CUDA-only D2D Peer Copy Interference from D2H Traffic
I am seeing a large D2D peer-copy bandwidth drop only in one CUDA-only case. The tests use cudaMemcpyPeerAsync for D2D, cudaMemcpyAsync with pinned host memory for D2H/H2D, and CUDA events for D2D timing.
Test machine: 4x Tesla V100-SXM2-32GB, all tested GPU pairs are NV2, driver 580.159.03, CUDA 12.6.
The system has 4 Tesla V100-SXM2-32GB GPUs, and every GPU pair is connected by NV2 links.
Cases tested
4-GPU allpairs D2D
Every ordered GPU pair copies to every other GPU (
GPU i -> GPU j,i != j).Initial result: baseline is about
180.97 GB/s. With D2H background traffic, D2D drops to about127.97 GB/s; D2H background is about10.6-13.4 GB/saggregate. With H2D background traffic using the same 255 MiB copy size, there is no noticeable D2D bandwidth drop. -
4-GPU ring D2D
Ring pattern:
GPU i -> GPU (i + 1) % 4.Initial result: no noticeable D2D bandwidth drop with either D2H or H2D background traffic.
2-GPU D2D
Two directed peer copies are used:
GPU0 -> GPU1andGPU1 -> GPU0.Initial result: no noticeable D2D bandwidth drop with either D2H or H2D background traffic.
Minimal commands
# 4-GPU allpairs baseline
./d2d_peer_bw --devices=4 --pattern=allpairs --size=255M --iters=120 --warmup=10 --no-sync-each-iter
# 4-GPU ring baseline
./d2d_peer_bw --devices=4 --pattern=ring --size=255M --iters=500 --warmup=20 --no-sync-each-iter
# D2H background, run in another terminal
./pcie_background_copy --devices=4 --direction=d2h --size=255M
# H2D background, run in another terminal
./pcie_background_copy --devices=4 --direction=h2d --size=255M
Question
Why does sustained D2H traffic significantly reduce 4-GPU allpairs D2D peer-copy bandwidth, while H2D traffic with the same copy size does not? Also, why are the 4-GPU ring and 2-GPU D2D cases almost unaffected by either D2H or H2D background traffic?
My guess is that allpairs creates enough source-side peer-copy pressure to become sensitive to GPU-local memory/copy/fabric arbitration, and D2H competes with that path more directly than H2D. Is this expected behavior, and which GPU resources are likely being contended?
Source code
d2d_peer_bw.cu
#include <cuda_runtime.h>
#include <cstdio>
#include <cstdlib>
#include <cstring>
#include <string>
#include <vector>
#define CHECK_CUDA(call) \
do { \
cudaError_t err__ = (call); \
if (err__ != cudaSuccess) { \
std::fprintf(stderr, "CUDA error at %s:%d: %s\n", __FILE__, __LINE__, \
cudaGetErrorString(err__)); \
return 1; \
} while (0)
struct Options {
int devices = 4;
size_t bytes = 255ULL * 1024ULL * 1024ULL;
int warmup = 20;
int iters = 500;
std::string pattern = "ring";
bool sync_each_iter = true;
static size_t parse_size(const char* s) {
char* end = nullptr;
double value = std::strtod(s, &end);
if (end == s || value <= 0) return 0;
double scale = 1.0;
if (*end == 'k' || *end == 'K') scale = 1024.0;
if (*end == 'm' || *end == 'M') scale = 1024.0 * 1024.0;
if (*end == 'g' || *end == 'G') scale = 1024.0 * 1024.0 * 1024.0;
return static_cast<size_t>(value * scale);
static void usage(const char* prog) {
std::printf(
"Usage: %s [--devices=N] [--pattern=ring|allpairs]\n"
