Dashboard not working with cux (RAPIDS 25.08)
When running this notebook in Jupyter: 10 minutes to cuxfilter — cuxfilter 25.08.00 documentation
The following error is encountered:
d = cux_df.dashboard(charts_list, sidebar=sidebar, title=‘Auto Accidents Dashboard’, layout=layouts.feature_and_base, theme=themes.default)
Compilation failed:
.conda/envs/rapids-25.08/lib/python3.12/site-packages/cuxfilter/charts/datashader/custom_extensions/graph_inspect_widget.py:CustomInspectTool.ts:42:25 - error TS2345: Argument of type '"customInspect"' is not assignable to parameter of type '"auto_box_zoom" | "box_select" | "box_zoom" | "copy" | "crosshair" | "freehand_draw" | "fullscreen" | "help" | "hover" | "lasso_select" | "pan" | "redo" | "reset" | "save" | "undo" | "wheel_zoom" | "zoom_in" | "zoom_out" | "tap" | "doubletap" | "click" | "examine" | "pan_down" | "pan_east" | "pan_left" | "pan_north" | "pan_right" | "pan_south" | "pan_up" | "pan_west" | "poly_select" | "xbox_select" | "xbox_zoom" | "xcrosshair" | "xpan" | "xwheel_pan" | "xwheel_zoom" | "xzoom_in" | "xzoom_out" | "ybox_select" | "ybox_zoom" | "ycrosshair" | "ypan" | "ywheel_pan" | "ywheel_zoom" | "yzoom_in" | "yzoom_out"'.
42     this.register_alias("customInspect", () => new CustomInspectTool())
An exception has occurred, use %tb to see the full traceback.
SystemExit: 1
/home/jdh4/.conda/envs/rapids-25.08/lib/python3.12/site-packages/IPython/core/interactiveshell.py:3707: UserWarning: To exit: use 'exit', 'quit', or Ctrl-D.
  warn("To exit: use 'exit', 'quit', or Ctrl-D.", stacklevel=1)
Here is some more information:
conda list
# packages in environment at /home/jdh4/.conda/envs/rapids-25.08:
# Name                              Version          Build                                Channel
_libgcc_mutex                       0.1              conda_forge                          conda-forge
_openmp_mutex                       4.5              2_gnu                                conda-forge
_python_abi3_support                1.0              hd8ed1ab_2                           conda-forge
aiohappyeyeballs                    2.6.1            pyhd8ed1ab_0                         conda-forge
aiohttp                             3.12.15          py312h8a5da7c_0                      conda-forge
aiosignal                           1.4.0            pyhd8ed1ab_0                         conda-forge
anyio                               4.11.0           pyhcf101f3_0                         conda-forge
aom                                 3.9.1            hac33072_0                           conda-forge
argon2-cffi                         25.1.0           pyhd8ed1ab_0                         conda-forge
argon2-cffi-bindings                25.1.0           py312h4c3975b_1                      conda-forge
arrow                               1.3.0            pyhd8ed1ab_1                         conda-forge
asttokens                           3.0.0            pyhd8ed1ab_1                         conda-forge
async-lru                           2.0.5            pyh29332c3_0                         conda-forge
attr                                2.5.2            h39aace5_0                           conda-forge
attrs                               25.3.0           pyh71513ae_0                         conda-forge
aws-c-auth                          0.9.1            h48c9088_3                           conda-forge
aws-c-cal                           0.9.2            he7b75e1_1                           conda-forge
aws-c-common                        0.12.4           hb03c661_0                           conda-forge
aws-c-compression                   0.3.1            h92c474e_6                           conda-forge
aws-c-event-stream                  0.5.6            h82d11aa_3                           conda-forge
aws-c-http                          0.10.4           h94feff3_3                           conda-forge
aws-c-io                            0.22.0           h57f3b0d_1                           conda-forge
aws-c-mqtt                          0.13.3           h2b1cf8c_6                           conda-forge
aws-c-s3                            0.8.6            h4e5ac4b_5                           conda-forge
aws-c-sdkutils                      0.2.4            h92c474e_1                           conda-forge
aws-checksums                       0.2.7            h92c474e_2                           conda-forge
aws-crt-cpp                         0.34.4           h60c762c_0                           conda-forge
aws-sdk-cpp                         1.11.606         h32384e2_4                           conda-forge
azure-core-cpp                      1.16.0           h3a458e0_1                           conda-forge
azure-identity-cpp                  1.12.0           ha729027_0                           conda-forge
azure-storage-blobs-cpp             12.14.0          hb1c9500_1                           conda-forge
azure-storage-common-cpp            12.10.0          h4bb41a7_3                           conda-forge
azure-storage-files-datalake-cpp    12.12.0          h8b27e44_3                           conda-forge
babel                               2.17.0           pyhd8ed1ab_0                         conda-forge
beautifulsoup4                      4.14.2           pyha770c72_0                         conda-forge
bleach                              6.2.0            pyh29332c3_4                         conda-forge
bleach-with-css                     6.2.0            h82add2a_4                           conda-forge
blosc                               1.21.6           he440d0b_1                           conda-forge
bokeh                               3.8.0            pyhd8ed1ab_0                         conda-forge
bokeh-sampledata                    2025.0           pypi_0                               pypi
branca                              0.8.2            pyhd8ed1ab_0                         conda-forge
brotli                              1.1.0            hb03c661_4                           conda-forge
brotli-bin                          1.1.0            hb03c661_4                           conda-forge
