My hardwares:
- nvidia jetson xavier nx
- zed camera (3.5)
I developed a special model on darknet. I used a zed camera for the image processing algorithm. When cudnn_half = 1 in the makefile file in darknet, I get “cuda status error” error.
If I run it on only one video file without using a camera, then the system works. I’m getting 40 to 60 fps.
If cudnn_half = 0, both zed camera and other instances are working correctly. I’m getting 18-20 fps.
I could not solve this problem. Thanks for your help.
Makefile
GPU=1
CUDNN=1
CUDNN_HALF=1
OPENCV=1
AVX=0
OPENMP=0
LIBSO=1
ZED_CAMERA=1
ZED_CAMERA_v2_8=0
# set GPU=1 and CUDNN=1 to speedup on GPU
# set CUDNN_HALF=1 to further speedup 3 x times (Mixed-precision on Tensor Cores) GPU: Volta, Xavier, Turing and higher
# set AVX=1 and OPENMP=1 to speedup on CPU (if error occurs then set AVX=0)
# set ZED_CAMERA=1 to enable ZED SDK 3.0 and above
# set ZED_CAMERA_v2_8=1 to enable ZED SDK 2.X
USE_CPP=0
DEBUG=0
ARCH= -gencode arch=compute_72,code=[sm_72,compute_72]
OS := $(shell uname)
# GeForce RTX 3070, 3080, 3090
# ARCH= -gencode arch=compute_86,code=[sm_86,compute_86]
# Kepler GeForce GTX 770, GTX 760, GT 740
# ARCH= -gencode arch=compute_30,code=sm_30
# Tesla A100 (GA100), DGX-A100, RTX 3080
# ARCH= -gencode arch=compute_80,code=[sm_80,compute_80]
# Tesla V100
# ARCH= -gencode arch=compute_70,code=[sm_70,compute_70]
# GeForce RTX 2080 Ti, RTX 2080, RTX 2070, Quadro RTX 8000, Quadro RTX 6000, Quadro RTX 5000, Tesla T4, XNOR Tensor Cores
# ARCH= -gencode arch=compute_75,code=[sm_75,compute_75]
# Jetson XAVIER
# ARCH= -gencode arch=compute_72,code=[sm_72,compute_72]
# GTX 1080, GTX 1070, GTX 1060, GTX 1050, GTX 1030, Titan Xp, Tesla P40, Tesla P4
# ARCH= -gencode arch=compute_61,code=sm_61 -gencode arch=compute_61,code=compute_61
# GP100/Tesla P100 - DGX-1
# ARCH= -gencode arch=compute_60,code=sm_60
# For Jetson TX1, Tegra X1, DRIVE CX, DRIVE PX - uncomment:
# ARCH= -gencode arch=compute_53,code=[sm_53,compute_53]
# For Jetson Tx2 or Drive-PX2 uncomment:
# ARCH= -gencode arch=compute_62,code=[sm_62,compute_62]
# For Tesla GA10x cards, RTX 3090, RTX 3080, RTX 3070, RTX A6000, RTX A40 uncomment:
VPATH=./src/
EXEC=darknet
OBJDIR=./obj/
ifeq ($(LIBSO), 1)
LIBNAMESO=libdarknet.so
APPNAMESO=uselib
endif
ifeq ($(USE_CPP), 1)
CC=g++
else
CC=gcc
endif
CPP=g++ -std=c++11
NVCC=nvcc
OPTS=-Ofast
LDFLAGS= -lm -pthread
COMMON= -Iinclude/ -I3rdparty/stb/include
CFLAGS=-Wall -Wfatal-errors -Wno-unused-result -Wno-unknown-pragmas -fPIC
ifeq ($(DEBUG), 1)
#OPTS= -O0 -g
#OPTS= -Og -g
COMMON+= -DDEBUG
CFLAGS+= -DDEBUG
else
ifeq ($(AVX), 1)
CFLAGS+= -ffp-contract=fast -mavx -mavx2 -msse3 -msse4.1 -msse4.2 -msse4a
endif
endif
CFLAGS+=$(OPTS)
ifneq (,$(findstring MSYS_NT,$(OS)))
LDFLAGS+=-lws2_32
endif
ifeq ($(OPENCV), 1)
COMMON+= -DOPENCV
CFLAGS+= -DOPENCV
LDFLAGS+= `pkg-config --libs opencv4 2> /dev/null || pkg-config --libs opencv`
COMMON+= `pkg-config --cflags opencv4 2> /dev/null || pkg-config --cflags opencv`
endif
ifeq ($(OPENMP), 1)
ifeq ($(OS),Darwin) #MAC