" [--size=255M] [--warmup=20] [--iters=500] [--no-sync-each-iter]\n\n"
"Patterns:\n"
" ring GPU i -> GPU (i+1) %% devices (default)\n"
" allpairs every ordered GPU pair i -> j, i != j\n",
prog);
static int parse_args(int argc, char** argv, Options* opt) {
for (int i = 1; i < argc; ++i) {
if (std::strncmp(argv[i], "--devices=", 10) == 0) {
opt->devices = std::atoi(argv[i] + 10);
} else if (std::strncmp(argv[i], "--pattern=", 10) == 0) {
opt->pattern = argv[i] + 10;
} else if (std::strncmp(argv[i], "--size=", 7) == 0) {
opt->bytes = parse_size(argv[i] + 7);
} else if (std::strncmp(argv[i], "--warmup=", 9) == 0) {
opt->warmup = std::atoi(argv[i] + 9);
} else if (std::strncmp(argv[i], "--iters=", 8) == 0) {
opt->iters = std::atoi(argv[i] + 8);
} else if (std::strcmp(argv[i], "--no-sync-each-iter") == 0) {
opt->sync_each_iter = false;
} else if (std::strcmp(argv[i], "-h") == 0 ||
std::strcmp(argv[i], "--help") == 0) {
usage(argv[0]);
std::exit(0);
} else {
std::fprintf(stderr, "Unknown option: %s\n", argv[i]);
usage(argv[0]);
return 1;
if (opt->devices < 2 || opt->bytes == 0 || opt->warmup < 0 ||
opt->iters <= 0 ||
(opt->pattern != "ring" && opt->pattern != "allpairs")) {
usage(argv[0]);
return 1;
return 0;
static int enable_peer(int dst, int src) {
int can_access = 0;
CHECK_CUDA(cudaDeviceCanAccessPeer(&can_access, dst, src));
if (!can_access) {
std::fprintf(stderr, "GPU %d cannot directly access GPU %d\n", dst, src);
return 1;
CHECK_CUDA(cudaSetDevice(dst));
cudaError_t err = cudaDeviceEnablePeerAccess(src, 0);
if (err == cudaErrorPeerAccessAlreadyEnabled) {
cudaGetLastError();
return 0;
if (err != cudaSuccess) {
std::fprintf(stderr, "cudaDeviceEnablePeerAccess(%d -> %d) failed: %s\n",
dst, src, cudaGetErrorString(err));
return 1;
return 0;
static int issue_copies(const Options& opt, const std::vector<void*>& src,
const std::vector<std::vector<void*> >& dst,
const std::vector<cudaStream_t>& streams) {
for (int s = 0; s < opt.devices; ++s) {
CHECK_CUDA(cudaSetDevice(s));
if (opt.pattern == "ring") {
int d = (s + 1) % opt.devices;
CHECK_CUDA(cudaMemcpyPeerAsync(dst[d][s], d, src[s], s, opt.bytes,
streams[s]));
} else {
for (int d = 0; d < opt.devices; ++d) {
if (d == s) continue;
streams[s]));
return 0;
int main(int argc, char** argv) {
Options opt;
if (parse_args(argc, argv, &opt) != 0) return 1;
int device_count = 0;
CHECK_CUDA(cudaGetDeviceCount(&device_count));
if (opt.devices > device_count) {
std::fprintf(stderr, "Requested devices=%d, device_count=%d\n",
opt.devices, device_count);
return 1;
std::printf("D2D peer memcpy benchmark\n");
std::printf("devices=%d pattern=%s size=%zu bytes (%.2f MiB) warmup=%d iters=%d sync_each_iter=%s\n",
opt.devices, opt.pattern.c_str(), opt.bytes,
opt.bytes / 1024.0 / 1024.0, opt.warmup, opt.iters,
opt.sync_each_iter ? "yes" : "no");
cudaDeviceProp prop;
CHECK_CUDA(cudaGetDeviceProperties(&prop, d));
std::printf("GPU %d: %s\n", d, prop.name);
if (d != s && enable_peer(d, s) != 0) return 1;
std::vector<void*> src(opt.devices, nullptr);
std::vector<std::vector<void*> > dst(opt.devices,
std::vector<void*>(opt.devices, nullptr));