brotli-python                       1.1.0            py312h1289d80_4                      conda-forge
brunsli                             0.1              he3183e4_1                           conda-forge
bzip2                               1.0.8            hda65f42_8                           conda-forge
c-ares                              1.34.5           hb9d3cd8_0                           conda-forge
c-blosc2                            2.21.3           h4cfbee9_0                           conda-forge
ca-certificates                     2025.10.5        hbd8a1cb_0                           conda-forge
cached-property                     1.5.2            hd8ed1ab_1                           conda-forge
cached_property                     1.5.2            pyha770c72_1                         conda-forge
cachetools                          6.2.0            pyhd8ed1ab_0                         conda-forge
certifi                             2025.10.5        pyhd8ed1ab_0                         conda-forge
cffi                                2.0.0            py312h35888ee_0                      conda-forge
charls                              2.4.2            h59595ed_0                           conda-forge
charset-normalizer                  3.4.3            pyhd8ed1ab_0                         conda-forge
click                               8.3.0            pyh707e725_0                         conda-forge
cloudpickle                         3.1.1            pyhd8ed1ab_0                         conda-forge
colorama                            0.4.6            pyhd8ed1ab_1                         conda-forge
colorcet                            3.1.0            pyhd8ed1ab_1                         conda-forge
comm                                0.2.3            pyhe01879c_0                         conda-forge
contourpy                           1.3.3            py312hd9148b4_2                      conda-forge
cpython                             3.12.11          py312hd8ed1ab_0                      conda-forge
cucim                               25.08.00         cuda12_py312_250806_g86b4ac7_0       rapidsai
cuda-bindings                       12.9.2           py312hebe1815_1                      conda-forge
cuda-cccl_linux-64                  12.9.27          ha770c72_0                           conda-forge
cuda-crt-dev_linux-64               12.9.86          ha770c72_2                           conda-forge
cuda-crt-tools                      12.9.86          ha770c72_2                           conda-forge
cuda-cudart                         12.9.79          h5888daf_0                           conda-forge
cuda-cudart-dev                     12.9.79          h5888daf_0                           conda-forge
cuda-cudart-dev_linux-64            12.9.79          h3f2d84a_0                           conda-forge
cuda-cudart-static                  12.9.79          h5888daf_0                           conda-forge
cuda-cudart-static_linux-64         12.9.79          h3f2d84a_0                           conda-forge
cuda-cudart_linux-64                12.9.79          h3f2d84a_0                           conda-forge
cuda-nvcc-dev_linux-64              12.9.86          he91c749_2                           conda-forge
cuda-nvcc-impl                      12.9.86          h85509e4_2                           conda-forge
cuda-nvcc-tools                     12.9.86          he02047a_2                           conda-forge
cuda-nvrtc                          12.9.86          h5888daf_0                           conda-forge
cuda-nvvm-dev_linux-64              12.9.86          ha770c72_2                           conda-forge
cuda-nvvm-impl                      12.9.86          h4bc722e_2                           conda-forge
cuda-nvvm-tools                     12.9.86          h4bc722e_2                           conda-forge
cuda-pathfinder                     1.3.0            pyhcf101f3_0                         conda-forge
cuda-profiler-api                   12.9.79          h7938cbb_0                           conda-forge
cuda-python                         12.9.2           pyhb6702c7_2                         conda-forge
cuda-version                        12.9             h4f385c5_3                           conda-forge
cudf                                25.08.00         cuda12_py312_250806_6cea3743         rapidsai
cudf-polars                         25.08.00         cuda12_py312_250806_6cea3743         rapidsai
cudf_kafka                          25.08.00         cuda12_py312_250806_6cea3743         rapidsai
cugraph                             25.08.00         cuda12_py312_250806_e0f09e50         rapidsai
cuml                                25.08.00         cuda12_py312_250806_b081fcd0         rapidsai
cupy                                13.6.0           py312h0317cef_2                      conda-forge
cupy-core                           13.6.0           py312h16a6543_2                      conda-forge
custreamz                           25.08.00         cuda12_py312_250806_6cea3743         rapidsai
cuvs                                25.08.00         cuda12_py312_250806_9ce11a0f         rapidsai
cuxfilter                           25.08.00         cuda12_py312_250806_3858d64d         rapidsai
cycler                              0.12.1           pyhd8ed1ab_1                         conda-forge
cyrus-sasl                          2.1.28           hd9c7081_0                           conda-forge
cytoolz                             1.0.1            py312h66e93f0_0                      conda-forge
dask                                2025.7.0         pyhe01879c_0                         conda-forge
dask-core                           2025.7.0         pyhe01879c_1                         conda-forge
dask-cuda                           25.08.00         py313_250806_bde9a4d3                rapidsai
dask-cudf                           25.08.00         cuda12_py312_250806_6cea3743         rapidsai
datashader                          0.18.2           pyhd8ed1ab_0                         conda-forge
dav1d                               1.2.1            hd590300_0                           conda-forge
