check the Kernel customization section.
Regarding the compatibility i will check.
But i want to understand whether this kernel driver package cypress-backports-v4.14.77-2020_0115-module-src.tar.gz can be integrated in the tx2-sdk kernel-4.9.140, or it should be compiled explicitly using the toolchains and include the .ko in the final build ??
Do you want go say build-in as a kernel image or a .ko file as a external module?
Generally, such wifi driver is built as a external module.
Ok, then ultimately this package should be built as external kernel module.
Hi Wayne,
I want to enable uart3 for bluetooth, I have shared the schematic earlier in this thread.
Can you please suggest how can i enable it.