std::vector<cudaStream_t> streams(opt.devices, nullptr);
std::vector<cudaEvent_t> start(opt.devices, nullptr);
std::vector<cudaEvent_t> stop(opt.devices, nullptr);
CHECK_CUDA(cudaSetDevice(d));
CHECK_CUDA(cudaMalloc(&src[d], opt.bytes));
CHECK_CUDA(cudaMemset(src[d], d & 0xff, opt.bytes));
if (s != d) CHECK_CUDA(cudaMalloc(&dst[d][s], opt.bytes));
CHECK_CUDA(cudaStreamCreate(&streams[d]));
CHECK_CUDA(cudaEventCreate(&start[d]));
CHECK_CUDA(cudaEventCreate(&stop[d]));
for (int i = 0; i < opt.warmup; ++i) {
if (issue_copies(opt, src, dst, streams) != 0) return 1;
CHECK_CUDA(cudaStreamSynchronize(streams[d]));
CHECK_CUDA(cudaEventRecord(start[d], streams[d]));
for (int i = 0; i < opt.iters; ++i) {
if (opt.sync_each_iter) {
CHECK_CUDA(cudaEventRecord(stop[d], streams[d]));
CHECK_CUDA(cudaEventSynchronize(stop[d]));
double max_sec = 0.0;
float ms = 0.0f;
CHECK_CUDA(cudaEventElapsedTime(&ms, start[d], stop[d]));
double sec = ms / 1000.0;
if (sec > max_sec) max_sec = sec;
std::printf("Elapsed GPU %d source stream: %.3f ms\n", d, ms);
int copies_per_iter = opt.devices;
if (opt.pattern == "allpairs") copies_per_iter = opt.devices * (opt.devices - 1);
double total_bytes = static_cast<double>(opt.bytes) * opt.iters * copies_per_iter;
double aggregate_gbs = total_bytes / max_sec / 1e9;
std::printf("Directed copies per iteration: %d\n", copies_per_iter);
std::printf("Aggregate D2D bandwidth: %.2f GB/s\n", aggregate_gbs);
std::printf("Per-copy average bandwidth: %.2f GB/s\n", aggregate_gbs / copies_per_iter);
cudaEventDestroy(start[d]);
cudaEventDestroy(stop[d]);
cudaStreamDestroy(streams[d]);
cudaFree(src[d]);
if (dst[d][s]) cudaFree(dst[d][s]);
return 0;
pcie_background_copy.cu
#include <atomic>
#include <chrono>
#include <cstdio>
#include <cstdlib>
#include <cstring>
#include <thread>
#include <vector>
#define CHECK_CUDA_OR_FAIL(call) \
do { \
failed->store(true, std::memory_order_release); \
return; \
} while (0)
struct Options {
int devices = 2;
int dev0 = 0;
int dev1 = 1;
bool use_pair = false;
int warmup = 5;
int report_sec = 2;
const char* direction = "d2h";
double scale = 1.0;
std::printf(
"Usage: %s [--devices=N | --dev0=0 --dev1=1] [--size=255M]\n"
" [--direction=d2h|h2d] [--warmup=5] [--report-sec=2]\n",
prog);
opt->use_pair = false;
} else if (std::strncmp(argv[i], "--dev0=", 7) == 0) {
opt->dev0 = std::atoi(argv[i] + 7);
opt->use_pair = true;
} else if (std::strncmp(argv[i], "--dev1=", 7) == 0) {
opt->dev1 = std::atoi(argv[i] + 7);
} else if (std::strncmp(argv[i], "--direction=", 12) == 0) {
opt->direction = argv[i] + 12;
} else if (std::strncmp(argv[i], "--report-sec=", 13) == 0) {
opt->report_sec = std::atoi(argv[i] + 13);
usage(argv[0]);
std::exit(0);
} else {
usage(argv[0]);
return 1;
if (opt->devices <= 0 || opt->dev0 == opt->dev1 || opt->bytes == 0 ||
opt->warmup < 0 || opt->report_sec <= 0 ||
(std::strcmp(opt->direction, "d2h") != 0 &&
std::strcmp(opt->direction, "h2d") != 0)) {
usage(argv[0]);
return 1;
return 0;
static void worker(int device, const Options opt,
std::atomic<unsigned long long>* total_bytes,
std::atomic<int>* ready, std::atomic<bool>* go,