debugpy                             1.8.17           py312h8285ef7_0                      conda-forge
decorator                           5.2.1            pyhd8ed1ab_0                         conda-forge
defusedxml                          0.7.1            pyhd8ed1ab_0                         conda-forge
distributed                         2025.7.0         pyhe01879c_0                         conda-forge
distributed-ucxx                    0.45.01          py_250806_c25d2cdb_h7e233d3          rapidsai
dlpack                              0.8              h59595ed_3                           conda-forge
exceptiongroup                      1.3.0            pyhd8ed1ab_0                         conda-forge
executing                           2.2.1            pyhd8ed1ab_0                         conda-forge
fastrlock                           0.8.3            py312h8285ef7_2                      conda-forge
folium                              0.20.0           pyhd8ed1ab_0                         conda-forge
fonttools                           4.60.1           py312h8a5da7c_0                      conda-forge
fqdn                                1.5.1            pyhd8ed1ab_1                         conda-forge
freetype                            2.14.1           ha770c72_0                           conda-forge
freexl                              2.0.0            h9dce30a_2                           conda-forge
frozenlist                          1.7.0            py312h447239a_0                      conda-forge
fsspec                              2025.9.0         pyhd8ed1ab_0                         conda-forge
geopandas                           1.1.1            pyhd8ed1ab_0                         conda-forge
geopandas-base                      1.1.1            pyha770c72_0                         conda-forge
geos                                3.14.0           h480dda7_0                           conda-forge
gflags                              2.2.2            h5888daf_1005                        conda-forge
giflib                              5.2.2            hd590300_0                           conda-forge
glog                                0.7.1            hbabe93e_0                           conda-forge
h11                                 0.16.0           pyhd8ed1ab_0                         conda-forge
h2                                  4.3.0            pyhcf101f3_0                         conda-forge
holoviews                           1.21.0           pyhd8ed1ab_0                         conda-forge
hpack                               4.1.0            pyhd8ed1ab_0                         conda-forge
httpcore                            1.0.9            pyh29332c3_0                         conda-forge
httpx                               0.28.1           pyhd8ed1ab_0                         conda-forge
hyperframe                          6.1.0            pyhd8ed1ab_0                         conda-forge
icalendar                           6.3.1            pypi_0                               pypi
icu                                 75.1             he02047a_0                           conda-forge
idna                                3.10             pyhd8ed1ab_1                         conda-forge
imagecodecs                         2025.8.2         py312h4ecb025_4                      conda-forge
imageio                             2.37.0           pyhfb79c49_0                         conda-forge
importlib-metadata                  8.7.0            pyhe01879c_1                         conda-forge
ipykernel                           6.30.1           pyh82676e8_0                         conda-forge
ipympl                              0.9.7            pyhcf101f3_2                         conda-forge
ipython                             9.6.0            pyhfa0c392_0                         conda-forge
ipython_pygments_lexers             1.1.1            pyhd8ed1ab_0                         conda-forge
ipywidgets                          8.1.7            pyhd8ed1ab_0                         conda-forge
isoduration                         20.11.0          pyhd8ed1ab_1                         conda-forge
jedi                                0.19.2           pyhd8ed1ab_1                         conda-forge
jinja2                              3.1.6            pyhd8ed1ab_0                         conda-forge
joblib                              1.5.2            pyhd8ed1ab_0                         conda-forge
json-c                              0.18             h6688a6e_0                           conda-forge
json5                               0.12.1           pyhd8ed1ab_0                         conda-forge
jsonpointer                         3.0.0            py312h7900ff3_2                      conda-forge
jsonschema                          4.25.1           pyhe01879c_0                         conda-forge
jsonschema-specifications           2025.9.1         pyhcf101f3_0                         conda-forge
jsonschema-with-format-nongpl       4.25.1           he01879c_0                           conda-forge
jupyter                             1.1.1            pyhd8ed1ab_1                         conda-forge
jupyter-lsp                         2.3.0            pyhcf101f3_0                         conda-forge
jupyter-server-proxy                4.4.0            pyhd8ed1ab_1                         conda-forge
jupyter_client                      8.6.3            pyhd8ed1ab_1                         conda-forge
jupyter_console                     6.6.3            pyhd8ed1ab_1                         conda-forge
jupyter_core                        5.8.1            pyh31011fe_0                         conda-forge
jupyter_events                      0.12.0           pyh29332c3_0                         conda-forge
jupyter_server                      2.17.0           pyhcf101f3_0                         conda-forge
jupyter_server_terminals            0.5.3            pyhd8ed1ab_1                         conda-forge
jupyterlab                          4.4.9            pyhd8ed1ab_0                         conda-forge