CFLAGS+= -Xpreprocessor -fopenmp
else
CFLAGS+= -fopenmp
endif
LDFLAGS+= -lgomp
endif
ifeq ($(GPU), 1)
COMMON+= -DGPU -I/usr/local/cuda-10.2/include/
CFLAGS+= -DGPU
LDFLAGS+= -L/usr/local/cuda-10.2/lib -lcuda -lcudart -lcublas -lcurand
else
LDFLAGS+= -L/usr/local/cuda-10.2/lib64 -lcuda -lcudart -lcublas -lcurand
endif
endif
ifeq ($(CUDNN), 1)
COMMON+= -DCUDNN
CFLAGS+= -DCUDNN -I/usr/local/cuda-10.2/include
LDFLAGS+= -L/usr/local/cuda-10.2/lib -lcudnn
else
CFLAGS+= -DCUDNN -I/usr/local/cudnn/include
LDFLAGS+= -L/usr/local/cudnn/lib64 -lcudnn
endif
endif
ifeq ($(CUDNN_HALF), 1)
COMMON+= -DCUDNN_HALF
CFLAGS+= -DCUDNN_HALF
ARCH+= -gencode arch=compute_72,code=[sm_72,compute_72]
endif
ifeq ($(ZED_CAMERA), 1)
CFLAGS+= -DZED_STEREO -I/usr/local/zed/include
ifeq ($(ZED_CAMERA_v2_8), 1)
LDFLAGS+= -L/usr/local/zed/lib -lsl_core -lsl_input -lsl_zed
#-lstdc++ -D_GLIBCXX_USE_CXX11_ABI=0
else
LDFLAGS+= -L/usr/local/zed/lib -lsl_zed
endif
endif
OBJ=image_opencv.o http_stream.o gemm.o utils.o dark_cuda.o convolutional_layer.o list.o image.o activations.o im2col.o col2im.o blas.o crop_layer.o dropout_layer.o maxpool_layer.o softmax_layer.o data.o matrix.o network.o connected_layer.o cost_layer.o parser.o option_list.o darknet.o detection_layer.o captcha.o route_layer.o writing.o box.o nightmare.o normalization_layer.o avgpool_layer.o coco.o dice.o yolo.o detector.o layer.o compare.o classifier.o local_layer.o swag.o shortcut_layer.o representation_layer.o activation_layer.o rnn_layer.o gru_layer.o rnn.o rnn_vid.o crnn_layer.o demo.o tag.o cifar.o go.o batchnorm_layer.o art.o region_layer.o reorg_layer.o reorg_old_layer.o super.o voxel.o tree.o yolo_layer.o gaussian_yolo_layer.o upsample_layer.o lstm_layer.o conv_lstm_layer.o scale_channels_layer.o sam_layer.o
ifeq ($(GPU), 1)
LDFLAGS+= -lstdc++
OBJ+=convolutional_kernels.o activation_kernels.o im2col_kernels.o col2im_kernels.o blas_kernels.o crop_layer_kernels.o dropout_layer_kernels.o maxpool_layer_kernels.o network_kernels.o avgpool_layer_kernels.o
endif
OBJS = $(addprefix $(OBJDIR), $(OBJ))
DEPS = $(wildcard src/*.h) Makefile include/darknet.h
all: $(OBJDIR) backup results setchmod $(EXEC) $(LIBNAMESO) $(APPNAMESO)
ifeq ($(LIBSO), 1)
CFLAGS+= -fPIC
$(LIBNAMESO): $(OBJDIR) $(OBJS) include/yolo_v2_class.hpp src/yolo_v2_class.cpp
$(CPP) -shared -std=c++11 -fvisibility=hidden -DLIB_EXPORTS $(COMMON) $(CFLAGS) $(OBJS) src/yolo_v2_class.cpp -o $@ $(LDFLAGS)
$(APPNAMESO): $(LIBNAMESO) include/yolo_v2_class.hpp src/yolo_console_dll.cpp
$(CPP) -std=c++11 $(COMMON) $(CFLAGS) -o $@ src/yolo_console_dll.cpp $(LDFLAGS) -L ./ -l:$(LIBNAMESO)
endif
$(EXEC): $(OBJS)
$(CPP) -std=c++11 $(COMMON) $(CFLAGS) $^ -o $@ $(LDFLAGS)
$(OBJDIR)%.o: %.c $(DEPS)
$(CC) $(COMMON) $(CFLAGS) -c $< -o $@
$(OBJDIR)%.o: %.cpp $(DEPS)
$(CPP) -std=c++11 $(COMMON) $(CFLAGS) -c $< -o $@
$(OBJDIR)%.o: %.cu $(DEPS)
$(NVCC) $(ARCH) $(COMMON) --compiler-options "$(CFLAGS)" -c $< -o $@
$(OBJDIR):
mkdir -p $(OBJDIR)
backup:
mkdir -p backup
results:
mkdir -p results
setchmod:
chmod +x *.sh
