DirectX 11 application from directx-sdk-samples-reworked/Direct3D11Tutorials/Tutorial02 at main · walbourn/directx-sdk-samples-reworked · GitHub instead of rendering a triangle produces a white framebuffer if running under a D3D11On12 mapping layer (for instance, if running with a d3d11.dll from GitHub - doitsujin/elf-auf-zwoelf: D3D11 wrapper library using Microsoft's D3D11On12 implementation · GitHub). Here is my gpu spec:
NVIDIA System Information report created on: 09/29/2026 20:00:22
System name: RU1-WW-2419
[Display]
DirectX version: 12.0
GPU processor: NVIDIA GeForce RTX 4090
Driver version: 580.97
Driver Type: DCH
Direct3D feature level: 12_1
CUDA Cores: 16384
Resizable BAR Yes
Core clock: 2520 MHz
Memory data rate: 21.00 Gbps
Memory interface: 384-bit
Memory bandwidth: 1.01 TB/s
Total available graphics memory: 57012 MB
Dedicated video memory: 24564 MB GDDR6X
System video memory: 0 MB
Shared system memory: 32448 MB
Video BIOS version: 95.02.3C.40.1B
IRQ: Not used
Bus: PCI Express x16 Gen4
Error Correction Code (ECC): Off
Device Id: 10DE 2684 A6751025
Part Number: G139 0332
[Components]
nvui.dll 8.17.15.8097 NVIDIA User Experience Driver Component
nvxdplcy.dll 8.17.15.8097 NVIDIA User Experience Driver Component
nvxdbat.dll 8.17.15.8097 NVIDIA User Experience Driver Component
nvxdapix.dll 8.17.15.8097 NVIDIA User Experience Driver Component
NVCPL.DLL 8.17.15.8097 NVIDIA User Experience Driver Component
nvCplUIR.dll 8.1.940.0 NVIDIA Control Panel
nvCplUI.exe 8.1.940.0 NVIDIA Control Panel
nvWSSR.dll 32.0.15.8097 NVIDIA Workstation Server
nvWSS.dll 32.0.15.8097 NVIDIA Workstation Server
nvViTvSR.dll 32.0.15.8097 NVIDIA Video Server
nvViTvS.dll 32.0.15.8097 NVIDIA Video Server
nvLicensingS.dll 6.14.15.8097 NVIDIA Licensing Server
nvDevToolSR.dll 32.0.15.8097 NVIDIA Licensing Server
nvDevToolS.dll 32.0.15.8097 NVIDIA 3D Settings Server
nvDispSR.dll 32.0.15.8097 NVIDIA Display Server
nvDispS.dll 32.0.15.8097 NVIDIA Display Server
PhysX 09.23.1019 NVIDIA PhysX
NVCUDA64.DLL 32.0.15.8097 NVIDIA CUDA 13.0.78 driver
nvGameSR.dll 32.0.15.8097 NVIDIA 3D Settings Server
nvGameS.dll 32.0.15.8097 NVIDIA 3D Settings Server