jupyterlab_pygments                 0.3.0            pyhd8ed1ab_2                         conda-forge
jupyterlab_server                   2.27.3           pyhd8ed1ab_1                         conda-forge
jupyterlab_widgets                  3.0.15           pyhd8ed1ab_0                         conda-forge
jxrlib                              1.1              hd590300_3                           conda-forge
keyutils                            1.6.3            hb9d3cd8_0                           conda-forge
kiwisolver                          1.4.9            py312h0a2e395_1                      conda-forge
krb5                                1.21.3           h659f571_0                           conda-forge
lark                                1.3.0            pyhd8ed1ab_0                         conda-forge
lazy-loader                         0.4              pyhd8ed1ab_2                         conda-forge
lazy_loader                         0.4              pyhd8ed1ab_2                         conda-forge
lcms2                               2.17             h717163a_0                           conda-forge
ld_impl_linux-64                    2.44             ha97dd6f_2                           conda-forge
lerc                                4.0.0            h0aef613_1                           conda-forge
libabseil                           20250512.1       cxx17_hba17884_0                     conda-forge
libaec                              1.1.4            h3f801dc_0                           conda-forge
libarchive                          3.8.1            gpl_h7be2006_101                     conda-forge
libarrow                            19.0.1           hd136fde_33_cuda                     conda-forge
libarrow-acero                      19.0.1           hb826db4_33_cuda                     conda-forge
libarrow-dataset                    19.0.1           hb826db4_33_cuda                     conda-forge
libarrow-substrait                  19.0.1           h9d9f3f8_33_cuda                     conda-forge
libavif16                           1.3.0            h6395336_2                           conda-forge
libblas                             3.9.0            36_h4a7cf45_openblas                 conda-forge
libbrotlicommon                     1.1.0            hb03c661_4                           conda-forge
libbrotlidec                        1.1.0            hb03c661_4                           conda-forge
libbrotlienc                        1.1.0            hb03c661_4                           conda-forge
libcap                              2.76             h0b2e76d_0                           conda-forge
libcblas                            3.9.0            36_h0358290_openblas                 conda-forge
libcrc32c                           1.1.2            h9c3ff4c_0                           conda-forge
libcublas                           12.9.1.4         h9ab20c4_0                           conda-forge
libcublas-dev                       12.9.1.4         h9ab20c4_0                           conda-forge
libcucim                            25.08.00         cuda12_250806_g86b4ac7_0             rapidsai
libcudf                             25.08.00         cuda12_250806_6cea3743               rapidsai
libcudf_kafka                       25.08.00         cuda12_250806_6cea3743               rapidsai
libcufft                            11.4.1.4         h5888daf_0                           conda-forge
libcufile                           1.14.1.1         ha8da6e3_0                           conda-forge
libcufile-dev                       1.14.1.1         h5888daf_0                           conda-forge
libcugraph                          25.08.00         cuda12_250806_e0f09e50               rapidsai
libcugraph_etl                      25.08.00         cuda12_250806_e0f09e50               rapidsai
libcuml                             25.08.00         cuda12_250806_b081fcd0               rapidsai
libcumlprims                        25.08.00         cuda12_py310_250806_59064b25         rapidsai
libcurand                           10.3.10.19       h9ab20c4_0                           conda-forge
libcurand-dev                       10.3.10.19       h9ab20c4_0                           conda-forge
libcurl                             8.14.1           h332b0f4_0                           conda-forge
libcusolver                         11.7.5.82        h9ab20c4_1                           conda-forge
libcusolver-dev                     11.7.5.82        h9ab20c4_1                           conda-forge
libcusparse                         12.5.10.65       h5888daf_1                           conda-forge
libcusparse-dev                     12.5.10.65       h5888daf_1                           conda-forge
libcuvs                             25.08.00         cuda12_250806_9ce11a0f               rapidsai
libdeflate                          1.24             h86f0d12_0                           conda-forge
libedit                             3.1.20250104     pl5321h7949ede_0                     conda-forge
libev                               4.33             hd590300_2                           conda-forge
libevent                            2.1.12           hf998b51_1                           conda-forge
libexpat                            2.7.1            hecca717_0                           conda-forge
libffi                              3.4.6            h2dba641_1                           conda-forge
libfreetype                         2.14.1           ha770c72_0                           conda-forge
libfreetype6                        2.14.1           h73754d4_0                           conda-forge
libgcc                              15.2.0           h767d61c_5                           conda-forge
libgcc-ng                           15.2.0           h69a702a_5                           conda-forge
libgcrypt-lib                       1.11.1           hb9d3cd8_0                           conda-forge
libgdal-core                        3.11.4           habfead2_4                           conda-forge