.PHONY: clean
clean:
rm -rf $(OBJS) $(EXEC) $(LIBNAMESO) $(APPNAMESO)
darknet_custom.py
#!python3
Python 3 wrapper for identifying objects in images
Requires DLL compilation
Original *nix 2.7: https://github.com/pjreddie/darknet/blob/0f110834f4e18b30d5f101bf8f1724c34b7b83db/python/darknet.py
Windows Python 2.7 version: https://github.com/AlexeyAB/darknet/blob/fc496d52bf22a0bb257300d3c79be9cd80e722cb/build/darknet/x64/darknet.py
@author: Philip Kahn, Aymeric Dujardin
@date: 20180911
# pylint: disable=R, W0401, W0614, W0703
import os
import sys
import time
import logging
import random
from random import randint
import math
import statistics
import getopt
from ctypes import *
import numpy as np
import cv2
import pyzed.sl as sl
# Get the top-level logger object
log = logging.getLogger(__name__)
logging.basicConfig(level=logging.INFO)
def sample(probs):
s = sum(probs)
probs = [a/s for a in probs]
r = random.uniform(0, 1)
for i in range(len(probs)):
r = r - probs[i]
if r <= 0:
return i
return len(probs)-1
def c_array(ctype, values):
arr = (ctype*len(values))()
arr[:] = values
return arr
class BOX(Structure):
_fields_ = [("x", c_float),
("y", c_float),
("w", c_float),
("h", c_float)]
class DETECTION(Structure):
_fields_ = [("bbox", BOX),
("classes", c_int),
("prob", POINTER(c_float)),
("mask", POINTER(c_float)),
("objectness", c_float),
("sort_class", c_int),
("uc", POINTER(c_float)),
("points", c_int),
("embeddings", POINTER(c_float)),
("embedding_size", c_int),
("sim", c_float),
("track_id", c_int)]
class IMAGE(Structure):
_fields_ = [("w", c_int),
("h", c_int),
("c", c_int),
("data", POINTER(c_float))]
class METADATA(Structure):
_fields_ = [("classes", c_int),
("names", POINTER(c_char_p))]
#lib = CDLL("/home/pjreddie/documents/darknet/libdarknet.so", RTLD_GLOBAL)
#lib = CDLL("darknet.so", RTLD_GLOBAL)
hasGPU = True
if os.name == "nt":
cwd = os.path.dirname(__file__)
os.environ['PATH'] = cwd + ';' + os.environ['PATH']
winGPUdll = os.path.join(cwd, "yolo_cpp_dll.dll")
winNoGPUdll = os.path.join(cwd, "yolo_cpp_dll_nogpu.dll")
envKeys = list()
for k, v in os.environ.items():
envKeys.append(k)
try:
try:
tmp = os.environ["FORCE_CPU"].lower()
if tmp in ["1", "true", "yes", "on"]:
raise ValueError("ForceCPU")
else:
log.info("Flag value '"+tmp+"' not forcing CPU mode")
except KeyError:
# We never set the flag
if 'CUDA_VISIBLE_DEVICES' in envKeys:
if int(os.environ['CUDA_VISIBLE_DEVICES']) < 0:
try:
global DARKNET_FORCE_CPU
if DARKNET_FORCE_CPU:
except NameError:
pass
# log.info(os.environ.keys())
# log.warning("FORCE_CPU flag undefined, proceeding with GPU")
if not os.path.exists(winGPUdll):
raise ValueError("NoDLL")
lib = CDLL(winGPUdll, RTLD_GLOBAL)
except (KeyError, ValueError):
hasGPU = False
if os.path.exists(winNoGPUdll):
lib = CDLL(winNoGPUdll, RTLD_GLOBAL)
log.warning("Notice: CPU-only mode")
else:
# Try the other way, in case no_gpu was
# compile but not renamed
log.warning("Environment variables indicated a CPU run, but we didn't find `" +
winNoGPUdll+"`. Trying a GPU run anyway.")