std::atomic<bool>* failed) {
CHECK_CUDA_OR_FAIL(cudaSetDevice(device));
void* h = nullptr;
void* d = nullptr;
cudaStream_t stream = nullptr;
CHECK_CUDA_OR_FAIL(cudaMallocHost(&h, opt.bytes));
CHECK_CUDA_OR_FAIL(cudaMalloc(&d, opt.bytes));
CHECK_CUDA_OR_FAIL(cudaStreamCreate(&stream));
CHECK_CUDA_OR_FAIL(cudaMemset(d, device & 0xff, opt.bytes));
std::memset(h, device & 0xff, opt.bytes);
cudaMemcpyKind kind = std::strcmp(opt.direction, "d2h") == 0
? cudaMemcpyDeviceToHost
: cudaMemcpyHostToDevice;
void* dst = kind == cudaMemcpyDeviceToHost ? h : d;
void* src = kind == cudaMemcpyDeviceToHost ? d : h;
CHECK_CUDA_OR_FAIL(cudaMemcpyAsync(dst, src, opt.bytes, kind, stream));
CHECK_CUDA_OR_FAIL(cudaStreamSynchronize(stream));
ready->fetch_add(1, std::memory_order_acq_rel);
while (!go->load(std::memory_order_acquire) &&
!failed->load(std::memory_order_acquire)) {
std::this_thread::yield();
while (!failed->load(std::memory_order_acquire)) {
total_bytes->fetch_add(opt.bytes, std::memory_order_relaxed);
Options opt;
cudaError_t err = cudaGetDeviceCount(&device_count);
std::fprintf(stderr, "cudaGetDeviceCount failed: %s\n", cudaGetErrorString(err));
return 1;
std::vector<int> devices;
if (opt.use_pair) {
devices.push_back(opt.dev0);
devices.push_back(opt.dev1);
} else {
for (int d = 0; d < opt.devices; ++d) devices.push_back(d);
for (int d : devices) {
if (d < 0 || d >= device_count) {
std::fprintf(stderr, "Requested GPU %d but device_count=%d\n", d, device_count);
return 1;
std::printf("PCIe background copy\n");
std::printf("devices=");
for (size_t i = 0; i < devices.size(); ++i) std::printf("%s%d", i ? "," : "", devices[i]);
std::printf(" direction=%s size=%zu bytes (%.2f MiB)\n", opt.direction,
opt.bytes, opt.bytes / 1024.0 / 1024.0);
std::printf("Each GPU uses one pinned host buffer, one device buffer, one stream, and repeats memcpy+stream sync forever.\n");
std::fflush(stdout);
std::atomic<unsigned long long> total_bytes{0};
std::atomic<int> ready{0};
std::atomic<bool> go{false};
std::atomic<bool> failed{false};
std::vector<std::thread> threads;
for (int d : devices) threads.emplace_back(worker, d, opt, &total_bytes, &ready, &go, &failed);
while (ready.load(std::memory_order_acquire) < static_cast<int>(devices.size()) &&
!failed.load(std::memory_order_acquire)) {
std::this_thread::sleep_for(std::chrono::milliseconds(10));
go.store(true, std::memory_order_release);
using clock = std::chrono::steady_clock;
unsigned long long last_bytes = total_bytes.load(std::memory_order_relaxed);
auto last = clock::now();
while (!failed.load(std::memory_order_acquire)) {
std::this_thread::sleep_for(std::chrono::seconds(opt.report_sec));
auto now = clock::now();
unsigned long long current = total_bytes.load(std::memory_order_relaxed);
double seconds = std::chrono::duration<double>(now - last).count();
double gbps = static_cast<double>(current - last_bytes) / seconds / 1e9;
std::printf("bytes=%llu window_bytes=%llu time=%.3f s aggregate_bw=%.2f GB/s\n",
current, current - last_bytes, seconds, gbps);
last = now;
last_bytes = current;
for (auto& t : threads) t.join();
return failed.load() ? 1 : 0;