libgfortran                         15.2.0           h69a702a_5                           conda-forge
libgfortran5                        15.2.0           hcd61629_5                           conda-forge
libgomp                             15.2.0           h767d61c_5                           conda-forge
libgoogle-cloud                     2.39.0           hdb79228_0                           conda-forge
libgoogle-cloud-storage             2.39.0           hdbdcf42_0                           conda-forge
libgpg-error                        1.55             h3f2d84a_0                           conda-forge
libgrpc                             1.73.1           h1e535eb_0                           conda-forge
libhwy                              1.3.0            h4c17acf_1                           conda-forge
libiconv                            1.18             h3b78370_2                           conda-forge
libjpeg-turbo                       3.1.0            hb9d3cd8_0                           conda-forge
libjxl                              0.11.1           h6cb5226_4                           conda-forge
libkml                              1.3.0            hf539b9f_1021                        conda-forge
libkvikio                           25.08.00         cuda12_9_250806_2f72c39a             rapidsai
liblapack                           3.9.0            36_h47877c9_openblas                 conda-forge
liblzma                             5.8.1            hb9d3cd8_2                           conda-forge
libnghttp2                          1.67.0           had1ee68_0                           conda-forge
libnl                               3.11.0           hb9d3cd8_0                           conda-forge
libnsl                              2.0.1            hb9d3cd8_1                           conda-forge
libntlm                             1.8              hb9d3cd8_0                           conda-forge
libnuma                             2.0.18           hb9d3cd8_3                           conda-forge
libnvcomp                           4.2.0.11         hb7e823c_1                           conda-forge
libnvcomp-dev                       4.2.0.11         hb7e823c_1                           conda-forge
libnvjitlink                        12.9.86          h5888daf_1                           conda-forge
libnvjpeg                           12.4.0.76        h5888daf_0                           conda-forge
libnvptxcompiler-dev                12.9.86          ha770c72_2                           conda-forge
libnvptxcompiler-dev_linux-64       12.9.86          ha770c72_2                           conda-forge
libopenblas                         0.3.30           pthreads_h94d23a6_2                  conda-forge
libopentelemetry-cpp                1.21.0           hb9b0907_1                           conda-forge
libopentelemetry-cpp-headers        1.21.0           ha770c72_1                           conda-forge
libparquet                          19.0.1           h006c7c7_33_cuda                     conda-forge
libpng                              1.6.50           h421ea60_1                           conda-forge
libprotobuf                         6.31.1           h9ef548d_1                           conda-forge
libraft                             25.08.00         cuda12_250806_2fb92393               rapidsai
libraft-headers                     25.08.00         cuda12_250806_2fb92393               rapidsai
libraft-headers-only                25.08.00         cuda12_250806_2fb92393               rapidsai
librdkafka                          2.8.0            h2e2c4f7_0                           conda-forge
libre2-11                           2025.08.12       h7b12aa8_1                           conda-forge
librmm                              25.08.00         cuda12_250806_63a4d366               rapidsai
librttopo                           1.1.0            h96cd706_19                          conda-forge
libsodium                           1.0.20           h4ab18f5_0                           conda-forge
libspatialite                       5.1.0            gpl_hcb59c51_118                     conda-forge
libsqlite                           3.50.4           h0c1763c_0                           conda-forge
libssh2                             1.11.1           hcf80075_0                           conda-forge
libstdcxx                           15.2.0           h8f9b012_5                           conda-forge
libstdcxx-ng                        15.2.0           h4852527_5                           conda-forge
libsystemd0                         257.9            h996ca69_0                           conda-forge
libthrift                           0.22.0           h454ac66_1                           conda-forge
libtiff                             4.7.1            h8261f1e_0                           conda-forge
libucxx                             0.45.01          cuda12_250806_c25d2cdb               rapidsai
libudev1                            257.9            h085a93f_0                           conda-forge
libutf8proc                         2.11.0           hb04c3b8_0                           conda-forge
libuuid                             2.41.2           he9a06e4_0                           conda-forge
libuv                               1.51.0           hb03c661_1                           conda-forge
libwebp-base                        1.6.0            hd42ef1d_0                           conda-forge
libxcb                              1.17.0           h8a09558_0                           conda-forge
libxcrypt                           4.4.36           hd590300_1                           conda-forge
libxgboost                          3.0.3            rapidsai_h1399887_0                  rapidsai
libxml2                             2.15.0           h26afc86_1                           conda-forge
libxml2-16                          2.15.0           ha9997c6_1                           conda-forge
libxml2-devel                       2.15.0           h26afc86_1                           conda-forge
libzlib                             1.3.1            hb9d3cd8_2                           conda-forge