else:
#lib = CDLL("../libdarknet/libdarknet.so", RTLD_GLOBAL)
lib = CDLL(os.path.join(os.getcwd(), "libdarknet.so"), RTLD_GLOBAL)
lib.network_width.argtypes = [c_void_p]
lib.network_width.restype = c_int
lib.network_height.argtypes = [c_void_p]
lib.network_height.restype = c_int
predict = lib.network_predict
predict.argtypes = [c_void_p, POINTER(c_float)]
predict.restype = POINTER(c_float)
if hasGPU:
set_gpu = lib.cuda_set_device
set_gpu.argtypes = [c_int]
make_image = lib.make_image
make_image.argtypes = [c_int, c_int, c_int]
make_image.restype = IMAGE
get_network_boxes = lib.get_network_boxes
get_network_boxes.argtypes = [c_void_p, c_int, c_int, c_float, c_float, POINTER(
c_int), c_int, POINTER(c_int), c_int]
get_network_boxes.restype = POINTER(DETECTION)
make_network_boxes = lib.make_network_boxes
make_network_boxes.argtypes = [c_void_p]
make_network_boxes.restype = POINTER(DETECTION)
free_detections = lib.free_detections
free_detections.argtypes = [POINTER(DETECTION), c_int]
free_ptrs = lib.free_ptrs
free_ptrs.argtypes = [POINTER(c_void_p), c_int]
network_predict = lib.network_predict
network_predict.argtypes = [c_void_p, POINTER(c_float)]
reset_rnn = lib.reset_rnn
reset_rnn.argtypes = [c_void_p]
load_net = lib.load_network
load_net.argtypes = [c_char_p, c_char_p, c_int]
load_net.restype = c_void_p
load_net_custom = lib.load_network_custom
load_net_custom.argtypes = [c_char_p, c_char_p, c_int, c_int]
load_net_custom.restype = c_void_p
do_nms_obj = lib.do_nms_obj
do_nms_obj.argtypes = [POINTER(DETECTION), c_int, c_int, c_float]
do_nms_sort = lib.do_nms_sort
do_nms_sort.argtypes = [POINTER(DETECTION), c_int, c_int, c_float]
free_image = lib.free_image
free_image.argtypes = [IMAGE]
letterbox_image = lib.letterbox_image
letterbox_image.argtypes = [IMAGE, c_int, c_int]
letterbox_image.restype = IMAGE
load_meta = lib.get_metadata
lib.get_metadata.argtypes = [c_char_p]
lib.get_metadata.restype = METADATA
load_image = lib.load_image_color
load_image.argtypes = [c_char_p, c_int, c_int]
load_image.restype = IMAGE
rgbgr_image = lib.rgbgr_image
rgbgr_image.argtypes = [IMAGE]
predict_image = lib.network_predict_image
predict_image.argtypes = [c_void_p, IMAGE]
predict_image.restype = POINTER(c_float)
def array_to_image(arr):
import numpy as np
# need to return old values to avoid python freeing memory
arr = arr.transpose(2, 0, 1)
c = arr.shape[0]
h = arr.shape[1]
w = arr.shape[2]
arr = np.ascontiguousarray(arr.flat, dtype=np.float32) / 255.0
data = arr.ctypes.data_as(POINTER(c_float))
im = IMAGE(w, h, c, data)
return im, arr
def classify(net, meta, im):
out = predict_image(net, im)
res = []
for i in range(meta.classes):
if altNames is None:
name_tag = meta.names[i]
else:
name_tag = altNames[i]
res.append((name_tag, out[i]))
res = sorted(res, key=lambda x: -x[1])
return res
def detect(net, meta, image, thresh=.5, hier_thresh=.5, nms=.45, debug=False):
Performs the detection
custom_image = cv2.cvtColor(image, cv2.COLOR_BGR2RGB)
custom_image = cv2.resize(custom_image, (lib.network_width(
net), lib.network_height(net)), interpolation=cv2.INTER_LINEAR)