libzopfli                           1.0.3            h9c3ff4c_0                           conda-forge
linkify-it-py                       2.0.3            pyhd8ed1ab_1                         conda-forge
llvmlite                            0.44.0           py312he100287_2                      conda-forge
locket                              1.0.0            pyhd8ed1ab_0                         conda-forge
lz4                                 4.4.4            py312h5d89b6d_1                      conda-forge
lz4-c                               1.10.0           h5888daf_1                           conda-forge
lzo                                 2.10             h280c20c_1002                        conda-forge
mapclassify                         2.10.0           pyhd8ed1ab_1                         conda-forge
markdown                            3.9              pyhd8ed1ab_0                         conda-forge
markdown-it-py                      4.0.0            pyhd8ed1ab_0                         conda-forge
markupsafe                          3.0.3            py312h8a5da7c_0                      conda-forge
matplotlib-base                     3.10.6           py312he3d6523_1                      conda-forge
matplotlib-inline                   0.1.7            pyhd8ed1ab_1                         conda-forge
mdit-py-plugins                     0.5.0            pyhd8ed1ab_0                         conda-forge
mdurl                               0.1.2            pyhd8ed1ab_1                         conda-forge
minizip                             4.0.10           h05a5f5f_0                           conda-forge
mistune                             3.1.4            pyhcf101f3_0                         conda-forge
msgpack-python                      1.1.1            py312hd9148b4_1                      conda-forge
multidict                           6.6.3            py312h178313f_0                      conda-forge
multipledispatch                    0.6.0            pyhd8ed1ab_1                         conda-forge
munkres                             1.1.4            pyhd8ed1ab_1                         conda-forge
muparser                            2.3.5            h5888daf_0                           conda-forge
narwhals                            2.7.0            pyhcf101f3_0                         conda-forge
nbclient                            0.10.2           pyhd8ed1ab_0                         conda-forge
nbconvert-core                      7.16.6           pyh29332c3_0                         conda-forge
nbformat                            5.10.4           pyhd8ed1ab_1                         conda-forge
nccl                                2.27.7.1         h49b9d9a_3                           conda-forge
ncurses                             6.5              h2d0b736_3                           conda-forge
nest-asyncio                        1.6.0            pyhd8ed1ab_1                         conda-forge
networkx                            3.5              pyhe01879c_0                         conda-forge
nlohmann_json                       3.12.0           h54a6638_1                           conda-forge
nodejs                              24.9.0           heeeca48_0                           conda-forge
notebook                            7.4.7            pyhd8ed1ab_0                         conda-forge
notebook-shim                       0.2.4            pyhd8ed1ab_1                         conda-forge
numba                               0.61.2           py312h907b442_2                      conda-forge
numba-cuda                          0.14.1           pyhcf101f3_0                         conda-forge
numpy                               2.2.6            py312h72c5963_0                      conda-forge
nvidia-ml-py                        12.575.51        pyhd8ed1ab_0                         conda-forge
nvtx                                0.2.13           py312h4c3975b_1                      conda-forge
nx-cugraph                          25.08.00         py312_250806_7984845a                rapidsai
openjpeg                            2.5.4            h55fea9a_0                           conda-forge
openssl                             3.5.4            h26f9b46_0                           conda-forge
orc                                 2.2.1            hd747db4_0                           conda-forge
overrides                           7.7.0            pyhd8ed1ab_1                         conda-forge
packaging                           25.0             pyh29332c3_1                         conda-forge
pandas                              2.3.3            py312hf79963d_1                      conda-forge
pandocfilters                       1.5.0            pyhd8ed1ab_0                         conda-forge
panel                               1.8.1            pyhd8ed1ab_0                         conda-forge
param                               2.2.1            pyhd8ed1ab_0                         conda-forge
parso                               0.8.5            pyhcf101f3_0                         conda-forge
partd                               1.4.2            pyhd8ed1ab_0                         conda-forge
pcre2                               10.46            h1321c63_0                           conda-forge
pexpect                             4.9.0            pyhd8ed1ab_1                         conda-forge
pickleshare                         0.7.5            pyhd8ed1ab_1004                      conda-forge
pillow                              11.3.0           py312h7b42cdd_3                      conda-forge
pip                                 25.2             pyh8b19718_0                         conda-forge
platformdirs                        4.4.0            pyhcf101f3_0                         conda-forge
polars                              1.31.0           default_h70f2ef1_1                   conda-forge
polars-default                      1.31.0           py39hf521cc8_1                       conda-forge
proj                                9.7.0            hb72c0af_0                           conda-forge
prometheus-cpp                      1.3.0            ha5d0236_0                           conda-forge
prometheus_client                   0.23.1           pyhd8ed1ab_0                         conda-forge
prompt-toolkit                      3.0.52           pyha770c72_0                         conda-forge
prompt_toolkit                      3.0.52           hd8ed1ab_0                           conda-forge
propcache                           0.3.1            py312h178313f_0                      conda-forge
psutil                              7.1.0            py312h4c3975b_0                      conda-forge
pthread-stubs                       0.4              hb9d3cd8_1002                        conda-forge
ptyprocess                          0.7.0            pyhd8ed1ab_1                         conda-forge
pure_eval                           0.2.3            pyhd8ed1ab_1                         conda-forge
py-xgboost                          3.0.3            rapidsai_pyh7b92683_0                rapidsai
pyarrow                             19.0.1           py312h7900ff3_0                      conda-forge
pyarrow-core                        19.0.1           py312h09cf70e_0_cuda                 conda-forge
pycparser                           2.22             pyh29332c3_1                         conda-forge
pyct                                0.6.0            pyhd8ed1ab_0                         conda-forge
pygments                            2.19.2           pyhd8ed1ab_0                         conda-forge
pylibcudf                           25.08.00         cuda12_py312_250806_6cea3743         rapidsai
pylibcugraph                        25.08.00         cuda12_py312_250806_e0f09e50         rapidsai
pylibraft                           25.08.00         cuda12_py312_250806_2fb92393         rapidsai
pynvjitlink                         0.7.0            12.9_py312_250625_3693c9cd_hd6618c4  rapidsai
pynvml                              12.0.0           pyhd8ed1ab_0                         conda-forge
pyogrio                             0.11.1           py312h6e8b602_1                      conda-forge
pyparsing                           3.2.5            pyhcf101f3_0                         conda-forge
pyproj                              3.7.2            py312h9b6a7d9_2                      conda-forge
pysocks                             1.7.1            pyha55dd90_7                         conda-forge
python                              3.12.11          h9e4cc4f_0_cpython                   conda-forge
python-confluent-kafka              2.8.0            py312h66e93f0_0                      conda-forge
python-dateutil                     2.9.0.post0      pyhe01879c_2                         conda-forge
python-fastjsonschema               2.21.2           pyhe01879c_0                         conda-forge
python-gil                          3.12.11          hd8ed1ab_0                           conda-forge
python-json-logger                  2.0.7            pyhd8ed1ab_0                         conda-forge
python-tzdata                       2025.2           pyhd8ed1ab_0                         conda-forge
python_abi                          3.12             8_cp312                              conda-forge
pytz                                2025.2           pyhd8ed1ab_0                         conda-forge
pyviz_comms                         3.0.6            pyhd8ed1ab_0                         conda-forge
pywavelets                          1.9.0            py312h4f23490_1                      conda-forge
pyyaml                              6.0.3            py312h8a5da7c_0                      conda-forge
pyzmq                               27.1.0           py312hfb55c3c_0                      conda-forge
qhull                               2020.2           h434a139_5                           conda-forge
raft-dask                           25.08.00         cuda12_py312_250806_2fb92393         rapidsai
rapids                              25.08.00         cuda12_py313_250806_6825ee7c         rapidsai
rapids-dask-dependency              25.08.00         250806_fb4cb9f6                      rapidsai
rapids-logger                       0.1.1            h98325ef_0                           rapidsai
rapids-xgboost                      25.08.00         cuda12_py313_250806_6825ee7c         rapidsai
rav1e                               0.7.1            h8fae777_3                           conda-forge
rdma-core                           59.0             hecca717_0                           conda-forge
re2                                 2025.08.12       h5301d42_1                           conda-forge
readline                            8.2              h8c095d6_2                           conda-forge
referencing                         0.36.2           pyh29332c3_0                         conda-forge
requests                            2.32.5           pyhd8ed1ab_0                         conda-forge
rfc3339-validator                   0.1.4            pyhd8ed1ab_1                         conda-forge
rfc3986-validator                   0.1.1            pyh9f0ad1d_0                         conda-forge
rfc3987-syntax                      1.1.0            pyhe01879c_1                         conda-forge
rich                                14.1.0           pyhe01879c_0                         conda-forge
rmm                                 25.08.00         cuda12_py312_250806_63a4d366         rapidsai
rpds-py                             0.27.1           py312h868fb18_1                      conda-forge
s2n                                 1.5.26           h5ac9029_0                           conda-forge
scikit-image                        0.24.0           py312hf9745cd_3                      conda-forge
scikit-learn                        1.7.2            py312h4f0b9e3_0                      conda-forge
scipy                               1.16.2           py312h7a1785b_0                      conda-forge
send2trash                          1.8.3            pyh0d859eb_1                         conda-forge
setuptools                          80.9.0           pyhff2d567_0                         conda-forge