im, arr = array_to_image(custom_image)
num = c_int(0)
pnum = pointer(num)
dets = get_network_boxes(
net, image.shape[1], image.shape[0], thresh, hier_thresh, None, 0, pnum, 0)
num = pnum[0]
if nms:
do_nms_sort(dets, num, meta.classes, nms)
res = []
if debug:
log.debug("about to range")
for j in range(num):
if dets[j].prob[i] > 0:
b = dets[j].bbox
else:
res.append((name_tag, dets[j].prob[i], (b.x, b.y, b.w, b.h), i))
free_detections(dets, num)
return res
netMain = None
metaMain = None
altNames = None
def get_object_depth(depth, bounds):
Calculates the median x, y, z position of top slice(area_div) of point cloud
in camera frame.
Arguments:
depth: Point cloud data of whole frame.
bounds: Bounding box for object in pixels.
bounds[0]: x-center
bounds[1]: y-center
bounds[2]: width of bounding box.
bounds[3]: height of bounding box.
Return:
x, y, z: Location of object in meters.
area_div = 2
x_vect = []
y_vect = []
z_vect = []
for j in range(int(bounds[0] - area_div), int(bounds[0] + area_div)):
for i in range(int(bounds[1] - area_div), int(bounds[1] + area_div)):
z = depth[i, j, 2]
if not np.isnan(z) and not np.isinf(z):
x_vect.append(depth[i, j, 0])
y_vect.append(depth[i, j, 1])
z_vect.append(z)
try:
x_median = statistics.median(x_vect)
y_median = statistics.median(y_vect)
z_median = statistics.median(z_vect)
except Exception:
x_median = -1
y_median = -1
z_median = -1
pass
return x_median, y_median, z_median
def generate_color(meta_path):
Generate random colors for the number of classes mentioned in data file.
Arguments:
meta_path: Path to .data file.
Return:
color_array: RGB color codes for each class.
random.seed(42)
with open(meta_path, 'r') as f:
content = f.readlines()
class_num = int(content[0].split("=")[1])
color_array = []
for x in range(0, class_num):
color_array.append((randint(0, 255), randint(0, 255), randint(0, 255)))
return color_array
def main(argv):
thresh = 0.25
config_path="cfg/yolo-custom.cfg"
weight_path ="yolo-custom.weights"
meta_path = "cfg/custom.data"
svo_path = None
zed_id = 0
help_str = 'darknet_custom.py -c <config> -w <weight> -m <meta> -t <threshold> -s <svo_file> -z <zed_id>'
try:
opts, args = getopt.getopt(
argv, "hc:w:m:t:s:z:", ["config=", "weight=", "meta=", "threshold=", "svo_file=", "zed_id="])
except getopt.GetoptError:
log.exception(help_str)
sys.exit(2)
for opt, arg in opts:
if opt == '-h':
log.info(help_str)
sys.exit()
elif opt in ("-c", "--config"):
config_path = arg
elif opt in ("-w", "--weight"):
weight_path = arg
elif opt in ("-m", "--meta"):
meta_path = arg
elif opt in ("-t", "--threshold"):
thresh = float(arg)
elif opt in ("-s", "--svo_file"):
svo_path = arg
elif opt in ("-z", "--zed_id"):
zed_id = int(arg)
input_type = sl.InputType()
if svo_path is not None:
log.info("SVO file : " + svo_path)
input_type.set_from_svo_file(svo_path)
else:
# Launch camera by id
input_type.set_from_camera_id(zed_id)
init = sl.InitParameters(input_t=input_type)
init.coordinate_units = sl.UNIT.METER
cam = sl.Camera()
if not cam.is_opened():
log.info("ZED Camera Open..")
status = cam.open(init)
if status != sl.ERROR_CODE.SUCCESS:
log.error(repr(status))
exit()
runtime = sl.RuntimeParameters()
# Use STANDARD sensing mode
runtime.sensing_mode = sl.SENSING_MODE.STANDARD
mat = sl.Mat()
point_cloud_mat = sl.Mat()
# Import the global variables. This lets us instance Darknet once,
# then just call performDetect() again without instancing again
global metaMain, netMain, altNames # pylint: disable=W0603
assert 0 < thresh < 1, "Threshold should be a float between zero and one (non-inclusive)"
if not os.path.exists(config_path):
raise ValueError("Invalid config path `" +
os.path.abspath(config_path)+"`")
if not os.path.exists(weight_path):
raise ValueError("Invalid weight path `" +
os.path.abspath(weight_path)+"`")
if not os.path.exists(meta_path):
raise ValueError("Invalid data file path `" +
os.path.abspath(meta_path)+"`")
if netMain is None:
netMain = load_net_custom(config_path.encode(
"ascii"), weight_path.encode("ascii"), 0, 1) # batch size = 1
if metaMain is None:
metaMain = load_meta(meta_path.encode("ascii"))
# In thon 3, the metafile default access craps out on Windows (but not Linux)
# Read the names file and create a list to feed to detect
try:
with open(meta_path) as meta_fh:
meta_contents = meta_fh.read()
import re
match = re.search("names *= *(.*)$", meta_contents,
re.IGNORECASE | re.MULTILINE)
if match:
result = match.group(1)
else:
result = None
try:
if os.path.exists(result):
with open(result) as names_fh:
names_list = names_fh.read().strip().split("\n")
altNames = [x.strip() for x in names_list]
except TypeError:
pass
except Exception:
pass
color_array = generate_color(meta_path)
log.info("Running...")
key = ''
while key != 113: # for 'q' key
start_time = time.time() # start time of the loop
err = cam.grab(runtime)
if err == sl.ERROR_CODE.SUCCESS:
cam.retrieve_image(mat, sl.VIEW.LEFT)
image = mat.get_data()
cam.retrieve_measure(
point_cloud_mat, sl.MEASURE.XYZRGBA)
depth = point_cloud_mat.get_data()
# Do the detection
detections = detect(netMain, metaMain, image, thresh)
log.info(chr(27) + "[2J"+"**** " + str(len(detections)) + " Sonuçlar ****")
for detection in detections:
label = detection[0]
confidence = detection[1]
pstring = label+": "+str(np.rint(100 * confidence))+"%"
log.info(pstring)
bounds = detection[2]
y_extent = int(bounds[3])
x_extent = int(bounds[2])
# Coordinates are around the center
x_coord = int(bounds[0] - bounds[2]/2)
y_coord = int(bounds[1] - bounds[3]/2)
#boundingBox = [[x_coord, y_coord], [x_coord, y_coord + y_extent], [x_coord + x_extent, y_coord + y_extent], [x_coord + x_extent, y_coord]]
thickness = 1
x, y, z = get_object_depth(depth, bounds)
distance = math.sqrt(x * x + y * y + z * z)
distance = "{:.2f}".format(distance)
cv2.rectangle(image, (x_coord - thickness, y_coord - thickness),
(x_coord + x_extent + thickness, y_coord + (18 + thickness*4)),
color_array[detection[3]], -1)
cv2.putText(image, label + " " + (str(distance) + " metre"),
(x_coord + (thickness * 4), y_coord + (10 + thickness * 4)),
cv2.FONT_HERSHEY_SIMPLEX, 0.5, (255, 255, 255), 2)
(x_coord + x_extent + thickness, y_coord + y_extent + thickness),
color_array[detection[3]], int(thickness*2))
cv2.imshow("ZED", image)
key = cv2.waitKey(5)
log.info("FPS: {}".format(1.0 / (time.time() - start_time)))
#log.info("Resolution: {} , {}.".format(round(cam_width, 2), cam_height))
else:
cv2.destroyAllWindows()
cam.close()
log.info("\nFINISH")
if __name__ == "__main__":
main(sys.argv[1:])