shapely                             2.1.2            py312h950be2a_0                      conda-forge
simpervisor                         1.0.0            pyhd8ed1ab_1                         conda-forge
six                                 1.17.0           pyhe01879c_1                         conda-forge
snappy                              1.2.2            h03e3b7b_0                           conda-forge
sniffio                             1.3.1            pyhd8ed1ab_1                         conda-forge
sortedcontainers                    2.4.0            pyhd8ed1ab_1                         conda-forge
soupsieve                           2.8              pyhd8ed1ab_0                         conda-forge
sqlite                              3.50.4           hbc0de68_0                           conda-forge
stack_data                          0.6.3            pyhd8ed1ab_1                         conda-forge
streamz                             0.6.4            pyhd8ed1ab_1                         conda-forge
svt-av1                             3.1.2            hecca717_0                           conda-forge
tblib                               3.1.0            pyhd8ed1ab_0                         conda-forge
terminado                           0.18.1           pyh0d859eb_0                         conda-forge
threadpoolctl                       3.6.0            pyhecae5ae_0                         conda-forge
tifffile                            2025.10.4        pyhd8ed1ab_0                         conda-forge
tinycss2                            1.4.0            pyhd8ed1ab_0                         conda-forge
tk                                  8.6.13           noxft_hd72426e_102                   conda-forge
tomli                               2.2.1            pyhe01879c_2                         conda-forge
toolz                               1.0.0            pyhd8ed1ab_1                         conda-forge
tornado                             6.5.2            py312h4c3975b_1                      conda-forge
tqdm                                4.67.1           pyhd8ed1ab_1                         conda-forge
traitlets                           5.14.3           pyhd8ed1ab_1                         conda-forge
treelite                            4.4.1            py312h90c54bd_1                      conda-forge
types-python-dateutil               2.9.0.20250822   pyhd8ed1ab_0                         conda-forge
typing-extensions                   4.15.0           h396c80c_0                           conda-forge
typing_extensions                   4.15.0           pyhcf101f3_0                         conda-forge
typing_utils                        0.1.0            pyhd8ed1ab_1                         conda-forge
tzdata                              2025b            h78e105d_0                           conda-forge
uc-micro-py                         1.0.3            pyhd8ed1ab_1                         conda-forge
ucx                                 1.18.1           h990bcc0_2                           conda-forge
ucx-py                              0.45.00          py312_250806_d53bdda0                rapidsai
ucxx                                0.45.01          cuda12_py312_250806_c25d2cdb         rapidsai
unicodedata2                        16.0.0           py312h4c3975b_1                      conda-forge
uri-template                        1.3.0            pyhd8ed1ab_1                         conda-forge
uriparser                           0.9.8            hac33072_0                           conda-forge
urllib3                             2.5.0            pyhd8ed1ab_0                         conda-forge
wcwidth                             0.2.14           pyhd8ed1ab_0                         conda-forge
webcolors                           24.11.1          pyhd8ed1ab_0                         conda-forge
webencodings                        0.5.1            pyhd8ed1ab_3                         conda-forge
websocket-client                    1.8.0            pyhd8ed1ab_1                         conda-forge
wheel                               0.45.1           pyhd8ed1ab_1                         conda-forge
widgetsnbextension                  4.0.14           pyhd8ed1ab_0                         conda-forge
xarray                              2025.9.1         pyhd8ed1ab_0                         conda-forge
xerces-c                            3.2.5            h988505b_2                           conda-forge
xgboost                             3.0.3            rapidsai_pyh452a892_0                rapidsai
xorg-libxau                         1.0.12           hb9d3cd8_0                           conda-forge
xorg-libxdmcp                       1.1.5            hb9d3cd8_0                           conda-forge
xyzservices                         2025.4.0         pyhd8ed1ab_0                         conda-forge
yaml                                0.2.5            h280c20c_3                           conda-forge
yarl                                1.20.1           py312h178313f_0                      conda-forge
zeromq                              4.3.5            h387f397_9                           conda-forge
zfp                                 1.0.1            h909a3a2_3                           conda-forge
zict                                3.0.0            pyhd8ed1ab_1                         conda-forge
zipp                                3.23.0           pyhd8ed1ab_0                         conda-forge
zlib-ng                             2.2.5            hde8ca8f_0                           conda-forge
zstandard                           0.25.0           py312h5253ce2_0                      conda-forge
zstd                                1.5.7            hb8e6e7a_2                           conda-forge
Please describe your issue or request: (tick the boxes after creating this topic):
Please tick the appropriate box to help us categorize your post
Bug or Error
Feature Request
Documentation Issue
Other
Hi jdh4,
Could you please post this as a GIthub issue at the Rapids Github? Thank you!
This has been moved to:
